- Anybody put in the LGM G2 Y-pipe 2.75" in their car?
- Is there anyway to adjust the throttle cable on a TCS car?
- QTP customer service is Top Notch!
- Thunder Racing Headers
- LS-6 Intake...Is it worth it to replace the LS-1 stock intake?
- What Guages?
- Electrical problem, need help!!!
- Need help with Stealth Air Box!!!
- Exhaust help needed
- Please tell me why this isn't true (true duals question)
- Please tell me why this isnt true
- FLP Longtubes / SLP Loudmouth Combo Question -->
- Holley intake Q
- Any drawbacks of SLP-Y-pipe?
- Manifold injector hole question & concern
- High Flow Cats
- MTI vs ASP pulley pros/cons
- What Epoxy to use for closing throttle body idle hole?
- NE1 actualy gain much with smooth bellows?
- Question about gaping gauge
- I know this should not be in here, but you guys seem to at least answer me
- Next Mod ??? HELP
- What about underdrives other than ASP
- boltons
- Cam or Headers
- X-PIPE
- I WANT ONE
- MAC LT headers and catback?
- Possible to take motor out the bottom without a lift
- Will an LS1 borla fit an LT1
- tire pressures?
- Knock Sensor - HELP!
- Gaskets for headers, best ones?
- MAF Ends
- PAGING NICK FILPPIDES
- Shaner vs Bauer
- Header Question
- shifter boot plastic frame
- bassani headers-what gain?
- Rubber boot for floor jack / jackstands
- New LS1 Items Available (check it out)
- Need advice on exhaust issues...
- QTP & Grot Headers
- X-Pipe with a Torque Arm Cross Brace???
- Hooker Cat-Back Any Good??
- Justin sutton's x-pipe (Any contact info)????
- WHICH BULLET IS LOUDER
- Gutted Cats
- SLP 85mm maf?
- Long Tube Headers SLP or Hooker
- Racenetone
- LS1/6 in 69' Camaro ???
- Ported TB
- Please help car still not running right after longtube install...
- FRA ?
- write-up on the 3-1116 ES poly motor mount?
- What do you think of true dual? Should I do it?
- What mod should I get next?
- o2 sims?
- give me your thoughts on this stuff
- Where are front o2 sensors?
- header choice? SLP or Hooker
- Best Cat-Back / Header combo
- driving with open headers
- fast toys ram air& direct flow combo vs. k&n Fipk ?!!!!
- Radiator Flushin? Any how to guides?
- selling SLP loudmouth and SLP 3" Y-pipe!!!
- could i bend the y-pipe instead of my long tubes if i....
- ASP pulley question?
- EGR w/LS6 Intake Question
- Does someone manufacture a 3" Y-pipe for the LS1 cars?
- Best place to get a 12 Bolt
- LS1 motorsport lid or SLP?
- Merge collectors?
- new longtubes
- PPC Headers?
- Y-pipe for SLP LTs and Mufflex 4"
- X vs Y vs H
- FRONT BUMPER SUPPORT QUES?
- Stock CME with Jet-Hot LTs (Sound)
- Ground Clearence with MACs
- Drain Plug???
- Are QTP headers coated with Jet-Hot?
- install dynomax
- Whats the height of the stock ram air lower airbox?
- Throttle Body??? inside
- Stock rear
- exhaust debate
- Off-Road Y-pipe
- Seal Airbix Hood Question
- slp headers
- Difference between 01 trans am and 01 ws6?
- Direct-Flow Lid install for 2002 Firehawk
- Any way to fix broken ls6 intake
- This is a cool way to do an electric water pump......
- Sticky Pedal
- LS6 dyno results before/after
- 380 rwhp using all stock LS1 internals?
- Why is stock PCV grounded?
- Help: Need to make choice btw Stealth Airbox and Direct-Flo lid!
- Need a 3" muffer with inlet and outlet on same side...
- Need part number for ASP crank pulley belt
- Any info on muffer flow figures?
- What Y-Pipe with Corsa CatBack ?
- Why was the topic(what do you think closed?)
- Anyone know anything about the new Spintech catback?
- exhaust setup information.? need help pleae
- Question bout 4.10's
- ASP pulley problem ( HELP)
- Oil Consumption solved....
- white tip spark plugs?
- rasp???
- How much does a 3" pipe flow?
- thermostat?
- poly motor mounts/ where do spacers go?
- SES light problems
- which induction piece
- Useful life of K&N? Opinions....
- Just installed my Bauer ported TB
- 3200 VIG OR HOOKERS LT
- Car stutters and backfires over 4K RPM after Long tube install...
