View Full Version : Generation III External Engine
- Question on LT1 ram air intake!
- Dual exhaust supplies
- QTP cut outs
- Any reason not to do bump stop mod?
- I am doing my own TD Setup and.........
- 3 inch inlet Dual Outlet Tips
- Good Set Up?? Please Comment.
- Typical LS1 header dimensions needed
- Need Help!! Which Exhaust???!!
- need help choosing?
- Would you spend a couple bills on a new MAF?
- starting troubles (wierd)
- I know it's been asked like 1000000 times... But...
- Help! Coolant leak from the BACK of the engine somewhere!
- TSP headers installed!
- Need huge HElP!! Got a missfire and tripped a code.
- muffler question???
- slp exhuast or ???
- What to get next???
- Factory Exhaust Removal?
- Paint Headers?
- exhaust help
- Yet Another Long Tube Post..
- Raptor Shift Light Installation guide
- Fast 90 Throttle body porting??
- Professional Products 80mm Throttle Body with Cable Style Throttle Linkage (Polished)
- how bad will open headers be temporarily......
- bullets or sweet thunder??
- SLP pully ?
- Want to swap to 98-99 TB
- LT's, catted Y and magnaflow catback?
- intake info
- Need help, Tips motor mount install>>
- Exhaust systems...
- Exhaust opinions (Y Pipe related)
- O2 extension ????
- Vacuum diagram for LS1...
- ramair for the regular TA?
- Any Interest For A New !!BETTER!!! Air LiD?
- Taking out exhaust in one piece, any last advice?
- edelbrock shorty headers anybody have these?
- Which sensor drives A/C clutch?
- Sound clip: Schtick Saga Continues=TD's/1 Chambers
- headers for 01 camaro SS vert
- Header pics C5 or F-Body
- fast 90
- Which should i get????
- Please Advise
- Some useful exhaust info
- How to tell if you have the ls6 or ls1 engine block
- port your own TB?
- headers install gone wrong
- finished installing headers& motor mounts
- oil breathers?
- Reinforce LT emissions fittings?
- Help needed on exhaust system!!!!!
- dont know where to post this, hopefully some one helps me out!!
- Flowtech LT's w/ ORY any good????
- Opinions on Setup, (thought I knew what I wanted but I dont)
- Magnaflow lovers step in and take a peek
- Dynatech Longtubes...... Y Pipe?
- C5 Catback?
- GMMG install
- guys using Husky filter as catch can
- Grounding points
- Installed Pacesetter headers EASY!!!
- catch can? before or after pcv valve?
- o2 sensor is throwing a code!
- exhaust and headers and how much HP gain?
- unplugged wire after install
- maf
- Clip of the new exhaust.
- backorder TSP tru duels
- True 3" dual SIDE EXIT
- 90/90 w/SLP 90mm MAF
- SLP Underdrive pulley "I need HELP"
- fast 90mm?
- Newb Question
- Mufflex or Flowmaster?
- Anyone using LPE 100mm MAF
- Head Plate, they make one for the drivers side?
- Ssra ram air intake measurements!
- maybe its just a dumb idea???
- Headers Came in
- Best LS6 Manifold
- BBK intake
- Ls6 ?
- QTP owners HELP!!!!!!!!
- best price on Nick Williams 90mm TB
- Lowered 2 1/2" w/ LT's and ORY....
- Lid ... which one with F.a.s.t. 90/90 and SLP 85mm MAF?
- 2 clips of my car b4 the wreck. Cam LT's ORY GMMG
- What part is this?
- Loudmouth clearance
- corvette 02 sensor on my formula?
- 3" to 2.5" hurt performance?
- Best cat back exhaust system???
- PS headers & TSP tru duels
- B&M Ripper?
- throttle body drilling
- Professional Products 85mm Throttle Body
- LS6 Intake vs the competition
- Who's running a 78mm FAST intake?
- 2" headers...any downsides ?
- seal for cutout
- WS6 air box/lid
- What do you guys think of this setup?
- SLP cats are they any good?
- QTP/KooK Ypipe
- intake manifold
- what next??
- what's the diff between '98-'02 throttle bodies??? are there better years?????
- Throttle body help!
- Stupid NEWBIE QUESTION!!!!
- Driveshaft Let loose on Dyno
- help me figure out my next power mods :)
- Best street-legal catback system
- Engine running cold
- LS1-LS6 interchangleable parts?
- Anyone using the Victor Jr. EFI Intake?
- Question for those with SSRA
- Who makes a tool to put on an ASP pulley?
- Who makes a good Underdrive Pulley?
