View Full Version : Generation III External Engine
- leaking coolant
- True Dual Question????
- Help with CME questions
- Muffler Suggestions and Location.
- ls6 intake gains question
- texas speed catted y fitment issues + how to do cutouts?
- What's the average length of primaries on longtubes?
- What headers?
- Meziere Water Pump
- what do you think?
- Can I Swap A Catted Y For An Ory?
- Catch can question...
- Exhaust help
- Help me....misfire at idle
- ORY and inspection stickers????
- Is $170 a deal for macs?
- where to get catted y for pacesetters?
- Problem chewing up belts.. plz help
- TD question
- Which Catback?
- Open Headers??
- is there a write up on debaffling for the intake
- Co2
- best fitting lid out there?
- Lid/MAF coupler & MAF/Throttle Body coupler
- Ram air or aftermarket intake
- FAST Manifold question
- Which exhaust setup?
- pipe size
- Starter wires????
- Intake advise
- Has anyone had their Mezieere STRRET water pump rebuilt
- Sweet Thunders at end of System??
- Rocker arm ratio
- 2 mod ? pulley / sensor
- Ls6 Intake, What's The Advantage?
- Header Gaskets
- stock y pipe pics
- ls1 accesorie interchange
- Difference between dual/dual and slasher tips on Loudmouth?
- please help
- Car Wont Start
- Flowtech Headers
- Problems after header & exhaust install
- NEW PRODUCT: Offroad Pipes For Dynatech's SuperMaxx Headers!
- Can Any 1 Tell Me What The Best Muffler Is For A 95 Z28?!
- Difference in Valve Covers???
- Which exhaust on a WS6???
- after header install, throwing a few codes...need help
- Adding Fast 90/90
- what exhaust should i run?
- Front/Rear o2 swap
- Cant decide on headers.
- Squires turbo??
- Header question???
- ATS carbon-fiber valve covers
- Truck coil wires
- Front and Rear O2s Interchangeable?
- removing intake
- what should I gap my plugs to
- Was anyone else dissapointed by their "perforance" exhaust?!
- LT Header Help...
- what would a set of brand new Z28 flat black tips be worth???
- Damaged water pump during cam install?
- Whas this right????
- weld exhaust components together?
- O2 Sensor Interchange
- Dynatech Supermaxx Clearance Pictures?
- Ported Throttle Body
- Modding Advice???
- Will this work??????
- I need an exhaust recommendation for my 6.0L
- best fit and sound
- Exhaust for a full size chevy?
- ORY vs Legal Y
- Pacesetter y-pipe vs TSP y-pipe
- tsp rumbler with flowmaster 1 chamber
- Stock Headers off, Stock gasket question
- Water pump
- Throttle body
- spark plug
- Need help please
- exaust size difference Q
- Cheap 1 chamber's like flowmasters?
- SLP LT and the car wash
- Can exhaust systems be pressure tested?
- Installing a NW/FAST 90/90
- Is it possible to get 12 secs from bolt-ons only
- doug's headers - anybody used them?
- Just got my Borla on
- 408 LQ9 P1SC vette
- SEMA >> Professional Products Intake Manifold
- Advantage from Texas Speed true duals over Borla?
- What fuel filter should I get?
- How far did you grind down your K-member for headers?
- Header dyno#'s and clearance?'s
- i have a slp loudmouth and want new tips
- Anybody put bullets in place of cats on a C5 vette?
- Silverado 02 Sensors
- no start please help asap
- Headers ?????
- Which Y-pipe?
- how to fix
- How well will this exhaust set-up work?
- How much for cut-out install?
- Pro Flow F4 series Twister Mufflers?
- Pacesetters...
- Hooker LT's
- truck intake manifold
- This damn cutout - advice please
- th400 guys, what exhaust are you running?
- confused about ram air and intake.
- egr/air questions
- quick spark plug wire question!
- Added performance from Canton racing oil pan
- When is my RWHP restricted with this exhaust setup?
- ls1 alternator/ a/c hook up question!!! need help!!
- What are my 1 7/8" header choices?
- Finally got my EWP installed!!!!
- katech tensioner question
- ported ls2 v.s box stock fast 90
- ls6 vs fast 90
- o2 Sim price hike?
- P&P TB
- A few LS6 question...
- So Damn close!!!!!!!!!!!!!
