PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 [159] 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Cheap o2 Sims
  2. Will a 350 engine cart hold a LS6?
  3. Anybody lowered with dumped TD's
  4. Cat location
  5. XS Stainless LT's installed... vid clips...
  6. maybe a blown gasket?
  7. header bolts
  8. vapor locking
  9. massive engine missfire after alt change
  10. Warlock race mufflers
  11. A slightly different header install question
  12. Good or Bad........Dedicated A4 oil cooler?
  13. FAST LSX 90mm??
  14. QTP electric cutout Installed
  15. High flow catalytic converters
  16. AC line
  17. Need a picture of the fuse boxes
  18. anyone here have a 4 inch mufflex catback?
  19. Self Install or Not?
  20. help needed on header install asap
  21. LM2 Installation Question
  22. !AIR question
  23. pacesetter headers TSP true dual
  24. Switched intakes
  25. True Duals quote
  26. Help! Broken Oil Pressure Sensor...
  27. Gen III custom programming?
  28. FAST 90 intake help
  29. LS6 intake vs. 6L Truck intake
  30. CME exhaust ?'s
  31. Pacesetter install prob??
  32. Flowmaster Catback
  33. Pacesetter lt headers
  34. How to swap alternator pulley?
  35. idle problems with shaners?
  36. slp LM2 vs flowmaste w/cutout. LM2 owners welcomed!
  37. Which MAF sensor is sufficient enough for me?
  38. bbk 80mm intake and tb
  39. How to re-charge a/c
  40. 4" to 3" reducer
  41. Underdrive pulley change Alternator Pulley Yes/No??
  42. Bassani True Dual and UMI tunnel brace torq arm???
  43. Bassani True Dual and umi tunnel brace torq arm???
  44. Idle Relearn Procedure
  45. Help me find part numbers for misc. items
  46. Coil Pack Relocation Kit
  47. True Dual H-Pipe Dump. Moroso Spiral Flows OR Dynomax Bullets?
  48. Those with 400+rwhp and the Corsa exhaust system come on in!
  49. motor mount question
  50. Cleaning out injectors
  51. To Pulley Or Not To Pulley That Is the Q?
  52. Moroso Spiral Flows OR Dynomax Bullets?
  53. Quick Exhuast question
  54. LT+ lowering help!!!
  55. O2 problems/qestions
  56. I need quick help... drivers side manifold
  57. need programmer for 02 SS for 4.10 speedo change!!!
  58. Block-off plates
  59. I posted this in suspension also looking for answers anywhere
  60. Epoxy hitting IAC
  61. MSD Digital 6 Plus Ignition Box
  62. LS1 Alternator Bracket
  63. Help with Spark Plugs and Gap
  64. Sorry Guys ! I need alittle help!!
  65. Igniton
  66. noobie
  67. underdrive pulley tool
  68. ok i want pace setter long tubes
  69. Took Breather off today
  70. Bosch 13111
  71. best place to buy long tubes
  72. Is the ATI balancer worth the coin over the TCI
  73. long tubes or mid lenghts
  74. header install not being friendly...
  75. Got my cutout!
  76. Just Got An '07 6.2 And 6 Spd Auto
  77. Well got my Vic jr today
  78. dumb question
  79. I'm Lost...What Causes These Codes? Please help me.
  80. tomorrow, i attempt my LT install, alone, in my apartment complex parking lot
  81. Anyone try this???....
  82. look what came in from a member on here..
  83. American Racing Headers
  84. do auto stores sell lids?
  85. ? About installing LT's and Y-pipe
  86. no tach and car won't run
  87. ported fast vs. stock fast intake
  88. Fastest way to change fuel pump?
  89. fast intake
  90. DNA Mufflers???
  91. Is the hole on my TB blade toooo big?
  92. 8.1 496 cats
  93. bassani true-dual
  94. Typhoon=Bad??
  95. Does Anyone Have PIC's of the New Edelbrock LT's
  96. SLP vs Whisper, any real difference?
  97. mti lid air inlet sensor clearance problems
  98. Header noise
  99. LT Edelbrock ground clearance Questions???
  100. Low RPM misfire
  101. MAF question.... Anyone know?
  102. Typhoon Has Been Installed
  103. what else do i need when i do header install
  104. no tach and car won't run
  105. FAST 90 intake monifold hiding question
  106. Taking top shell of FAST off to paint it
  107. misfiring
  108. SES light, bad exhaust emissions, can O2 sims fix?
  109. Install questions
  110. true duals
  111. Engine running rough (weak) and could use advice on what to check for
  112. anyone regreat buying a fast 90/90?
  113. oil on tb blade and in intake?
  114. I'm going with TRUE DUAS. need suggestions
  115. tts headers
  116. Impressions of Edelbrock LT's + Hooker Catback
  117. Cat Question
  118. stock vette manifolds
  119. Cracked lid
  120. How efficient is this custom intake?
  121. FAST 90/90 too much for my setup?
  122. rubber couplers
  123. Flowtech Headers?
  124. need some exhaust help please
  125. cutouts what next?
