PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 [297] 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. LS6 Block
  2. will a O2 simms drop my mile per gallon?
  3. Any real header hp# on stock motor.
  4. Does anyone carry or make a true dual kit?
  5. What to replace Loudmouth with?
  6. How to tighten throttle cable on non-asr f-body?
  7. What size cutout?
  8. Accessories to go with a new LS6 Intake
  9. loudmouth exhaust
  10. I feel like I'm loosing power
  11. Headers or LS1 Edit?
  12. qtp lt's and ls6 heads?
  13. Did Corsa solve the weld breaking....
  14. ANY BODY GOT THIS SET UP?
  15. how to change o2 cencors?
  16. Best sounding exhaust with Mac's?
  17. 01 Headers on 00 Ls1 .
  18. can I weld flowtech cutouts into hooker Y pipe?
  19. Biggest diameter to bore stock throttle body?
  20. What about a Tri-Y Header for an LS1?
  21. LS1 WITH 2OTL.......HOW DOES IT SOUND
  22. Whats the verdict on QTP LT's, worth the wait?
  23. Legal Trouble with loudmouth in lewisville area??
  24. Hurst Roll Control Install (Thunder Kit) QUESTION!
  25. Gutted cats
  26. UNcrushed Y PIPE
  27. more KOOKY questions?!?
  28. PORT OR NOT TO PORT?
  29. Side exhaust and ground effects
  30. Can BG Ramair damage a descreened MAF?
  31. oxygen sensors
  32. who has the best priced LT headers???
  33. What all is needed for a header installation?
  34. Where to mount PS cooler with FTRA installed?
  35. WTF is a kooks header, never heard of them
  36. Does the 2002 Firehawk come with an LS6 intake?
  37. hooker LT and no cats with SS muffler sounds bad
  38. spark plug gap??
  39. Who knows the additive that replaces coolant??
  40. Thunder Racing headers vs. Hooker LT's
  41. Need write-up on installing headers!!
  42. Is this exhaust going to sound bad?
  43. how much is this f-up gonna cost me
  44. Correct way to bleed coolant system ?
  45. KOOKS headers
  46. how much hp gain with hooker.............
  47. Kooks and QTP Clearance
  48. Looking for cheap mods
  49. Dynomax Bullet.
  50. Fuel Line to Fuel Pres. Gauge
  51. Autolite 104 vs NGK TR-55
  52. i have duals now, but getting new TQ arm.....
  53. Those w/headers, no cats and Corsa exhaust, inside
  54. Another header question....
  55. Where can I find the part# for 02 Z06 injectors?
  56. What size header for Alum Block 409 LS1
  57. ? for those using Total AirFlow Bellows
  58. 2OTL or Loudmouth......help me decide.
  59. Anyone think of a use for Stainless Wire Ties?
  60. LS6 manifold install?
  61. TB??
  62. anybody use pacesetter long tubes?
  63. FRA! on a 02 Firehawk
  64. UPS finally arrived...From Kooks with love!
  65. hooker LT/cats/LM question and opinions
  66. Help. I pulled a good one.
  67. Looking for the FORD part number for 2.5" FLP band
  68. Headers+Catback
  69. Mac mid-lenghts to Kooks long tubes-How much HP?
  70. Best source for Lt headers and pipe?
  71. GM part # for pulleys?
  72. Something is wrong with my car =(
  73. Couple of Questions
  74. Texas Speed & Performance lid question?
  75. PPC headers
  76. Cars running rich help!!
  77. hooker y pipe to stock I pipe loose fit any fix?
  78. One more header question........
  79. Help, Heads/Cam Swap Complete, PCM dead
  80. Best Damn Site in the World
  81. turndown offroad pipe questions
  82. Ported Throttle Body
  83. Which MAF is better Z06 85mm or SLP 85mm???
  84. 91 firebird
  85. True Duals - 2.5" or 3"? Did Search
  86. Will Aftermarket Lid fit 85mm MAF???
  87. Smoke while WOT
  88. Help with my sig.
  89. Intake Manifold Rework - Plastic Welding?
  90. Longtubes +3" True duals + lowering springs = ???
  91. duals on stock manifolds? no one has done it? why
  92. ls6 intake install lit up dash engine light??
  93. Which catback is the loudest?
  94. torque specs for header install?
  95. I'll ask again... 1 3/4" or 1 7/8" longtubes??
  96. ENGINE NOISE?
  97. Service Light On ...Car Hesitating...HELP!!!
  98. gutting cats
  99. pully
  100. people with exhaust cut out, I need help
  101. Putting 2 bullets in Y-pipe, kill rasp?
  102. Recieved and Installed my Hooker Catback today
  103. What can cause misfires like this?
  104. Does anyone know?
  105. AC Diagram
  106. MAC headers and ORP for $500?
  107. NEED HELP ASAP!
  108. exhaust manifold Qs please help
  109. Which pipes should i go with?
  110. Intake system component website?
  111. o2 extensions for hooker lt's?
  112. Coil pack holder question
  113. Who as the money?
  114. Coil packs arcing over
  115. True duals parts with x pipe
  116. A4 Question
  117. FLAT FOOTING @ 51K MILES (bad day)
  118. K&N OR HOLLEY
  119. Ceramic Coating for headers.... any other colors?
  120. 85 MM MAF question....
  121. My Review of BBK Throttle Body
  122. Throwing a MAF code, need help......
  123. Dyno numbers........
  124. Any way to tell how to correctly wire coil packs?
  125. Thinking of ditching my SLP LT Headers
  126. 1 3/4" or 1 7/8" longtubes for a 383??
