PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 [186] 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. oil catch can location?
  2. e-cut out questions
  3. whats the differnce in desing between 98-99 manifolds and 00-02 manifoldss
  4. slp center exit exhaust cleaning
  5. Where can i get an H pipe
  6. Starter clicking
  7. k and n intake
  8. what kind of power increase will a dynotune give me
  9. where to buy an ls6 intake manifold?
  10. need help identifying part
  11. Inside of a busted FAST
  12. which headers for a huge cam
  13. Someone PLEASE explain this to me
  14. Elec cutout in Borla cat-back?
  15. Next Big Mods
  16. Adding EGR to aftermarket or LS6 intakes?
  17. My LTs might be banging a bit.. HELP
  18. I love the sound of this exhaust!!!
  19. With gutted Cats, are O2 sims neccesary?
  20. Exhaust clamps... easy take off...
  21. want to remove cats but stay quiet???
  22. maf ???
  23. Need Help!!! Car Overheats!
  24. 2000 Camaro: ground for coil packs
  25. Dyno'd 4" catback w/cutout
  26. LT Install HELP Hookers wont clear!!! Tips?
  27. TSP duals and SLP SFC
  28. Optimal coolant temp at the Track?
  29. Is it bad to run open headers?
  30. Stainless header question
  31. just ported my tb
  32. qtp y w/ qtec
  33. Just how much?
  34. SLP Lid and Blackwing fiter?
  35. How hard to install TB?
  36. which one sound better
  37. Muffler Help
  38. Help, steering knuckle rubbing headers!
  39. GMMG vs 1 Chambers
  40. How do I adjust throttle cable for FAST TB?
  41. X,h,or Open Headers?????
  42. Anyone in CA with LT's???
  43. corsa on the way...lookin for headers&ORY to go along w
  44. What would be my best bet for Duals?
  45. !QTPs are in!!!!!!!!!!!!!
  46. K&N performance kit
  47. magnaflow true duals
  48. whats the electric plug on..
  49. Installing FTRA - Best Tool to Cut Airbox?
  50. electric cutout
  51. write up on header install
  52. What kind of Catback is this?
  53. 1 3/4" vs. 17/8" primaries???
  54. Mass produced full length dual exhaust
  55. LS6 PCV Conversion Idea
  56. Which headers?
  57. TB idle inlet orifice for TPS question
  58. will a loudmouth thats for lt1 fit my ls1?
  59. TB idle inlet orifice for TPS question
  60. TR-55 or TR55IX on Stock Motor?
  61. Exhaust on the quiet side for LT's/ORY...
  62. How to insulate wires next to headers
  63. Mufflex LS1-HR Anti Y-Pipe Banging Part Install?
  64. Should be prowling the streets again on Monday Night
  65. Under or Over Axle True Duals
  66. Any 383/402/408 Owners with LS6 Intake?
  67. A4 guys running FTRA or other CAI
  68. best sounding flowmaster on ls1
  69. Debating LTs setup or just catted Y in Mass.....
  70. Best Fuel Rails
  71. Don't wait to get rid of your EGR/AIR! Check your PCV system too!
  72. installing headers
  73. Headers
  74. waterpump?
  75. cutout ???
  76. EGR mounting instruction for SLP LS6 intake
  77. Cutting out plastic piece below filter?
  78. Water temp gauge is in...
  79. Back To Stock??spark Plug Help!!!
  80. What you think it will do?
  81. LG lid DOES NOT fit 85mm maf...
  82. few qtp header questions
  83. Another Tune or no tune...?
  84. Composite gaskets, any tips on preventing them from sticking...
  85. Anyone running a Wilson Ported FAST?
  86. filter removal tips? Need TQ!
  87. 2000 T/A Exhaust
  88. How much will i gain?
  89. stock head question
  90. SLP header Q mainly about welds.
  91. Borla Catback fitment question
  92. stock throttle body size
  93. About to order headers...
  94. FAST intake warning
  95. Does this work or is it a rip off ???
  96. Headers?
  97. Pic request: 99' LS1 intake w/ EGR intakes
  98. band clamps
  99. Loudmouth ?
  100. BG Ram Air any good for WS6 guys?
  101. 98 WS6 almost overheating
  102. Great! My LM came off
  103. How much HP gain will this get me...
  104. little tweaks
  105. Car is back firing after header install
  106. Help me figure this out...
  107. coolant problem
  108. gmmg or stainless works?
  109. Looking for car need help
  110. Kooks Y Pipe
  111. Need help with vaccuum hose (line)
  112. 2002 Ls1 Freeze plug??????
  113. Emmissions block off plates.....How thick?
  114. Exhaust sounds and video clip
  115. Show me pics of your ORY ground clearance
  116. oil catch can question
  117. Can't Decide: Corsa or B&B?
  118. manual cut out...
  119. Will i see any gains?
  120. Headers!!!!!!!!!!!!!!!!
  121. What Is A Good Replacement O2 Sensor
  122. Pacesetter connection
  123. Flawless!!! Installed my longtubes today.
  124. Manual Fan Switch
  125. What ARP headers studs for an LS1?
  126. Mufflers right off the headers.
  127. 3.5in Collector to 3in Xpipe system?
