View Full Version : Generation III External Engine
- Idle surge
- Best flowing catback?
- 02 Corvette no spark or injector pulse please help
- Longtubes with stock catback?
- GMPP intake questions?
- C5 vette TB
- fast 92/92 on 99 ls1 advice
- side exhaust
- Valve Covers
- Off-road Y-pipe for stock manifolds?
- Short belt mod with 25% underdrive
- trick flow 235
- Dynojet wideband going coocoo
- Switching EGR 99 to 00+
- Oil pan??
- looking for info on ordering hardware and tb gasket for fast 92
- SLP Loudmouth 1
- What's the Quieter Exhaust Setup?
- Pacesetter LT's and Y-pipe
- Is the ATI crank pinning kit the only option?
- Powerbond/Summit UD Pulley Help
- What mufflers for true duels?
- Wire's W/ Headers?
- No code after !EGR
- Ls1 headers
- Intake Manifold Options (best for the money)
- old design slp longtube help.
- Tips on installing heads with ARP studs with engine in the car
- 1999 Firehawk Cutting out
- Typhoon T/B Gasket
- Where to put the sending unit for water temp
- aftermarket Oil pressure guage and stock OPS
- ported fast 90?
- Anyone know? LS1-TA headers on LS6-V?
- how much rpm can my motor take?
- Billet MAF Housing ends
- CAI Anyone Tried These?
- oil pan gasket with umi kmember
- question about what mass air to use with 92/92 fast
- Part wanted
- How do I beat this car?
- 346 piston
- Should i change my timing chain?
- Installed Headers, Now a Ticking sound??
- SLP high flow cats
- Pacesetter Headers!!!!
- New Design SLP header guys come in...
- MAF delete bellows
- fast 90 fast 92
- New y-pipe to old catback..
- fast toys air lid or k&n cold air intake
- Need help/advice with motor mounts
- 1 3/4 OR 1 3/4 to 1 7/8?
- suggestions on plug wires/boot protectors with headers
- Alternator or Battery Woes?!?...
- What Sensor Is This (that I broke)?
- Coil pack question
- Intake Question
- Smoq Q
- Electrical problem with 98 TA
- SLP Airlid
- gutting cats
- Hole in header
- Borla Quiet?
- Flowmaster or Magnaflow
- Stud's on headers?
- Quick question on swaping to ls6 pcv
- Is this a good deal???
- Catch can
- Quick O2 sensor question - rears only for emissions testing?
- !ARP header bolts!
- Which head will yield more power....
- O2 Sensor Question
- 04 truck cats
- Carbed LS3
- victor jr ls1 intake?
- Getting rid of flow master!
- Slp muffler question
- True Duals to Catback. Y Pipe Question.
- FAST Intake Question
- Have to chg mufflers lets hear your thoughts
- exhaust bypass elbow?
- AIR Removal? Pros? Cons?
- idle problems
- So what goodies did ya'll get for x-mas?
- Magnaflows ????
- March Pulley difference
- UD pulley effect cam lope??
- Bracket for stock y pipe?
- EGU removal...im looking to remove my EGU component.
- Speed Density??
- Front are Rear C5 O2 sensor
- Thoughts on new exhaust.
- # inch exhaust clearance
- no spark please help
- ls1 to ls6
- brand new fast 92 issue???
- ls6 intake part#
- motor mounts
- Katech Performance 2009 Catalog now available. Hard copy and downloadable PDF
- FAST 90 w/ my setup
- alternators....
- vic jr. vs LS6 intake
- Cali/EPA guys - BEST cats found 100cpsi
- What makes a good merge?
- Catalytic Converter Break in?
- Are MAF g/sec readings a good indicator of airflow efficiency?
- Need a New Lid (larger)
- **My thoughts on the VOLANT CAI System - PICS INSIDE**
- Just ordered My Vengenace PORTED FAST 92/NW92!!
- !Maf Question
- Tuning a Supercharger with a Vinci/Crane Tuner???
- ls6 intake manifold
- Dynatech Supermaxx setup???
- Exhaust size sound differences?
- Cut-out
- What next?
- Searching for a cut out
- Battery too weak for my cam...
- JAAM ram air kit from Fast Toys?
- ?? on motor build
- testing fuel pump?
- Is an E-cutout my best bet?
- cylinder head question
- ported LS6 gains?
- Significance of blue dot on front of block...
