View Full Version : Generation III External Engine
- AIR System removal..
- how many different GM mafs are there for the LSx family??
- Estimated Horsepower Increase of the following:
- Advice on next HP mod
- reliable street setup
- What is the maximum power level of ls6 intake
- Where can I buy red 4in intake hose?
- 3.5" Dual Exhaust??!!!
- 2" vs. 1 7/8" headers for 427???
- LT and Cat Y pipe?
- Recommend a company for an exhaust butterfly valve.
- SLP loudmouth + silencer??
- Whats dealer price on a full 00 trans am catback system? (insurance reasons)
- which is better??
- Throttle body porting
- Should I upgrade injectors for retune?
- Cold air vs. lid only
- Anyone have any issues REMOVING Hooker Comp Long Tubes?
- 80mm Tb
- Ls6 Intake Install Questions
- SLP LTs.... cats?
- kooks headers and y pipe
- Installed headers with off road y
- tsp exhaust on third gen??????
- What size Cut out do I need for a 01 ss w/ stock exaust ?
- There was a Motor Trend oil filter in the Trans Am.
- My New True Dual Exhaust, Tell Me What You Think!
- What all is needed for LT headers on a 01 F-body?
- Kooks 2" Race Header
- Attention....Formula owners with Corsa Catback
- What do I need for a zo6 maf to work?
- XS Headers installed.
- Alt. overdrive pulley. do i need a belt?
- MAP sensor
- Duals: Magnaflow 4X9 clearance
- Rpm gauge not reading?
- Single 3"?
- TRUE DUALS Install and Edelbrock Victor Headers
- What is this?
- Super Trapp disc system
- ls1/6" rod?
- DO I need to get my FAST intake ported before I Install?
- Wtf Why
- What to plug SLP lid AIR hole with?
- Let's play the "What is this part?" game...
- where is the cheapest place to buy paceseeter headders w/ y?
- Question about PCV while doing motor swap
- EGR removal question
- open headers, how long can i drive?
- Need Help- Stalls out comming to stop or from a start
- Coolant plugs for LS6 swap
- Rod bolts, Prothane mounts INSTALLED with pics!
- Fast intakes
- Anyone use those Dynatech vortex cone inserts?
- looking for tips & advice on lt & ory install
- ls2 intake on a ls1
- PCV routed into the exhaust?
- LT's/ORY on stock catback + cutout?
- PowerBond pulley
- Will Pacestter LTs NON-EGR/AIR fit 99 LS1?
- Car Wont Start!!!!!
- AIR Removal and wind shield wiper fluid?
- Gibson Fbody exhaust review...
- Ls1/ lq4 throttle body exchange
- how to identify ported heads?
- Bad Backfire!! Help!!!
- MAF part number
- which flow better slp or pacesetter headers?
- NICE exhaust clip...
- a few exhaust recomendations
- Best Plug wires
- Need injectors cam only? Bad port job?
- ls6 manifolds
- Ordered my 90mm intake and TB today!
- American Racing Headers New LS1 2" Race Headers
- mechanical o2 sims actually working so far...
- Compression ratio
- Bassani Y-pipe and O2 simulators question
- exhaust question
- Anyone dealt with Jet Hot on their warranty?
- Oil Leak!!! Rear Main Seal, flywheel bolts, or rear plug....? You be the judge.
- Can someone explain - starter sloenoid
- Fst Toys 85mm Lid and Delphi 85mm MAF??
- manual fan switch/FTRA users inside please
- BBK or Typhoon setup?
- ls6 manifold to ls1
- Cutout: Worthless or not?
- hole in the evaporator hose
- Old Line Cleanup
- Want to see rear elec set up pics
- Looking to install a cutout
- Hooker Comp Jet Hot's rusting.. THinkin' about a switch?
- fan/overheating problem.
- loudmouth 1 vs. loudmouth 2
- My car smells HORRIBLE!!
- Might try making a custom intake tell me what you think
- Sealed Hood/Lid Pics...
- Harlan 2 Step and TransBrake Question
- Where is the resistor on an SLP 85 mm MAF?
- coil packs
- LS6 Intake Read this before trying to change intake.
- 2004 ls1 heads 241s, with 98 ls1 exhaust manifolds?
- Changed tips, car got quieter????
- F.A.S.T. Fuel Rails
- how much restriction?
- whats this wire
- 90mm tbs that dont stick post list
- Where can I buy new or used LS1 e-fans?
- True Duals or keep my current set-up
- Gauges not reading... Help :(
- Where is the best Cut out location on a 01 ss w/ stock exaust
- Loudest Muffler?
- laptop tuners?
- Converter Question
- I'm done, cats go on.
- Ive been looking to get an intake package for my 01 tell me what you think
- Mounting the Throttle bracket to a z06 intake???
