PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Quick drive by vid. Bolt ons, catted Y/LM1
  2. Alternator output voltage is low
  3. bad battery or alt?
  4. 2000 LS1 valve cover gasket part number??
  5. Another belt squeak/chirp question
  6. Will Volant dual cone intake fit Camaro SS hood?
  7. Texas speed duals vs SLP loudmouth sound?
  8. Home made LM1/Borla style exhaust???
  9. SLP Traction Logic Module Question
  10. Different mufflers and tips
  11. ls6 TB vs ls2
  12. Ls6 intake swap oil press gauge
  13. broke bolt on header install!! need advise!
  14. Need replacement Hooker Aerochamber muffler
  15. Fast 90/90 MAF?
  16. Which heads?????
  17. Intake leak - power loss?
  18. PCV help 2002 ws6
  19. Which mm throttle body gasket?
  20. Fast fitment?
  21. Did Some Mods, now the car runs like garbage
  22. Part number for the pin tetainer at the top of the clutch pedal
  23. O2 sensor confusion...Help
  24. Will L99 or LS3 Exhaust Manifolds fit an LS1
  25. Are all ls motors the same on the outside?
  26. slp lid doesnt fit on stock lower airbox?????? help!!
  27. Meziere Black Anodized WP
  28. Chrs1313 a/c vs non a/c version
  29. Intake Question
  30. Stock T-Stat on a Car Tuned for Lower Temp T-Stat?
  31. Broken wires to oil level sensor and alternator
  32. White smoke/Cold Startup
  33. Front crank seal, inner diameter dry or lubed?
  34. 5.3 head choice! Need help
  35. TSP ORY fitment issues
  36. VATS or Ignition Switch?
  37. Fbody Long Tubes and Autokraft Pan???
  38. Need pics of moroso vac pump mounted to block.
  39. Gains from Mid tube headers to LT headers on a Heads/Cam car?
  40. EGR and A.I.R delete?
  41. ls1 engine harness ? whats the differences
  42. JAAM vs. Chris1313 Ram Air?
  43. exhuast is to loud, need help
  44. Lower MAP readings with FAST 102 intake .
  45. Trouble starting/running with bigger MAF
  46. Which setup would you suggest?
  47. What year for Z06 MAF?
  48. Pep Boys intake pieces?
  49. Cold air intake box options
  50. TPIS 90MM ls6 guys, what lid/maf setup are you running?
  51. C6 throttle body question
  52. C6 throttle body question
  53. Pacesetter lt's
  54. Exhaust, cut-out based question....
  55. Blade and Boot slip MAFS
  56. Installed TFS 215 milled to 61cc(.018") with Torq V2
  57. manual-single plane guys ??
  58. Long tubes
  59. Bosch HR9LPX plugs cheap
  60. Cbm twin turbo 440 937 rwhp dyno video
  61. Cbm twin turbo 454 1008 rwhp dyno video
  62. Poly motor and trams mounts...
  63. squishy V-band gaskets
  64. used a BFH to make magnaflows fit in the back
  65. headers ? 01 gmc
  66. Idler and sump question
  67. Air / Egr Delete !! help the newb !
  68. Dry Sump / Vacuum pump and stock PCV?
  69. APS starter/American Racing exhaust interference
  70. 99 WS6 problems?
  71. headers+exhaust
  72. Anyone in the Richmond,VA area know of a good exhaust shop
  73. MAP Location critical?
  74. starter motor with solinoid underneith facing down
  75. LS1 fuel rail clips
  76. Headers
  77. Where to get 4" cutout?
  78. Unusually High Idle.. (99 SS Auto)
  79. Did GM use Anti-seize?
  80. tsp lt headers and bolts help
  81. Deleting my AIR lines after a Long Tube install....
  82. LS1 and LS2 Injector O-ring Confusion (Manifold)
  83. What is the correct tubing to connect 100mm MAF to 92mm TB?
  84. Gas mileage issue
  85. need help with pushrod length
  86. Best Air Intake for the money?
  87. Ebay headers guys come in here
  88. ls2 intake on a ls1
  89. Any idea how to mount d585 coils onto perimeter bolt valve covers
  90. One more Ebay header question
  91. C5 coil relocation
  92. Questions about MAF
  93. please identify this part!!!
