PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 [204] 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Spintech mufflers
  2. pacesetters or hooker L/T's???
  3. Dynomax mufflers @ end of headers (!catback)
  4. Front and rear O2 sensors are the same, just have a different length pigtail correct?
  5. ls6 to FAST
  6. LS6 PCV Conversion Question
  7. What cat-back do i have?
  8. Vortex V-Baffle Muffler
  9. Pics of my new air intake
  10. Long/Short/Stock
  11. Long tube Headers
  12. tb bypass
  13. Greddy catch can results after 6k miles!
  14. Pulley?
  15. First mod - LG lid installed and ?s
  16. spark plug wire clearance
  17. Swapped heads, intake and T.B. Now....
  18. Pacesetter LT Install?
  19. Smell?
  20. what muffler with true duals
  21. Magnaflo Metallic Cats
  22. Inspection
  23. Help with spark plug wire and texas speed catted y pipe!
  24. where can you get ravin mufflers
  25. true duals?
  26. PICS of SLP UD Pulley vs Stock
  27. fast intake 78/90
  28. More Edelbrock pics and info (not 56k friendly)
  29. SOTP with Underdrive Pulley?
  30. 2001 Ls1 Egr
  31. are glasspacks that much worse than bullets?
  32. Thread Locker on Valley Cover Bolts
  33. What are these??
  34. information from vin number
  35. pacesetter lt air pipe broken!!!!!!
  36. BMR alternator bracket belt size?
  37. Mufflex Bump Stops
  38. Benefits of True duals?
  39. new coil pack brackets...confused..HELP
  40. Exhaust loudness in db
  41. Replacement for BGRA (WS6 ram air spacer)
  42. perimeter bolt heads
  43. Pulley an dbelts
  44. how to tesll if pulley is SFI approved?
  45. quiet, good flowing muffler???
  46. help! secondary air injection removal
  47. HELP! ls6 intake install ??
  48. How much radiator fluid?
  49. gut cats?
  50. straight headers
  51. Service Engine Soon Light Due to Exhaust?
  52. PCV help!
  53. Help on removing LS6 manifold
  54. Fast Intake gaskets okay to run on LS6?
  55. Wierd noises from SLP subframes or DS loop
  56. What Headers for California?
  57. Routing O2 sensor wires with LT's
  58. Were to weld a bung for LC-1?
  59. Planning Exhaust: GMMG/True Duals
  60. tried search no luck, ypipe size
  61. Earlier model LS6 intake?
  62. Dielectric grease
  63. Duals welded onto the collectors
  64. Stainless XS Supercomp headers!
  65. Magna Flow W/Cats
  66. Oil filler neck/cap
  67. How much would you pay for Used LS6 Intake?
  68. a Q. about cutouts
  69. why are my duals so close to my fuel lines
  70. Part Number
  71. Sheet Metal intake
  72. Welding plates on SLP headers
  73. are these coated or non coated?
  74. Solid Or Poly Motor Mounts?
  75. What causes rasp!
  76. Power gains with electric water pump?
  77. Need pic of Loudouth on car
  78. !AIR part question
  79. since im getting headers
  80. Borla, Magnaflow, and Dynomax muffler experience...
  81. Whose runnind td's straight out the back (no cats or mufflers, but not dumped)
  82. how loud is the LM
  83. Help with Free Mods and Simple Bolt-Ons
  84. dmh cut out help
  85. For the Fast 90mm setup, whats needed exactly? bigger lid?
  86. Electric cutout + Deep puddles = ???
  87. whose side exhaust?
  88. Got my KOOKS!! Now I want to polish, what do I use?
  89. car caught fire... from an unshielded cutout throwing flames!
  90. Headers or Trans???
  91. foam gasket for lid
  92. Backfire??
  93. QTP catted Y made out of stainless steel?
  94. maf replacement coupler...help
  95. Dynomax Powercat NJ emissions problem "not ready"
  96. Need Air Lid Help
  97. Corsa exhuast?
  98. GMMG pic wanted
  99. Replace IAT?
  100. Which Muffler for LM
  101. 160* thermostat or 180* thermostat
  102. Corsa with QTPs and Catted Y
  103. Fan Temp...need some HELP
  104. egr mod question???
  105. TD under axle
  106. can you verify model year by serial # on block?
  107. Longtubes to avoid?
  108. Borla Too Loud ???
  109. Header Q's
  110. LS6 Maf
  111. best performing headers/ypipe for the money?
  112. best headers for money
  113. Throttle Body Water Bypass worth $17?
  114. Underdrive Pulley Specials?
  115. vid of duals
  116. where to get LS6 MAF, 2002+ with pigtail?
  117. Anyone have a picture of an ATI Super Damper for a F-body?
  118. Maf?
  119. Coil misplacement.
  120. Muffler Replacement
  121. Intake manifold bolt thread and pitch?
  122. Engine temp after headers?
  123. Early X-Mas for Me!!
  124. who makes a good flowing muffler that i can slip on the colector thats quiet
  125. which gives u more power for 98 z28 camaro True Dual, X pipe, or Y pipe ??
