PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 [148] 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Identifying Heads LSX
  2. MTI or Ported ls6 throttle body?
  3. Bang for my buck...
  4. Is this an ls1 or ls6...
  5. front 02 bung/install
  6. Any homemade BGRA's out there?
  7. Oil Cooler
  8. which cam
  9. Anyone Running Tsp Ory
  10. slp mass air and smooth air bellow
  11. Cam / Rockers / Rods / Tune - cost?
  12. where can I find a clear intake lid???
  13. 2 Rear Intake Sensors???
  14. Meziere Install Problem? Opinion Needed
  15. Gauges Question
  16. Need Help wiring up LS2 TB in 02 Vet
  17. LS6 intake
  18. !EGR and !AIR mod : SNIFFER TEST
  19. Is this a Shaner tb? If not, how's it look?
  20. pacesetter or flowtech long tubes????
  21. Coolant bypass is smelly?
  22. Ideas for Best header/exhaust/cats setup?
  23. Not using correct bolts for your FAST intake = broken intake!!
  24. Easiest way to install oil temp or fuel pressure gauge?
  25. Resistance of stock plug wires
  26. BBK throttlebody...help?
  27. Having trouble removing front O2 sensor!
  28. Question about Cats/Sensors
  29. is a lid worth the money?
  30. Serpentine Lubricants
  31. Sticky???
  32. Are these interchangable?
  33. When does the Fast intake become a restriction?
  34. xs headers and a catted y
  35. header install Question
  36. jet hot or ceramic coated headers?
  37. average gain??
  38. are cutouts illegal to have on are cars
  39. what type oil
  40. Is it possible to find a LS6 intake at a junkyard?
  41. LS1/6 Intake onto a 5.3
  42. FAST 90/90 question
  43. Lowest possible coolant temperature?
  44. boom tubes!! help me pick setup!
  45. Stock LS1 exhaust mods
  46. what should i soak???
  47. Magnaflow or Loudmouth 2 cat back???
  48. Where can I get 3.5" Stainless
  49. What all do I need for LS1 to LS6 intake swap?
  50. what do i need to stay cool???
  51. LS6 Intake vs. LS1 Intake
  52. Professional Products Manifold and Throttle Body
  53. Spark Plug Heat Shield Help
  54. Air Filter distance from motor???
  55. New Bellow Not Fitting
  56. Xs Header Install
  57. Looking for REAL FAST 90/90 Flow #'s,,
  58. cutting cats off.....
  59. qtp header install....
  60. Best cat back w/ Kooks long tubes?
  61. Question for anyone thats installed a Pacesetter y-pipe lately.....
  62. thinking about switching from QTP to ARH
  63. egr on 02ss
  64. Do you have to remove headers for poly motor mount install?
  65. cheap pacesetter headers
  66. Dynomax bullets V. Magnaflow cat-back
  67. throttle bodies?
  68. msd wires
  69. LT1 vs LS1 radiator pics
  70. FAST 78mm TB?
  71. Cats smoking?
  72. Anyone switch from Flo-Pro Twisters to ST's or vice versa?
  73. serious brake issue tonight...questions.
  74. How loud will this be?
  75. borla stingers on a TA?
  76. Slack in the throttle cable??
  77. Baker Precision Hose...
  78. Older ASP pulley and double roller. How much to machine?
  79. Exaust Question?
  80. SLP lid fitment issues?
  81. Simple Question about headers
  82. ls1 gurus
  83. Help: Overheats With Ac On @ Hwy Sppeds
  84. SLP Intake!!
  85. Gaskets for LSX ????
  86. For those considering TD setup
  87. header bolt length
  88. Loud Mouth Tip Size?
  89. shops for TB porting
  90. Question about EGR AIR removal
  91. Holley Wieland LS6 manifold
  92. STOP GRINDING for Long Tubes
  93. LS7 heads for my LS1
  94. Getting new heads, which header bolts should I use?
  95. best intake manifold
  96. Looking to upgrade my existing headers?
  97. what would you do?
  98. what would you do?
  99. Common For O2 Sims To Go Out?
  100. Help!!! possible flywheel or starter issue?
  101. Throttle Body hole
  102. running rough after LT install
  103. Free Ram Air Mod??
  104. Anyone installed an oil cooler?
  105. Should I trade my XS ORY for a LS6 cam and springs
  106. ported fast intake ????
  107. Do you guys burn oil?
  108. GMPP, Edelbrock or 4150 style users check in.
  109. Best MAF?
  110. What do I need for ram air????
  111. AutoMeter water temp guage install
  112. Grinding sound from front engine.
  113. Kooks Header Install
  114. TSP Rumbler catback
  115. LS1 Sounds couldn't help me.
  116. thermostats????? somebody chime in ????
