PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 [199] 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. air lid info
  2. Corsa Exhaust.
  3. At end of summer what should i do?
  4. Electrical charging problem???
  5. Where to get ARP header bolts??
  6. Ported TB
  7. Help! Quick!
  8. Questions before Install of TSP?
  9. Egr,air pump removal & power gains?
  10. How long should High flow cats last on header install with no dyno tune?
  11. Coil relocation guys step in
  12. firebird cats
  13. Underdrive pullys, which one?
  14. What is the little vacuum fitting on the back of the intake for?
  15. is 98 pcv system different?
  16. difference of headers
  17. Ported LS2 TB
  18. GMMG ordering
  19. cut-out question
  20. can you put an ls1 intake on an lt1
  21. ls2 intake on an ls1
  22. What exhaust is this?
  23. Need numbers for GM parts,Crossover tube and plugs for a LS6 Conversion?
  24. Passin the sniffer
  25. Corsa Tips?
  26. Anyone tried car chemistry inserts!
  27. HELP! LS6 Intake swap. Motor Revs High!
  28. Part Number for Brake Reservoir Cap
  29. how to remove dipstick for header install?
  30. What exhaust do I have??
  31. Bigger TB + Old Lid?
  32. Need Help With Headers!
  33. Any theories or ideas?? Area behind license
  34. Help picking and air cleaner
  35. LS1 Belt Questions LS1 NEWB
  36. My K&N filter has 40k miles on it....should I buy a recharge kit, or a paper filter?
  37. Modded my ram air
  38. Vette rear o2 sensor $180 each!
  39. High flow cats....
  40. Anybody seen those xs headers on EBAY?
  41. 18 inch bullets with turn downs
  42. Ok, now before I go out and buy this....
  43. Jethot Y Puipe
  44. What to do with the rear O2s ???
  45. tb spacer?
  46. offroad pipes for 02?
  47. Best sounding/performing exhaust with STOCK y-pipe and headers
  48. Qtp problem...need help please!!!!
  49. Intake manifold question
  50. I need a new Alternator?
  51. Will the Borla 14464 fit a 2000z28
  52. Headers
  53. how much?
  54. slp longtubes with y pipe
  55. Whats this
  56. will my 90/90 FAST NW set up SLOW ME DOWN??
  57. LS1 = Bolt on Badass????
  58. Which Slp Lm Is Louder I Or Ii
  59. Is it posible to take off the I pipe without cutting ?
  60. new muffler
  61. headers and y pipe will it be a big diff
  62. flowmaster vs. hooker
  63. TSP Catted Y
  64. Here's my Pacesetter LT's
  65. Converting a 78mm Fast Intake
  66. Raced 04 Mach 1 but..
  67. 85mm Granatelli MAF, I have a dyno tuning coming up, should I have got a ZO6 instead?
  68. PaceSetters for GTO's
  69. Longtubes for 69
  70. Piks of duals run out back
  71. Idle setting with NW90
  72. Water got up to intake. What now? ALL Diagnostic Trouble Codes (DTCs) INSIDE!
  73. What could be used to quiet down a true dual setup?
  74. Performance Shops in Central TX????? EXHAUST HELP!!!
  75. New intake bolts for FAST 90...
  76. Exhaust Setup in Progress...?Advice?
  77. Ok, hopefully my last exhaust question...
  78. lm exhaust pic
  79. GMMG or True duals?
  80. Thinking of Selling My Y-Pipe w/ High Flow Cats (What's it Worth)?
  81. cleaning MAF
  82. crank pulley problem
  83. Any one try these
  84. QTPs - standard vs. HVMC...
  85. cutout life
  86. Porting Pasesetter Y
  87. Finshed my new air intake!
  88. Just wondering is this is true about dual cutouts?
  89. Fitting Under Driven Pulley
  90. slp air lid install
  91. ??true Duals??
  92. hooker headers???
  93. slp lm vs tsp rumbler 3"
  94. Throttle body cable question..
  95. best intake?
  96. Figured out my exhaust isn't stock after all...
  97. Car is getting a lot LOUDER...why?
  98. Jet Hot emissions
  99. whats the difference b/w the lm muffler and dynomax
  100. Help
  101. whats the loudest exhaust
  102. when do you need bigger injectors?
  103. Need Some Help Quick
  104. Ls6 intake swap....plugged egr hose with JB ?
  105. Knock Sensor harness
  106. Ok for tips to touch bumper cover?
  107. Carb. Vs. LS6 intake on LS1...
  108. slp lm 1 replace resanator.
  109. Poll: Ever had or heard any rasp with a Magnaflow?
  110. Will tune get me past sniffer test.
  111. what bellow to use with FAST/NW 90/90?
  112. Borla vs GMMG w/ H/C
  113. Corsa Dual Knock off's vs SLP Original CME?
  114. GHL exhaust for 99' Camaro???
  115. headers for a 383
  116. Installed loudmouth, now SES light
  117. Header capped itself a hole in the runner tonight!
  118. a little help please
  119. What size of O2 extensions for Header install ?
  120. exhaust cutout on my tahoe
  121. SD people, talk to me
  122. swap plugs- then misses/surges at idle??!
