View Full Version : Generation III External Engine
- AMW catch can users in here... I have a Q?
- Weiand intake on LS6 crate engine?
- Exhaust change ... which Borla mufflers????
- Best Ory? Qtp Or Kooks?
- header flange possibly bent..
- correct placement of rear O2 sensor on custom catted y-pipe
- side exit exhaust
- Instead of sweet thunder duals, for y-pipe folks?
- pully
- WS6 Hood - 3 Options - K&N FIPK, Lid & Plain Lower, Lid & WS6 Lower - Help?
- '99 Ls1/'01 Ls1 Maf Queston...
- Flowtech cutouts...poor quality
- Difference in 98-99 Lids versus 00-02 Lids
- Need help with headers
- Weird Startup.
- Keys Won't Come Out
- Need Advice/Help Designing CAI for LS1
- Thermostat question..
- coolant crossover tube?
- Is the vertical PCV mod any better than a catch can?
- Greddy catch can-15mm or 9mm
- bottom part of fast intake
- Ls1 To Ls6 Intake
- Sqeeky at start up
- True duals
- Which lids will work with a 85mm MAF????
- yes ive searched
- misfire / hesitating... could be fouled o2 sensor?
- true duals or y pipe?
- Ok Im sick of true duals now, what can I do??
- First header install (pending) in 20 years, LOL
- what type of wrench...remove solenoids star headed bolts from starter??
- Electric WP on a 430whp TA? What increase?
- FAST LSX Question about EGR connection
- Which one or maybe more (exhaust) ??????
- K&N and MTI sealing
- new mufflers(Borla TD's)
- LS6 intake install
- LS2 -vs- edelbrock intake
- Does Donaldson make a replacement air filter or CAI for the Fbody?
- Can o2's cause this much of a problem?!
- Exhaust Manifolds?
- Help! What the hell is this sound? (video clip)
- 1st Spark Plug Change Report
- Any shorty header track results?
- How bad will this sound..
- MTI lid vs. Others
- installed catch can wrong
- Bassani True Dual 99
- loudmouth 2
- BG ram air
- Need to change maf
- How can you check which model year Ls1 you have?
- This might be a dumn question but I'll ask any how.
- cleanin the maf
- diameter of stock y-pipe?
- Installation of Pacesetter midtube shorties for my 98
- Cat questions
- Different CME options?
- how much to ask for stock exhaust?
- how smooth should a ported throttle body be?
- Anybody got the Hedman complete exhaust?
- Duals under the axle guys...
- How do I get my oil fill neck out of the valve cover?
- quick 02 sensors question
- LS1 with no cats
- Took Off My Y Pipe Today
- GM Perf. vs. SLP LS6 Intake?
- FTRA kit and SLP Lid??
- Maf?
- WTF Plug wires !!!
- Will I be OK?
- O2 extenders
- Air Removal?
- Exhust Question
- ??? Nick Williams TB?
- Y-Pipe hi flow for Stock Exhuast
- QTP catted y woes/question.
- XR-1 Loss of power!!
- better tune after longtubes????
- Hooker headers or Pacesetter?
- exhaust headers
- intake help!
- Need help with duals, X or H pipe.
- LS2 Exhaust Manifolds vs LS1/LS6?
- Anyway to simulate the EGR or make the computer think it is functioning?
- big problem please help
- Floorboard knock, A/C compressor, and exhaust Qs
- header gaskets?
- Any 1-7/8" 32" Primaries Headers for C5?
- mti clear lid vs voolant air intake
- '00-02 Exhaust Manifolds Better Than '98-99?
- Help!
- ORY and MPG
- Spintech
- help with o2!
- best cheap cats for gutting
- Electric AC compressor
- Z06 MAF..No MAF???? Can't decide! Need help!
- exhaust
- Best Headers & Y: LT/ORY
- Radiator work if hoses are switched?
- Muffler length question
- Which exhaust flanges seal the best?
- 160 thermo
- o2 sensor (delete or sim)
- what headers and y pipe
- O2 sensors went bad helpp???
- Would you recommend this?
- PORTED MAF questions
- Open Headers
- LT's+ORY or LT's + TD set up.. power potential
- Straight duals
- Electric cutouts?
- Header Cons?
- HI-Flow Cats Worth It?
- what mufflers after x pipe....
- Alternator charge voltage
- throttlebody
- Fellow MTI Lid Owners do you have this same problem?
- will a lid from a 2002 fit a 2000?
- Pulley Belt Question
- How to Service the A/C
- cooling question...need help!!
