PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 [320] 321 322 323 324 325 326 327 328 329 330
  1. Want to build Fuel system
  2. mass air flow unit
  3. what size is the ypipe for the hooker headers?
  4. anybody running MAC ORP with magnaflow catback?
  5. In Line or In Tank fuel pump questions.....
  6. If you have an SES light and no scanner.
  7. Can someone point me to where I can buy the Metco breathers everyone talks about.
  8. Ported Throttle Body, can you SEE the difference?
  9. Headers
  10. External Fuel Pump
  11. Oil pressure and fuel pressure: Where to tap in...
  12. electric cutout ?
  13. Paging Nineball
  14. anybody besides lpe make an egr kit for the ls6 intake?
  15. new SLP long tube headers!!
  16. INJECTOR SIZING, WHAT ARE YOU GUYS USING?
  17. Question about LT installs.....
  18. 160 powerstat...
  19. SES light after Hooker LT install...
  20. what's needed 2 intall ls6 intake on 99ta?
  21. Getting ready to install LS6 intake
  22. How i can port mac headers ?
  23. Does Y-Pipe Fit???
  24. a/c down?
  25. Does anyone sell pre-fab over-axle pipes for our cars?
  26. How restrictive is Borla w/full block-off plate?
  27. coolant question
  28. ported throttle body sticking!!!
  29. no catback?
  30. y-pipe hitting drive axle
  31. Having a problem please help
  32. Problem with car shaking/surging
  33. Is this a LS6 intake?
  34. What should be my next mod??
  35. timing advance
  36. Electric Cutout Quest
  37. What should my gap be for my TR-55's???
  38. Fuel Cut-Off switch?
  39. If a plug wire is bad...
  40. Intake Questions
  41. anyone know asp website
  42. gmmg with headers
  43. BANGING BANGING BANGING!!!
  44. HOW MANY PEOPLE USE K&N AIR FILTER OR HOLLEY /OTHER
  45. Anyone gained from a SLP LS6 Intake?
  46. Sound bytes - Warlock and ONYXSS
  47. Pics / sound of GMMG.........
  48. Orlando area CORSA / GMMG owners
  49. Nuzee & OldSStroker thanks
  50. anyone ever installed 2 cutouts ?
  51. how do i recharge my AC?
  52. swapped mufflers,did i lose power?
  53. Where is the Water Temp. Sensor?
  54. NEED HELP FAST!! car wont stay running after head replacement-
  55. Where is a cheap source of mandrel bends?
  56. spark plug ?
  57. drag radials..which do i get?
  58. Any flow difference between the dual/dual and the 2OTL?
  59. synthetic oil drain intervals?
  60. Help! Anyone with Z06 MAF?
  61. What is the best bang for the buck long tube headers?
  62. Newbie here, a few dumb Qs
  63. LS6 intake ques.
  64. Descreening MAF
  65. What do you think my next go fast 'bolt on' should be...
  66. why is it that!?
  67. Help! Car is missing at full throttle.
  68. OK 4.10's or LS6 Intake?????
  69. Gutted Cats
  70. Need to Quiet LT-ORP-Corsa Setup W/O Power Loss
  71. Meziere Water Pump let's figure it out
  72. Paging Bret Bauer, Bauer Racing Engines
  73. what is rasp?
  74. Some pics of my new exhaust
  75. NEED TO GET RID OF RASP!!
  76. Throttle cable adjustment w/ Traction control.
  77. Gear question
  78. silly header question.
  79. Looking for folks with an aftermarket cam in all stock engine
  80. Car troubles again....HELP!
  81. Gauges
  82. Holley Powershot for my SS
  83. dual cutouts on orp, how far back from headers?
  84. LT headers need tuning?
  85. Best Headers
  86. Any increase in mph/et/dyno #'s from anyone with the new Air-box??
  87. Off-road Y-pipe
  88. Would a Ram Air hood give me much HP?
  89. short belt part#
  90. Strange rattling sound coming from exhaust....
  91. LT1 plug wire help
  92. Help W/ True Duals On a Convert.
  93. Ultimate Exhaust Topic
  94. shorty's or stock manifolds
  95. Will 00 MAC headers fit on a '01 car
  96. GMMG vs CORSA
  97. SLP LS6 intake ?
  98. Inline pumps
  99. Any problems with gutting cats?
  100. FLP Rough on Car!!!HELP
  101. Paging Mike from FMS>>>>
  102. Spark Knock with my ASP Pulley...
  103. my dyno numbers with mac headers
  104. What plugs and wires should I get?
  105. piller mount gauges?
  106. 50#'ers + Walbro 340 Enough for 600rwhp?
  107. Those Without Ram Air Hood But Want Ram Air Come On In
  108. Going to the muffler shop soon, would this sound good?
  109. Shift light install?
  110. SFI Flexplate?
  111. Problem with Direct Flo Lid and SLP Bellow
  112. K&N FILTER HP GAIN?
  113. A MUST do for all Mac owners......
  114. How do you know if you have a bad coil pack??
  115. automatic camaro
  116. Hooker headers?
  117. !@#@)(*&!Stripped out fuel pressure test port!!!
