View Full Version : Generation III External Engine
- SLP Radiator Porblems?
- Compatibility of vette engine vs. Camaro engine.
- Pulley bolt from hell.
- sounds a little weird
- PS cooler and SLP CAI interference?
- Annoying exhaust rattle at idle (Broken Cat?)
- Oil Sensor is not wroking right.
- Changing to True Duals REAL soon
- Stock Exhaust
- This all I need for ASP pulley, or do I need a Balancer bolt?
- gmmg exhaust considered a street legal cat back?
- H/C Install, which injectors to upgrade to?
- Car wont crank help
- Best Bolt on Mods for 2001 C5
- electric exhuast cutouts
- Welding for LM
- I'm giving up on my Blowmaster...
- installed my bullet muffler today
- Evap Problem
- Exhaust and Steering Column
- Could a makeshift 85mm airlid be made...
- Are the foam Pieces on the bottom of the intake really nessasary?
- LT's to stock exhaust?
- pricing on kooks?
- belts jumping
- New Bbk Ssi Intake Info!!
- LSX FAST intake leaking... help
- My SES light is on.
- scraping
- Sold the Borla and got some ?'s
- Where can I get the silver foam pieces that are on the bottom of the ls6 intake?
- Race Hose Sizes
- Do I have to have O2 sims?????
- smoke out the front after header install?
- What gains with Kooks on stock motor??
- Headers,True Duals, weird 1/8th times??
- True duals and bmr extreme T/Q arm
- How do you like your catted y-pipe ?
- 98 Y pipe same as 2000 Y pipe?
- FTRA install......
- TSP True Duals are on.....ho-ly-shit (few questions also)
- Idea for ORY 3'' dump
- LG headers & catted pipe,is tune a must???
- Engine noise at and above 2000 rpms
- Smog on Macs w/ Vortec
- BGRA guys, whats your experience?
- Exhaust flow for big HP?
- Anybody looking for AIR and EGR block off plates come on in
- True Duals
- Headers ORY-pipe + what catback for no rasp/drone?
- doing my intake swap, need to know what this port is?!
- fast 90mm tb issues fixed?
- plug wire againest header
- Help Please! SS Won't Start
- which headers are right for me
- True-duals to a cat-back?
- Bolt ons and SOTP difference
- do i need new injectors??
- True duals ???
- can someone please help me on these part numbers?
- Shaner Tb
- 1 cat instead of two
- How much clearance at your lowest exhaust point? 4 fingers w/TSP ORY here.
- cutout install location question
- Anyone Removed Their Baffles?
- SS SLP stock exhaust better than z28 stock exhaust for a 2000z28??
- Grotyhan Headers?
- Best Cheapest Underdrive Pulleys?
- Self-Circulating catch can.
- Header people Quick Question?
- under the axle duals
- How much power to be gained?
- Those with HEADERS & LOUDMOUTH
- Headders - will I need o2 extensions?
- LS1 in a TVR
- AMW catch can install location
- squeaking at start up, then disappers..
- this will be interesting
- Jethot Catted Y pipe
- Who does custom exhaust work?
- TSP duals vs. Y-pipe w/ cutout - power ??'s
- oil filler cap
- tune after headers
- Need a little help
- Bad 02's?
- Help with Headers On FireHawk
- Stock y-pipe ( pics )
- preping edelbrock stepped headers
- New O2's Worth It?
- Electric water pump, worth the money?
- oil still in the intake after catch can
- MTI & TSP Clear lids??????
- Problem after the track today.
- Do I need to replace the intake gasket during ls6 swap?
- Lid and SSRA installed, liking both.
- header question
- Cylinder head grounding bolts
- help.car is tweking wth asp pulley install
- Car is in smog mod: ( How slow am I )
- Pullies cherping like birds!
- lt headers question
- True duals and CA
- Dual 2.25" exhaust too small for 450hp?
- Part # request
- Can This Intake Setup Be Setup Without A Headache?
- LSX90MMT/B & INTAKE vs PORTED STOCK T/B & LS6 INTAKE
- hooker catback??????
- FLP Headers how do they compare
- Gto T/b Size
- EGR Valve
- Help with pulley install
- One quick question
- Just ordered TSP Duals, what mufflers do they use? TSP dual owners inside....
- I'm thinking of putting the cats back on
- Please HELP,Does anyone have a close up pic of their Catch Can?
- should i bother...
- Rumbler-LM comparisson please
- What are good type headers
- LS6 Intake + Ported TB = ????
- Long tubes Installed
- Lubrican for TB and TB cable
- Another TSP duals question.
- To those with cam only setups...
- HELP ... Intake swap > busted sensor > what's it called????
