PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 [314] 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. mac headers/ no cats
  2. TB port/polish help
  3. Fuel rail fitting for slip on style to AN
  4. stock or not
  5. Help!
  6. HP Loss?
  7. Oxygen sensors
  8. Oxygen sensors
  9. With Only Bolt-Ons.....
  10. Can you add cats to the Hooker OR Y-pipe?
  11. Anyone with info on TTS long tubes
  12. Horsepower gains?
  13. Installing lid ?
  14. Help, Im Leaking!!! Leaking!!!!!
  15. Fuel injection service...when?
  16. 60k...what needs to be serviced?
  17. FLP's and Drain Plug Issue
  18. SLP CAI
  19. How much power have you all picked up after tune?
  20. People with the Fernco bellows, c'min
  21. tips for the slp dual-dual exhaust??
  22. Anyone interested in brackets for the Harlan Shiftlight?
  23. dual cutouts vs single
  24. REMOVING CATS
  25. My homemade catch can(pics)
  26. X-pipe with fake tips(pic)
  27. Looking for information on the Harlan Two step!
  28. HELP FAST!!!!
  29. header install
  30. X pipe with chambered Sweet Thunder mufflers?
  31. Bassani Longtube Headers???
  32. Bassani Longtube Headers???
  33. LS1 vs LS6
  34. How fast with stock exhaust manifolds?
  35. grotyohann headers?
  36. what is wrong with my car
  37. Directions for Changing Plugs
  38. MAFs and Tuning
  39. Can the rear o2's and front o2's be swapped?
  40. ram air?
  41. Anyone have the Lingenfelter Signature Series Aluminum intake?? Gains???
  42. Best Flowing 3" Cats?
  43. PLEASE HELP!!! car wont start...maybe alarm problem?
  44. Used the search, still confused, which headers
  45. My track time blows...
  46. Exhaust cut outs
  47. Has anybody done a header swap?
  48. Fitting for a greddy catch can??? 9mm or 15mm
  49. Where to run wires on Drivers side
  50. ! cats with hooker cat-back
  51. Will X-pipe system fit w/spohn torque arm??
  52. bought hooker headers and ypipe what else do i need
  53. LS6 intake
  54. Anyone using the new Hedman LS1 Block Hugger headers?
  55. Anyone in Houston w/ True Duals
  56. Crimp/Dent in SLP Dual/Dual I-Pipe
  57. Dr. Gas True Duals on M6 ( PICS/VIDEO )>>>
  58. Is my exhaust FUBAR?
  59. MAFT @ stk MAF or Ported MAF
  60. Pics of the new QTP QTEC Y Pipe & Header Info
  61. need help!
  62. SLP hood
  63. Ultra-Z Hood: blockoff plate in scoop?
  64. LS6 throttlebody vs LS1 throttlebody ????
  65. Using a crossflow muffler as Ypipe
  66. turbos???
  67. Car Weight
  68. truth be told
  69. truth be told
  70. differences???
  71. off road pipes
  72. SLP Air Temperature Module???
  73. Installed my Air/Fuel Guaged HELP!!!
  74. Katech Tensioner
  75. OK heres a question....Who makes a fuel cell that will fit our cars?
  76. FTRA install help
  77. are 98+ injectors shorter than 97- injectors or svo's?
  78. Gas tank from Speed Inc.....
  79. Ok, about to install my Hooker LT's
  80. Wanted: Dynomouth sound clips
  81. shifters -- stock hurst w/lss vs. 5.0 vs. other
  82. MAF Sensor direction!!!
  83. size of I-pipe for 2000 Z28
  84. Exhaust cut outs
  85. need help with 02's.......
  86. Volant ? where does cold air come from on Z28(nonSS)
  87. Port and polishing TB..
  88. Best power adder?
  89. Cats
  90. Dr. Gas
  91. How Much Hp from Direct-Flo Lid, Loud Mouth and SLP Y-pipe
  92. FLPs and emissions?
  93. Bad Detonation could this be the problem???
  94. WTF is this Banging?
  95. Coil Relocation Kit
  96. Throttle Stop Mod
  97. Ported TB ?
  98. direct hits ignition?
  99. Another Ported MAF?
  100. Which headers
  101. Open headers?
  102. Will stock injector work on a 382 Stroker?
  103. Gmmg!!!!!!! Com inside
  104. Okay to pull AIR pump fuses after I remove the pump?
  105. whats the story for pulleys?
  106. Aftermarket Ls1/Ls6 intake Manifolds
  107. What diamter is the collector on the slp y-pipe?
  108. What Diameter is the Loud Mouth Over the Axle Pipe?
  109. Exhaust experts within, please!!
  110. Help identify this intake manifold
  111. quick core related radiater question
  112. Header Questions
  113. Paging ND4SPD !
  114. best mod for $500
  115. who uses a f/p regulator and who doesnt..
