PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 [203] 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Right Rear 02 Sensor - Rattling Sound Inside Pipe
  2. difference between hook and pacesetter lts?
  3. Fluidampr Pulley?? Anyone use this? Results?
  4. ses light ?
  5. K&N Filters and Oil on MAF Wires
  6. Headers and Ypipe clearance issues.
  7. MAF's
  8. Sweet Thunder Mufflers
  9. FIPK with 90mm
  10. Professional Products Intake Manifold
  11. Lid Won't Work!!!!
  12. Who is running TTS LT's ??????
  13. Do I need a new tensioner?
  14. Lots of freakin' drawing..
  15. Help!!!poly Motor Mount Install???
  16. Squeeling =(
  17. can anyone tell me what brand headers these are??
  18. can anyone tell me what brand headers thses are??
  19. NGK TR55 question
  20. Xpipe setup
  21. LS6 coolant line conversion
  22. What kind of headers do you have? Pt.2
  23. LS6 pcv questions/problems
  24. antone have slp lts & running dumped?
  25. Anybody have the Donaldson paper filter part number...
  26. Does anyone sell pre-lengthened O2s???
  27. Anyone has TSP TD's with FLP headers?
  28. strange noise
  29. FT SLP CAI RA upgrade VS FTRA
  30. Pacesetter LT Install Complete
  31. Thick plug wires?? 10mm+?
  32. Is my lid package complete?
  33. Header Install List
  34. throttle body question
  35. Problem w/headers, pls help!
  36. best headers
  37. Cheap underdrive pulleys...
  38. Need a pic of PS Cooler Help
  39. True dual side exhaust on a Z28??
  40. Plug wires
  41. Tab busted on map sensor. Is it ok??? Pics
  42. question about corsa knockoffs
  43. 3" exhaust
  44. alright i dont know to much about exhuast systems but lemme kno how much
  45. what do you really need to remove to install LT headers
  46. Quick question about the BBK intake
  47. ** The best poly motor mount write up ever written **
  48. anyone have any advice
  49. clips on coilpacks
  50. Problems with Jet Hot coatings
  51. 6in round magnaflow fit?
  52. K&N FIPK filter only???
  53. what other stock water pumps fit?
  54. Pics of True Duals w/ Sportline Springs
  55. Stupid O2s
  56. Whats Better X Or H-pipe?
  57. Cut Out on stock exhaust- good or bad sound?
  58. Quick EGR! question
  59. cutout or tsp?
  60. What kind of headers do you have?
  61. Idler pulley bolt info
  62. Oil pressure and water temp guages
  63. fast 90 losses?
  64. O2 Sensor's
  65. intake change
  66. Remove the pcv
  67. evap purge valve
  68. How much power will a dirty air filter rob ?
  69. header bolt question...
  70. How long until your headers rusted?
  71. mti lid holes?
  72. EGR question
  73. Weight savings from headers/ORY?
  74. Header gasket ?
  75. Sx Super Comp Headers Installed With Pics
  76. Underdrive key way??
  77. Intake/throttle Body Question?
  78. little help?
  79. catalytic converter question....
  80. Raptor shift light not working :(
  81. h pipe clearance with spohn t/a????
  82. why doesnt my exhaust sound like a camaro with exhaust
  83. Oil in intake PCV test
  84. Replace oil filler cap with breather.
  85. 2.5" or 3" pipe for exhaust set-up
  86. EGR and other things I dont know what they are?
  87. Stock TB, will it work with the LSX?
  88. Cutout for stock Y pipe
  89. removing egr valve and a.i.r on dd?
  90. 01' catching a ton of oil?? how to stop it
  91. Removing AC?
  92. Hooker
  93. TB question
  94. throttle bodies spacer problems
  95. Advantages of Cutouts
  96. Poly motor mount install.
  97. New exhaust system
  98. Cut Outs
  99. QTP, Electric Cutout and Subframes Install Problem
  100. msd 8.5 boot is touching pacesetter LT
  101. whats the best 25% underdrive pulley?
  102. Aaron's sheetmetal valve covers
  103. Etp Heads 245cc 11 Deg.
  104. Exhaust upgrades
  105. QTP with True Duals??
  106. driver side valve cover
  107. Lower airbox clips.
  108. how do you install o2 sensor simulators?
  109. Does this look right? O2 sensor wire question.
  110. Pics of custom air intake installed!
  111. 4" QTEC on 4" Catback Dyno Numbers
  112. No dyno tune available, headers?
  113. strange noise from exhaust??
  114. will this fix y pipe banging?
  115. Any reason for this?
  116. CA smog w/ headers
  117. Where to get exhaust pipe kit??
  118. SLP headers: do they really make LESS power?
  119. anyone ever tried making their own CME?
