- Where can I find GMMG mufflers
- qtp catted y
- Hooker CatBack?
- installing headers
- clearance issues with updated pacesetters
- How much did you pick up?
- Nick Williams TB
- hp gain?
- How Will My Ss Sound
- EGR delete
- Suncoastcreations airbox vs. any Airlid?
- When to upgrade to FAST??
- Shorty headers
- over the axle dual...?
- Wat size Converter for SLP headers and SLP Y
- Truck Intake Manifold power vs. LS6 intake?
- oil pan drain bolt size
- Are my TTS cats hurting my performance?
- Aftermarket Oil Temp Sensor
- Pacesetters are in but I have a ?
- Header Install Tips
- help choose muffler
- HELP QUICK!!!!, simple answer needed ASAP
- What is up w/ the water pump on these engines?
- Cover of Feb. 06 Hot Rod
- Anyone have a pic of their FLP cats on their car?
- Clearance with tsp true duals???
- P/n for K&N Pod air filter straight on to Throttle BODY
- cold air intake?
- sound advice
- boot replacement
- MAF question
- Edelbrock Stepped LT's 1 3/4" to 1 7/8" (more collector options now?!) Part 6583
- O2 sensor wire routing with LT's
- throttlebody for ls6 intake?
- Do the FAST intakes whine?
- ls1 to ls2 intake question...
- will 2002 z06 manifolds fit a 00ws6
- true dual system
- true duals question
- need help
- question about qtp hvmc
- True duel question
- bolt on questions
- True duals?
- how much to expect
- Intake install question?
- duals?
- Need some numbers!
- Ram Air question
- Aftermarket catback vs aftermarket Mufflers
- mufflex y-pipe ?
- K.I.S.S. loose plug
- best place to get catch can
- SLP Headers...Maxxed out??
- cutout location ?
- Gettin headers soon!
- Switched coil packs?Rough idle!
- How much is an oil pressure sending unit?
- Pacesetter long tubes and tsp ory pipe ????
- moroso spirals
- where can I find?.....
- stock thermostat
- Ssra
- hooker long tube coating warranty?
- Finaly
- Running Rich
- ? Ls2 throttle body
- Those with the SLP TCS Logic Module -> IN
- Throttle Body Swap
- antifreeze?
- slp y pipe & exhaust system
- jet hot or pacesetter
- which y-pipe?
- Headers w/EGR
- What kind of exhaust should i get fro my T/A
- exhaust setup??
- New exhaust changes... HELP!
- LT sound with no cats, and cutouts open
- GMMG exhaust
- what LT header has the best clearance
- Question about swapping headers
- autometer tach hooker up,but not operating?
- Difference between FAST Toys RA and SLP??
- AC-Delco plugs ?
- QUICK, ordering pacesetters, race header or 00-02 with egr?
- FAST 90 Intake and NW TB results
- Need Help Identifying O2 Code
- Plugs and wires
- even MORE cut out questions
- motor mount install
- Here's my self ported throttle body
- is this the ls6 intake i need?
- need belt part # for slp pulley.
- power effects muffler?
- 500 rpm idle ?
- Cats or no cats?
- Kooks headers, dual cutouts and ory
- long tube header install ?
- part number
- Coolant system vent tube....thing...
- ORY help
- Help I.D. Maf(Pic Included). Aftermarket?
- which lid is this?
- bosch spark plugs
- exhaust
- O2 extensions for front O2s for LT install?
- i found the secret to good gas mileage!
- spark plugs
- Air Pump Removal Question
- amw catch can problems
- Quality Pacesetter welds!
- FAST intake and TB...
- SLP AIR LID VS. K&N FIPK
- FAST 90 install. HELP!!
- Need Help with Headers
- Noob Header Install Questions
- How good is this Port Job? (TB)
- SLP CAI question
- hOW TO CHECK TPS FOR CORRECTNESS?
- how much i pipe with hooker catback?
- LS6 Intake Swap
- PCM Cover
- Buying a cutout
- sensor question
- I know everyone dogs Flowmaster but......
- Improvement with Corsa?
- No Volant Intake Reviews??!!
- lid or flow pac ??
- Search is not working, Looking for EGR/Exhaust Manifold Bolt info
- Improve LS1 Intake Manifold?