  118. Hooker LTs vs. SLP LTs (videos)
  119. Hooker L/T's on Stock LS1
  120. 02 and 01 WS6 Exhausts
  121. Headers
  122. misfire at idle
  123. moving fuel pump outside
  124. Hooker Headers with what size Y?
  125. Smooth bellow
  126. Deleting the EGR valve.. questions...
  127. Car "shakes" at idle with new exhaust....
  128. IMPORTANT OIL FILTER QUESTION?
  129. FRAM OIL FILTERS VS STOCK
  130. Anyone else overheating with FTRA installed??
  131. Stock Y pipe porting
  132. What's that smell??.....After LT/ORP install
  133. Porting cast iron manifolds
  134. What's the Difference Between Chambered and "Regular" Cat Back Systems?
  135. FLP V-Flange Clamps
  136. Denso Spark Plugs, please come in
  137. SLP bellow kit, waste of money??
  138. St ock w/80 series vs Corsa?
  139. Anyone else lose torque?
  140. Stock GM y-pipe vs SLP y-pipe?
  141. hooker lt's, will they fit?
  142. In dash error code.
  143. I can hear my fuel pump buzz...WTF?
  144. Macs on, Temp up..
  145. Car shut off as I was driving. Fuel pump?
  146. Hooker Exhaust video clip!
  147. Question on true duals
  148. slp dual/dual power gain?
  149. recharing the Air conditioner
  150. Problems after pulley install
  151. Electrical Problem: Any Suggestions?
  152. Hooker LT's, what do i need for 01 LS1
  153. MMS Throttle body, help ASAP, Advice :\
  154. GMMG Chambered exhaust....
  155. Emergency Questions on advancing timing
  156. Turbo Technology kit VS LS1 Motorsport kit
  157. LT1 vs. LS1 exhaust sound
  158. Very serious NEED HELP
  159. CORSA vs other exhaust(for my SS)
  160. Intake Manifold & Valve Cover gasket P/Ns ?
  161. LS6 MAF on an auto
  162. Which exhaust to get for the most power?
  163. How well does LPE adapter work for adding EGR to LS6 intake?
  164. stat from stock
  165. Which calibrated MAF to get
  166. Stainless Steel Headers
  167. Pics of My SS inside
  168. Who has an ATI harmonic balancer?
  169. will this grill mod work on a 2000?
  170. Intake Manifold Plenum Volume...............
  171. oil filter question
  172. THERMOSTAT INSTALL PROBLEMS
  173. anyone heard of Stainless Works headers??
  174. Ported MAF housing and Ported TB?
  175. Headers installed...IDLING VERY ROUGH!! SES LIGHT! HELP!
  176. Bolting these on. Possible 12's?
  177. Question about Dynatech Long Tubes?
  178. What are the part #s for belts used with ASP pulley?
  179. Custom made headers
  180. Custom intake inlets:
  181. Need part# for short belt with stock pulley???
  182. MTI Air Lid question.
  183. Need Brian Green site
  184. hooker aerochamber before the axle?
  185. LS6 vs. Holley
  186. LS 6 Intake Manifold part # vs. casting # ?
  187. Direct-Flow lid from LS1 motorsports!
  188. EXTENDED OIL FILTER ANY BENEFIT?
  189. REDLINE ON LS1?
  190. Airbox opening
  191. What is this connector for?
  192. cleaning fuel injectors when off car?
  193. Cat back?
  194. P0430 what are the options?
  195. Need info on how to get to the ignition tumbler and switch.
  196. is fuel injector cleaning recommended
  197. Hooker LT's w/ORYP and Corsa exhaust
  198. HP GAINS WITH BORLA/MTI LID/K&N
  199. O2 sims failure or something else?
  200. 2003 cobra h-pipe
  201. Windshield wipers are screwed up
  202. Anyone running Cats into straight pipe?
  203. Cutout - cable or motor options?
  204. Flowmaster Catback
  205. How to cool engine down?
  206. Hookers and dropping engine
  207. Hooker Catback with Hooker LT's
  208. ls6 intake install questions
  209. Part # and where to buy Dynomax Bullits for true duals
  210. off road y-pipe vs. long tube headers
  211. TBB Mod...I need help deciding if it's worth it or not!
  212. 6.0L heads and headers
  213. NEED HELP PLEASE!
  214. I have an ice maker under the hood (ac)
  215. AIR system removal
  216. Question about stock MAF screen
  217. y-pipe banging
  218. Aftermarket TB or no aftermarket TB?
  219. PCV mod,restricter plate....
  220. 1 5/8" headers & H/C motors
  221. y pipe hitting the tunnel brace????
  222. Question about DrGas Xpipe "kit"
  223. Should I descreen My 85 mm maf?
  224. Low hanging Y pipe
  225. Loose hose after mod install
  226. Air Lid & filter ?'s
  227. Do i need an MAF translator?
  228. Spark plug question
  229. Asp crank pulley
  230. Hooker cat-back? Need help
  231. 02 Sensors
  232. Welcome The New Forum Director
  233. LS1 Air conditioning Recharging
  234. Do I need to upgrade my fuel system?
  235. Fuel Pump for 98 LS1 Z28
  236. Radiator Fans ??????
  237. Are GROTYOHANN headers stainless steel?
  238. GODD@MN Grot headers
  239. Porting Holley Intake??
  240. Exhaust Question, not the usuall catback BS
  241. Fitment question about Hooker headers
  242. why would removing the pcv system be a bad thing?
  243. Post your pics of true duals in here
  244. Where to hook up coolant Temp sender
  245. FLP or Hooker ?
  246. 98Camaro with 02 Z06 Engine -Maf question
  247. True Duals - any measurable differences
  248. I need info
  249. Are 98 Exhaust manifolds different than 00's???
  250. Hooker Muffler!!!
