PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 [276] 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. corsa cutout, welding, and SS #'s help
  2. New exhaust setup for T-Rex Cam - opinions
  3. GM now warns about K&N TYPE (oiled) air filters!
  4. Help with TTS headers
  5. Spark plug wire came loose.
  6. Which is more difficult?
  7. Flow? Sound?
  8. VPlus Volt Booster Install Questions ?????
  9. Anyone Install Their Evans WP Yet?
  10. Any differences between OEM and aftermarket SLP dual/dual cat-backs?
  11. Reusable air filter warranty issue?
  12. 25 Megaton Thermonuclear Backfire
  13. TPIS 90mm F-BODY THROTTLE BODYS ARE AVAILABLE NOW!
  14. Are oil pan gaskets reusable?
  15. installing macs this weekend how hard is it going to be
  16. Share Some Info With me on SLP Headers!
  17. Pacesetter Header Fitment Problems?
  18. I need a new cat back
  19. installed headers now stumble at idle
  20. how do you get good exhaust sound w/LTs
  21. QTP or Kooks
  22. What muffler will i need for my true dual setup?????
  23. pop sound when shifting
  24. Pics of TSP Tips
  25. LT's and LM with a Catted-Y
  26. what needed for a ls6 swap?
  27. K&N filter fitment issues?
  28. true duals
  29. evans pump pic!
  30. Electric Water Pump or factory pump?
  31. removing A/C
  32. Which poly motor mount company?
  33. Exhaust Assistance Please.
  34. Accurate Machine Catch Cans
  35. Mids Vs. LT's
  36. Pace setter Problems??
  37. TB Question, Will an 02 TB work on a 99?
  38. GMMG ?'s
  39. What are the 2001 Z06 fuel injectors rated at? And is the fuel pump bigger than F-bod
  40. Costly Mistake? Please Help
  41. TSP Rumbler Video.. (link fixed..check it out)
  42. Jet Hot headers
  43. Hold off on coating Macs?
  44. Flowtech LTs
  45. Which bolt to remove to loosen the motor mount?
  46. Could this be hurting my times?
  47. Any performance gains switching from SLP factory D/D to MAgnaflow catback?
  48. MTI Clear Lid
  49. wont idle at startup after shaner>??
  50. FTRA Owners Come In
  51. Think my alternator is going bad....
  52. anyone get the new 4" QTEC yet?
  53. Quick question ( LS6 manifold)
  54. NEW Under Axle Pics are HERE!!
  55. What is this sound
  56. 90mm T-Bodies in stock at MTI!
  57. Hooker Muffler
  58. comparison between these two headers brands... opinions please!
  59. Ordered Mufflers for TD's: Where Should I Place Them
  60. Do I need to take off my FRC's to change my spark plugs?
  61. SES Light after LT Header install
  62. FLP LT's
  63. which 3 in y pipe with pacesetters?
  64. cheapest place to buy a starter?
  65. Who sells header/manifold gaskets???
  66. Moroso Spiral Flows Vs. Dynomax Bullets
  67. SLP loudmouth "resonator" vs. dynomax bullet
  68. SSRA Owners Please Come In...
  69. Cats Removed ?
  70. Need Opinions: True Dual Set-Up
  71. Anyone with a homemade Battery Relocation?
  72. Any 6.0L iron blocks running a shortbelt.
  73. qtec's and y-pipe
  74. Tell me everything about the QTEC
  75. update:went to the track after switching from borla to lanes true duals
  76. Pacesetter Y-pipe
  77. Lsx Sound question?
  78. im going to install flowtech headers my self i need some tips
  79. Bad Cat Converter?
  80. Pacesetter and TSP install Complete
  81. Is anybody this dumb?
  82. Crank snout too beig for balancer? Help
  83. Why do I smell Antifreeze
  84. gutted cats with Lts?
  85. C5 Chambered Exhaust
  86. Anyone got any dyno #'s for eldebrock new headers?
  87. Gains with FTRA
  88. Too Many Choices!!!help!
  89. Header Install Instructoins
  90. Installed Catch can!
  91. Header People insidE!
  92. A "plug" for Kooks Headers
  93. 3" Xpipe-no mufflers!
  94. Initial LSX Opinion
  95. Signs and symptoms of worn motor mounts.
  96. Header/ Y-pipe Install.. I may be in trouble
  97. Difference Between 12" and 18" Bullets?
  98. [B]Do I need to Re-Program[/B]
  99. Serpentine belt breaking during race?
  100. Mac Headers People
  101. Installation link?
  102. magnaflow to true dual...mess up dyno tune?
  103. Header Install Question (pic)
  104. 3 inch y pipe suggestions
  105. Quick!!!!
  106. whats all need to do ls6 intake swap
  107. Need Help now...PLEASE
  108. Take a look at this
  109. Removing crank pulley?
  110. For anyone looking for a PCV catch can inside.
  111. Which mufflers for true duals?
  112. WTF? Jet Hot catted Y
  113. Lsx contacting cam position sensor....
  114. 3 inch y-pipe
  115. exhaust set up question
  116. Getting FLPs and Cam installed on the Z this weekend
  117. car doesnt want to start.makes horrible noise on start. Due to header hitting?