  126. Pacesetter leak where header bolts to heads
  127. Anyone with Hooker LT's, Hooker ORY and Magnaflow catback?
  128. Ported LS6 Intake?
  129. fuel rail, fuel line steup
  130. header bolts???
  131. changing o2s quick question...
  132. swap from ls6 to fast 90
  133. Help With tach and shift light install
  134. Car runs like poop!!!!!!!!!!!
  135. Weiand intake and factory throttle body...
  136. American Racing Headers and Streight Line Performance
  137. replacing Spiral Flows w/ Magnaflow mufflers on TD's
  138. Replacement bellow for speed density.
  139. Installed Exhaust Yesterday - What next?
  140. 1 7/8 Headers
  141. Which exhaust is most tame at idle but loud/mean at WOT?
  142. horsepower on vacation?
  143. gasket question
  144. Exhaust banging....How did you fix it?
  145. Dynatech 4 Bolt Flange where to find? TD build
  146. powdercoated throttlebody guys
  147. True duals with manifolds?
  148. Exhaust question
  149. Y pipe? yes or no
  150. 6.0 intake
  151. LS6 manifold swap question
  152. weld or don't weld?
  153. QTP LT's, Hooker ORY, SLP LMII?
  154. Truck VS LS1 harmonic balancers
  155. Installed my new Intake Manifold and ....
  156. Header Questions
  157. SpeedInc. best deal on coated pacesetters
  158. Lid
  159. going to attempt motor mount install...wish me luck
  160. Can you identify this exhaust?
  161. Stainless Headers and Y-pipe NEW TECH SPONSOR
  162. any tricks for the oil dipstick
  163. 3" TD just installed..pics too
  164. cat with AIR or without
  165. Coil harnesses
  166. which setup to choose
  167. coolant tubes
  168. professional products LS1 96mm intake
  169. professional products LS1 96mm intake
  170. which 85mm maf is better SLP or Grannateli??
  171. which 02 are which???
  172. coil pack relocation
  173. 5.3 wont start
  174. Spark plug?
  175. coil relocation brackets
  176. Could my intake manifold gasket cause this?
  177. New Spark Plugs From GM??
  178. what type of connectors/clamp to use
  179. Exhaust pissing me off
  180. What else for full bolt-ons?
  181. what else for full bolt-ons??
  182. Granatelli wires, why so much $$$, worth it?
  183. Jet hot lt
  184. accessory belt came off?
  185. Tach signal
  186. Popping exhaust
  187. if i take the emissions system off of my car.............
  188. Hooker or Pacesetter.... help
  189. Removing AIR, need HELP!!!
  190. Longer Balancer bolt...
  191. stainless bullet?
  192. Evap system information HELP!
  193. LM resonator change to spiral flow process
  194. Group Purchase for TSP True Duals?!?!?!?
  195. Are cut outs bad for your car?
  196. Anyone else have trouble with collector flange bolts rattling loose?
  197. help!
  198. Expanding Exhaust
  199. Exhaust??
  200. Thermostat and PCM Tuning
  201. stock air lid question
  202. A New AIR Idea - What do ya think
  203. Multiple Misfire code after LT install
  204. Christmas came early this year! Check out what the UPS man brought me
  205. FAST intake install should I replace my port gaskets?
  206. Best setup for my car?
  207. qtp y pipe, bad ground clearance!!!
  208. Full exhaust with true duals...
  209. How much?
  210. Electric Cutout
  211. Dynatech headers arrived today - Small problem
  212. LS1 longtube headers for my 2500HD?
  213. Intake vs. Intake/TB
  214. o2 extensions
  215. Ls6?
  216. couple of ? about header install.
  217. LS6+ PP TB= Happiness
  218. remote oil filter installation
  219. Catch Can question??
  220. quieting down exhaust
  221. questions about headers slp, pacesetter, or jet hot
  222. painting headers
  223. Fly by wire options for my vette
  224. need help on head bolts
  225. Am I missing anything for this install??
  226. Stock Manifolds
  227. Radiator removal help?
  228. New Kinsler Itb Manifold
  229. LS1Sounds..Anyone else having a problem contacting him?
  230. Porting and descreening MAF
  231. Fipk
  232. how much power will the bassani flow
  233. What causes a brand new battery to leak?
  234. california exhaust
  235. what can i expect rwhp wise?
  236. Newbe From Oz Needs Help
  237. Feelin the itch to mod.....
  238. Loud Mouth 2 or TSP Rumbler?
  239. help...
  240. Help me fix my Car!!!!!
  241. TSP TRUE DUAL come ON IN!!!!
  242. Changing motor mounts make baby Jesus cry
  243. TB/ Intake manifold...
  244. Had loudmouth, now magnaflow, but just not happy....loudmouth II?
  245. Pacesetters?
  246. Any opinions on which headers?
  247. How do you know when your o2s are shot
  248. Pacesetter coated Y or Hooker stainless Y?
  249. Exhaust Banging?
  250. Oil type?
