PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 [174] 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. No Muffler?
  2. is a 3" x pipe better than a 3" y pipe
  3. broken oil pressure sending unit
  4. header install problem
  5. x - pipe related...
  6. Thermostat Brand
  7. True Dual sound clip (Spintech mufflers)
  8. help I.D. oil pan
  9. True duals w/magnaflow mufflers
  10. Dynatech stepped race headers installed today
  11. xs stainless header owners...
  12. LS6 Intake on a 6.0 Escalade?
  13. Broke Off Bolt In Block! Help!
  14. Ultra Z with FTRA/SSRA
  15. tb's
  16. Oil drain Bolt and FLP Headers - will it come out? Pic Inc
  17. lt1 headers
  18. ls6 intake
  19. Texas Speed Catted Y
  20. Full Bolt On Help!~!!!!
  21. Mac Header Coating
  22. o2 question
  23. Need advice to pass inspection in Germany
  24. Nology Hot Wires
  25. What should my car idle at?
  26. whats up with the spintech mufflers?
  27. Exhaust Manifolds
  28. Ls6 intake question
  29. SDPC Billet Vette Throttle Body
  30. Fuel Rails with the Prof. Products Intake and ???'s
  31. Water pumps all the same?
  32. Ws7???
  33. Cats
  34. are these the correct pulley belts?
  35. Exhaust quote...
  36. One of my cats broke....
  37. LS1--back of oil pan leak
  38. Header recommendations??
  39. Catch Can Questions
  40. Put on BorlaMouth today, results video
  41. Fernco Mod
  42. please someone make this a sticky
  43. EGR advise!
  44. question about f-body cats
  45. 02 extensions
  46. best intake w/boost???????
  47. QTP Exhaust GP, click link....
  48. 160 deg thermostat
  49. Sound Byte Needed
  50. No Oil pressure!
  51. Help ASAP!!! PLEASE
  52. Water Temp Gauge Adapter
  53. Don't need to drain coolant to take off intake?
  54. Anyone have pics of the mufflex 4 inch single tip exhaust
  55. professional products manifold wire wont reach
  56. hooker aero chamber muffler
  57. Here is the Part Number for O2 plug
  58. Bassani
  59. Which Kooks should I get?
  60. Inconsiderate Parking Lot People
  61. Long Tube Temp
  62. help please! tb voltage...
  63. single out exhaust........what do u think
  64. is it possible that ls6 has egr off 02 camaro?
  65. Header help please.....
  66. AIR system line connection points
  67. What brand underdrive pulley is this?
  68. Bolt walking out of the crank!!!
  69. installing headers in the morning
  70. How Do I Install My headers!??
  71. Header has no threads on O2 bung? WTF
  72. Question about cats
  73. Motor Mount Install Question????
  74. FAST Bolts & Parts
  75. Mac HTS header coating???
  76. which drive shaft loop with TSP true duals?
  77. Head and cam combo
  78. Stock manifolds and catted y to LT headers and ORY, weight saving??
  79. What kind of exhaust is this!
  80. How to tell,ls6 from ls1, while installed?
  81. muffler??
  82. New NHRA Rule?
  83. TB bump stop
  84. Kooks 1 7/8"
  85. 85mm lid???
  86. what should i do?
  87. New Homemade ram air thread!ANybody fab up anything new?
  88. FAST Intake & evap solanoid question
  89. Duals vs SIngle C/B.... Weight and HP
  90. inlet/outlet muffler ?
  91. Ugh... just ordered cats
  92. best place to get the bosch 13111's and how much $$$?
  93. Hooker Headers
  94. TSP True Duals
  95. Emissions headers wity ORY pipe
  96. bolt ons
  97. LS6 Intake AND Valley Cover Coolant Question
  98. dynomax bullet questions
  99. O2 Sensor Question....
  100. Need help on Pulleys...
  101. hooker catback
  102. OR Header Smell
  103. Help - Starter Wiring Problem
  104. Powerbond Pulley
  105. header gasket ??????
  106. flowtech headers????
  107. muffler flow comparison
  108. PCV Catch Can Placement
  109. Catback.... Which one? VOTE!
  110. header & catback install tonight
  111. Hedman header back exhaust
  112. hose
  113. No "X" or "Y" Pipe....
  114. which intake for 500 hp car?
  115. what additional install parts do I need for ls-6 intake?
  116. 4inch fernco on a 90mm TB...no?
  117. Headers installed
  118. Spark plug question
  119. FYI on changing to LS6 intake on a 98
  120. Need Help, cam position sensor clip.
  121. Intake manifold question...
  122. differences of tb's
  123. A few Header questions
  124. Doing a LT's / O/R Y , slP lm1 or lm2
  125. quick oil pressure sending unit question.
  126. Getting the stock exhaust off in one piece
  127. Cutout Question
  128. F.A.S.T. 90 Intake with what TB???
  129. can shorty headers install from the top
  130. LS6 Camaro intake vs. LS6 Corvette intake
  131. Magnaflow...what a beautiful thing...check out pics!!
  132. victor jr. ,sheetmetal?