  120. MagnaFlow Ultra High Flow and Compact Metallic-Cat Product line
  121. Hooker Aero Chamber for duals?
  122. Whining sound from under my hood !!
  123. MAC mids OR Pacesetters?
  124. Exhaust recommendations needed.
  125. Soundclip Of My Custom True Dual Setup
  126. SLP package Question
  127. Sorry For The First Post About The Wrong Throttle Body Guy But I Still Want One
  128. 98->99+ Valve Cover Conversion
  129. Meziere LS1 Electric Water Pump
  130. starter?
  131. Ac Help!!
  132. Please help........Thank you.
  133. anyone try these cats?
  134. is this a real LS6 intake
  135. Ported stock Throttle body Ok for cam car?
  136. Over axle duals on non tcs cars?
  137. Help on long tube install on a 2002 WS-6
  138. new mods
  139. Down to the wire...I need your help!
  140. import theory crossover
  141. true duals out the back
  142. need exhaust advice
  143. Running Rich!!!
  144. Lsx Intake For Ss
  145. stupid question, please help
  146. True Dual Clearance
  147. Special Delivery from QTP
  148. Need a quick answer
  149. Least Raspy true dual mufflers??
  150. Service Engine Soon Light From Gutted Cats?
  151. Pictures of exhaust with V-band clamps
  152. where to get gmmg exhaust and where to get it installed?
  153. ls1 injector o-rings...
  154. Magnaflow muffler
  155. How Big of flanges should I get?
  156. pacesetter or hooker?
  157. 450 Bhp
  158. Bullet Muffler
  159. Running LEAN
  160. Patriot Intake?
  161. Ws6 Ram Air Box??
  162. SLP Exhuast online
  163. header measurements
  164. Need a link or phone # for Bo White throttle bodies
  165. FRA and Computer Reset
  166. Exhaust tip restricts flow?
  167. TB Bypass proof
  168. Best Flowing
  169. ory
  170. Quick Question.. HELP!!
  171. Advise: On the Volant system which oil can I use?
  172. custom air lid intake!
  173. Stock WS6, cats with No muffler
  174. Can I simply cut off my catback
  175. !AIR question....
  176. question about hood/intake
  177. SLP Loudmouth with lowered cars in here now!!!
  178. Stainless vs. Coated headers
  179. is a T.S.P 85mm lid worth more over a stock size T.S.P lid?
  180. stripped thread help
  181. What Exhaust hangers for True Duals?
  182. Anyone run NGK Oxygen sensors?
  183. JAZ catch can
  184. Throttle Body Choices!!!
  185. Am I able to do this on my 2000 Trans Am?
  186. Clearance issue.....someone PLEASE help!
  187. open headers
  188. Powersteering reservoir?
  189. What Is The Difference In Gto And Ls1 Intake
  190. Which side in the rear should I put my battery?
  191. Bbk Vs. F.a.s.t.
  192. Which intake is this part number??
  193. Which pipe
  194. What kind of headers
  195. Whats the difference
  196. Catted Y-Pipe Fit Question?
  197. Race Headers
  198. Race Mufflers
  199. Intake
  200. True Dual
  201. emissions part question
  202. Mafless CAI
  203. motor mount install from hell - help needed STAT
  204. Does anyone make a 170 degree thermostat?
  205. People who have uncoated headers
  206. Intake manifold ?
  207. TD Under vs Over
  208. Race Style Headers
  209. Installing Autometer Gauges
  210. Exhaust wrap
  211. i now hate f-bodys
  212. Kooks Headers Rusting????
  213. LS1 intake EGR plate/cover?
  214. Christmas for ME!
  215. electric cut out
  216. Hooker Headers
  217. Anyone done a 4 inch cutout over a 3 inch?
  218. gain or loss??
  219. slp underneath ram air???
  220. ported TB
  221. Who has the best sounding LS1
  222. Difference between 99 and 00 pacesetter's
  223. Fast 90
  224. Need Help w/TSP True Duals
  225. True Dual LM!!!
  226. car throwing code
  227. Anyones Poly motor mounts NOT fix the y bang???
  228. What it is and can it go away?
  229. Did Pacesetter lt's yesterday
  230. flo pro twisters??
  231. Why you don't want slip on collectors...
  232. Air Pump problems???
  233. any idea on what this exhaust is?
  234. TR-6-IR with nitrous
  235. what thermostat to go with?
  236. Fast Wont Fit With Slp 2pt Tower Brace
  237. flowmaster 80 series and lt's
  238. SS ram air
  239. Borla or True duals?
  240. stock spark plugs
  241. Stock Cats
  242. Can O2 sensors be cleaned ?????
  243. Who has or does porting on tb's
  244. home made WS6 mod
  245. exhasut shootin out stuff
  246. dumb question, stock sizes
  247. look what the cat dragged in today!
  248. How restrictive is the stock catback?
  249. Will CAI Help My "FRA"?
  250. will a bad cat affect gas mileage??