- Borlamouth "choking" my exhaust??
- Can someone tell me what this guy is trying to tell me(for a cutout)
- Just installed my pacesetter LT's and ORY 1 PROBLEM!!
- New Era Performance Ported TB Worth It?
- Slp Loudmouth 2 Help Asap!!! 01 Ws6!!!
- How do you guys think this would sound?
- Cleaning catalytic converters
- Welding in the cats
- qtp and kooks??
- no cats=bad sound???
- Tpis intake
- How much power can i gain with these 3 mods?
- slp exhaust??
- clearance issues?!?!?!?
- Will a single cutout still sound good??
- has anyone used this flowmaster pipe kit
- quick question on long tubes?
- air injection Question
- TSP true duals install question
- What do you think?
- Need external oil cooler recommendation
- do mandrel bends really matter
- Custom true dual VS SLP loudmouth kit
- Has anyone here tried/tested one of these?
- Catalytic converter
- true duals with magnaflows
- Can I change my Bullet muffler on TSP Rumbler to a Sweet Thunder?
- What next?
- td kit?
- cross over....?
- MAF Cleaning Questions ??
- cast chevrolet valve covers?
- Anybody use the meziere race electric water pump
- Hvmc on pacesetters
- will a tb affect my dynotune?
- NON coated header help
- Pacesetter collector has flat spot!
- whats the purpose of poly motor mounts?
- Question about true dual install
- Overdrive pulley
- Ssra???
- Electric Cutout Question.
- What to expect from SLP LT's
- Single or dual cut-outs?????
- Muffler shop screwed up Catback
- Pics of Greddy Catch-Can Install. (!56k)
- ? using 6.0 manifold
- Cheapest Place to get Flo Pro Twisters?
- what is the best antifreeze?
- disabling AC on defrost setting to save power?
- SLP center exhaust questions
- cut out on a stocker
- cat back question>>>
- FAST intake *Pics*
- exhaust question
- Aftermarket Valve Covers
- Underdrive Pully??
- Engine Motor Mount Bushings!!!
- Motor Mounts
- Crank pulley bolt?
- Anyone with a Nick Williams TB?
- Radix 5.3 truck, how should i gap the tr6's?
- Quick ? on installing TSP lid
- TSP x-pipe won't fit coated pacesetters
- emission block offs?
- Kool blue or K&N?
- A great muffler shop in your area???
- Headers with Magnaflow
- Get catted y?
- relocate powersteering on LS1
- Slp ORY with pacesetter LT's?
- slp loudmouth owner!!
- exhaust
- Will DynoMouth lower my exhaust by 12 decibels?
- Another PCV question...
- switch my ORY?
- Kook's ORY with any other header?
- Is this exhaust stock?
- Header Question
- Fast Toys ram air Kit + SS hood????
- Wich Header Gasket? LS1 Camaro?
- question about exhaust setup
- Kooks LT Headers with Video Clips (2005 GTO)
- Underdrive pulley quiz
- Question about Maf ends!
- New Plugs and Wires in >>>>
- Pulled wires out of O2 sensor connector! How to fix?
- QTP Headers = How low do they hang?
- exhaust clamps.....question about a leak
- keep old parts?
- Holley 90mm TB for LS1's Check it out.
- Starter help
- does hooker make 1 7/8 LT's?
- Throttle body Bling (Pictures)
- Good y-pipe for cut-outs?
- Exhaust Hanger Bolt Size?
- Pacesetter header question
- Questions on MAF
- ngk tr55 requ
- what o2 sensors do i need with my set up???
- tb enhancer
- Can you port a LS6 manifold? Is it even worth it?
- all mufflex y owners inside please!
- Questions on SLP intake....help
- Those with Custom Duals
- Mecham Exhaust
- Need Advise!!!
- *Pics inside--unported FAST 90mm, NOT MUCH TO PORT
- Anyone tried this?
- Who to go to for ported stock TB's?
- can i put a 3" qtec on the stock ws6 I-pipe?
- pulley question
- Dual Elec. Cut outs...PROBLEM!!
- Is this set up crap??
- Who can port a fast 90 intake?
- where can I buy a cable operated cutout?
- Best Bang for the Intake Buck?
- want exhaust louder
- Volant vs FTRA