  133. ATI Superdampner Question
  134. Making my own true dulas....
  135. Will BBK TB Fit 98-88 Cars?
  136. Making my own TD'S
  137. Just installed long tube headers and new y-pipe
  138. My new 3" true duals by lane!!!
  139. Took off air pump, now car won't start.
  140. Male Plug, Crank Postioning sensor broken
  141. Cats Or No Cats ??????
  142. **!!>NEW<!!** Sound Clip: MS4, Pacesetter LT's, ORY, Corsa
  143. Motor reinstall
  144. 3" or 2.5" TD's?
  145. true duals mufflers
  146. Homemade air tube block off plates
  147. ran over speed bump wrong, dented headers
  148. About to get dyno tune, need answer for tb
  149. help! cant get ls1 intake off!
  150. AIR Block Off Plates
  151. Help!Ls6 intake!
  152. What kind of paint for true dual exhaust?
  153. magnaflow fit
  154. Dynomouth set-up......help please!!
  155. POLY MOTOR MOUNTS- hardest install EVER..... HELP!
  156. Water Pump Pulley???
  157. Okay
  158. What Is The Best Set Up?!
  159. ngk tr5's or tr6's
  160. Need Help. What is this used for???
  161. TB bypass/ Water temp. sending unit install
  162. What are these for?
  163. Another true duals video
  164. New intake lid?
  165. header gaskets
  166. Stock heads?
  167. good deal i thought
  168. Serpentine Belt?
  169. can i use my rear o2's in the front?
  170. What else needed with LT and Catted Y pipe
  171. LS6 intake/cleaning heads
  172. Unofficial LG Motorsports Dual Exhaust Update
  173. Question about exhaust pipe sizing formula (math)
  174. Need New Radiator...Need Suggestions ASAP!
  175. My up coming setup
  176. Anyone have 4in Mufflex Exhaust
  177. Yet another header problem
  178. LS1 Intake
  179. Beru Silverstone spark plugs?
  180. MSD's LS1 and LS2 Coils
  181. Fabricated Valve Covers
  182. New CME design
  183. PVC Catch can?? Do you recommend them??
  184. Exhaust system question. I KNOW, I KNOW
  185. Problem during header install
  186. True Duals Help
  187. Questions regarding my plans with e-Cutout
  188. Are these plugs bad?
  189. MAF error code, just a fluje or on its way out?
  190. How far to drop the axle to get the stock exhaust in or out?
  191. charge system fault???
  192. What catted y-pipe to gp with Pacesetters?
  193. Alternative 90mm TB's
  194. Pulley Opinions
  195. Parts list for catch can?
  196. LT's and LM2
  197. Should I cat
  198. car is missing after Lt install(help)
  199. Anyone in the NoVa area with a HP tuner or something?
  200. New Headers...Engine Rebuild??
  201. Charging Problem???
  202. Anyone know the diameter of the intake tube?
  203. Exhaust Question
  204. Finally installed my LS6 Intake>>>
  205. True Duals
  206. Engine Cover Swap Question's
  207. Problem!: Idler Pulley assembly!
  208. removing stock exhaust in 1 piece
  209. True Duals
  210. so who all does porting on the fast intake and
  211. 408ci - what long tubes to get?
  212. who makes a 4" catback?
  213. Magnaflow catback....go catted or ory pipe???
  214. My exhaust setup idea....need advice
  215. trash in radiator?
  216. Accufab 105mm users!!!
  217. Popping sound after open headers
  218. Where are Kooks and QTP headers made at?
  219. TSP408: LS6 oil pump wont fit!
  220. Does anyone have directions on how to install headers
  221. Pacesetter LTs, ORY Hooker Catback, Tailpipe not staying on hangar
  222. Cost of having a shop fabricate a Y-Pipe in 3" Stainless Steel?
  223. o2 sensor Problem HELP!!! Please
  224. Installed SLP Flow Pack
  225. Threw 2 codes....lil help??
  226. ls2 intake
  227. ticking noise after intake sawp
  228. New Headers????? Emmisions Legal
  229. Y-Pipe with GMMG
  230. Electric cut-out
  231. Bit's Build Up Cont..
  232. Cmmg Cat Back
  233. Need Help!!
  234. suggestions for bullet muffler?
  235. Motor mount installation
  236. 98 auto harness
  237. 98 LS1ers only!
  238. intake/tb
  239. Why so much play at WOT?
  240. Headers Anything else i need?
  241. Dynomax bullet
  242. code P0430...need help
  243. TA DAH! my first P/P'ed TB.
  244. k&n filter part number
  245. Will a Tsp ORY+ QTP LTS work?
  246. CA exhaust ?'s
  247. Building true duals
  248. Sound Clip: MS4, Pacesetter LT's, ORY, Corsa
  249. Do you use map sensor from ls1 to ls6 manifold conversion
  250. SLP Air Temp Module..Too good to be true?