- 1998 Z28 exhaust interchangability
- Header Install time
- carb'd style intake questions
- FAST 90mm intake
- ssra dimensions
- LS6 intake install, Slade's take on it...
- Loud Mouth questions?
- opti spark (red top)
- Attention LG Motorsports!!
- Rear end question
- GM 85mm MAF
- Is this ok to clean a throttle body with?
- Silicone Bellow length for 90/90 set up.
- Where/who to get FAST 90mm intake ported by?
- which exhaust is louder?
- Ported TB and geting P0171 & P0174 codes.
- Car doesn't pull strong right before the limiter
- SES light delte smog system questions
- QTP vs. KOOKS
- questions on spark plugs and wires.
- I need few tip on changing my plugs and wire
- CAI & IAT's
- (Noob) Question on motor mounts
- Flowtechs, will it fit stock y-pipe?
- My 3" true dual over the axle exhaust.
- LS6 or Holley
- TD's under axle?
- vacuum pump wiring help
- Help with an SLP/Blackwing Lid !!
- Fast 90/PTM 90's Back In Stock!!!
- LS2 intake bracket for throttle cable
- How to port FAST 90 intake??
- Installed Ported TB recently....got a question
- Pacesetter question
- little help on portin n mildin plz...
- which flowmaster catback louder n more aggressive?
- C5 Exhaust and Air Cleaner
- Intake swap help: quick question
- LS6 into 98 a4
- lt1 SLP lm1 owners
- dynomax bullet vs. sweet thunder
- Intake bolt torque specs
- Valve cover spacers?
- LS6 intake casting numbers.....
- Corsa vs. Gmmg
- ported my tb and maf
- Ls6 Intake?
- Calling all Header installation experts 2002 WS6
- Guys running duals with mufflers..
- whats the easiest way to remove windshield washer reservoir?
- Fuel line size?
- sweet thunder swap in tsp rumbler
- livewire plug wires
- Squeaky belt, belt lube=a bad idea???
- long tube versus short tube headers
- Ok, WHAT MANIFOLD? ?
- Question About Air Pump
- Ok... LAST EWP question and im done
- LT + ORY + GMMG problem fix
- parts needed for ls6 swap to fast90/NW90 ...
- Should I buy?
- anyone with the TSP Rumbler...
- Cooling problem, upper hose coming off???
- Parts needed for ls6 manifold install?
- Winter Approaching: Reverse Throttle Body Bypass???
- Kooks ORY fit a Pacesetter header
- what size O2 extensions do I need?
- Do I really want to go 90/90?
- Can you take apart the throttle body?
- How hard to swap my oil pressure sender?
- wilson pictures
- Corsa sound profile: Video inside
- corvette o2's in fbody
- O2' sensors for longtubes
- Longest lasting spark plugs?
- Porting
- Gap on spark plugs
- AC Removal
- Headers Question
- When installing headers, don't forget...
- Thoughts on the Flowmaster D-port h-pipe...
- Painted and Installed LS6 intake. Definite HP increase.
- At what point does the stock MAF become a restriction?
- What air filter/lid/induction?
- SES light when removing rear 02's
- How hot??
- Loudmouth II Question
- Mounting points for EWP relay?
- No catalytic converter???
- 99 vette has a rough idle when warm?
- removed airbox and airfilter connected to intake pipe to MAF...and cut box
- Will this intake work with R/A hood ?
- S.o.s !!!
- side exhaust
- Curious?
- what intake is this???
- Need 6.0l truck exhaust recommendation
- Is there any interest in a ram air kit for WS6's still?
- LS6 to FAST intake swap..
- BG Ram air..
- Look at my freeze frame tell me whats wrong
- Meziere EWP help NOW!!!!
- ignition coils
- pacesetter gaskets
- true dual exhaust
- Slp Maf...help
- Anyone Got A Little Extra Header Wrap????
- speed density guys...
- Which Intake
- Cooling problem need help...
- Headers and SES light
- 1 3/4 or 1 7/8? which size....2.5 or 3"?
- slip in cats?
- Little gap help on TR6's
- Pre Fab X or H Pipes
- question for people running x pipe w/sweet thunders
- ls6 intake port job
- New Coil Relocation Kit - take a look
- Too loud?
- IAC question...
- BOrla ..or CORsa ...help me out ...
- Power Steering Pump
- Problem after Knock sensor replacement
- Bullet in place of catalytic