  126. What do i clean my MAF with?
  127. shorties/long you tell me
  128. Waste of Time?
  129. custom cold/ ram air
  130. help on a set up
  131. help
  132. ZO6 MAF but no 85mm lid?
  133. Any precautions needed?
  134. Loudmouth 2 muffler really loud?
  135. TSP true dual question
  136. Which Header? Kooks or QTP?
  137. Help Gutting My Cats
  138. borla plates?
  139. Which Spark Plugs to choose...
  140. QTP vs Mc Cord
  141. True Dual Over The Axle...
  142. Are two cut-outs overkill?????
  143. mounting switches where the TCS would be
  144. Couple of questions.
  145. Cant get oil filter off of my ls1
  146. loudmouth question
  147. pacesetters install question
  148. P.T.M. throttle body
  149. Just got my cutout welded in...
  150. header bolts
  151. a.i.r?
  152. ADJUSTING BORLA CATBACK- Stuck!
  153. Bolts on suncoast creations air intake box
  154. TD guys with flo-pro!!
  155. Cat shells cured my rasp.
  156. question on headers
  157. What O2 wire does what?
  158. Will GMMG from 96 SS work on 98 WS6?
  159. Inside View Of Bullet Muffler
  160. H-pipe placement
  161. True Duals *sponsors*
  162. ordering headers this week and still need a lil help on my choice
  163. Porting TB
  164. Couple bolt-on questions...
  165. Aluminized Steel - How Long Does It Last?
  166. exaust ideas?
  167. Full Bolt Ons??
  168. i feel like a newb, gap question
  169. poly motor mount people, come in!!!
  170. 2.5 or 3" true duals?
  171. Look What I Got *PICS*
  172. Steering shaft removal for pacesetters?
  173. another n00b ?, exhaust this time
  174. help me indentify these parts...
  175. just got GMMG and LT pacesetters...
  176. Stainless Works Mufflers
  177. loumouth resonaters on rumbler
  178. COMPLETE intake install
  179. 1 3/4'' or 1 7/8'' headers
  180. how do i tighten the belt?
  181. Flowmaster 80 series??? 1997 TA
  182. Anybody ever heard of......
  183. Kooks Race Mufflers
  184. Throttlebody question
  185. collector ring...?
  186. Help!
  187. Hooker Vrs Pacesetter
  188. Phenolic Carb Spacers for Victor LS1 EFI
  189. time for a new alternator?
  190. Another oil consumption question (I searched)
  191. Power Steering Pump
  192. MSD LS1 blaster coils
  193. Engine Coolant Temperature (ECT) Sensor
  194. Water pump leak.. need advice
  195. rough idle
  196. LT's+ORY+Magnaflow CB = too loud! Ideas?
  197. Best aftermarket valvecovers that keep the coils on top?
  198. SLP Headers & Cat back system
  199. can a single plane carb intake really net 50hp
  200. Broken oil pressure sender w/ intake swap
  201. FAST intake? big difference?
  202. Header leak
  203. Low Resistance plug wires....
  204. How much is this Hooker costing me?
  205. need help quick...
  206. First Mod Woohoo!!
  207. Power, Heat Range and Plug Gap rule of thumb?
  208. LTs and Sportlines??
  209. Anyone know about these.....
  210. Breather Tube????
  211. installing longtubes, need quick help.
  212. Horsepower engineering big box of goodies?
  213. high flow cats
  214. What size are the tips on ls1sounds?
  215. Gutted cats...do they rob power
  216. Guys running MAFless.
  217. PCV, catch can & breather - Is this routing correct?
  218. Quiet catbacks
  219. Do warm air extractors on aftermarket hoods really help performance?
  220. TB Bypass??
  221. Can it be done?
  222. SLP Header Question
  223. Header????
  224. how hard is it to put 3 inch collectors on macs?
  225. Pacesetter Header Install
  226. what are the benefits?
  227. catch can or breather filter
  228. NGK TR6 plug question
  229. Help Broke Manifold Flange Bolt
  230. headers longtube install $$$$
  231. oil cooler
  232. o2 placement for Edelbrock Slip On Merge Collector Headers?
  233. Does anyone else have this problem?
  234. Exhaust Q's?
  235. TSP Catted Y
  236. Anyone make a part to secure the MAP to the FAST 90 intake?
  237. Kooks 1 3/4 Stainless Jet-hot Coated with 3 inch Y RANT!!!
  238. Were to get replacment intake ls6 gaskets?
  239. Borla Question
  240. Plugs and Wires
  241. SLP Exhaust options
  242. QTP Headers
  243. free mods question
  244. Cross threaded plug
  245. weight savings with catback?
  246. Finally Ordered my headers
  247. GMMG owners, help please!
  248. GMMG owners help please
  249. true duals
  250. dual or single cut out
