PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 [235] 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. GMMG uninstall question....
  2. Custom headers?
  3. catch can bracket
  4. air lid question
  5. Front and Rear 02's
  6. question concerning o2 sensors with new headers HELP!
  7. Qtp Electric Cut Out
  8. What ORY to go with?
  9. Cutout VS TSP Rumbler Catback
  10. Need help installing asp pulley
  11. Almost melted my motor today! Help needed
  12. JEG'S Universal x-Pipe Kits
  13. duels pics
  14. Sweet-thunder muffler
  15. Slight hesitation when accelerating at times.
  16. Which one???
  17. powerbond belt #'s
  18. Borlamouth or GMMG with Headers and ORY?
  19. Stumbles for 1/4 mile......
  20. Jet Hot header leak.....???
  21. F-body Y Pipes, Stock Vs Aftermarket, Any Gains?
  22. installed kooks
  23. 160 t-stat part number for meziere elec water pump?
  24. install help - in a rush
  25. back to stock...question about stock manifolds and AIR system
  26. Which Muffler???
  27. ordering headers... got some ?
  28. replace view tube for Greddy catch can ?
  29. TX Speed True Duals Question...
  30. ticking noise, exhaust related
  31. borla XR1
  32. !egr without programming?
  33. Electrical Fan Question...
  34. Borla Adj. vs Corsa
  35. Denso Oxygen Sensors
  36. vacuum leak?
  37. Dumps vs Tail Pipes
  38. Need some O2s...
  39. '98 LS1 PCV or breather question
  40. Stainless Works Catback?
  41. LS6 intake/Ported TB or 100 shot?
  42. overheating ?
  43. Anything to get this raspy sound
  44. Fast 90mm Intake -remove the plastic???
  45. o2 extensions
  46. 1 7/8" or 1 7/8 stepped to 2" for 427
  47. Best street header setup?
  48. Electric cutout owners, where did you put your switch???
  49. spintech pro street vs sweet thunders
  50. Headers kick ass
  51. How much gain?
  52. Pulley puller part #?
  53. major power steering issue. help!!!!
  54. LT's vs. wheels
  55. borlamouth sound clips needed
  56. High pitch noise at wot before shift
  57. How much cfm does the stock fan have?
  58. High idle.
  59. y pipe with cats only
  60. Headers, Y-pipe, and 02 simulaters
  61. 10% Underdrive ATI Super Damper and no power steering, what size belt?
  62. LSX fuel rails?
  63. Sould I do this
  64. how to get rid of Y-pipe banging
  65. Best Method of gutting cats...
  66. Header Paint
  67. electric water pump ?
  68. motor rad 160 degree thermostat
  69. which bullet to install??
  70. SES light...DTC P1416 Secondary Air Injection (AIR) System Bank 2
  71. NEED HELP FAST: anyone know what brand MAF this is?
  72. Slp Underdrive Pulley
  73. 90mm TB ? please read if you have one
  74. ORY to accompany my QTP headers?
  75. Recommend me some good O/R X and H pipes...
  76. TSP ORY install
  77. I need 02 Simulators?
  78. A/C compressor install
  79. just got my pacesetters
  80. good news for me....
  81. Pacesetters + TSP catted Y + Dynomouth disappointed!!
  82. starter heat shield...
  83. EMISSIONS! HELP!!!! o2 Simulators?
  84. which dr gas X-pipe do i need?
  85. Need help fast-Pacesetters,Edelbrock or Flowtech?
  86. Hooker LTs,Offroad Y, and Flowmaster
  87. Flutter? Moroso Spiral Flow/Flo Pro Twisters...
  88. realistic gains from Flowmaster catback to TSP rumbler..
  89. hooker or borla?
  90. Pulleys
  91. header installer in ga
  92. Notch the K-member for Pacesetters
  93. Need to quiet down my true duals, will Magnaflows do the trick?
  94. tach signal wire?
  95. tru duals with what muffler
  96. QTP LT's and ORY to come, but...?
  97. Personal opinions on customer satisfaction...
  98. i want to install pulley's..HELP
  99. Changed The Plugs Today Check Out the old ones...
  100. if i put a bigger pulley on...
  101. ASP pulley?
  102. Convince me to swap Sweet Thunder's for my bullets
  103. Exhaust Gasket Part #??
  104. new edelbrock muffler ?
  105. corsa exhaust
  106. Pulley Problem
  107. ASP pulley belt size question
  108. DR. Gas x pipe and sweet thunder mufflers
  109. Drone and Resonance
  110. LTs and direct bolt on bullet ?s
  111. Loudest exhaust possible
  112. Edelbrok steped headers performance???
  113. MAF question
  114. intake
  115. What X-pipe is everyone running?
  116. Is this right?
  117. Opinions Please
  118. Spark Plugs
  119. Headers
  120. Gains from intake/header/pulley change on a 408....
  121. Who has the Borla xr1 40085 muffler for sale??
  122. TD sounds like crap
  123. Hooker Catback???
  124. Problem with TB Bypass...
  125. Should I replace my O2's?
  126. LS1 Vacuum Pump How To? Here you go...
  127. tsp rumbler bullet size
  128. loudmouth install help!
