PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 [272] 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. LSX installed
  2. ASP pulley?
  3. noise comming from engine bay!! help!
  4. Y-pipe size?
  5. O2 sensor question?
  6. Alternator Whine on LS1's?
  7. Exhaust Parts Questions... Where to Buy?
  8. Who makes an engine torque strap?
  9. Catch can idea,Whatta ya think...
  10. Overheating Question
  11. Re-did my AMW bracket mount.
  12. Cat Failure on 00' T/A
  13. Corsa, Borla or SLP Dual
  14. Where can i get 3 inch flanges?
  15. banged my cat the other day
  16. any benefits to the ASP Alt Pulley?
  17. Macs O2 location
  18. Did I MESS UP!!!
  19. Catch can
  20. Very strange question regarding catch can?
  21. mac headers
  22. Pulleys?? More underdrive % ???
  23. Is this for real....?
  24. Porting
  25. Mufflex Off road or cut-out and catback?
  26. LS6 Intake installed - question
  27. How much to install an intake?
  28. FAST intakes question
  29. Looking for muffler comparisons
  30. Kooks Headers
  31. Going from Rumbler to Borlamouth (kinda)
  32. DMH E-Cutout Results (Cool, but a little dissapointed)
  33. need y pipe help
  34. Put '01-'02 Manifolds on a '99??!!
  35. Need Part Number for ASP Underdrive belt
  36. loudness
  37. Any before/after LSX 78mm--->90mm results?
  38. True Dual questions...
  39. Dr. Gas and pacesetter headers?
  40. K&N FIPK vs. Lid with FTRA
  41. 02 SS With Kook's Headers and GMMG Exhaust Sound Clip
  42. Mufflex owners inside!
  43. Question about 85mm MAF?
  44. What Gaskets part #'s?
  45. FTRA intake air temp
  46. Air & EGR removal
  47. bullets vs. flowmaster vs. magnaflow
  48. ASP pulley question
  49. Lookie what I got :)
  50. Installing Asp crank Pulley! Need Advice!!!
  51. Just installed Jethot longtubes, some ?'s.
  52. Pics of my Hooker catback installed....
  53. Got a free LSX intake today, have questions
  54. Throttle Cable Slack
  55. Gains from Magnaflow
  56. 3 inch dual exhuast problems
  57. Flowtech Coated Lts+ORY
  58. Clearance problems with True Duals on a lowered car?
  59. Best way to gut cats?
  60. I Want True Duals on my WS6
  61. LsX Intake Issues In Terms of Tuning??
  62. Installed 160º stat, Meziere EWP, changed fan settings, yet it still reads under 210º
  63. Porting the LSX intake..
  64. Anyone using Stainless Works LT's?
  65. True dual idea
  66. homemade o2 sim vs cheap sim vs real sim
  67. Help With Valve Covers
  68. Coolant temps with Evans pumps..
  69. Fans Work , but..
  70. Help with headers for 98 C5
  71. Oxygen Sensors ?
  72. crank bolt on home tools ????
  73. How do you guys think this would work for a "custom" exhaust
  74. please help!!!!!
  75. Pacesetter LT's are on their way
  76. Just install poly motor mounts, should I do trans too?
  77. Battery Relocation....where to get and how
  78. LS6 Intake seals.?
  79. what gains should i expect
  80. Stage 8 header bolts - reusable?
  81. SLP header measurment
  82. Mech or Electrical Guages
  83. What size Cut-out
  84. how do you relocate pcm wires????
  85. Duals Vs 4" single
  86. Tsp x-pipe, how is it coming?
  87. Spiral-mouth installed!
  88. Off road y to stock manifolds?
  89. Exhaust set up
  90. Exhaust set up
  91. Which Intake ?
  92. O2 sensor wiring?
  93. Timing problem, what sensors?
  94. LT headers+ORY+Magnaflow=HP?
  95. AMW catch can is a nice piece!
  96. Is this even feasable?
  97. Taylor 409 racewires
  98. Header decision
  99. Hooker cat back, is this normal? (PIC)
  100. plugs and wires
  101. How long did you wait for your Kook's LT's??
  102. LT header installed ... need help
  103. "True Dual"
  104. SES light came on after Meziere EWP install?
  105. Anyone have a pic of underneath their car with pacesetters and the pacesetter orp?
  106. Burning valves
  107. Possible header leak---black soot on top of tube!!
  108. Horsepower Loss Through High-Flow Cats?
  109. Pacesetter LT troubles???
  110. Installing ASP UD Pulley have question about keeping engine balanced.
  111. A/C isnt working and its too friggin HOT!!!
  112. 1 3/4 primary to 1 7/8
  113. Cut-Out with FLP's?
  114. Posting for friend: Intermittent miss on 99'Z
  115. EGR Elimination
  116. FLP/Hooker/MAC install notes
  117. Is it supposed to be this dirty? (PIC)
  118. ac/heat problem
  119. Header gaskets
  120. Does the gap change as you add HP?
  121. JB Weld on a header leak?????????
  122. Plug Indexing Help
  123. Any lead race fuel resistant o2 sensors available??
  124. Aeroturbine exhaust
  125. How to tell?
  126. Best Throttle Body Size?
  127. what would i gain switching to the fast 90mm...
