View Full Version : Generation III External Engine
- Need help with my o2 sensor
- I really need answers on what to do about exhaust on my 2001 ram air
- DWH Electric Cutouts - Need Flowtech or Not?
- Vacuum Leak issues after LS6 intake install
- trying to remove my cat back.
- rear 02's and obd2 inspection??
- 2001 LQ4 Starter Bolts
- How To Get Rid Of Rasp
- Slp Y Pipe
- 10ga OJ wire?
- catalytic converter
- Exhaust hangers
- Fuel Rail upgrade nessesary?
- Gatorback belts - What sponsors sell them?
- Disassemble Throttle Body
- y-pipe screwup, can you find it?
- Direction of cutout?
- wiring schematic for 5 pin map swap?
- Tpis
- Belt Tensioner?
- 408 oil pan
- LS6 corvette Intake
- Those that drilled the tb..then plugged it
- Head Gaskets Question
- Headers, ORY, and stock catback?
- New intake setup soon, Expectations?
- Looking to get the cheap stuff out the way
- Another broken oil sending unit!!!
- Curious-Nitrous question
- Header Options
- 243's and patriot golds problems?
- water pump torque question???
- Is my Y pipe banging?
- What sponsors sell carsound cats?
- cut outs on y pipe?
- What vendor has the best deal on PCV conversion?
- Valve cover with one elbow not 2?
- new intake M, and now AC doesnt work
- Intake & Ported TB
- need pic of driver side fuel rail
- stainless muffler dual tip
- finished my h/c, sounds like harley lol vid inside
- Good place to purchase throttle cable.
- Very bad sounding noise what is it?
- Bullet in the I pipe?
- can i delete the egr only?
- what headers for texas speed y pipe?
- After h/c motor swap, car wont start... no spark
- Throttle Body Help!!!
- Need Help ASAP!!!!!
- anybody have pics of their ebay stainlees dual tips?
- How much better are the 241's over the 853's
- Ported Victor Jr. intake info with 110-108 LSA cams?
- Header Install...What Do I Need?
- What injectors are these?
- Good Catch can recommendations?
- LS1 coils to LS2 truck coil...
- Useful Info
- GM 25534416 gmpp or LS6 intake
- Starting Problem
- Long Tube Header Question
- O2 Simumators!!
- Just joined the "over rev of the month club"
- ORY for Kooks?
- How does rasp sound?
- o2 sensors
- 6 0r 7 in Mecham Oval Tips
- best place to buy Hooker aero chamber muffler??
- Blue plug wires
- lowered car exhaust question????
- Exhaust help for Brother-in-laws C5
- Temperature Gauge Dead?!
- MOTOBLUE H.O Pulleys
- Pics of my exhaust-ARH & Magnaflow
- Help, got a stupid problem!!
- 383 Stroker Question?
- ARHs (pictures)
- SLP Long Tubes & Cutout - VIDEO!
- why is my Y-pipe making my car rattle?
- 6.0 head bolt/stud issues
- Flowmaster catback + 440 RWHP car
- optimum air/fuel mixture
- How restrictive is Borla?
- ???cruise Control Delete???
- TR-55 plug install
- Exhaust too loud, suggestions please...
- Is not getting a fast holding me back much?
- Relocating coils to side of block?
- Headers??
- Exhaust Rear TIPS
- O2 Questions.
- throtle cable
- Header and exhaust install Saturday
- LS2 water pump
- New exhaust~3.5" single exhaust w/single chamber
- Header clearence question/solution?
- look wht i did..
- Open Headers????
- Do long tubes help the engine cool down faster?
- fuel injector problems
- AC Idler pulley
- Best bang for $$$ Heads for a 408
- 3.5" too big for my setup?
- Will Fast 78mm TB work on LS6
- Throttle Body Question. HOW BIG?
- What else could be done?
- 2000 Trans am
- Clogged cats?
- Serpentine belt comes off at dragstrip!
- Borla adjustable
- Car idling too fast
- Bent push rod?
- Help!!! Signs you have fried your cats...?
- Idea for more air flow
- What intake should i get..
- which throttle body
- Quick FAST 92 install questions
- Gutting the cats?
- Heads??
- FTRA SSRA - how it works and why is it better than FRA
- ???what Is The Normal Idle Stock???
- Installing my first cat back
- Beck + Accufab = sex Pics!
- List of full bolt-ons for a V6 camaro?
- Arp Header Bolt Kit
- Best exhaust for a V6 camaro?
- valve covers?
