View Full Version : Generation III External Engine
- Are all center bolt valve cover coil the same?
- Where does this vacuum line go?
- Dual cats, or single??
- Cruise control, abs, and tcs delete
- Fuel Rails
- Coil swap yields 9.25 HP and 18.6 TQ
- Deleting Air Con, require block off plate.
- help! oil on spark plugs
- Im looking for a raspy Exhaust
- intake suggestions
- FAST throttle body? CRAP??
- power steering lines
- Rubber Hose on Intake
- exhaust tips on 2002 z28
- Muffler Question
- Car runs better cold (open loop?)
- Lid for 99 and 01 the same?
- flowmaster merge after ORY??? yay or nay?
- Center mount exhaust?
- best budget header
- MAF stuck on stock lid
- I need some advice about push rods and rockers as well as lifters with .595 lift cam
- More noise after 92/92 install
- Any Alt. bearing rebuild kits for our cars around?
- Fast Install Question
- MAC exhaust?
- CMMG Catback
- water pump
- MAF question...
- Banging TDs?
- Sound Like a Good 427ci Set-up...
- A/c question
- List you best mod....
- 2000 ws6 egr removal
- 1sickSS, who is this frost guy?
- Edelbrock Pro Flow Intake
- LS1 525 HP heads and cam package??
- Notching the k-member
- What is a good dependable and streetable cam and heads, that you can tell it's there?
- Exhaust Question
- 799 heads on stock LS1
- FTRA or Others? With Trans Cooler???
- GMMG Vs Borla Vs Corsa
- heat soak..
- removing stock muffler in one piece??
- Need Alt. Opinions
- Bassani True Duals on a 2000 camaro opinions
- car idling fast
- Stupid head gasket question
- Intake for sunoco hood?
- How is the bassani true dual kit for a 2000 camaro
- Backfire after header install?
- Exh. Cutout questions!!!!!!!!!!
- Vacuum lines on an F-Body
- Whats size.....
- Could I get some spark plug & wires help?
- benefit of TSP Y pipe over Pacesetters Y pipe?
- Does any one know how to do this coil relocation process
- Got the new duals on, but........
- cams which is better
- intake tube
- Mac Air filter. Anyone use these??
- LS1 water pump nipple thread size
- header question
- BBK 80mm TB will it work with LS6 intake?
- Quieter exhaust suggestion?
- 11.8 Volts WOT?
- car is misfirering
- To use or not to use...
- Anyone have a lead on a new inner LSX intake gasket?
- ls2 and ls1 coil packs
- Just got my mail order tune from frost.
- HELP: Possibly stripped a header bolt in the head. Can I fix it?
- In need of help!!!! Odd noise, cannot identify!
- What happens when you have codes tuned out?
- Mail order tune
- New Product ---> Fast Toys CLEAR 85mm Air Lid
- help need repalcement exhuast tips!!
- Easiest Header install
- SS exhaust
- How type should the belt be when not using the stock tensioner?
- Headers ONLY with Spiral Flows?
- Sponsors selling MAC-43098 ???
- TSP Rumbler True Dual
- PLEASE look at these throttle bodys!! NEED advice before I purchase!!
- Some exhaust questions before I buy...
- Alternator Relocation Bracket
- Pacesetter Header Gasket Part Number
- ac will not come through vents
- FAST 90/90 what MAF and Lid
- Look at the location of my 02 bung
- Bad Balancer? Slight Wobble?
- Where to buy coil pack connectors?
- WS6 Intake Options
- quick milling/pushrod question
- How much power ? Do i need a tune?
- 98 LS1 Alterntor Question, please Help..
- MSD blaster coils??
- How to fix exhaust leak on 96 LT1 with Edelbrock shorties
- Cat Bypass Pipes
- LS6, Longtubes, EGR/AIR Debacle
- Edelbrock 4150 TB with spectre hat pictures within
- I hate asking questions like this...what is this?
- Exhaust fabrication question
- How much RWHP?
- magnaflow install problem
- Fast ported 96mm or Edelbrock Intake
- tsp ory
- Is a 00 LS1 the same as a 04 LS1
- Quick ? on dipstick
- What exhaust is this?
- Safe to Remove EGR System?
- Full system exhaust setups????
- Textralia Clutch question.
- Best DS loop for H pipe duals?
- Important ? spark plugs asap
- LPP Headers Quality?? Who has them?
- Coolant Crosssover LS1 to LS2 Intake
- SLP exhaust
- Sheetmetal intake questions
- Twin throttle intakes
- Quietest 3" in/out
- Coolant crossover and FAST int
- LPP Headers and solid motor mounts installed I have a question
- c5 header help
- New Ported Vic Jr. 4150 TB 311 Cfm 243's
- Can't wait its killing me?
- Lingenfelter help!!!!
