PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 [249] 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. radiator
  2. How hard would this true dual system be to fix? (pics)
  3. Anyone remove support tube from Volant?
  4. Volant or K&N cold air intake
  5. Searching for another 20whp.. Suggestions?
  6. Magnaflow
  7. pulleys
  8. Headers and hooker exhaust
  9. muffler inquiry
  10. intsalling loud mouth
  11. TB/Intake Manifold question
  12. SLP lid and SLP Loudmouth track DATA
  13. I Wanna Be Faster
  14. Will a car with LT's pass visual emission inspection in VA?
  15. Ok, this has me just a little concerned....
  16. Flowmaster muffler fit on V6?
  17. F.A.S.T intake ?
  18. Difference in Catback and Muffler
  19. 02 sensors
  20. Loud Mouth 2
  21. will a vaccum leak show up on autotap??
  22. Don't waste your money on BBK
  23. FLO-PRO twister in LM
  24. air pump wont shut off ??
  25. Duals on Lowered TA
  26. exhaust question????
  27. Need your help to diagnose my problem please
  28. Do i need 02 extensions for pacesetter L/Ts?
  29. oil temp gauge
  30. mating pipes is hard..
  31. torque spec question
  32. MCG Automotive Products Elec cutouts
  33. How to clean MAF wires?
  34. Coated or not
  35. what y pipe?
  36. differant header mean differant sound???
  37. How much would you spend to add 10 rwhp throughout the powerband?
  38. Flowtech headers
  39. Does anyone have experience w/the SLP Loudmouth II?
  40. How much louder with gutted cats?
  41. can anyone tell me the length of the bolt used for GMPP intake?
  42. Question about stock Exaust manifolds...
  43. Pics on Y-pipe banging fix
  44. BG Ram Air Induction System
  45. Custom headers anyone?
  46. Kook's with SLP Dual-Dual...
  47. ORY help!
  48. Ordering Pulley soon!!!
  49. Why isn't it good to buy an aftermarket maf?
  50. Need Help Asap!!! Ordering
  51. Any way to make my temp guage work?
  52. MSD makes LS1 coils now
  53. Electric Water Pumps?????
  54. Oil Question
  55. Bolt ons to make 550-600 crank hp
  56. LT's = SES light .. help!
  57. Stealth Air-Box
  58. cats clogged
  59. differences in 99 vs. 01-02 stock TB's ?
  60. *Anybody overheat with there FTRA?*
  61. How high to lift car to change headers and clutch?
  62. Aftermarket power steering pumps?
  63. Deleteing air system need some help
  64. Hooker catback opinions wanted
  65. Will I have a problem?
  66. How much for Cat-back install these days?
  67. Need help finishing bolt ons
  68. KOOKS or QTP's
  69. To MSD or not to MSD?
  70. ok what the hell, no one has this...help!!!!!
  71. X-pipe for Kooks?
  72. Sticky throttle cable... Lube ?
  73. Pacesetters New Fitment?
  74. Slp performance pack?
  75. muffler decision for duals
  76. FLP's or Kooks LT Headers???
  77. Spark Plug install, quick question.
  78. Quick Question please help
  79. Fast Intake
  80. SLP Y-PIPE (low)
  81. have a Hole in my header!
  82. SLP 2 on the Left exhaust
  83. Which is louder??
  84. Fast 90mm intake or sheetmetal intake on large cubic inch LS1?
  85. What muffler?
  86. Mufflex Hanger Install?
  87. Headers
  88. LS SPYDER Intake
  89. Can't Find Idle
  90. How to install O2s
  91. custom cold air intake
  92. 160 t stat question
  93. Free ram air!!
  94. qtp header question ?
  95. Lids
  96. 450 Horsepower???
  97. anyone have a exhaust leak near the manifold on a stock car?
  98. stock exhaust manifolds
  99. ABS in front and not back?
  100. Anyone tryed these
  101. can ls1 vette rear 02's be used
  102. *Pics* Under axle true duals (56k = long time)
  103. Anyone have Loudmouth Sounds?
  104. What did your o2 dyno with pacesettters?
  105. custom ORY, need flanges
  106. catted y...or true duals?
  107. Correct me if I'm wrong 160 termostat
  108. Opinions on FIPK and Volant kits???
  109. ive got a 85mm maf and dont know whats its for
  110. tsp 85mm lid question
  111. DS safty loop and TSP true duals
  112. MAFs, all 98-02 Work together?
  113. Advise: Thanks all I went with the 224cam/342gears/3200stall now which lt headers
  114. Missfire Problems??? HELP
  115. Does anyone have the GM part number for the long vette 02?
  116. stupid question about removing accessories from LS6 manifold
  117. When is the fast intake going to go down in price?
  118. Passenger Header Bolt
  119. Pulley install
  120. car on ls1sounds.com?
  121. coil packs
  122. is there a lightwieght battery?
  123. Under the Axle Duals
  124. help! exhaust question....
