PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 [298] 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. are you waiting for your QTP headers?
  2. Actual gains running gutted cats?
  3. 160* or 180* thermostat in a stroker? Opinions?
  4. How is Spintech exhaust?
  5. radiator support
  6. Can aluminum foil on the plug wires cause a prob??
  7. A/C problem...
  8. FIPK hood down - DYNO - question & graph
  9. Headers for California
  10. routing LS6 pcv system??
  11. car wont shift
  12. o2 sensor
  13. Motorvator Throttle Body Spacer ...WTF is this??
  14. ATTENTION! All registered members inside please
  15. ARE valvecovers/ how to do pcv & oil cap?
  16. plug wires for relocating coils?
  17. Question about header install
  18. 02 sims
  19. Loudmouth with Sweet Thunder muffler
  20. CAN'T DECIDE WHICH EXHAUST!!!! OPINONS WANTED
  21. Best header for a lowered car???
  22. QTP headers installed this weekend
  23. Re-installing STOCK Crank pulley....question
  24. Any cure for RASP??
  25. Which muffler w/MACs and no cats to eliminate rasp
  26. Random Tech CAT ???
  27. Throttle Body Bump Stop Mod
  28. Another gutted cat question
  29. Underdrive pully and engine stress
  30. Anyone have Mufflex 4" (Flowmaster)with "big" cam?
  31. to remove or not to remove......
  32. Best way to remove long tube from ORP
  33. Hooker cat-back exhaust clips.
  34. Sorry, but another bunch of exhaust questions....
  35. New and old FTRA, what's the difference?
  36. best plugs and wires?
  37. Drilling TB hole for new H/C setup?
  38. Dead battery blues......
  39. flowmaster cat back not replacement muffler
  40. macs with hooker cat back
  41. IS THIS A LS-6 INTAKE?
  42. ARE valvecovers/ whats involved to make work?
  43. need help with headers/exhaust
  44. Post Dyno Numbers with Long Tubes, please
  45. HELP FAST!! 02 sims problems
  46. Where can I get NGK TR55's PLEASE??!!!???
  47. 98Z Needs More Power
  48. Any gains?
  49. test
  50. Would I benefit from Kooks 1 7/8" to 2" stepped...
  51. What is the best WS6 T/A Lid?
  52. does the tsp 85mil.lid and maf?
  53. Concerning water & trans temp guages
  54. amature with header questions
  55. TB Questions
  56. Gains from hooker shorties
  57. Spintech single/sigle vs gen. single dual muffl?
  58. Best Cat-Back System for 2002 SS ??
  59. Header Install Problem
  60. Questions about pulleys
  61. Difference in headers
  62. Stock SS Muffler vibrating after gutting cats.
  63. Texas Speed & Performance website is up!!
  64. My new whupass true dual X pipe setup(pics)
  65. Anyone use Crower valvetrain parts?
  66. What to do next?
  67. Battery voltage drops significantly above 3500 rpm
  68. Supersucker Ram-air?
  69. any1 have goodluck with hp3 program? *DELETED*
  70. Custom intake manifold
  71. Need Help! Simple mods how-to's and how-not's
  72. Unexpected (welcome) side effect of MSD plug wires
  73. Anybody using Jeg's UD pulley?
  74. Z28 and Long Tubes with Lowered Car? Scrubbing???
  75. EXHAUST DESCRIPTIONS/INPUT/OPINIONS WANTED
  76. exhaust opinions needed
  77. What to clean top end with??
  78. Exhaust Tips
  79. SS exhaust on a V6 ?
  80. more H.P from a new style air lid?
  81. Hints at a soon to be 5th Gen. Camaro SS???
  82. Strange sqeaking sound....help me diagnose
  83. Removing A/C Compressor, can I drive w/o it?
  84. How do you clean the MAF???
  85. Question on LS6 Intakes
  86. Some help on new exhaust please.
  87. Spark Plug Gap
  88. General Help needed on this project comairing...
  89. GMS maf, comments please.
  90. Throttle Body question
  91. True Duals or Mufflex 4 inch
  92. Serpentine belt jumped off a bit?
  93. Removing ASP crank pulley...tips?
  94. Which converter is better?
  95. Have some ?'s about changing the Key IGN Switch.
  96. Hooker Shorties
  97. New Forum Sponsor - Stainless Works
  98. Kooks review
  99. Exhaust flow
  100. Shaner VS BBK Throttle bodies
  101. Login Problems? Suggestions w/n --->
  102. Question about GM Performance Red wires....
  103. mac headers install
  104. Calling 00-02 Camaro SS
  105. jet-hot headers ~ feedback please
  106. New Corsa tip design!
  107. spark plugs tr55????
  108. 10 to 15rwhp possible?
  109. spark plugs?????
  110. Dual Cutouts at the Y
  111. asp pulley ?????'s
  112. Full Length Exhaust
  113. Borla too quiet
  114. Carbon
  115. Intermediate pipe
  116. (TRUE) True Duals!!?
  117. true duals & x pipe vs. borla catbak
  118. greddy catch can results?????
  119. Bauer Racing contact info
  120. no header gasket?