  128. crank pulley help!
  129. torque spec
  130. where 2 get parts i need to convert ls1 to ls6 on 2000 ss
  131. I found out why the ebay headers were so cheap.
  132. How to identify an LS6 intake?
  133. Am I losing this much horsepower with GMMG?!
  134. egr question
  135. Just did the coolant bypass mod.
  136. new oil pump?
  137. high idol with TB swap
  138. Lane?
  139. 160º t-stat...can't find one for the 'turd!
  140. is the throttlebody bypass worth getting
  141. Weird spark problem!!
  142. Mixing exhaust parts.
  143. Header Install Nightmare
  144. sensor on back of intake
  145. Quick Question
  146. Corsa?,borla?,or Magnaflow?
  147. SLP LM1 resonator
  148. opinions needed on mods install
  149. noob true duals question..
  150. JEGS xpipe... anyone?
  151. LS1 to LS6 PCV conversion w/ LS1 steam tube.....GURU's please come inside!!
  152. difference n ls1&ls6 int
  153. Anyone make F-body TD's that aren't dumped?
  154. cats
  155. Ls6 Or Fast 78mm Intake What To Get???
  156. fixing EGR leak
  157. Summit X Pipe Kits
  158. Asp underdrive pulleys
  159. This weekend = Cutout & !EGR/!AIR
  160. Ported My TB...
  161. Killing cats?
  162. which air intake is better
  163. Will UMI's 3point SFC's work with TSP True Duals?
  164. whats best y pipe to buy
  165. air breather for a lid?
  166. Bassani TD
  167. Should I bother w/a cut out?
  168. H/c Swap. Pace Setters Dont Fit!!!!
  169. cut camaro grille for better cooling?
  170. what's the consensus on running an ORY and an open cutout for daily driving?
  171. header install time
  172. 1-chamber in I-Pipe?
  173. new ls6 intakes
  174. My ported throttle body...
  175. whats the true answer (cutout question)
  176. Help!! Just Did LS6 Heads/Intake, Car backfires and has very slow throttle response..
  177. ~Hooker or Magnaflow~
  178. TSP Catted-Y question
  179. mid length headers that will pass emissions in cali?
  180. Header gasket blew!
  181. my torque wrench slipped and smashed.........
  182. 5.3 TB vs 5.7 TB
  183. Hooker Comp Vs. Super comp, where the difference?
  184. Headers for LS6 in an T/A
  185. Is LS2 MAF sensor applicable for LS1 swap?
  186. Quick exhaust question
  187. Longer Power Steering hoses
  188. What is this hose for?
  189. looking for exhaust tips like these
  190. What size aluminum radiator?
  191. Kook's Lts install issue
  192. FAST90/LS2 TB problems Help?
  193. WS6 intake?
  194. NEED HELP! TB Oring Q!
  195. eBay intake?
  196. Lt's or mids?
  197. Air lids?
  198. headers?? so many which one is the best for the money??
  199. V clamp for FLP longtube headers????
  200. Header install, please help
  201. Where to find a cap for the AIR hose in my lid
  202. aftermarket starter
  203. NX 85mm Throttle Body ?
  204. Can I weld my headers in the engine bay?
  205. SLP D/D on LT1 Car?
  206. pulley stuff
  207. c5 sheet metal intake pics please!!
  208. SLP LID AND K&N FILTER OMG
  209. Loudmouth II for Hooker??
  210. SLP Lid Question Please Help
  211. cut out question
  212. Those w/borla & qtp cutout
  213. !Bump Stop Mod
  214. O2 sensors ?
  215. headers on Ebay
  216. New LS6 intake?
  217. weiand intake questions/problems
  218. Limited Slip for F-Body 4 Sale!!
  219. Gutted Cat
  220. How to P&P TB?
  221. march underdrive pulleys
  222. porting a tb...
  223. loudmouth installed! holy shi...
  224. Shorty's or Long tubes?
  225. HELP!!!! Did I just break the oil pressure sensor (LS6 intake swap)
  226. Broken Exhaust Manifold Bolts
  227. colant
  228. looking to get hooked up
  229. What kind of clamp are you using on cat to header?
  230. ls7 intake??
  231. tech question?
  232. change exhaust
  233. What would the best exhaust option for me be?
  234. WHAT GAINS FROM LS6 OR FAST 78MM INTAKE & SHANER PORTED TB??
  235. Hooker Headers
  236. Stuck cutout??
  237. corsa owners inside
  238. Upgrading plug wires: Worth it or Not?
  239. This ok to seal my EGR hole?
  240. FEL PRO Gaskets ok?
  241. What is the hose in the lid for?
  242. 1995 Firebird Exhaust
  243. glasspack???
  244. ExhaustVid (Borla,bullet,trueduals)
  245. Security Problem, Car won't Start. NEED HELP FAST!
  246. CME with a bullit muffler
  247. Dynatech supermaxx ?
  248. GM LS6 VS Holley Aluminum LS1
  249. how good is the moble oil filter
  250. Flowmaster cat back