  127. IAT sensor location?
  128. Quick Disconnect for MAF sensor
  129. SLP CAI - Sealed airbox or not?
  130. TPIS 1200cfm Throttle Body???
  131. CUSTOM EXHAUST!!!!
  132. Coat Stainless Steel headers or not?
  133. Got Headers Loudmouth TOO loud !!! HELP!!
  134. Help what do i do
  135. Do all longtube headers install from the bottom?
  136. map sensor malfunction?
  137. Magna. or SLP Loud Mouth?
  138. Just installed Borla Pro XS muffler
  139. runnin with NO o2 sensors???
  140. 85 mm MAF Sensors, Do they work?
  141. 160 or 180 deg. Thermostat?
  142. help I think I hurt her, mpg way down,
  143. 6.0 truck intake man vs LS6 intake
  144. Guys running true duals, what kind of DS loop are
  145. Is it possible to swap valve covers?
  146. Tools needed for header install?
  147. Water Temp gauge install questions
  148. ZO6 fuel rail covers
  149. Billet LS1 dress-up items?
  150. Lid questions?
  151. Gain going from MAC mid-lengths to longtubes? *DELETED*
  152. Cheap H.P. upgrades????
  153. LS6 intake worth it on Hotcam / Mac header car?
  154. Cut&weld egr connection on FLP header?
  155. MAF / Tunning?
  156. SLP Headers install question
  157. Which pullies???
  158. I NEED MORE POWER!!!!!
  159. Need a picture of installed fuel injectors
  160. tsp lid compared to slp
  161. i am FRAGGIN pissed off about EGR!!!!!!!
  162. Egr Removal?
  163. LS1 underdrive pulley....
  164. My Exhaust *DELETED*
  165. I have a serious problem,,,, help please
  166. Ported TB Question
  167. best throttle body
  168. AC ???? HELP!!!!!!!!
  169. WHICH HOOD WILL PERFORM BETTER?
  170. velocity ported LS6 heads vs. S2 5.3
  171. "X" vs "H" Pipe Discussion
  172. which epoxy to use on TB
  173. ASP Pulley Question
  174. Sold borla...now guys says it won't fit
  175. Help...89 S10 blazer won't start
  176. BBk Throttle Body???
  177. How to modify stock thermostat to 172* or 160*?
  178. What kind of "can" are you using for a catch can?
  179. Concerning "Greddy" oil catch can
  180. A.I.R.. block-off plates
  181. tuning needed after ASP pulley install?
  182. Stealth Air Box Question
  183. Are headers that loud with no exhaust?
  184. cats or no cats?
  185. I NEED A PART###..
  186. How to maximize power out of my 422ci hydraulic?
  187. MSD 6AL hookup?
  188. release date for jpr electric water pump?
  189. help with bolt ons
  190. Header dent, anyone know who can fix it?
  191. air box lid help!!
  192. Easy, BUT STUPID Question
  193. SSRA Super Sucker Better Than Other CAI Systems?
  194. Spintech mufflers?
  195. Where to get TQ wrench with a degree gauge?
  196. headers?
  197. Installed ASP pulley today: Impressions
  198. Why is there oil in my intake?
  199. FLP header clearance, please help me out
  200. throttle sticking problem!!
  201. cats/y-pipe much gain
  202. suggestions on dumping cats
  203. Where To Find ASP Tensioner Pulley?
  204. What HP will a Granitelli MAF Support?
  205. K&N gasket question
  206. I was a TB skeptic....
  207. LS6 intake
  208. LS6 intake/EGR question
  209. Does anyone have any info on the Cartek intakes?
  210. ASA Cam Question.
  211. QTEC leaking need help!!!!!!!!!!!!
  212. will headers affect wiring?
  213. IMPORTANT!: All with aftermarket headers come in..
  214. Going to order Kooks but what about the Y...
  215. LS1 Hot Cam
  216. foglight +highbeam mod
  217. Where is the crank position sensor
  218. Polished Holley aluminum intakes in stock!
  219. descreeing MAF with SLP IAT sensor
  220. Coolant hose being worn away by waterpump pulley
  221. serpentine belts??
  222. Exhaust is too loud, need some advice on mufflers?
  223. Harlan Shift Light Question??
  224. car wont shift please help
  225. Opinions WANTED!!!!!!!!!!
  226. Upgrades to car, awsome performance.
  227. Wiring up A/F Ratio gauge. Got a question.
  228. Anyone running TTS headers???
  229. FTRA on a WS6
  230. Is there one lid thats better than the other?
  231. Attaching Y pipe to I pipe
  232. 2002 SS centered exhaust
  233. weird noise around 5000 rpm
  234. gone thru 10 O2's PLEASE HELP!
  235. Best place to get Hooker long tubes with y-pipe???
  236. Catch Can install/config.. will this work?
  237. Lead proof 02 sensors working
  238. Pully clearance question (stock pully)
  239. Underdrive pulley-should I or shouldn't I?
  240. How many inch lbs = 1 foot lbs??
  241. Screeeeeching noise
  242. upgrades for LS1 SPARK PLUGS?
  243. borla exaust question
  244. got spanked- need help!
  245. TSP lid
  246. horsepower est. and 1/4 mile times with boltons
  247. Need help please 02 sims
  248. Borla Pro Xs
  249. Backfiring at WOT in high RPMS
  250. Solid Motor Mounts