- ASP Pulley + Double Timing Chain Poll
- MAFT
- Exhaust Shop Help
- anybody have aftermarket throttle body?
- What do you think?
- Sub Frame Connectors good for Drag Racing?
- Exhaust install question
- SLP Y-pipe
- Would I benefit from headers?
- cutout and computer?
- Has anyone tried the new 17" et streeets??
- Fast Toys ram air kit question?
- Another question about the squeeling??
- Help installing ASP alternator Pulley
- LS6 Intake
- When closed, would cutouts decrease power due to turbulence in exhaust flow?
- Help!! loudmouth exhaust
- Who's running 3.5" header collectors... Beeler... Beeler
- Need belt sizes for ASP crank and alt. pulleys!
- MAF causes tranny issue's??????
- Need help fast ....( jet hot LT)
- New 24" Smooth Tube and 30" Chambered
- Considering a Y-Pipe
- Borla muffler
- PORTED MAF END TEST ON A4 RESULTS
- which of these two do you think is the louder one ???
- K&N FIPKII info???
- which one of these is a louder exhaust ???
- Pics of the new Supersucker "track" lower airbox
- Where can I find a pre-bent (mandrel) 3.5" intermediate pipe?
- Filter tray bridge cut out for more air....... why not?
- QTP's, and then just dumps....
- Autometer FP gauge questions...
- cut out question
- Camaro
- QTP Headers
- Opinions on the lightest SFC 's available....
- Will a catback for an LS1 fit onto an LT1?
- Fuel line question (lines to/from fuel rail)
- ready 2 bolt on hp
- Install cats in Hooker Y Pipe?
- Anyone have a tranny cooler write-up...
- short belt ?????
- Questions about 00' C5.. please help!!
- Need PS pump pulley puller
- At what point do you need dual 3"...
- Y-pipe w/cats confusion
- true duals v. gmmg !??!?!!
- ASP and power problem
- Random Tech Cat Question
- mufflers
- Hooker y -pipe pics ?
- Ultimate Exhaust Installed!
- idle problem
- idol problem
- idol problem
- Need some help...
- Long Tubes
- Battery relocation problem help
- MODS & WARRANTIES
- Equal Length Y-Pipe
- 2000-02 Hooker long tubes now in stock!
- Single or Dual Outet Catback Poll
- which way should i go???
- NEW Magnaflow catback just released... check it out.....
- 85mm MAF + Stealth Air Box?
- Bauer High Flow TB pics!, Finally
- ASP pulley ?
- new problem
- code po300
- code po300
- Hooker exhaust over Flowmaster??
- y pipe question
- Camaro coming back??
- more mods?? help!!
- Removing the Air Condition System..
- are any of you guys going to reply to my post ??
- Need Help Which Mods should I get?
- have the loudmouth and i'm considering this set-up? please help
- Long Tube Header Opinion
- Any opinions on POR-20 or other High temp paint?
- Quiet mufflers for 3" true duals.
- How to determine optimal exhaust pipe size?
- TSP Air Lid. 2 thumbs up :)
- My Optima Yellow top battery bit the dust after only 15 months!
- Long Tube Header Poll VERY Important Poll
- who makes the best maf???
- Anybody know whats up w PPO?
- Jet-Hot Headers Install Questions
- Poll Those with headers...did your oil consumption increase?
- random tech cats
- Alittle concerned about FLP headers...
- Loudmouth
- help on slp pully
- Quick Alternator testing question
- bleeding power steering pump
- car keeps dying?
- Best Bang for the New Buck
- Installed new flp dual cutouts
- a response to QTP and their Y-pipe
- Ready to Spend Some Serious Cash, Need Advice
- ASP Crank Pulley and belt question
- test
- Hooker Cat-Back Question
- Hooker Cat-Back Flow?
- Speed,Inc true duals
- Does Magnaflow sell just the muffler?
- Belt problems.
- Anyone replace the Dual/Dual over-axle pipe with...
- Air induction Q's.....
- Removing MAP Sensor From LS6 Intake...
- LS6 MAF
- ANYONE KNOW ANUTHING ABOUT JEGS UNDERDRIVE PULEY.
- lid and bellows?
- Engine Swap (LT1 for LS1 for LS6)
- Borla XR1 and xpipe
- Where to buy Dr Gas Xpipe??
- Hooker Header Corrosion??
- High Idle, Than slow to come Down?
- Dynomax UltraFlo quiet?
- Harlan Shift Light Install help!!
- Options for swapping out loudmouth resonator
- bassani mid-length headers?
- Need SLP CAI mod.......pain in the butt!!!!!!!!!!
- Exaust
- Meziere Water Pump For LS1