- 02 Sensors
- Header ???
- Header Clearance
- Glass packs on an x pipe
- engine vibration
- Best Place To Install Wideband Bung?
- 2001 chevy 1500 4.8 need help!!!1
- exhaust question
- Heads or 100 shot?
- Straight pipe catback?
- Roller rockers with aftermarket heads?
- TB Differences?
- 2.5" or 3" true duals
- Guys with headers, I have a quick question.
- Anybody know how Spintec muffles flow? compared
- Seriously TSP, tr(Y) again.
- Jegs catback on a stock car
- Y-pipe for 02 SS Convertible
- Trans Am true duals
- Question about Fast Toys Ram Air (FTRA)
- Power Steering Pump bolts
- Long tube headers
- Should I upgrade injectors
- new timing chain
- Need richer exhaust, HELP
- Exhaust sound
- Plz .. I need ur help guys!!!!! FAST question
- Have cut-out - raspy sounds on idle down
- intake gaskets
- My headers or y pipe are hitting my floorboard...
- Magnaflow Dual/Dual (quad tip) Kit
- Yet another Vic Jr vs Fast 90 thread
- 90mm Street warrior Intake, and dyno results
- installed a FAST 90
- Question about bore/stroke
- headers
- My LPP header review
- 4.8 Truck valve covers + brackets
- slp dual tips don't look right...
- 42# pinjectors
- MAC headers and Y-Pipe?
- 00 TA Exhaust Questions Headers/Cats/EGR/AIR
- I have a question for you guys....
- AIR/PCV problem! HELP!!!
- Borla/Corsa exhaust setup? Got a question
- Short belt mod
- What kind of headers are these???
- 3 in pipe
- Any sponsors have this part in stock?
- So what happens when your catch can fills up all the way?
- Please critique these headers
- Cleaning duals
- Magnaflow muffler placed in Loudmouth?
- stupid question
- Volant hole plug - HOW TO - PICS INSIDE
- have kooks headers/kooks catted y and b&b...not loud enough
- TSP catted y with kooks headers?
- LTs, Mufflers, and turn-downs
- LS6 vs FAST 90/90 vs Fast 92/92
- skip shift??
- Port our LS6 Intakes
- LS Spyder manifold
- Rotten egg smell
- best shift point
- Sewing Machine + Ticking/Knocking from collectors = ????
- Aftermarket Intake and throttle body which ones ?
- Ls1 Polyurethane Engine Mount?
- Corsa look alike tips, $55.
- Fast 90 -92 Is one better than the other
- A4 or M6
- 2000 trans am build up questions
- It feels alot like Christmas!Lt's and others arrived some Pics!!
- Need HELP!!!!!
- just ordered my pacesetter Lts!!!!
- TPIS 90mm ls6 intakes
- question about pplacement of a vacuum line
- help with engine info
- What would you do?
- California legal headers?
- e cut out wiring installation
- Meziere EWP install....some tips for Fbodys
- Plug wires longer than MSD's?
- Can I make my own Y-pipe anti-floor-board banging hanger?
- Bigger than 1 7/8 headers?
- MAF to close to TB
- anyone running trick flow 235cc with victor jr?
- Edelbrock 3864 90mm TB
- best y pipe for clearance??
- Bosch green-tops too much for h/c?
- header torque rate
- LS6 intake question
- Anybody used Hooker Max Flow mufflers?
- intake lsx 9.700
- How to clean....
- biggest cam i could go....... plz help
- ls6 intake with cam swap
- Power Steering
- Throttle cable
- Hooker headers any good?
- removing FAST intake lid
- going from 3.42's to 3.73's
- Torque specs
- question about installing fast 92/92
- motor mount bolts
- Possible LPP LS1 Header GP:)
- Which hi flow cats?
- *I need a Y-pipe*
- need help!!!!
- Need help big time?
- Connecting 92mm TB to 85mm MAF?
- MAF sensor help, bought new MAF and STILL not working...
- What to do for my exhaust and emissions
- TSP help
- resonator or bullet muffler?
- Turn downs,Enough back pressure???
- Fabricated an X-pipe today
- Flexplate
- what is this?
- Weiand intake gaskets?
- exhaust tick/rattle/annoying sound on decel HELP---VIDEO!
- Anyone with a cutout even make more power closed?
- tsp 1 7/8 header install questions
- Thrush.....