- What Catback on 2000 camaro z28
- Deal too good to be true?
- freakin harsh
- Do I have a LS6 intake?
- Stock Exhaust Pipe size
- Throttle cable to short? (Pic).
- Quieting down the Loudmouth 2... Please experts inside
- reuseable intake gaskets?
- does anyone know the correct torque for a powerbond udp
- cyl 7 misfire
- Wont stay running after rebuild! help me
- Air Lid question and SLP 85mm MAF Sensor
- thunderbolt cats/cats in general - ceramic or metallic?
- 02 SS Camero vert. ARH/w High flow cats
- MISFIRE!!! raw gas in drivers side exhaust!
- True Dual Question
- need vid's off magnaflow with LT's
- whats the best intake setup for a ls6?
- What exhaust set up will give me good street performance and that old muscle carsound
- What kind of tranny oil should i use??
- straight pipe exhaust question
- will s.e.s. light reset showup when inspecton rolls around in Texas
- What Fire Extinguisher?
- Best way to raise engine for motor mount swap
- ARH long tubes and LS6 manifold installed
- Anyone have a C5 and Fbody??? I need help PLEASEE
- Pulley Question 98 LS1----
- Quick ? on open headers need opinions
- Difference in exhaust brackets for 98 and 99+?
- will ls6 vette parts fit cts-v?
- Wiring Harness
- quick question bout 5.3 liter truck heads...
- 98 LS1 performance problem after header install
- Budget Build Exhaust
- Front 2 cylinder on drivers side keep fowling
- Bad lifter or lifters causing fueling trouble?
- Exhaust hanger
- Best Headers for Magnaflow exhaust?
- Spark Plug Socket And Boot Puller
- 92/92, plug & play ?
- Ls1 runs for 5 seconds shuts off Not VATS
- Stock TB is sticking.. How to fix??
- 92/92, will I need larger MAF
- Anyone use the Edelbrock EFI Intake Manifold?
- What 90mm TB are you using??
- Head & cam setup
- Is this ok for PCV?
- Head/Cam to go with sts turbo?
- Whistling from engine
- question about borla xr1
- Ls6 intake ?
- FAST 90 what RPM does it stop making HP
- Fast Intake swap ?'s
- o2 sensor question
- How to fix bangin y pipe?
- MAF ends and lid questions
- EGR Plug Question
- ls1 block plugs on the outside
- Reverse solenoid fuse burns?
- Vacuum Leak??
- Which plate to use in my borla?
- Ordered my Edelbrock 4150 TB today
- How much are Cats going for now?
- GM EGR Block Off
- Who still sells O2 sims?
- Thinking of some BBK longtubes w/ y pipe, opinions?
- Jury rig ram air for non-ws6 hood?
- K&N FIPK II swap to SLP Lid set up
- Car doesnt seem Faster with New Longtubes
- TSP Rumbler Install Question
- slp ram air scoop install???
- The New Corsa Tips?
- Throwing codes???
- Detoxx's PowerFlo exhaust vid
- Good Headers?
- O2 questions?
- Question on O2 extension with Pacesetters
- What is this sensor called or pn for it.
- Weiand VS LS6 Intake
- Knocking after Header install
- reduced exhaust length, now backfire???
- Exhaust blows smoke at WOT
- Full exhaust on... Do I need to keep the Y-pipe support brace?
- Have you guys ever heard of....
- Got my ported FAST from Vengeance!!..1 Q
- Problems ASR switch
- Exhaust options
- manifold questions..
- exhaust question?
- Muffler Questions
- AC underdrive pulley?
- lid pointless with z hood?
- Alternator not lasting...
- LS1 cooling?
- gen II and gen III timing gear drive
- Meziere Electric "Street" Water Pump-Daily Driveable?
- Hooker Y pipe and o2 sensor ?
- Cat Flange Clamp- Need help finding this!
- Video of True Duals (over axle)
- Foam pads on intake manifolds
- Borla XR-1's with TSP TD's
- 2001 z28! need some help!
- LS1 to Truck coils... Help...
- Intake overkill???
- LS4 oil pump on LS6 block
- true duals over the axle or ARH y pipe with cutouts and SLP dual dual
- Happy with your FAST intake?
- SLP Dual/Dual vs Power Flo
- Fast throttle body !!
- Starter-Alternator issue
- electric cutout switch???
- Oil pressure gauge pegged at 80psi..
- PS Pump Pully Removal
- Will 99 T/A Manifolds fit an 00' Corvette ls1?
- LS1 and LT1 the same MAF??
- Please help me I.D. these harness plugs
- Sweet Thunder VS. Dynatech/Borla
- Question?
- LPP header question?
- LS6 Intake to a Fast Intake Swap
- Sensor above Tp sensor
- Moroso Spiral Flows