  123. Mounts for transmission and motor
  124. Do I really need the SLP header Install kit? SLP LT Header owners inside please?
  125. Hooker catback sound (noise level mostly)
  126. QTP/Y-pipe/Cutouts
  127. 90 Fast/90nw + Lt Ory Pacesetters + Tune
  128. HELP THIS LOOKS DIFFERENT THAN my stock ls1 intake is it the ls6??????
  129. ram air box is it ok to cut out for cold air????
  130. Headers vs starter
  131. Installed the Magnaflow...
  132. flow master's and headers
  133. pacesetter headers and y pipe?
  134. TB cable problem
  135. who makes this......
  136. will these work together ?
  137. New mods!
  138. BIG THANKS to QTP
  139. Aluminum motor noob?
  140. Vette and F-body Starters
  141. Wow Come Inside!!!!
  142. how easy is it to port my TB
  143. kooks or QTP?
  144. Rusty Exhaust
  145. TSP Rumbler 2.5" or 3'?
  146. Need a good heat shield (cutouts too hot)
  147. True Duals with 3" Borla
  148. Exhaust Manifold Gasket Part Number
  149. Read O2 sim & header FAQ, but still have ??
  150. ABS INOP light came on after header install...
  151. has anyone used these?
  152. Side-exit duals...
  153. Harmonic Balancer
  154. What's the catch?
  155. TSP y-pipe: cats or no cats
  156. I need CME tip demensions, help me out
  157. Couple of questions about what the guy at the shop said / Exhaust options. *Merged*
  158. kook's Header's and O2 sensor's ??
  159. pacesetter headers
  160. limits of stock manifolds?
  161. Is there a way to monitor whether an elec.H2O pump is operating or failed?
  162. my used headers
  163. 98 Camaro Intake in a Vette?
  164. Cme
  165. Possible to run rest of piping for TSP Duals?
  166. Will TSP TD work with UMI trans mount adj. torque arm ?
  167. Are opti spark plug ends the same as LS1 coilpack ends?
  168. PS Headers and Kooks Y-pipe, compatability?
  169. after o2's
  170. Header gasket question
  171. You can stone me, but dont hit my car!
  172. how do u knw if ur motor mounts are going bad
  173. What does everyone think of hooker headers
  174. X and H-piping
  175. SLP loud mouth 2?
  176. Exhaust advice
  177. where to find ls1 mani. bolts
  178. What's The Difference Between 2otl and Dual/Dual
  179. Pics pics pics
  180. Front of engine oil leak, what seals should I replace?
  181. LS1 Header questions
  182. OEM Formula Exhaust??
  183. Can I pass smog with bad cats?
  184. Connecting xpipe to headers?
  185. header pics please!
  186. Headers and lowered can dont go together
  187. TSP Rumbler noise level?
  188. hooker LT'S and TSP TD's needing installd
  189. What muffler to substitute for LM1 resonator (don't want the normal response)
  190. intake manifold
  191. TSP ORY and SLP LTs
  192. I can fit 1 finger between tire and fender...am I screwed for exhaust clearance?
  193. Help with slight confusion
  194. Question for Borla Adj CB Owners...
  195. Pacesetter vs Kooks pic
  196. How much is a MAF gonna cost me?
  197. Header question?
  198. Headers installed!
  199. Exhaust pipe kinked from clamp
  200. Poly Motor Mounts
  201. Tranny removal with longtubes
  202. Question - What is this part?
  203. Header and steering linkage... i think
  204. cheapest true Dual
  205. Intake manifold question
  206. Best Combo with SLP LM Cat back
  207. idle issues please help
  208. Best exhaust setup (with sound please)
  209. Can stock fuel rai be used on Wieand Intake?
  210. removing engine?
  211. Flowtech Cuttout
  212. Do I need to get my fast 90 intake ported?
  213. How to clean O2 sensors?
  214. Dr. Gas 3" X 2..5"..........
  215. LS2 vs. LS6 intake manifold
  216. Alternator Pig Tail
  217. Debating on going with duals...need some opinions
  218. Y Pipe hitting, what rubber cushion do you use?
  219. could i port my own tb?
  220. Solid Motor Mounts on 6 liter Block?
  221. I'm Sam1 from the middle east 700Hp is my target
  222. I'm sick of hearing this....
  223. Plug wire and header clearance...
  224. Exhaust upgrade?
  225. More power??
  226. 160 degree thermostat increase speed?
  227. hand ported TP turned on check engine light
  228. Who here has installed SLP LT Headers? Any tips or info appreciated!
  229. Best headers (1 7/8 ) for lowered f-body
  230. Do I have this cutout on right??
  231. Starter Problems
  232. Kooks vs. PaceSetter ~ Installation and Fitment question
  233. Book time for motor mounts/exhaust.
  234. Has anyone actually had a FAST 90mm TB work as advertised?
  235. guys who sells oval piping?
  236. noob buying lt headers
  237. What Metal for X-Pipe?
  238. How much power with a qtp cutout?
  239. swapping 98-99 tb cam to a 00+ tb?
  240. Raptor Ram Air Hood functional air kit..
  241. Would my car benefit with 90/90
  242. Cruise control
  243. 6 Liter Block Problems Bolting Up Alternator...
  244. Stock TB flow
  245. MOTOR PLUGs..GUIDE PLUGS...??
  246. Nothing too good for my LS1 lol
  247. Ls6 Intake on to a 99 egr block off ?
  248. header bolts and gaskets from speed inc
  249. problems with qtp y-pipe
  250. GMMG fit on a borla I pipe??
