View Full Version : Generation III External Engine
- What other bolt ons can i do?
- Where to buy exhaust hanger?
- Will ls1 pacesetters fit ls6 heads?
- Possible to buy just I Pipe?
- air filter
- Cutouts?
- How The F***
- Hooker Header o2 sensor Clearance issues
- Exhaust Manifold Bolts??
- O2 Sensor
- LT's and ORY installed now the car runs like crap
- Headers 4 lowered car.
- exhaust to quiet... help
- My Headers are on !!!!! My Check Engine Light is not??
- ordering my pacesseters this wk
- 160, 180, or stock thermostat?
- Finally Installed TSP Duals!!
- corsa and cut-outs
- Egr
- which headers for my ls1?
- Cutout benefits?
- How do I.....Remove a March Underdrive pulley?
- Anyone with Jet Hot headers
- Fast 90/90 Falling on it's face:(
- exhaust piping size...
- 1 question and I'll leave---y-pipe
- Radiators
- Code P0160
- ported MAF gains...yes i actually had some
- TSP y pipe question PLZ help
- x pipe fab up
- e cutout vs. manual cutout
- header gasket ?'s
- wats the diffrence between a 98 and 01 t-body
- Where to buy
- post install gains?
- Where to put cutout?
- Headers
- electronic turbos?
- TSP TRUE DUAL guys inside PICS!!!
- NGK TR55s Q.
- 135* angled spark plug wires
- LS2 TB question
- Intake Material?
- Woot! Just ordered true duals...
- What do you think about this?
- What to do???
- Are LS1 injectors longer or shorter than LS2 injectors?
- TSP duals torque arm?
- Typical gain of LS6 + Pacesetters?
- flow tech
- 1-3/4" headers or 1-7/8"?
- Lid install problem....
- o2 sensors with LT's not hot enough. Tips.
- FAST 90 with heads and cam??
- Broke oil pressure sending unit
- pacesetters
- PCV System Question
- Flowmaster Single Chamber.....
- Headers for a 402ci LS2 ....
- Catalytic converters fried?????
- What is the difference?
- BG ram air w/ lower air box mods?
- slp MAF
- Advice: Everyone with a VOLANT cai system please come in.
- Hooker
- UD pulleys
- went to hell.....
- where can i get a flat alternator tensioner pulley??
- How bad is this? crack in timing/front cover seal *pic*
- LS1 to LS6 Intake Swap
- gap in rear of air lid
- New GMMG is awesome! Even passed "the neighbor test"....
- heat shields
- Are Hedmans long tubes or mids?
- Pulley Squealing?
- Success!
- How much does Cutout really change sound?
- What color wire am i looking for on new bosch o2 sensor
- quick question, quick answer
- 93-97 F-body exhaust?
- coated pacesetter headers?
- TSP catted Y pipe and adjustable torque arm fitment?
- Which Header gaskets ?
- Small K&N needed for lid install?
- FLP offroad tubes
- Vids of TD systems wanted
- Headers + true duals = too loud, opinions on quieter exhaust?
- Headers and gas milage !!
- Help! What intake do I have might of gotten ripped off?
- I'm fixin' to give up, here.
- advice about taking off intake
- heat shield problem
- Tensioner Problems?HELP!
- Help, What The Hell Is This
- Dynamax Super turbo or Flowmaster
- Accuseal Exhaust Clamps - FYI
- Fast Toys ram air upgrade.
- Did I do something wrong? (header install)
- Post your spark plug wire brand and resistance here...
- Clearence Issues
- Cats robbing power
- Would 98-99 Lt's Fit A 2000?
- tired of the loudmouth, which CHAMBERED muffler?
- going for LOUD
- I think I'm going with true duals...
- starting up problem
- Any problems reusing the stock header gaskets?
- ls6 intake question
- Newbie ? I searched :)
- What sealant on coolant temp sensor?
- Just got my headers today but have a ?
- how to port a stock tb?
- throttle body question?
- nose foam
- What's the best catch can to buy?
- thinking about true duals...
- A pic of my homdemade catch can about $20 bucks total.
- Will Long Tubes + Duals + 1-Chambers rasp?
- were to get loudmouth cheapest?
- custom true dual owners
- Rust question
- anyone running a Ford (Accufab) style throttle body yet with stock PCM?