  116. Loudmouth?....
  117. Give me your Input!!!!!
  118. Anyone Sell Just an Over the Axle Pipe?
  119. porting MAF
  120. Cutouts After the Cats on Stock Exhaust
  121. De-screened MAF vs Ported MAF
  122. Throttle Body Bypass help
  123. Straight scoop on MSD ignitions for LS1
  124. Another oil catch tank report.
  125. SES Light 2 weeks after Header Install!! HELP
  126. The Next Generation G-TECH/Pro Performance Meter
  127. LS6 Oil Valley Cover and PCV system
  128. SLP Y-Pipe/sportlines
  129. loudmouth comparison
  130. EGR MOD QUESTION
  131. RAM Clutch
  132. Replacing starter - pretty straight forward?
  133. Any easy bolt on s for 2002 LS6 to make more power?
  134. Anybody else thought about electronic power steering?
  135. friends y pipe!
  136. Anyway to make fans come on?
  137. Who has modded the factory airlid and modified the silencers?
  138. Anyone have a 2OTL on an LS1?
  139. fuel rail/injector re-install help needed
  140. Air Induction on 94 Z28 with LS1 Installed
  141. BUmp StaRT??? now whistling..
  142. money to spend
  143. Larry pulley????
  144. slp loudmouth
  145. New and need help on what to do next
  146. fuel filter
  147. A HUGE problem with FLP headers ... they are mispackaging the headers!
  148. 3.5" Collectors/Cutout/Y-Pipe
  149. BG ram air mod
  150. WTF, I blew the AIR tube right off the Grott headers!!
  151. what do u think??? (exhaust)
  152. What size for Drag lites and M/T Streets...
  153. The best way to get a deep tone ?
  154. MAF to TB connector tube: who makes one for Fbod?
  155. Bolt question?
  156. FLP owners > How many O2 sensor extentions needed?
  157. reseting my ecu
  158. Misfires on each cylinder..please help asap
  159. Will Hooker's "98-99" longtubes work with an '01 car?
  160. anyone have a sound bite of Mufflex?
  161. Best Sound and Ideas
  162. Porting Plastic Intake Manifold
  163. help with ASP tensioner pulley
  164. True duals VS Borla catback
  165. Bigger homemade FTRA good idea??
  166. MAC headers, air valves burning up???
  167. How to keep Mufflex Y from banging?
  168. MAC combo question
  169. Ramps For Installing Headers!!!!
  170. question on turndowns....
  171. MSD STACKER 8 IGNITION
  172. Here is some pics of the Holley intake done by GTP!!!!!
  173. Will FRA mod help my '99 SS?
  174. Foreman Motorsports Catch can Update
  175. K&N Generation II FIPK vs Whisper Air Induction Lid
  176. Putting Hooker LT's on tomorrow....need advice on how high to get the car up??
  177. nos and maf
  178. nos and maf
  179. loudmouth and dealership
  180. resonator vs dynomax bullet muffler
  181. Screen or no screen. That is the question........
  182. New style thermostat mod
  183. Dynatech Longtubes??
  184. when to change injectors
  185. supercharger and nitrous?
  186. How about this exhaust?
  187. Banks system
  188. Stock 2000 SS Torque?
  189. FLP Problem!!!
  190. Stupid question, how do I install new O2s?
  191. ATR exh?
  192. Battery disconnect switch
  193. Cost analysis - bolt-ons - HP gain per $ spent
  194. ported throttle body
  195. Is ram air hidden HP?
  196. lil blue flame
  197. jack stands or ramps required for supersucker install?
  198. Who uses a Shanner 2 TB?
  199. Exhaust/ Running Rich Cond.
  200. problem with battery after installing gutted cats!
  201. Dynomax 17536 installed!!!!
  202. New mod!
  203. SFC install help
  204. header bolts
  205. Whats the Largest Diameter Pipe that Will Fit Over the Rear Axle on Passenger Side?
  206. cat back install?
  207. FLP header owners inside...
  208. going to off road pipe, should I get new gaskets?
  209. Which is more practical when considering space limitations Y or True Duals?
  210. coolant system bleed
  211. power steering pump - trashed - help!
  212. x-pipe on my 98 T/A
  213. Need help figuring out a problem
  214. Wiring up an Aeromotive inline pump
  215. My Loudmouth making a "blowback" sound after i get off the throttle...
  216. Anyone know the stock size of the throttle body blade hole?
  217. IAT mod question
  218. ORY + Stock muffler...
  219. Proper welding procedures for electronics
  220. Can I go wrong???
  221. cut out question
  222. 98-99 A.I.R fittings.
  223. Need Help fast!
  224. What filter do you guys run at the track?
  225. SPEED CONTROL
  226. Who has........
  227. Custom exhaust
  228. corsa vs. bassani
  229. Mac ORY pipe quetion
  230. How to port the throttle body
  231. Just to let you know
  232. what other bolt-ons can I do?
  233. Badly smashed Corsa??
  234. Headers- mids vs LT's
  235. Strange fuel delivery problem
  236. Hooker Longtubes are on but need help with autotap readings
  237. muffler advice
  238. Anybody know what belts you run with the ATI dampner?
  239. Air pumps???
  240. GIve me your thoughts on my upcomming exhaust
  241. Mac headers and cat pipe
  242. My Borla is almost 2 inches below my bumper, is it to low? Anyone have pics of theirs
  243. Any Bassani header updates
  244. old man in the way!!!
  245. Which size injectors are you running in your 408-436ci NA setup??
  246. EGR Leaking, Need Help!
  247. How loud?!
  248. Holly (LS1) Intake > Help!!
  249. EGR
  250. wrapped headers?