  128. GMPP LS-1 carb singleplane intake
  129. Cost of replacing ignition cylinder?
  130. Cutout with Off-Road Y
  131. True Duals without Headers?
  132. Jet Hot LT's and Hooker or Magnaflow?
  133. fram air hog air filter
  134. Thinking of replacing my Dynomouth.
  135. Broken Plug inside head Now What
  136. SLP lid won't fit onto maf
  137. spark plug dropped into manifold #8 how to
  138. Long Tube Headers & Gas milage?
  139. Power steering pressure hose leak
  140. Any truth that SLP's "tuned" LT are better than equal length header?
  141. 78mm LSX + Stock, ported TB... WOT issues?
  142. Lm
  143. will i gain HP with port matching
  144. Quick SS exhaust question
  145. QTP offroad ypipe
  146. Non-Adjustable Borla
  147. Quick Cut-out Question
  148. what if i only run headers on the passanger side
  149. What Include In Bolt Ons?
  150. Have EGR/AIR Removal questions
  151. Boiling water on intake manifold
  152. Header Comparisons
  153. 02 Sensor
  154. Jet Hotting a Y-Pipe?
  155. Is This Possible..help
  156. Safety bypass on thermostat?
  157. coil packs and spark plug wires?
  158. Exhaust drama
  159. High Idle????
  160. True dual exhust
  161. Fast Intakes
  162. Got the headers installed...
  163. bassani w/ cut out vs. 3" duals video
  164. howz this catch can
  165. stock y-pipe
  166. Borla XR1 race mufflers...
  167. Calling all Kook's Longtube owners...
  168. need some header advice...
  169. wanting the car to be LOUD!!!! $1500 to spend...
  170. FlowMaster Magna flow muffler any good?
  171. CA and GM Top Engine Cleaner?
  172. Electric Water Pumps
  173. cat back exaust ?
  174. Running things in reverse?
  175. PPC Headers
  176. Seafoam.......
  177. Have Serious Sensor Problem
  178. Stock ported TB on LSX?
  179. Free Ram Air on a SS not worth it?
  180. What's that knocking noise?
  181. Can a header leak effect gas milage?
  182. Z06 Vs Fbody Radiator Shroud and Fans
  183. ? about Z06 MAF
  184. Technique for cleaning MAF??
  185. Free Mods.......?
  186. Would an LS1 intake work ok for a 382?
  187. Borla Exhaust Pop, Normal?
  188. Header bolts?
  189. How hot does it get?
  190. Lane true duals
  191. Lid causing hood to not shut all the way?
  192. EGR not hooked up, is this going to hurt performance?
  193. need to quiet the car down
  194. Moroso Spiral Flows = big restriction?
  195. Help... Power Steering Cap pops off
  196. Wieand aluminum intake...who sells it????
  197. Swapping to LS6 intake
  198. ASP Pullies, junk?
  199. What length o2 extensions should I buy?
  200. smallest cat for y pipe
  201. Flowmaster True Duals
  202. Anyone have this exhaust set-up?
  203. Running With Open Headers???????
  204. !AIR, what to do?
  205. BBK SSI intake manifold?????
  206. ASP pulley install?
  207. Car smoking, is it normal???
  208. What gains/benefits will I obtain going from a 1 3/4 to stepped 1 3/4-1 7/8 headers?
  209. !egr/!air
  210. Question when removing AIR
  211. Corsa Performance Cat Back Plus Ory?
  212. Spark plugs for Cammed cars...
  213. Stainless Hooker Headers
  214. Question about a do-it yourself coolant pipe for the LS6 conversion.
  215. Low resistance plug wires - any reliability issue?
  216. ls6 intake plugs and pipe P/N, are these the right numbers?
  217. Which CarSound Cats Should I Use?
  218. Got New Exhaust! Wow!!!!
  219. balancer bolt
  220. VPlus voltage booster, anyone using?
  221. need some help
  222. ls6 vs. lingenfelter intake?
  223. question about LTs and warrenty
  224. where to find silicone bellows
  225. Power difference between duals and Hooker
  226. Ported LS6 intakes
  227. Jet Hot ORY!
  228. QTP Y-pipe ?
  229. debating exhaust options...
  230. lowered+LT's
  231. Dip Stick
  232. Ory ?
  233. slow tach question
  234. LS6 PCV Conversion and LSX Intake
  235. 1/4 improvements on Hooker LT and ORY?
  236. Which ASP Pulley Kit should I get?
  237. Hooker LT's and Flowtech LT's, read>>>>>
  238. Anybody See A Power Difference When Using A Ws6 Airbox Over The Factory Trans Am One?
  239. Cooling Temp Sensor Wiring Problem
  240. SLP LT's Horror Story...manhole cover !
  241. MAGNAFLOW, 30" or 24" after cat, which one?
  242. mac ory
  243. BMR Upper Panhard Bar Relocator
  244. can the resiviour on a power steering pump be replaced?
  245. Lm
  246. Need help ASAP header install????
  247. flowtech header question
  248. 02's spacing from CATS
  249. Installed headers, now have bad 02 sensors
  250. EGR and Air pump caps