- Coolant Temp Reading
- What Boltons need a Tune?
- yay got my MTI lid
- Which cat-back will produce more HP?
- NEW K-Member anyone seen anything alike?
- New Air Lid/Can't Get IAT Sensor In!
- PCV wire needed?
- Whoa!! Got duals/x-pipe done!!
- How Much Do New Plugs and Wires Help?
- CME tips with borla muffler?
- duals with chambered pipe, and what is a chamber pipe?
- changing plugs and wires on my 2000 z28...
- wetness near the Oil Pan?
- What do use to lube a new ASP pulley
- A/C condensor problem
- My gas mileage sucks
- Third Gen To Ls1 Catback
- Looks like I have to install Edelbrock LT's myself
- clip for power steering cooler, whats the p/n
- Thermostat ?'s
- Go the the sale section for a GP on GMMG!!!
- Not fbody question but LS1
- Bling! Bling! tensioner pulley
- Come check this out! Now this is free ram air!!!!!!!!!!
- Need Help
- I know this ?? is old but, how much power with PS LT's and MagnaFlow CB
- Kooks arrived today
- SSRA benefits for 02 Z...
- Lose low end grunt with exhaust swap?
- Kooks Lt's and TSP TrueDuals installed!!
- What options are there for ready-to-go True Duals?
- Intake Tube
- JH Hooker header install, nice pieces but fitment is TRASH!! (bit long)
- Exhaust Leaks...
- Will i hear any Chop???
- headers
- where is...?
- Using a Battery Tender Plus while storing your car.
- Custom Low Pro HT motor mount
- Cracked primary header...suggestions??
- Anyone have Mufflex's y-pipe hanger?
- accufab 75mm throttlebody
- pacesetter install
- Who makes/sells shorty headers?
- changing spark plugs
- metallic grinding noise
- Need Help, Header Install aftermath
- Front Water Crossover for Throttle Body Neccessary?
- Exhaust question
- center mount
- True Duals or not True Duals?
- TSP Rumbler
- Radio, Tachometer, etc not working
- SLP LT 02 extensions....
- PCV hose question.....
- Starter wire connections
- air silencers removed
- Autometer A/F guage... O2's go bad..
- Weight of a Borla XR1 muffler?
- Underdrive Pulley? which one?
- Qtp, Tsp, Asp
- Part # for TB Blade??
- Where to get 02 sims?????
- Exhaust gains what would be better
- Headlight Arm for 99 TA
- Water pump pulley help needed ASAP
- ls6 intake
- true duals
- If you have a T/A and wanting True Duals, come in...
- Header Install?
- Straight Through exhaust
- QTP HVM LT's, QTP Dual Elect. Y-pipe, SLP 2OTL - First Driving Impressions
- .........custom true duals............
- Clarification on O2 sims and headers...
- Nice touch in the header collector....
- mac header install
- MSD Ignition for an LS1?
- serpintine belt ???
- Ftra ?????
- Sneaky emissions
- y-pipe swap
- dielectric grease
- where can i send my asp pulley to be machined?
- Meziere Electric Water Pump RACE vs Street??
- Egr - Pls Help
- LS2 intake??
- will cats off a 2002 TA fit a 2000 z28??
- header/stock y-pipe question
- Flotech LTs with TSPX Qs
- More issues with Fast 90mm TB :(
- how much HP does the AC use
- TSP true duals....
- Fixed y-pipe banging from Macs headers
- Stock Throttle bodies diff??
- Loss of MPG with volant airbox?
- adding Borla XR1 to cure rasp from LTs/ORY/Borla Cat-back
- Hmm not sure now
- Want to get rid of my cats
- true dual question
- Gutted my cat
- People who have removed their PCV system...
- loud exhaust please
- Non TCS cable for cruise/TCS delete
- What is the second cable?.....
- Flowtech or Pacesetter?
- Anyone made a thunder-mouth?
- Dynomouth!
- BBK 80mm TB, any problems out of it?
- Header Wrap for non coated PaceSetter LT?
- Single wire water temperature sensor?
- Throttle body size vs. power
- Borla or B&B?
- Has anyone done this type of "True Duals"?
- Valve Cover fitting
- 2002 exhaust manifold question
- cutout on a off road pipe?
- Pacesettersand Y pipe are in.
- MAF ends ?
- Sparks on launch; NOT good !!!
- Flowmaster or SLP D/D???
- Need Help...!air! System..
- Just talked to BBK sales dept.
- Dynomax Bullet Race mufflers, or Series 40 Flowmaster?
- Will FTRA inlet fit SLP CAI?
- SLP IAT Module
- Anybody use the dual o2 sim. on ebay?
