View Full Version : Generation III External Engine
- Nitrous and header combo?
- Stupid Header Question
- I got a question about my 99 SS
- 02 sensors..
- Sweet Thunders on a newer Silverado
- Its been said before: LTs+ORY+LM=No No
- temp gauge sensor bung
- my idea for an exhaust help?
- v10 plus exhaust...
- flowmaster vs magnaflow merge?
- O2 sensor how to tell left or right?
- L-O-L Shop story:
- Gutting Cats
- is it safe to drive
- Sidepipes on my camaro Z28
- Chambered Mufflers
- What are a good set of headers...
- Anybody have the JetHot Ypipe (Catted)?
- BGRA alternative?
- how much power do hooker long tubes and y-pipe add
- people with TSP rumbler...
- Quick question???
- How do I get my headers coated.
- Options for Catted Y-pipe
- Edelbrock Victor JR Intake (Pics and specs)
- Pulley or not to pulley?
- Xr-1 or Cats???
- Hotwires!!!
- Which torque arm w/ True Duals
- Need some help please!
- cutout or LM resonator loudest?
- part numbers needed
- ??Belt Size??
- true dual vs. Y
- ls6 intake price
- Slp performance pac
- Used vs New
- lt install 02 procedures?
- LT, Cats, Dual/Dual users inside
- Do you need the foam things on the bottom of the intake?
- FAST intake and Forced induction?
- Removing Cats.
- Fabricated exhaust vs Brand performance exhaust
- how much will this help
- Porting the FAST 90MM intake?
- Well I tried to get the intake install done but SNAP!
- Fixed my exhaust leak, basically for free
- Did the Sweet Thunder Swap
- My Own Custom Exhaust!!!
- DRONE - what causes it? Converters or Cat-backs?
- My home ported TB
- How can I make a quiet true dual?
- Another dynomax bullet question
- Has anybody had.....
- Removed aluminum plug insulators - bad idea?
- running like crap after new wires.
- LS2 intake manifold
- Flow Tech Headers...
- Exhaust FELL OFF!
- Who here is running with a TRex cam?
- stage 8 header bolts?
- Corvette intake, LS1 or LS6?
- Gmmg???
- Performance Pulley
- Someone has to have something to say...
- Cut stock system?
- True Dual Owners - Heating/Rattling/Knock/TQ Arm
- exhaust tips
- need help
- where to get plug wires
- oil between header gasket and head?
- Odd Air Conditioning Problem
- magnaflow vs spintech
- y-pipe for SLP Headers?
- Which one should I get?!?
- Borla guys in here. MPP?
- Fipk?
- stainlessworks y-pipe
- Mac Headers and Loudmouth Exhaust
- sounds like a supercharger under the hood
- Will a Gatorback belt fix my slipping problem?
- LT's, OFY, and stock catback
- oil being sucked into intake will small breather fix this?
- Blow Off Sounds
- Flowmaster 40 series
- Problem w/ intake swap
- O2 sensor wires
- Turn one pump
- Which one to do next??
- Flowtech Headers??
- best way to go about deleting EGR
- Cheaper?
- what is the loudest duynomax to replace the stock muffler
- passenger poly motor mount worth it?
- "X" or "Y" Pipes
- Small exhaust leak...problem for a few days?
- stock I pipe and bullet muffler?
- Which length Sweet Thunder to replace LM?
- Engine vibration at 2k-2.4k...I think it's the ASP pulley
- resonator exhaust tips
- Need some quick help with !AIR
- ory-p question
- slp exhaust's
- power steering free mod question?
- slp dual duals
- will x pipe made for dynatechs work with hooker LTs?
- Installed my Cut-out! Vid inside...
- Borla vs. GMMG
- LS1 to LS6 intake
- where to get dmh cutout
- What hardware is required to do a ls1 to ls6 intake manifold swap?
- Need Help with cutouts
- I think I there's a problem with.....
- ? for those w/duals or (insert muffler here)mouth
- Need help on air intake system
- All Ls1 oil pans the same???
- another problem
- Problem with FAST intake
- Any gains?
- cut out?
- machined valve covers and low mount alternator bracket
- Edelbrock Victor intake FUEL RAIL question...
- Front O2 sensors
- NGK TR55 spark plugs copper or v-power
- my new bolt ons
- breathers?
- MAC header install...