  121. QTP Headers... High Velocity Merge Collectors?
  122. SLP MAF : port or not to port
  123. Squealing noise after hot engine start
  124. Porting Stock Exhaust Manifold For Single Turbo
  125. New head/cam/intake/forged will not idle, ideas?
  126. hooker LT headers w/ hooker y-pipe
  127. Differences in MAFs between years?
  128. Does a 160 thermstat really help make power?
  129. Got an ASP pulley
  130. Just finished changing my plugs and ....
  131. Exhaust
  132. Cutout?
  133. What is the best performing catback? Any Dyno inf
  134. upgrading injectors, safe to drive without tuning?
  135. LS6 intake problems with pics,check it out.
  136. Radiator Baffles - Remove? Why? Why Not?
  137. Which Muffler should i get?
  138. whats you top 5 favorite or best bolt on's??
  139. RandomTech catbck= 22RWT & 20RWH (Sound?)
  140. K&N along with the FTRA. Can it be done?
  141. Pwr window intermitent > Bad motor > Easy to fix?
  142. Suggestions for catback to replace Borla
  143. what expoxy to use on my TB? drilled hole too big
  144. What size bullet muffler for the loudmouth?
  145. KOOK's Headers - Awesome service and product!
  146. LS6 INTAKE
  147. Replacing flowmaster muffler with regular pipe?
  148. people with macs come inside
  149. Phone number for Bauer?
  150. What exhaust for 414ci+?
  151. eng mounts
  152. Stainless Steel AND Coated Headers ??
  153. looking for electric cutout
  154. Best exhaust for 427ci solid roller Engine
  155. Ls6 Intake Evap thingy question
  156. what cats to use instead of mac's
  157. Car Hesitates / Surges
  158. exhaust setup question
  159. Corsca Cat Back exhaust
  160. I have an SLP center-quad exhaust available
  161. What is the TR55 part number???
  162. ABS INOP, BRAKE and SERVICE ENGINE lights all on?
  163. Is this good
  164. Installing an ASP pulley
  165. Lowering Air Dam
  166. Is this a LS1 intake or LS6 intake?? Please help.
  167. Value of our TB for sending UPS insured?
  168. Strange noise please read....
  169. Least money for the most improvement
  170. Help.. what intake to go with?
  171. What else to change w/ valvespring swap?
  172. How is this exhaust setup?
  173. How many horses do I actually have?
  174. Strange Electrical Problem
  175. RWHP
  176. hooker long tube question
  177. Anyone using flex joints in their exhaust?
  178. Need to know stock LS1 Weight minus accessories
  179. K&N along with the FTRA. Can it be done?
  180. Can not get the Stock crank bolt out!
  181. You tell me...427 RWHp and 12.5 bests
  182. Fuel Gauge problems
  183. New air lid, installation seems a bit weird.
  184. dyno #s alittle unhappy!!
  185. I need a red bellow to replace the OEM...HELP!!!
  186. WILL TRUE DUAL PASS INSPECTION???
  187. Any word on those new intakes from Cartek?
  188. Thermostat question please help!!!!
  189. The Heaviest most Expensive cat-back made....
  190. Modifications
  191. New Ls1 owner...whats a good exhaust system?
  192. Turndown?
  193. Holley Intake ?
  194. I know these are getting old......
  195. Does anyone make a larger throttle body??
  196. TEST forum 2
  197. Pics of Kooks Y-Pipe with Cats?
  198. Why should I buy Hooker headers when I can get Jet Hot's for 100 bucks cheaper?
  199. Throttle body Bypass???
  200. FIPK kit Vs a Ram Air Lid
  201. does anyone here know anything about true duals and x pipe please help
  202. why 3" y-pipe
  203. True duels
  204. What size bolt for the ground strap on front of motor?
  205. Anybody wanna sell me their qtp headers?
  206. WHERE CAN I GET A TRUE DUAL IN HOUSTON
  207. Budget Y - Pipe
  208. Budget Y - Pipe
  209. LT questions
  210. Headers
  211. LS6 intake gains on stock heads/cam motor??
  212. Edelbrock headers
  213. Serious water pump problems, need help.
  214. How much power from Hooker Catback
  215. Chambered Exhaust?
  216. Why Do Macs Rasp Really Bad?
  217. ASP install-can't be right?(PICS)
  218. What drive shaft loop for Bassani Y-pipe?
  219. Anyone know the radiator shroud part #?
  220. oryp
  221. Hooker Headers
  222. Site is going offline 4/25 for software upgrade at 11:30am CST
  223. sick of flowmaster,!! which muffler?
  224. What the heck could this be?
  225. Stainless Steel headers run too hot?
  226. Need Some Help on Disconnecting Fuel Line
  227. Help!!!
  228. First Dyno Session with LS1edit
  229. ARE K-Member, torque for Engine mount plate
  230. 160 degree thermostat
  231. Holley Manifold Gaskets
  232. Bassani Exhaust
  233. Where can i buy hooker headers?
  234. SLP LT's installed is tuning necessary?
  235. Electric water pump??
  236. Best Headers?
  237. Porting LS6 Manifold worth it?
  238. Exhaust
  239. Do I need a DS loop with a 02 z28?
  240. lid & cat back = SES?
  241. What mufflers are the quietest?
  242. Oil Press Gauge install, what size is fitting in back of block ????
  243. 02 sims
  244. NGK Solid Copper or Platium or Iridium ?
  245. y pipe which one should i get
  246. Long Tube guys Inside.....
  247. Which intake mod works best?
  248. Y pipe question
  249. Is it illegal
  250. Headers, ORP and CORSA Install