  117. How I killed the highway drone (and some of the power benefit) of my Corsa exhaust
  118. Cats or no Cats
  119. should i use an LS2 or LS6 intake
  120. Am I missing anything?
  121. Will this cause any problems?
  122. Weiand intake manifold install
  123. Rear o2 plugs?
  124. What are your thoughts about this? Good deal?
  125. Anybody install a Autometer 5350
  126. Somethings leaking
  127. XS headers and y pipe review
  128. Pulley install instructions?
  129. Knock sensor install question
  130. MAF Adaptor
  131. want to know what all needed
  132. Oil Pressure too High?
  133. Looking for True Duals intall pics and instructions.
  134. LS6 vs LS2 intake -- how to tell the diff?
  135. Rasp Thread
  136. What to do for throttle cable bracket when putting LS2 intake on LS1 Camaro???
  137. GM Part # for rear main seal?
  138. Adequite yet quietest possible muffler for big CI n/a engine?
  139. single plane intake manifold
  140. How do you remove the A/C?
  141. Edelbrock SDT muffler...
  142. Breaking in a magnaflow muffler ?
  143. Stock Y-pipe Question
  144. Hooker Cat back vs TSP true duals
  145. water temp and oil pressure gauge install help.. search no help
  146. '00+ owners - quick air breather question?
  147. L76 Intake
  148. straight pipes
  149. true dual setup?
  150. catback?
  151. Throttle Body Bypass
  152. 3 inch cut out placement
  153. just ordered wires
  154. Manifold plug
  155. 98-99 vs. 00-02 Headers?
  156. epoxy/filler for intake port matching?
  157. exhaust leak help
  158. cam install-un pulley question
  159. Innovative or AEM wideband
  160. done cut -out
  161. Finished my LS6 Intake install
  162. Stock WS6 catback vs. Hooker catback?
  163. HELP! 12" or 24" O2 extensions???
  164. Am I outflowing my exhaust?
  165. NW TB pcv port question?
  166. Replaced AIR pump and still making Noise! Help!
  167. Cheap Exhaust Idea
  168. slp lid as good as any?
  169. Holley Powershot
  170. Which lid do I have?
  171. porting fast intake
  172. Installed fast 90, got a quick question.
  173. opening up stock LS1 intake?
  174. Borlamouth/ Borla XR1 questions
  175. Mac header suggestion?
  176. Head swap....how hard?
  177. driver side radiator mounting question? (00 z28)
  178. Might build my own headers, but I have a few ?s
  179. advantages of using 02 sims over nothing?
  180. Help Wiring Up MSD Injector Plugs
  181. EGR Delete now too lean
  182. Catch can with a breather on top?
  183. stock headers and true duals ?????????
  184. Coil Question/Part #
  185. arp crank bolt socket size????????
  186. What tool are you using to torque down your intake manifold?
  187. silverado y-pipe Question
  188. Launchin N Da Dark? AHHHHH
  189. Advantages of going carbed
  190. Weird Ignitioin Problem- Need Help
  191. KOOKS new 2" race header
  192. Hood/Cowl notch for Vic Jr Efi, pics please
  193. so i just picked up a mezire water pump ... RWHP??
  194. Ls1 truck mass air flow benefits?
  195. Help me after intake install throwing a code!!!
  196. Which LS1 engines used Power Steering Pumps made by ZF?
  197. post your SS or Z28 engine bay pics.
  198. TSP Rumbler Picture help
  199. Back to a stock catback <for now>
  200. MSD wires...worth it??
  201. Port TB
  202. TSP LID's STILL FOR SALE!!??
  203. Pics of my Kooks 1 7/8 headers installed Pics!
  204. Hooker catback crew
  205. slp flowpac
  206. New exhaust sounds nothing like I had hoped
  207. Anyone with Coil Relocation
  208. Cam Only??? Ms3??
  209. Before heads/cam - what am I missing?
  210. Come Quick!
  211. Is it worth it getting a corsa catback?
  212. cam question?
  213. throttle body
  214. Starter tab broke off!
  215. quick question on FAST 9090 install
  216. Need you opinion on Cylinder Heads- Winter Project!!
  217. throttle cable
  218. How much hp does alternator tie up?
  219. Can I put wideband O2 in place of stock O2?
  220. looking for specific battery holder
  221. exhaust question... borla or corsa???
  222. Does anyone make a longer ls1 spark plug wire?
  223. Air filter attached to MAF??
  224. Need part # for LS2 TB Seal
  225. SLP Dual/Dual Tailpipe Hangers
  226. still haven header trouble
  227. Anyone have any pics of camaro with Magnaflow catback with the quad 4" tips?
  228. Cleaning MAF
  229. Header Idea
  230. LS2 TB To LS1 Intake
  231. name/function of this line?
  232. Car voltage and fuel pump question
  233. What exactly is the differance between the 98-99 TB to the 00-02 TB?
  234. Where to buy 3 bolt flange for stock exhaust manifold?
  235. SLP Air Box Fix
  236. need help with coil brackets
  237. Cam install/PCV WTF
  238. LS6 Intake Install - Any benefits to leaving the stock coolant lines?
  239. wtf is this plug for?
  240. Exhaust
  241. help in removing the a/c crap
  242. Did I buy the right injector o-rings??
  243. Exhaust Question
  244. hissing noise from D wheel well
  245. High RPM, full throttle pining/detonation
  246. part # for front 02 sensor?
  247. Exhaust suggestion
  248. My car surges up and down.
  249. Someone Sell Bo White a Darn TB for a 99 z28!
  250. wideband bung location?