- PCV Valve
- Anyone ever try doing this?
- Need A Battery
- Exhaust flanges
- Hooker Super Comp LT's and stock Y?
- long tube vs short tube
- Lt/ory/e-cutout Vs. Lt, Tsp True Duals
- LS2 Manifold
- LT Cat idea 2 pass emmissions?
- o2 extensions or sims?
- Porting Throttle body
- cutouts worth it on my setup?
- ? For Guys with Edelbrock headers/Y
- Stock ported TB's? Any difference?
- can i use a ls1 intake
- Accessory Drive Help
- dual exhaust Question
- vacuum/rpm problems.....still.
- Pacesetter vs. Kooks LT's
- EGR/AIR Removal
- vibration
- Guys with One chamber muffler come in
- Best coolant
- fast help
- Vette that sounded like an F1 car
- Quick Question
- Do you think its worth it to get SS LTs coated?
- spark coils interchangable?
- Sound clips of magnaflow and slp d/d slp lm2
- What exhuast comes on the slp camaro's
- How much did it cost to install your cat-backs
- can you put a 90mm TB on a LS6 intake???
- 02 sensors
- Ls2 Intake
- Scored a 78MM FAST/Ported TB cheap - worth porting?
- Looking for best ground clearance LT, Y-Pipe and Cats Combo
- mti rub???
- KOOKS catted Y!!
- Worth the Jump??
- True dual under or over Tunnel brace/TA kits?
- weiand intake came in today have a couple questions
- BGRA Gasket?
- Corsa...
- ASP pulley question?
- SLP LM and backpressure problems??
- Whats a better exhaust?
- Need Advise; Is anyone here running MSD Gen III coils w/Granatelli wires..
- Coolant crossover pipe
- do i need a tune!!!???
- water pump alternatives?
- true dual pictures inside....
- heat soke . . . .
- 90/90 combo > stock MAF vs SLP vs Granetelli?
- popping sound?
- Where can i find O2 Sims
- Are these a good deal?
- SLP LM1 Sound Clip
- Anyone know why my cooling fans constantly run?
- AIR removal ?'s
- Installing 160 t-stat
- Breslin header bolts?
- What a/c parts are these?
- 11 Volts causing power loss??? Alternator is dead or dying
- dynomax bullits or magnaflow?
- GM performance carb. intake manifold
- Is a NW 90 TB better than a FAST 90 TB?
- Td's Welded To Headers?
- How loud/decibels(dB) are true duals?
- LS6 intake on LS2 engine?
- Vic Jr/TB/Fuel rail question
- What hp do vendors claim out of a ported 90/90?
- 402, 408 ,427 Stroker Guys Please Come In!!!!!!!
- Pre-Install for LT's Getting Ready!
- Long Tube Header Help ASAP plz
- New exhaust on C5 and now it runs BAD. PLZ HLP
- lil info on Headers!!!
- Help Me Please
- question after ported tb
- aftermarket valve corers
- Those who removed cats?
- manderl bent over norm.
- To Loud?
- What gear/stall for F13 / PRC 2.5r heads?
- Exhaust to loud!!...inserts?-
- Anyone have close-up pics of BMR strut tower brace???
- Polished Kooks Headers
- vacuum line
- NJ Emissions Requirements
- alternator
- Ebay CME
- How much hp loss from 1 3/4'' headers on 402ci LS2?
- Jet Hots
- ticking noise on intake
- Watch out for strippermotorsports of ebay
- headers
- Oil In Catch Can Question
- coolest (temp) headers?
- Quick question about stock SS exhaust....
- ls6 intake ?s
- How can I reduce EGT?
- Stock cat-back????
- TSP Dual Muffler Question
- Stage 8 locking header bolts, like or dislike?
- what is the biggest restrict in
- Coolant System Questions - No coolant flowing into engine...
- Trouble getting a good seal between LT's and Y-pipe anyone have any tips?
- hooker short tube super comps
- Tb differences?
- Kooks Headers
- EdleBrock headers
- Head Cam questions
- XS headers and cated Jet Hot Y ?
- LS1 w/ the Mustang Sound - FINALLY!!!
- 78 mm fast intake whistle?
- Will a ported FAST LS1 intake & a Nick Williams TB give me big gains on my 2002 Z28?
- LS1 Y Pipe Help?! Swap question
- pics of a victor jr setup!!!!
- Cutout!!!
- Vic. Jr question
- LS1 head bolts
- Ported Fast 90 Intake!!!!!
- Header install ???
- Relocating coils
- Hookers Tuck up to much?
- Intake swap question??
- need a lid for a 90mm fast