- Patriot Headers...
- 02 sensors
- Do I have the right asp pulley belts??
- Poly trans mount in...y-pipe banging gone! (long)
- exhaust suggestions
- Throttle Body Bypass
- HELP!!! power steering pump went
- cutout
- Pics of my new SLP smooth bellows
- Can I trick the EGR?
- A/C on , rpms low
- Which ORY and LT's??
- Just failed inspection with LM. Which muffler/resonator to get?
- True duals W/Cats?
- 2.5" True Duals vs. 3inch y pipe ?
- What headers to use?
- Stock Cat Inlet/Outlets?
- cat back install
- which setup should i get??
- Whats The Difference
- Header install...*assemble order*
- Weird white residue from A/C
- SLP LM diameter?
- Arcing Spark Plug Wires...
- SLP Bolt-On SFC with LT's ??PIC'S...????
- brake fluid leak at master cylinder and Brake Booster...but...
- need part number for front turn signal case on T/A
- Should I get o2 sims?
- SLP Loudmouth II?
- Installing my march pulley???
- new knock sensors are in..
- Borla pro xs
- !AIR and O2 questions
- MAC ORY fit on stock manifolds
- Chambered muffler like sweet thunder, but 3" ID
- Jet hot LT's, ORY, and Borla on!! finally
- Pacesetters installed, ORY is a no-go. Options/opinions?
- flowtech header impressions
- power steering q's
- Should I cut out my cat. conv?
- LT's & ORY / Cutout / Stock Exhaust
- question on alternator and exhaust setup
- Remove bottom bolt of steering shaft? (header install)
- B&B long tube headers with catless x pipe for under 1000..quality? good deal?
- Anti-seize on header bolts?
- Just installed 160 thermostat, now I'm running hotter?
- looking to replace my flowmaster... how's the tsp rumbler?
- Help running the wire for the electric cutout
- Thinking of dumping my Borla
- Headers/y Pipe Combinations
- Throttle body ?
- a/c compressor
- Header Reducers
- Problem!
- backfire?
- Need help reguarding various sending units? info needed
- Jet Hot LT & Y-pipe
- QTP Lt's/Catted Y-pipe question
- Exhaust question.....
- hooker y-pipe question
- old ASP pulley
- How to Port and polish Throttle body
- another what will i gain question
- oil filter/ oil drain plug has to come out for header install?
- resognator for muffler
- passenger complains floor gets HOT!
- Removing the Heater Core
- Cut Outs
- Anyone running 1 7/8" stepped headers on stock cubes?
- Those waiting for a 90mm NW throttle body
- Exhaust Manifolds - Changes between years
- Just got hooker...
- AC Compressor question.
- Idea for porting throttle body
- Lamest Question Ever!!
- Taller lower air box?
- Where to find band clamps?
- LS2 TB on C5
- Help! header install.. steering shaft.
- Anybody running the 30" sweet thunders w/ true duals?
- Exhaust Setup
- True Duals
- FAST 90 TB... is it a POS?
- What to do with exhaust
- Granatelli Wires
- I want others to "feel" my car.
- 85mm maf
- After !EGR, what do you do with the plug and wire?
- pacesetter question
- !Muffler?
- making the SLP 2otl exhaust exit as a dual?
- Help?????????????????????????????????
- 00 onto 02,and 02 to 00,well it work?
- I need help with an A/C problem
- tteacher made interesting point, need input...
- Finally, success w/ FAST throttle body
- ls1 ----> ls6, tb question
- Switching Catbacks
- i need that rubber piece that goes by the air box on SS and Firehawks, help me
- header install question?!?!?!?
- Never noticed this before
- clearance with qtp cutouts and y-pipe
- Steel oil pan?
- pictures of F-body alternator bracket
- Question about band clamps
- Tips for home porting TB
- Kooks/GMMG
- Lid debate MTI or SLP
- true dual for QTP
- I hate the alternator =\
- dyi ported tb + smooth bellow
- Cut Out Results: True or False
- 'Jet-Hot' vs. regular ceramic vs. titanium ceramic vs. nickel plated vs. stainless ??
- Cutting pipe?
- QTP Electric Cut-Out
- best place to put cutout
- Cool part
- Getting Headers and ORY, what to get.
- How many Cats do I have?
- !EGR & !AIR While Smog Legal?
- Cai vs. Ram Air
- EGR delete questions
- qtp cutout problem
- what hp increase from an
- volant intake?
- Least Expensive ORY? (Pacesetter LT's)
