View Full Version : Generation III External Engine
- Best sounding bullet
- underdrive pulleys?
- testing plug wires
- Husky filter for oil catch can...observe polarity????
- How to improve Throtle response ?
- how much quieter is LM2 than LM1?
- exhuast too loud :(
- Dyoned my car with Paceheaders and TSP offroad y-pipe
- loudmouth and loudmouth II
- Every Free Mod!!!!
- why is my NW tb sticking?
- Broken Sensor..........
- Can I use my magnaflow catback piping with a corsa muffler? Dual/dual piping maybe?
- Remove LS6 plastic oil fill neck in cam cover?
- test pipes.....
- question about ssra & ftra??
- Need help, installing ls6 intake, EGR
- GMMG Y-pipe/Cats question
- Starter Problems?
- should i get a cutout? need your insights
- will GMMG sound good with my mods?
- beck intake
- Stock exhaust?
- rev limiter on 05 vette?
- Got My Magnaflow Catback....
- anything im forgeting-header install
- Anyone have TSP Rumbler oval tips pics?
- So who likes magnamouth catback?
- how much am i losing?
- My ASP Pulley Install Guide M6 cars.
- New 98 Z28 Mod ?'s.
- cats or no cats?
- why do you need o2 sims?
- Was my QTP Y-pipe supposed to.......
- exhaust leak
- Several !Catback questions
- Cut outs!
- LS6 Intake problem???
- kooks headers and qtp y
- Need Help!!
- How many people's Dual/Dual mufflers have blown the insides out?
- Pacesetter/TSP y pipe ground clearance
- Might get rid of the GMMG
- Maximum allowable warpage on LS6 intake
- where to buy shorter bolts for fast 90
- NICK WILLIAMS 90mm THROTTLE BODY
- Ported my TB: see pics (I Hope)
- Pacesetter install tomorrow...
- Did your cutout do this??
- everyone with Hooker Catback
- Sound Clip of rasp
- borla owners with headers come on in!!!
- Not just another GMMG post...
- Why am I getting knock retard@WOT with a bone stock LS1 Z28?!
- running like crap after LT install?
- Qtp Ory
- corsa with mid length headers
- o2 sims
- Spark Plug Gap
- just got the loudmouth 2 , should i ...?
- QTP headers question
- Taking the crank pulley off.
- QTP longtubes with ORY installed!! More...
- LS2 intake manifold..??
- Is it supposed to sound this way?
- i don't know if it will pass
- Exhaust/Catback opinion question..
- Pacesetter mid-tube headers
- pacesetter or eldebrock
- Dr Gas X pipe 3" to 2.5" or have a custom 3" TDs
- how to fix banging?
- Help me, what exhaust do I have. *Pix*
- True Duals, Over or Under Axle???
- My exhaust experiences.....
- catch can setup !!!!!!!!!
- Electric Water Pump
- Slp 85mm Maf
- Truck coils need longer plug wires?
- vette borla stingers on camaro?
- Pro’s and cons of stainless exhaust
- Question on SLP LM
- powerbond pulley ???
- harmonic balancer install
- how to start engine for the first time
- Started porting my Stock T.B
- Am I gunna hate gutting cats?
- Iridium Spark Plugs
- SLP Lid...
- header for 98-99 will it fit 00-02?
- Throttle body coolant bypass?
- What to do w/ heater hoses
- air pump fuse blowen after header install
- coil relocation ???????
- tsp true duals...
- bolt in true duals?
- BG Ram Air kit ??
- Important question about Borla adjustable plates!!
- How much do shops charge?
- hooker exhaust too noisy
- LT's,ORY, Stock SS cat-back.
- time for a new exhaust (81 camaro, 355)
- Looking for breather sizes for deleting PCV system
- Accufab TB?
- What to do, what to do..To QUIET!
- turndown?
- Cat Suggestions
- removed my stock muffler and tips today(accidently)
- coil differences?
- will LTs help and what kind to get/exhaust
- Thermostat Torque question
- catalytic converter
- Duals and prokit...
- What would sound better?
- slp header(ticking)
- Need Help, Pulleys?
- ory question
- Help car keeps blowing fuel pump fuses
- Question about Headers, Tuning, Etc...
- Maf ??
- Exhaust Ports
- Torque specs for starter motor bolts
- LS6 Intake ?
- Will true duals still have rasp without cats?
- Spark Plug gap..NGK plugs
- ported tb
- exhaust hangers?