  94. Single 3" cat
  95. Exhaust Cutout
  96. OR-Y for Factory Manifolds
  97. headers catback big gains
  98. Might Buy LS1 Car With Security Light On, 500 Miles Away
  99. need help/input on broken piece on my block
  100. Rectangular to Cathedral adapter?
  101. Plugs for e85 NA motor
  102. Need help figuring out a miss, wire resistance.. 99 LS1 (Video)
  103. Adding cats to TSP ORY
  104. Just Had My Engine Rebuilt
  105. Does anyone know the angle of this bracket?
  106. Is this upgrade worth while?
  107. NVUSZ28's Build Thread
  108. Good All motor/nitrous cam?
  109. 78 to 85mm maf issue
  110. Ebay header question
  111. Would this hurt my heads?
  112. Vette O2s
  113. Help! Car started freaking out
  114. question about cats
  115. To port or not to port 102
  116. Looking for a P&P TB, who sells them?
  117. Custom Y-pipe Questions
  118. That little gasket on the driver side pan
  119. Evans vs Edelbrock High Flow Water Pumps
  120. Looking for parts!
  121. Cant decide on next mod. some recommendations would be appreciated.
  122. SLP 85mm to 100mm maf sensor worth whats involved?
  123. m.a.f. help
  124. 2011 avalanche exhaust
  125. coils not firing need help
  126. Ported TB Question!
  127. Holley Valve Covers on LS1!
  128. Carback question
  129. My review of TSP LTs and ory...
  130. Pulling an ASP underdrive pully
  131. pacesetter armor coat
  132. 243 as cast gains
  133. LS6 intake vs. Ported Fast 78
  134. RX catch can bracket
  135. LM2 Pics?
  136. Slow Cranking
  137. For anyone that bought the BBK LTs and ory.....
  138. Any benefits by doing this to exhaust?
  139. Cbm at the sand sports super show
  140. Got all my ducks in a row - help me re-check my list
  141. porting intake question
  142. wireing the gauges
  143. Pros and Cons
  144. Beck intake TPS?
  145. Those with TSP 1-7/8" headers...
  146. fires up and dies imediatly then runs perfect 2nd time cranking
  147. Nick Williams 92 to Fast 92 intake
  148. 99 Trans am air intake setup
  149. Trickflow top end kit
  150. What size is the Brake booster fitting on intake
  151. Best cats for emissions
  152. DIY - Cylinder Head Gasket Replacement - Right Side (C5 Corvette)
  153. Kooks Cats.
  154. O2 sensor broke off
  155. Ok' so how did you weld your stainless y pipe??
  156. 15 dual valve springs, need 1 more?
  157. Bad Head Gasket or Intake Manifold Gasket?
  158. BBK Chrome headers durability
  159. Muffler swap question!
  160. kooks catted x-pipe
  161. gm 85 maf and trunion upgrade ?
  162. HELP- identify this broken sensor
  163. Installing TSP LTs...a few questions
  164. ls1 throttle body vs ls6 throttle body, are they the same?
  165. 85mm maf and water pump question
  166. -1998 LS1 Trans Am Auto A/C problems-
  167. late model engine take outs
  168. Paging Anyone From DMH or Texas Speed....
  169. 5.3 pcv quick question
  170. Magnaflow muffler swap
  171. Is a FAST 92/92 necessary?
  172. Combustion Chamber Volume?
  173. Can I use stock intake port seals on fast 92?
  174. True duals vs dual-single-dual - which one is better and why?
  175. Horsepower Question
  176. Just did Urethane motor mounts...have some suggestions.
  177. TSP y-pipe fitment issues
  178. How much different is my car going to sound?
  179. K&N FIPK replacement filter?
  180. longtubes and exhaust
  181. IAT Relocation-Where to??
  182. Victor Jr. vs Performer carb intake???
  183. ITB - Individual throttle body - air filters
  184. LS6 intake manifold cracking
  185. MAP sensor interchange?
  186. Ws6 Exhaust Help
  187. Need help on coil pack question!!!!!!
  188. Performance Chips
  189. Stock TB
  190. what causes a slow revving motor?
  191. what to expect from Headers and underdrive pulley?
  192. Starter turns when the key is off
  193. FAST 102 bolts vs stock
  194. 5.3 build hp question
  195. LQ4 Rebuild - What Cam?
  196. sq
  197. putting money into a ls1
  198. EGR on a 01 Z28?
  199. Heads milled, intake no longer fits...
  200. New Intake Manifold... New Problem.....:\
  201. high flow cats position???
  202. PCV question w/LQ4 valve cover and LS6 intake manifold
  203. Throttle cable for use with Victor Jr. intake
  204. Cai or ram air
  205. Installing electric cutout
  206. Head Vapor Port Fitting Question
  207. Need a Fast Lower Shell
  208. Anyone welded cats into a BBK y-pipe?
  209. Why is ARP showing pressure plate bolts as M10x1.5 when they're M10x1.25?
  210. TSP True Duals install help
  211. 2004 LS6 Valley Cover w/ built in pcv Need all part numbers.
  212. Throttle body options
  213. Root cause of broken starter mount on block?
  214. Where to get Stock heads CNC ported and Valves replaced
  215. Battery tray broken...need help fast.
  216. Installed headers, intake, catback, lid, feels like I lost power or gained zero?
  217. rear plug on ls1 intake
  218. Anyone use a F1 Racing eBay special chromoly flywheel?
  219. Best Price on Wires/Plugs
  220. HELP!! LS1 bottom end questions
  221. When you drive a ram-air equipped vehicle in the rain....
  222. security/starter issue? '00 t/a
  223. Starter bolt stripped.
  224. Help with a 96mm pp intake
  225. What's next?
  226. Is there room for cutouts then cats
  227. Switching out stock muffler
  228. My P0102 (MAF Circuit Low Input) SOLUTION
  229. SES Won't Reset
  230. Help with next mods. 92/92 or port my 243's, 1 7/8 headers, td's?
  231. TSP Duals and LPP LT's
  232. PCV Delete Question
  233. 243 coil brackets a must??
  234. Need Help! Misfire problem.
  235. I want my car to be quiet.
  236. March serpentine system
  237. can you use two driver side heads?
  238. headers look rough, wrap them??
  239. oil/coolant leak
  240. Help, can i cut this tab off the block ??
  241. ls1 to ls6 coolant tube pic does the go or stay
  242. LS1/LS6 intake/tb
  243. Problem with idle...jumps up and down, on its own.
  244. pn 12556915 where to get?
  245. Finally decided to buy LT`s...install advice?
  246. magnaflow 59959 metallic cats
  247. Not enough fuel pressure, help.
  248. BBK SSI intake
  249. ls1 gto water temp all over the place
  250. 99 ls1 header install