  129. best muffler location on true duals
  130. exhaust manifold gaskets
  131. Flp Cats ?
  132. mid's vs. LT's
  133. Pacesetter ypipe pros & cons
  134. How to quiet down a GMMG exhaust??
  135. So who now makes a 2-step that will work on our cars?
  136. Installing the FTRA
  137. do i have to keep those metal pieces around the plug wire?
  138. HELP: Where to get LS6 Valve Covers and Coil mount
  139. PaceSetter gaskets SUCK!
  140. Codes after header install..need help..
  141. Starter Fried itself. Help please!
  142. Anyone make a LS1 F-body Motor Torque link yet?
  143. Sweet thunders vs Spintech pro shoot out
  144. power loss?????
  145. slp 85 mm maf or not??
  146. Car is running bad @ idle and sometimes shutting off
  147. Sweet Thunder Guys!!! (kind of long)
  148. stock radiator cap pressure?
  149. Horrible Idle Problem
  150. Forum Director - Marker
  151. edelbrock TB
  152. Car Chemistry Insert Question
  153. I need the deepest/throatiest noise ever...
  154. tsp ory vs. catted y
  155. Tips for changing #8 spark plug.
  156. question about factory ls6 intake equiped car.
  157. "blackwing intake"
  158. Part Number help
  159. Removing Cats
  160. SLP LT's and Cats
  161. recharged AC, and green fluid shot out by the compressor after???
  162. Throttle Body by-pass worth it?
  163. Loose o2 wire
  164. horn problems
  165. Would anyone be interested in.....
  166. Bad 02's?
  167. Noise from A/C
  168. Need a little help.....
  169. LS1 to LS6 intake............
  170. Question about the WS6 hood and Induction
  171. which headers for a 98 t/a....
  172. collector inserts?
  173. conformation of compatibility
  174. Starting to get tired of loud exhaust.
  175. Sweet Thunders Where to buy!
  176. 10-bolt?
  177. Ram Air on Firehawk question
  178. Sweet Thunders vs. Flowmaster 1 Chamber
  179. O2 sensor ! How to check if they're bad?
  180. LT1 Borla cat-back fit LS1?
  181. Header/y-pipe pics
  182. Pics of my new exhaust tips!
  183. Maf??
  184. True dual gains?!
  185. GM Dealer Checkup
  186. mass air flow sensor ?
  187. patching a small vacuum leak?
  188. HELP Im having a cooling problem please help.
  189. Car will spin over but not crank! Help Please!
  190. well new parts and....
  191. lookin for rubber hose part #....
  192. Hooker Exhaust?
  193. True Duals & Daily Driving
  194. 1-7/8" or 1-3/4" headers for a 408?
  195. Question about AIR/ Tube on 2000-2002 Air Box
  196. first gear feels like I'm pulling a 36' boat!!
  197. 78mm/90mm Intakes and TB
  198. Alternator at 13.0 Volts after hot
  199. TSP Rumbler CB vs. Sweet Thunder TD's
  200. installed magnaflow catback
  201. True Duals on 1998 T/A
  202. Wideband mount
  203. 1-3/4'' or 1-7/8''
  204. header gasket keeps blowing out
  205. plugs plugs, everywhere plugs!
  206. Pacesetters lt with high flow catted y pipe and loudmouth
  207. Matching air lids
  208. ? on motor mounts
  209. Kooks Vibration..??
  210. Flow Tech headers
  211. sick of true duals
  212. maf wires
  213. A/C is messed up after FAST 90mm install..
  214. Long tube headers and dynomouth?
  215. good flowing, cheap, cats?
  216. The stock cat-back comes out without cutting after all.
  217. LS1 Coolant flow direction?
  218. Cylinder head cross-over tube
  219. Underneath Ram-Air?
  220. ls6 intake
  221. Dynatech SuperMax any good?
  222. Any FAST 90MM TB in corvette ?
  223. Just picked up a Corsa catback
  224. SLP LS6 Intake Install Complete
  225. TSP TDs, Which Torque Arm?
  226. Exhaust Setup Work?
  227. Headers
  228. Can you reuse stock cats after headers?
  229. problem w/ tsp lid
  230. Like my blockoff plates? lol
  231. Alternator Problems
  232. Random Technology cat back
  233. QTP headers
  234. LT Headers + Magnaflow + what y-pipe?
  235. Installing mufflers right after kooks Lt's
  236. Why am i going burning up alternators at High RPM?!
  237. WOT question
  238. Collector/y-pipe size
  239. Need input in removing muffler??
  240. Exhaust Leaks
  241. Pacesetter installation website
  242. what could be wrong
  243. Fast Install ? Re:Baffle
  244. EGR SUCKS...(PROBLEMS) Running very lean
  245. mccord electric cutoiut problem
  246. real stupid question.....................
  247. Going to install pacesetters on a friends car.
  248. Fan Mod SES
  249. Problem after i installed my FAST 90 mm
  250. Easiest way to notch k-member with headers already on...