  118. Should I still dump it and where?
  119. Will this work or not
  120. About the new CHP
  121. Off Road Y-Pipe
  122. post cut out pics
  123. i'm gettin flowtech headers need opinions
  124. What bolt to use with asp pulley?
  125. Power loss with Kook's headers and Magnaflow cats?
  126. Release date of the FAST 90mm Throttle Body?
  127. Newbie Question, TSP Rumbler...
  128. Just installed BG Ram Air
  129. What causes an engines rpm's to come down very slowly????
  130. whats the difference from lanes true duals or justin sutton?
  131. Easy sparkplug change-Pics
  132. Intake swap emergency
  133. Spark Plugs??
  134. full exhaust installed, car wont start today...help
  135. SLP Lid won't stay on!!!
  136. ARP Pulley bolt procedure?
  137. Corsa Installed 1st Impressions!
  138. Wiring a A/F Ratio Gauge
  139. LT Header system that is right for ME?
  140. Header Options?
  141. Looking for a resonator
  142. What Mufflers for true dual?
  143. Got my GMMG!!!!!
  144. Anyone make a dual plenum intake for a ls1?
  145. FIPK to Lid worth the effort and $$ ??
  146. ls6 manifold
  147. ls1 to ls6 pvc conversion
  148. dump exhast!
  149. Race headers and O2 sensors
  150. finished the pace setter install gotta Q
  151. LSX Questions
  152. New Carb LS1 setup made 40 hp over LS6
  153. New Carb LS1 setup made 40 hp over LS6
  154. intake ?'s and exhaust ?'s
  155. Having problems with new SLP radiator.
  156. How much is my stock muffler hurting me?
  157. Opinions on my possible True Dual set-up...
  158. Goza Coolant Recalculating Catch Can
  159. Who know this Exhaust?
  160. QTP Longtube Headers
  161. TB Mod needed to fit LSX!
  162. Remove post/support in intake???
  163. Flowtech Long Tubes....Quality, fitment??
  164. ASP Pulley really worth it?
  165. What mod to do NEXT??Opinions!!!
  166. Flowtech Headers
  167. mac header ?
  168. Height of Katech Valve Covers?
  169. ftra and bgm ram air together?
  170. GM Part Numbers
  171. Headers
  172. Exhaust Questions
  173. Borla & Hooker Longtubes?
  174. What do you guys think of this setup??
  175. 180 stat, what does your car run at?
  176. just got my t-body back from bauer(wow)
  177. ATTN lane
  178. Side exit exhaust
  179. Boom tube clip with rev.
  180. Need Radiator Hose ID Pleeeeez!
  181. Z06 MAF question
  182. Pulley install and Auto Trans
  183. FloPro Twisters vs. 50 Series Delta Flowmasters
  184. New to ls1tech - also headers installed.
  185. Anybody have pn# for 99+ coil pack brackets
  186. True Duals with Cutouts?
  187. Parts to convert to a lid??
  188. true duals vs. catbacks
  189. Need a quick answer! Harmonic balancer bolt size??
  190. True dual flowmaster or flowtech
  191. SLP Radiator - Any Good?
  192. Did I just pay $100 for a small appearance mod?
  193. Another way to mount the Accurate Works catch can.
  194. 3" ORY over a 2.5" ORY
  195. ls6 intake or lsx???
  196. LS1 Exhaust Question
  197. LS1 Coolant Flow
  198. ls6 manifold or holley?
  199. 5-Pin MAF into F-Body - Connector Wiring
  200. stock exhaust help!!
  201. Lightest/Most Efficient Radiator for street & circut
  202. Boom Tube sound clip
  203. shorter throttle response???
  204. I wanna hear a clip of Pacesetter LT's withloudmouth with the bullet muffler!
  205. CA Emissions and Hooker LT's
  206. Magnaflow Question!?!
  207. Just ordered BG Ram Air...
  208. BBK 80mm TB
  209. Dynomouth to Borlamouth
  210. Need to tone my Exhaust down.
  211. Where is a good place to get a stock MAF
  212. FLP header clamps
  213. air tube on pacesetters
  214. Hooker AC and Alt Brackets
  215. oil dipstick
  216. which bullet muffler should i get
  217. How much are new Pacesetter LT's?
  218. Blinking SES light? Car running rough...help!
  219. Rear O2 question--need quick answer
  220. Average price of a longtube header install?
  221. BOOM TUBE install complete!
  222. 02 sims question????
  223. going to switch from borla to true duals?
  224. Side Exhaust Legal?
  225. Does the coolant recirculate?
  226. need help!!
  227. Tuning after LS6 intake?
  228. Are some headers louder than others?
  229. What is this rasp you all speak of?
  230. Is the Flowmaster Y-Collector a direct fit?
  231. Help me out, What else do I need?
  232. ported throttle body
  233. Finished MAC install turned nightmare...
  234. Bolts supplied with Hookers Suck!
  235. How much power am I losing??
  236. Water pump exploded
  237. LS6 intake question
  238. Any problems with runnig headers and ORY through a cutout?
  239. Which is better for Headers, 304 or 409 stainless steel?
  240. Need HELP NOW....my SS is stranded!
  241. Drilling out the front baffles?
  242. ASP Pulley, New Stock Bolt, Threadlock?
  243. Results of Mac verses Pace Setter Headers
  244. Long tube question ??
  245. Where to get the best deal on a QTP electric Cutout?
  246. FLP's Installed!
  247. Flowtechs on backorder!!!!!
  248. Ugh, header install problems
  249. choice of mufflers, need opinions
  250. Can I run my car w/o EGR?