- Hey how do you think the driveability will be?
- Borla Exhaust system pipe
- Exhaust system Pipe for Borla question
- After Cam Install, I need new o2 Sensors! Z06? Stock? Help!
- Cammed LS1s - Motor/Tranny Mounts?
- Cat Service Bulletin?
- 2002 LS1 intake # help?
- Magnaflow catback-Weld or clamp??
- Guys w/ optima red top, help please
- EGR low voltage :: !EGR or replace?
- QTP elec. cutout quality?
- Switching AC compressors? Please Read~~
- Header Bolt Question & IAC Motor Screws
- Vararam Results
- are coil packs different on a 98?
- What to do about headers???
- 02 SS exhaust
- long tubes and ory with stock catback?
- ssra install????
- SES Light From AIR! Removel Question
- misfiring when hot
- Im stumped..
- header gaskets
- AIR valve question
- True Duals
- Exhaust II...stainless steel or aluminized steel
- SLP Fan Switch and T-Stat
- What exactly makes our exhaust tone(s)
- Exhaust.....what size to run from collectors back
- 2004 6.0 2500 Chevy free mods
- Where to get a set of Macs coated?
- Which Y Pipe for supermaxx headers
- !EGR & !AIR Quick Questions.
- Free Shipping For All Headers And Exhausts!
- quick time performance headers
- How Much will shorty's effect my....
- I Want Louder
- Is my intake missing something?
- V6 exhaust...3"?
- prothane motor mount install?
- Motor Mounts
- Volant intake system
- stock baffel???
- Got my vararam intake today!
- anyone have this
- headers
- LS1 Header flange CAD file
- Catch Can Options?
- i need part numbers for poly motor mounts
- DMH performance cutout=amazing
- would no muffler cause check engine light?
- TSP True Dual - Stainless or Aluminum?
- !EGR Guys - In Here!
- Edelbrock Victor Jr LS1 Intake
- 98 camaro long tube headers?
- alternator ?
- FTRA on a daily driver....
- !air
- LS6 or FAST
- Very good sticky in New LS1's
- Which air filter?
- Differential Drop
- Hooker Aerochamber owners inside....
- schrader valve size
- Spark Plug Install!!!
- emission removal tutorial link?
- hmmm last header bolt wont go on
- should i go with a 160 t-stat
- '97 Corvette exhaust manifolds...
- removal of intake
- throttle body open %
- difference between a cut-out and a TSP cat-back
- Speed inc x-pipe race kit
- shiftlight + A pillar gauges..
- Kook Size Headers. HELP??
- Ported Throttle Body issues
- Inline muffler for LS1
- Ticking under accel????
- Installed GMMG this weekend
- Exhaust leak.... bad
- B&B Triflo Power?
- Did FRA, TB Bypass, Rear Hose Mod This Weekend
- What a piece of $hit. PS pump and pulley gone.
- Coil Relocation Brackets
- GMMG exhaust on ebay
- Porting stock 99' exhaust manifolds?
- Airbox
- Just got done taking off the EGR/Air Crap
- Stock Exhaust Size??
- FAST 90/90 issue, help please..
- Green filter ?
- Ordering the LT's this week.
- LTs/ORY/Magnaflow WOT 1-4 vid
- gmmg exhaust tips
- *What ORY for stock manifolds?*
- Edelbrock Victor intake runner length?
- Need help finding rear o2 sensors
- SLP Headers with Loudmouth?
- y-pipe-SES light-powerloss?
- headers and tuning
- Gmmg
- LS 4 Question??
- Vara-Ram velocity stack,worth the money?
- Steering Linkage Removal
- Queston about o2 simulators
- ac belt tensioner and pulley?
- Texas Speed True dual - pacesetters.. noise level?
- Starter from 02 Tahoe
- undercar edelbrock victor header pictures???
- Broke an a/c pipe....what do i need to do?
- No Water Temp ?? Need Some Help Please
- Traction control ? do i have it or not?
- Type of filler for TB porting
- Difference Between SLP's Loudmouth and Loudmouth II?
- Motor mount install
- Does anyone make a real carbon fiber lid?
- Pacesetters and ORY are in!
- The X pipe
- WOW ! !EGR & !AIR ......
- Denso O2 Sensors
- Overheating question................
- witch LT'S and Y pipe to go with
- home ported TB?