- March Pulleys Pics
- vert headers
- Yet another true dual question (yes, I tried search...)
- What OTHER y-pipe/x-pipe/true dual options do I have with Jet Hot Headers?
- 90mm air lid
- LS6 v. FAST 78
- mid legnth headers and emissions
- Need a Catted Y
- corsa catback...
- Knock Sensor Ohm check
- Longtubes are on, but car won't start...
- another carb ls1 setup question.
- Does anyone know if the Flowtech X-pipe will bolt up to Pacesetters??
- Anyone run open T.B.?
- midtubes and shorties?
- Pulley Installed, have a question.
- Exhaust setup
- FAST install problems (pics)
- electric cutouts
- Coil relocation...differently
- Bassani Competition exhause
- RASP RASP RASP, this thing is too loud..
- Plug Wires
- hooker muffles baffles
- Pacesetters???
- Q about install of TSP Duals?
- New to ls1..need advice
- Swapping O2 sensors?
- What kind of Exhaust would u recommend??
- Just got tuned
- Headers Into Y-pipe Question
- What Plugs And Wires Should I Use???
- Release bearing spring block engine!! Help
- What type of headers??
- granatelli wires?
- Battery Suggestions
- Ported Throttle Body Writeup anywhere?
- ported throttle body?
- Intake options for etp c5r heads
- Differences in Y-pipes
- Installing new y pipe only...help!
- Water Temp Guage Fitting
- What spark plugs??
- Can the water pump pulley be removed?
- ASP pulley SFI vs. Non-SFI part #
- O2 Sensor wiring -- 2 brown wires?
- Installed my Jet Hot Headers this past weekend !
- HAVE to drop some time
- What do I tell them?
- LM Is it too loud??
- TREX+no cats+Borlamouth=too loud
- ls6 intake
- All Intakes Tested
- FRA on an SS??
- Spark Plugs?
- header y pipe combination
- Where to find Pacesetter Mids?
- How much HP to be gained by getting a Catback? (current H/C car)
- Schematic Needed
- LS1 to LS6 manifold swap question...
- Taylor thunder volt or msd
- getting new wires...
- Removing Alternator
- TB blade: hole too big??
- O2 sensors causing hesitation?
- best upgrades
- questions about installing headers
- MTI Clear Lid...
- SLP Off road Y-Pipe and clearance????
- Coil bracket question.
- How Much Does The Fast Flow?
- Installing stock exhaust manifolds, what to expect?
- Cat converter...
- Need a belt part #
- wires
- Pacesetter install question.
- Can i remove the black thing in front of the driver's side wheel?
- Gmmg
- porting stock manifolds
- Plug/gap for my setup... been using TR6's
- Whats wrong with my a/c?
- Another QTP catted y.......
- Kooks dyno numbers
- List of stuff to buy for new exhaust, anything missing or wrong?
- How bad is it to drive without a tune after EGR and AIR removal?
- header/catback sound clip request
- Mods to EGR for SLP LS6 intake (w/egr)
- e-fan ?
- k&n in a ws6=??problems??
- a/c clutch question
- Just finish hearder install
- just got an ls6 intake, cleaning tips?
- Need edelbrock LT's and a few ?
- True duals Video.
- Kook's C5 Headers
- 02 sims
- Next Mod: Need your Help
- Help!!
- headers
- Anyone have the part # for the belts for the SLP underdrive pully?
- fan speed
- Which Lid?
- Dual cutouts installed behind the axle.
- To buy or not to buy
- Removing !AIR
- free mods?
- Air tube into lid question.... (can i unhook the air tube?)
- how do glasspacks sound.
- Fast LSX vs LS6
- Last topic before I get my catback. Magnaflow vs. Hooker vs. TSP Rumbler
- squeaky noise
- I need the secret...TTS header removal...
- Welding on Ceramic Coating??
- has anyone created a Home made RAM air.
- Spark plugs for 402?
- poly motor mount bolts?
- cooling system pressure
- Poll: Have you heard any rasp from a TSP Rumbler (non X)?
- Bad Cat
- Qtp Open Appology.
- TSP TD with powerstick?
- True Duals$$
- Write up - How to remove your MAF
- any power gains with smooth....
- Fast intake install
- meziere water pump
- Information overload! Am I getting this right??
