PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 [128] 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. after header install problem
  2. LS1, LS6 intake, pcv system? i did a search.
  3. Performance Header Coating Process (w/pictures)
  4. 02 Sensors
  5. exhaust leak?
  6. Mac Catback for a LSx, anyone have it or heard it?
  7. Exhaust Question
  8. Aluminum intake heat soak reduction test
  9. How to quiet an F-body with LT's and ORY??
  10. who DD w/ their katech tensioner?
  11. NGK Spark Plugs?
  12. Did i do good or what!!!!
  13. PS LT's installed. Link for writeup inside.
  14. Running like Crap!! Sputtering & popping thru exhaust
  15. LT1 catback on an LS1?
  16. magnaflow exhaust question
  17. LT's Y pipe and high flow cats --> SNIFFER TEST (I searched!)
  18. To cut or not to cut?(Ls6 intake)
  19. Corvette fuel rail covers.....what else do i need?
  20. What size is stock exhaust?
  21. LS2 intake on LS1 questions
  22. just bought 3'' stainless pipe, how much will shop charge to do dual exhaust overaxle
  23. Sound clips: ARH 1 7/8 + catted Y + SLP D/D
  24. ok guys need some help
  25. ws6 store egr delete
  26. Where can I...
  27. LS1 Fuel rail mystery hose...help!
  28. spintech muffler?
  29. LS2 intake manifold?
  30. Spark Plug Part #'s??
  31. Got my Gibson catback today
  32. Fast 90 Porting
  33. New Numbers for H/C/I LS2
  34. Broken manifold bolt! Help!
  35. water pump
  36. FAST 92mm Opened up to 100mm by Vengeance Racing
  37. cams
  38. Anybody know anything about these cheap throttle bodys?
  39. 98 camaro ss first mods?
  40. E-Cutout Input
  41. Rear End
  42. Cat-back or replace Stock Muffler?
  43. What psi is the power steering pump? And what line can I use.
  44. New Jersey exhaust set up
  45. im having problems with my 99 vette...help
  46. Performance Clutch
  47. Which Ram Air Setup?
  48. ordered my ARH Headers 1 3/4 catted y today, with free shipping
  49. SS exhaust smell
  50. Is there a thread comparing intake manifolds?
  51. SLP or Fast toys air lid?
  52. Should I go ahead and get an ls6 intake now?
  53. Oil??
  54. Problem with throttle body
  55. when do you need to tune?
  56. Pacesetter Mid-tubes?
  57. 2002 SD-455 Trans Am Tribute Car
  58. Headers?????
  59. Exhaust rub.. Need ideas
  60. Loudmouth with borla muffler sound?
  61. what all for puley install???
  62. egr
  63. Normal voltage at idle? P1637
  64. MAC cats/how do they flow compared to stock..
  65. how to tell a u/d pulley?
  66. is this an LS6 intake
  67. AEM Longtube Headers?
  68. tsp catted y ?
  69. New Weiand intake this summer Street Warrior??
  70. Dyno results from lpp headers
  71. Duals or not?
  72. Which headers to get
  73. Are there different depth crank pulleys? Mine is not long enough?
  74. Jet Hot Longtubes 1/78
  75. my camaro ss traction control
  76. LS6 vs LS2 intake
  77. pacesetter Y hitting the floor
  78. LS1 fans question
  79. TSP catted y-pipe...should I add rear o2's?
  80. Fuel Guage not reading fuel level correctly
  81. OEM waterproofing tar gunk on PCM connection?
  82. Headers
  83. pcv valve tube....where does it go???
  84. Not Compatible on a Auto Trans Conv. ?
  85. exhaust leaks
  86. A/C dripping on header tube?
  87. Rear End
  88. E3 Plugs?
  89. PS LT's installed! Some after-install help needed. Thanks
  90. What would cause this??
  91. O2 Sensor's Question....
  92. squeak noise
  93. because no one made an adaptor
  94. Gears Or LS6 Manifold
  95. high flow cats
  96. corvette O2's
  97. Magnaflow True Duals W/ PICS
  98. ls6
  99. Fast or PTM Throttle Body
  100. hp/tq guesstimation
  101. to block off or not to block off
  102. oil pan rear bolt part number
  103. Raptor light installed, at what rpm do i engage the light, mods inside
  104. catted y or ory with lm1
  105. band clamp
  106. just installed my LPP longtubes
  107. real quick ques. maybe an hour to completion PS LT's
  108. Need Some help Quick!! Please read
  109. best place on exhaust to measure AFR??
  110. QTP Lt's HVCL and AR Y?
  111. ls6 intake difference
  112. kooks ory NEED HELP ASAP!
  113. SLP Loudmouth I Resonator vs Moroso Spiral Flow
  114. How much More HP is Fast Intake VS LS6
  115. Grrr. Creeping cooling temp???
  116. New O2 Sensors??
  117. Need to find my cats
  118. I phoned lingenfelter and....
  119. Just out of curiosity, those with PS LT's,??
  120. exhaust setup
  121. 99 v6 camaro
  122. installing my pacesetter LTs
  123. Dumb exhaust question
  124. SLP LMII Question....
  125. DYNO results - MACs to ARH 1 7/8 headers
  126. How's the port match look on my fast 90?
  127. Why should I upgrade from a stock harmonic balancer?
  128. L92's... What cc are the intake runners?
  129. msd wires and ohm resistance WOW!!!