  125. Can i pass emissions if i remove my EGR system?
  126. Does anyone make a tri-Y style header?
  127. QTP (1 7/8s) Header guys inside
  128. Forum Director - Marker
  129. Need help with cooling system problem
  130. AIR system removal and pcm?
  131. Question on cutouts?
  132. Ls6 intake w/o EGR?
  133. Front engine mount plate pics
  134. TSP duals and banging and modifications
  135. quick question
  136. *WARNING* Cat-back melting the gas tank...Found when putting on the true duals.
  137. Header question ???
  138. flushing power steering fluid
  139. Flushing coolant
  140. is it possible?
  141. Pacesetter Lt's Question
  142. Loudmouth ? :)
  143. ypipe with single muffler dumped before axle?
  144. How much does a Borla catback weigh?
  145. question about headers
  146. Stock Motor making 311 to wheels would..
  147. Should I use the 6.0 truck filter or the LS1 oil filter for Iron Block 6.0 408
  148. which is louder?
  149. Who's LS1 SS is this?? It sounds amazing!
  150. what if rear o2's werent deleted correctly???
  151. Gains from headers w/ stock cats & Y-pipe...
  152. Alternator on the way out????
  153. Ebay Seller Fraud!!!!!
  154. How do you reach MM bolts w/lt headers? poly mount install looks near impossible
  155. header question
  156. buy it? or pass it and go for another?
  157. Help with exhaust
  158. What is needed for Pacesetter lt? For installation which tools?
  159. Putting on FIPK on Friday.
  160. GMMG Dual-Duals?
  161. Advise: I am in Calif does LT headers only make you fail smog by visable inspection?
  162. Smoke stack exhaust setup?
  163. SLP "Pulley" mod with smog pump delete??
  164. K&N air filter???
  165. will a regular lid fit my 85mm maf?
  166. SLP LT's
  167. borla no cats
  168. im waiting for spring and im bored
  169. TPIS 90mm TB
  170. Could I do this with my catback?
  171. Two LS6 intakes..Oops, what to do?
  172. to those with hooker headers...
  173. Anyone with a Borla XR-1 muffler please read!!
  174. O2 sensor question
  175. FYI: GM 85mm MAF Conversion
  176. Need help removing exhaust tips from old exhaust
  177. Will a 98-99 intake manifold, fit a 2002 LS1?
  178. Poly Motor Mounts or Mufflex Hanger?
  179. Pulley questions
  180. Noise coming from Intake Plz Help!
  181. Question about ORYs
  182. Alternator issues
  183. NE1 w/ Kooks 3.5" to 3" reducer?
  184. Stock Exhaust Manifolds, what year is best???
  185. Need Help,Car wont start..it just clicks
  186. underdrive/overdrive
  187. A4 exhaust
  188. Good experience with TSP/Pacesetter
  189. Tsp Y-pipe Not Fitting
  190. information on k&n filter..
  191. Y Pipe A Banging
  192. Pacesetter LTs and true duals question
  193. loud power steering pump
  194. which headers and ORY??
  195. ls6 intake
  196. Confused about header sizes
  197. me exhaust sucks! what should i get
  198. no spark, need dignosis
  199. All the Bolt Ons Vs. Rearend
  200. Hooker Stainless Steel
  201. random tech cat back
  202. will jethot longtubes that have the egr and air hookups work on my 02 trans am?
  203. Is heavy condensation smoke on cold start normal even in 62 degree weather?
  204. O2 Extensions?
  205. Header/exhaust question ?
  206. Does a 6.0 liter block take a different oil filter than a 5.7 liter block???
  207. Best Cat Back Exhaust for Mac mids with Cats.
  208. WHich mufflers on dual exhaust reduce noise the most?
  209. Headers and accessories
  210. 18 inc vs 12 inc bullet... is the longer one quieter or what?
  211. Does anyone sell a smoked clear lid?
  212. 02 Sensors
  213. Aftermarket HVC later on?
  214. 98 temp sensor in 00???
  215. QTP and Kooks Y pipe
  216. Performance loss???(Long)
  217. Ported TBs
  218. where can i get ATR mufflers?
  219. LS6 intake Pipe and plugs
  220. Have MAC Cat's improved, or are they still junk?
  221. Borla
  222. Desperate for MAF connector close up pic..
  223. Edelbrock Single Plane Carb Intake
  224. Rattle from under my car
  225. What Is The Best Lid To Get?
  226. Bolt size/thread/pitch on the 3 threaded holes on the ASP pulley?
  227. Sweet Thunder on stock manifolds and cats??
  228. Just built custom headers, Who has the best coating?
  229. Headers
  230. Side exhaust
  231. lids....not what your thinking
  232. A True Dual Setup
  233. Whisper Lid keeps popping off....
  234. Normal Idle rpms...M6
  235. SSRA or Induction Kit(FIPK)?
  236. 02 Sim install
  237. This cannot be good....
  238. Header Question..
  239. catback rankings
  240. Ticking after Pacesetter Install
  241. Depths / width of Sumps
  242. advise: If you installed the ASP crank pulley what did you think? Is it worth it?
  243. Misfires Help
  244. Exhaust Advice
  245. pacesetter = easy
  246. Any more bolt on's ?
  247. Help installing O2 sensor...Please
  248. price of LT
  249. SLP header install ?
  250. New Bassani Exhaust