- O2s SLOW TO RESPOND
- building true duals; help me!
- Intake Lid "gasket?"
- Uneven Pipe Soot
- oil cooler delete help! plate part #?
- low idle?
- stock or not stock
- Could u fit dual 1 chambers before the tips?
- underdrive pulley
- Will ported throttle body require tune?
- need help
- Heads and cam Q' ms4, ms3 or trex?
- intake manifold and gear question
- Reuse or not to reuse 02's?
- Replaced Sail panel speaker, now car will not start.
- Sparkplugs...
- guess what came in the mail
- Cut-Out Location
- mufflers for true duals?
- What is a good y-pipe for hooker LTs
- What is this
- looking for pics of camaros w/magnaflow, need pics
- Estimate Horsepower!
- How can I tell if I have a LS6 intake
- borla xr-1
- Venturi Vs Standard Merg collecters
- Mezeire electric water pump inlet fitting
- Revs high... then dies!!!! after Header install????
- 90mm FAST intake install question
- Opinions on which oil pressure gauage to get...electric or mechanical?
- Will a Borla X-r1 outflow...?
- What Rims Look the best on my 99 z28
- Stock F-Body Fan wiring and plugs
- GM Gaskets with Pacesetter LT's
- exactly how hard is it?
- It Finally Sounds Right (Exhaust Vid)
- What length o2 extensions???
- B&B Catback
- Is it worth it?
- Slp
- Question about header size to head port size?
- O2 Simulators
- Foam padding for exhaust??
- Modified My Front Bumper Support
- 90mm FAST install questions, regarding GMHTP article>>
- smoke from my exhaust
- Harrop sticking throttle
- Egr Romved But What To Do With Vacume Line?
- Anyone need a TSP Y??
- Valve cover question
- Long distance driving w/ TD's.
- running just headers
- SLP Lid Fitment
- 2000 camaro rear end problems
- broken starter mount
- Car wont turn off
- Where to buy "Corsa look a like tips?
- Car wont start
- qtp
- slp lm problem
- Which lid? Fast toy 85mm vs TSP 85mm
- Burning oil smell and oil residue on top of intake
- what sze bolts to bolt up ls1 to engine stand?
- do ls1 gto heads casting 241 fit 98 ls1s?
- air lid question lag
- Autolite plugs
- Throttle body really worth it
- Stg. 8 Header Bolts... Which ones?
- can you identify this sb1?
- Best fitting headers...
- Headers!!!!!!
- Looking for 425-450hp to the wheels
- qtp lifting plate
- Lt1 Radiator For 2000 Camaro Ls1?
- Best place to get Magnaflow's.
- How To Quiet Down My Exhaust?
- Another "Painting the Fuel Rail Covers" Question
- E-cut out worth it ???
- Ported throttle body......worth it?
- ls6 intake = emission pass ?
- Percy's Header Gasket & ARP Studs
- Edelbrock Victor Series Stepped Headers Or Jet Hot coated Pacesetter Headers
- secondary intake air sensor?
- Headers and O2 sensors
- reasonable and good Catch Can?
- Throttle Body Help!
- Which knock sensor to get for a 1998 SS?
- Help! Need to find LS1 injector O-Rings
- St's...
- Question on my ls6 intake
- Drilling Lid
- LQ4 vs LS1 Heads. Which is best for my setup?
- new to the LS1 scene...need some HP
- exhaust leak??
- Katech billet belt tensioners now available in ORANGE
- Most power for the least amount of money ?
- Jet Hot Coating worth it?
- Strange issue mid track cutout
- Getting my new headers...
- ORY questiiionnnnnnn
- Fast 90/90 Porting Benefits
- qtp Lifting Plate
- Is it a pain to sand, polish and paint FAST Intake?
- Can this increase horsepower?
- long tube headers question?
- SLP ls6 manifold
- O2 Sensor issues can anyone please Help?
- TSP Rumbler exhasut clip inside........
- Dumped Illegal?
- Lt's that'll work with kooks y-pipe?
- Materials for FAST 90/90
- Well, just spent the dough...
- What kind of power is a Full Bolt On m6 ls1 putting down?
- what color would u paint your motor?
- 2002 Ss Original Exhaust Components For Sale
- Electric or manual cut out ? which should I get ?
- Ditched the K&N
- Power Steering
- Kooks Headers
- slp lid install
- What is the cheapest way to make my car louder ?
- Pacesetter Deals/Sponsor ?
- ASP Pulley and/or Meizre Electric water pump, worth the cost?
- torque rating
- c5 z06 sound
- TPS problem?
- Is there a dust cover for the sides of the bellhousing?
- intake manifold ?
- Passenger-side fenderwell wiring question
- O2 problems can anyone help?
- FTRA blocking tranny cooler?
- will gutting my cats make my car louder ?
- ORY vs. Hi Flow Cats