- engine runs horrible/low idle/
- ???CAR IDLES HIGHER AFTER REMOVING REAR o2's???
- manifold question
- stock exhaust????????? lowered car..
- Poly Motor Mounts......HELP!!!!!!!!
- Are power steering pump pulleys interchangeable?
- Just ordered ARH!
- Vic Jr. intake elbow?
- Bbk Vs. Fast
- Carb style intake on cam only 346
- Debating which header
- LS1 Heads (241's) milled .050"?????
- FAST 92 and X1
- You think this costing me some HP
- A/C Leak?
- higher rpm at idle
- Where to get this Magnaflow type part?
- Just put in the SLP Loudmouth 2
- the evil tick
- ARH Question
- LS1 Head Cleanup Questions.... Please help.
- Borla Owners.....Need your help
- Single Cutout vs Dual Cutouts?
- fast 90 loaded on ebay
- Best Buy? aftermarket waterpumps
- poly motor mounts
- Dumb intake question.
- Probably a dumb intake question.
- 98 Camaro SS
- Running Rich after Bolton Install
- New LS6 and P/P TB
- upgrades?
- Cutout installs???
- Where to get 3" Clamp?
- stock motor mounts
- Mezeire EWP clearance
- Last question before ordering catted ARHs
- Shorted Meziere Water Pump
- Over heating .ehhhhh
- ??? Anyone Heard Of Cutting Holes Under Filter On K&n Fipk???
- engine question!
- What throttle body for ported fast 90
- Do 304 SS headers rust or discolor?
- Pacesetters Installed, What to do with EGR?
- My perfect sound (vid)
- exhuast change car slower
- changing cam on throttle bodies (help)
- help! aftermarket valve covers, gaskets dont fit
- My New Jantzer Ported TB
- Should I keep the AIR and EGR on my 1999 Z28?
- Interior noise with ARH headers/ catted Y?
- Basanni true dual install
- How much to install?
- Loctite with poly motor mounts??
- Stock water pump not working well
- Temperature problem, stat? gauge?
- GOT MY o2 BUNGS PLUGGED UP!!!
- Truck crank pulley/ power steering pulley?
- Anyone done exhaust gas back pressure test?
- Winged Fuel Rails from Abear
- fuel tank leak
- LS2 Waterpump
- 05 Tahoe overheating
- Exhaust Choices
- Not the right place but Exhaust/CAI for Mustang V6 07'??
- Which Elbow? Small Cube small shot
- Different years have different looking water pumps?
- Relocating IAT
- underhood temp question re: coated long tubes
- Water pump install ??'s
- exhaust
- Nick Williams T/B
- Cooling System Pressure
- Motor mounts...where to get them???
- Magnaflow can you help me out?
- wet in passenger side floor board
- Fuel Injector Leak
- Bellows?
- should i port on my TFS heads to match my FAST92?
- Need help with ls6 intake???
- Carbed 4th gen?
- exhaust clip
- Who has the TSP 1 7/8" headers?
- does an ls2 intake work on ls1
- P0327 SES Code
- PCV Adapter
- Installed LS6 manifold, tach dies
- Has this happened to anyone else?
- What size headers for this setup. I keep heaaring mixed things.
- To cat or not to cat..........that is the question
- Whos done a single cat in I-pipe? Did it take away the fuel smell?
- Magnaflow Catback question.
- What would a Magnaflow 4" round muffler sound like right after y pipe sound?
- Buying Used 6.0L Truck Engine...Questions?
- 1998 WS6 Single Exhaust to Dual Conversion
- list of mufflers that can replace stock ???
- pacesetter or hooker longtubes?
- A MarylandSpeed PSA...SLP LMI and LMII mufflers DO NOT just weld on the stock exhaust
- Cutout Question!
- I am mad at myself...
- are 2 1/4'' cutouts enough?
- What do you guys think about my Home ported TB
- intake options on L92 headed cars
- mac mids y pipe
- What wires does everyone change to and why?
- anyone else make there own lids?
- Flow rates for various intake manifolds
- Exhaust Advice
- Those with SSRA, Fasttoys or SLP ram air
- from Flowmaster 80 series to Hooker Aerochamber
- Loud Exhaust Plans!!!
- Fast intake Bolt Question
- ls-6 intake manifold install
- qtp cutout problem
- ls6 intake manifold
- Throttle body dif?
- Bolt-On Mods Continue: all done after this...?
- New Induction system
- AIR Pump removal and SES
- motor mounts
- Will I notice a difference if I gut my cats?