  130. Heads, Cam, and other opinions.
  131. Headers Question
  132. going from MACS to LT's is it worth it?
  133. Help me out with an exhaust leak problem...
  134. ?
  135. bent o2 sensor
  136. what could cause this?
  137. Intake manifold.
  138. Best Gaskets For Qtp Long Tube Headers?
  139. Does anyone make a 90mm Lid?
  140. where to buy ls6 egr adapter? - besides LPE?
  141. Knock sensors harness???
  142. L92 Swap into a Fbody, None of the PASS coils firing?
  143. LT install question
  144. Header Question????? Please Help
  145. hooker comp vs super comp headers
  146. Catch cans back in stock!
  147. Hole in TB blade?!
  148. Porting TB
  149. Which year of z06 MAF is unscreened?
  150. Vacuum Hose
  151. TB CAm question
  152. After FAST/TB installed, loud screeching noise coming from intake
  153. removing stock muffler
  154. Question about ignition
  155. LS6 Intake compatability
  156. Where can i get SLP CME tips????
  157. MAC LT's
  158. Anyone have a clue of what exhaust these might be?
  159. Let me know what you guys think!
  160. Question about Oil Catch Can
  161. a question
  162. brake line prob.....pics
  163. Balancer bolt Question
  164. LS2 intake on a LS1
  165. Finishing LTs Install
  166. AC Delco o2 P/N
  167. Idle Issues...
  168. Is my thermostat stuck?
  169. how restrictive is the LM1?
  170. Anyone know how to repair FAST90s?
  171. LS1 carb setup???
  172. Where to buy gasket kits?
  173. GMMG is off - 4" Mufflex is on
  174. Installing o2 sensor....
  175. poly motor mount lube?
  176. fuel rail covers, fast intake
  177. Custom camaro ram air
  178. Just spent over $1000... Hope it's cool!
  179. ok real hp gains
  180. Lowering temperature. What is involved?
  181. Throttle Body Porting
  182. Those With U/d Pulleys
  183. Cylinder head air bleeds
  184. Is this workable?
  185. Anyone go from the stock exhaust and think WTH did I do that for?
  186. Cam only with 90/90
  187. Cutout dangerous to bottom of rear pass. seat?
  188. TB questions
  189. Exhaust dumps
  190. Starter problem (I tried in General Maint. to no avail)
  191. header extensions
  192. will a more restrictive exhaust hurt my tune?
  193. What intake/tb combo is this?
  194. Coolant tank overflow???
  195. 3" duals, over the axle, w/Flowmaster singlechambers
  196. Im tired of slp....
  197. Radiator Hose ?
  198. Weight of LS1 shortblock?
  199. flow?
  200. New Q's on TB 80mm to 85mm
  201. motor mount problems
  202. original cutout question
  203. best ORY for pacesetters LTs
  204. headers bolting up to aftermarket catback.
  205. Can A Fast 92mm Upper shell fit a 90mm intake
  206. Cool exhaust idea
  207. cheapest place to buy 3in mandrel bent pipes
  208. Need Advice
  209. Borla XR1 True Duals W/Corsa Clones
  210. Long awaited lts
  211. hp expectations?
  212. tps sensor
  213. The pulley... is it really worth it?
  214. tsp true duals
  215. ultra z hood w/volant or k&n cai
  216. is this true?? straight pipes can damage valves?
  217. help me identify these headers
  218. 92 mm FAST question
  219. 98corvette ls1 cyclinder flooding
  220. Jet Hot coated MACs?
  221. mufflex 4" true duals or corsa?
  222. single plane vs 92/92
  223. Header Bolts?
  224. Borla owners with long tubes, got a question
  225. TB Teardown
  226. Coil harness ?
  227. over the axle out he back y peice...???
  228. Any experience with slide valve throttle bodies?
  229. Interesting find...
  230. what makes more power???
  231. 98 T/A Spark Plugs
  232. Truck plug wires vs ls1 and other
  233. Magnaflow Catback Stainless Grade
  234. HOw can I seat the crank pulley all the way?
  235. Header Selection Dilemma
  236. Cleaning your MAF????
  237. New LPP stainless Headers and Y
  238. Throwing P0155
  239. About to put back on my power steering after 2yrs is there a bolt for the pulley ?
  240. ? about ftp 85mm lid and 85 mm maf
  241. 5.3L Vin # Location
  242. Headers and Y-Pipe
  243. 408 with LS6... am I right about this?
  244. threw code p0133
  245. How about TDs completely straight piped?
  246. best 2.5" Y-pipe for stock manifolds
  247. Bolt-on Track gains...??
  248. Well, finally got everything on.
  249. High flow cats question???
  250. Stainless cat for my custom Y for QTP's