- Best catback w/ LT's, CATTED Y, mild cam
- Is this bad on the motor?
- Katech's new modular Coil Relocation Brackets
- intake leak.
- Race longtubes or Emmissions?
- Need some qick help with a pulley
- need help with running untuned
- 90mm TB
- SLP pulley question
- thinner filter?
- Good deal?
- how many hp should i expect
- Another debaffled and sealed hood write up
- Which GM car/truck alternators will work on an LS1?
- What is that tiny vacuum line...
- bad vacuum leak!!
- Removing Cats
- People with longtubes come in please..
- maf sensor
- SLP lid owners, heads up.
- ? for people with coated LT's
- header bolt size/thread
- How loud?
- How much louder?
- Hedman Exhaust kit
- Need Help Fast! Header Y Pipe Question
- ASP pulley wont work with "Double Roller Timing Chain"?
- Hooker Muffler
- thuder racing tb and maf descreen?
- Pacesetters???
- TSP True Duals OMG!!!!!!!
- Remove T-stat For Ewp???
- Borla Sounds Like Crap After Header Install
- fast 90/90 with 224 cam...
- True Duals, questions answered here. Post YOUR information and pics too!
- LS1 Carby Intake Prices
- New Dynomax Bullet Catback
- is this a good set up
- More magnamouth for ya
- Lid and cold air intake,
- ORY with cutout vs. true duals?
- how hard is it to change intakes in a 4th gen f body?
- turbo catback- quiet and stright through. Ideas?
- 1 cat with long tubes
- Exhaust Leak? And where I can find band clamps?
- need help on belt size
- Next upgrade need advice!
- anyone noticed ?
- 6.0 Starter Question
- Which Exhaust,4inch Mufflex or TSP 3inch Duals with 2 chamber 40 series dumped
- hesitation and backfire Part 2
- 98-00 headers on a 2002?
- tsp true duals
- lead resistent o2s
- extra cooling fans
- Fast Intake Installed Now p0327, p0332
- extreme
- MAF & IAT unplugged (how bad did it hurt performance?)
- magnaflow -- need your opinion, was i ripped off?
- MAC ORY tube size?
- Fuel connector
- any other way to remove p/s pulley
- How much RWHP can i expect from X-Pipe?
- problem craking 383...for the first time....help....!!!!
- what size cerpentain belt for slp pulley???
- ls6 intake install coolant pipe and plug?
- Remove LS6 Intake connection?
- I Wanna See TA Exhaust Tips!
- Exhaust Set Up Question
- quick breather question
- Which Intake Manifold??
- New manifold.. leaking fuel like crazy
- Guys with CUSTOM true dual setups
- Problems with FAST 90/90
- which exhaust has absolute minimum drone w/ cam
- Porting Polishing FAST 90 T/B
- LS6 swap considering moving injectors around
- exhaust tips shake too much after cam install??
- How do these spark plugs look?
- Orderd Headers need a few things
- My magnamouth on dyno
- Question about QTP longtubes and Eibach springs
- Broke Evap valve????
- Why is my car doing this..
- 1 cutout vs 2 cutouts
- FAST intake, MAP leaks - solutions?
- cooling fan test
- Do we need a sticky just for true duals?
- Hit 94,027 miles and the alternator dies
- Romac Balancer?
- Put my cutout on today. ITs Great!!
- Quick Belt removal/Pulley question
- What to do with my MSD stuff
- Speed Inc. is the shit!
- Who sells the Edelbrock 1 3/4 to 1 7/8 stepped headers?
- Power LOSS< Dragging a yacht
- How do i port the stock throttle body?
- Non Adjustable borla
- Intake manifold and MAF questions help!
- exhaust
- LS6 exhaust pop--need some advice please
- True dual exhaust questions
- MSD Digital 6 wiring?
- Kooks Primary Measurement
- silicone balance tube
- TSP rumbler or Loud Mouth??
- Plug Wire Question...
- Headers or Roller Rockers?
- 6.0 intake on ls1
- Pacesetters are ON!!!
- Who's bellows is best for 90/90
- Gmmg Vs Borla
- Sound Difference in LT's???
- Will my o2's from car work in my 00 silverado?
- Exhaust Resonation
- Catback Systems
- the new GM trans fluid in my PS pump???
- Headers for a 98 formula - HELP
- Egr On 2002 Z28 Stripper Model
- What size
- exhaust???
- Drill Exhaust manifold??
- If it were you...
- painting headers
