PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 [274] 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Y pipe question
  2. Removing AIR
  3. Air Filters (Oiled vs. Paper)
  4. whats louder? lt/cats/slpdd, or stock/stock/gmmg?
  5. ASP Pulley worth it or not?
  6. Intake swap ?
  7. Descreened MAF
  8. Question about lids
  9. Ticking noise near collector...normal??
  10. Pacestter Headers what y-pipe?
  11. cooling issues...
  12. Jet Hot catted Y pipe clamps?
  13. Removeable cats in custom y-pipe
  14. Anyone ever get an EVAP code
  15. Ditching PCV
  16. Shaner, LSX, or MTI Throttle Body?
  17. Powerband comparison between ls1 and ls6 intake?
  18. drilling the throttlebody? (?) car not running well
  19. Anyone replace their ignition cylinder?
  20. Cant stop oil leak!
  21. Flowtech?
  22. Accurate Machine Works catch can
  23. What makes one set of longtubes different/better than another?
  24. Must choose between theese 2 mufflers (already have them ).
  25. Ls6 Intake
  26. hooker header question????
  27. MACs Questions
  28. true dual suggestions
  29. Will LT's solve the problem?
  30. Any info on hedman LT and hedder back system
  31. Mod'd OEM valve covers
  32. Help with flowtech headers
  33. a.i.r.removal
  34. fans not working...help
  35. Got My GMMG installed !!!
  36. LSX work with stock/ported throttle body?
  37. Idler Pulley Removal Procedure? Just a bolt?
  38. Question about bullet muffler???
  39. how much power loss from a stock catback on a h&c car??
  40. Nobody has Hooker catback in stock what are similar options?
  41. Problems after header install
  42. FLPs bang the floorboard
  43. Drivers Side Header bend angle
  44. can i run w/o cats in PA
  45. stock ported TB VS fast 78MM TB w/ lsx?
  46. whining noise?
  47. Loudmouth removed, time for duals...need suggestions on what mufflers to use.
  48. Headers and Exhaust?? need a little help
  49. mac headers with 3 inch x-pipe pics
  50. GMMG Exhaust new tips
  51. cutouts
  52. MAF installed backwards??
  53. Y pipe for Jet Hot headers
  54. FAST 78mm TB : Pics inside
  55. unplugged IAT sensor...
  56. Is there a better MAF then the SLP 85mm? Pro-M???
  57. LSX 78MM tb
  58. How much loss thru WS6 vs Magnaflow?
  59. need help
  60. lt install
  61. EGR Gasket slipping
  62. Need help on choosing next mods
  63. AIR pump disable question...
  64. QTP Headers Installed!
  65. Harmonic balancer pin kit needed
  66. MACs midlength....
  67. Removing AIR pump howto?
  68. SLP Dual Outlet or Magnaflow?
  69. Open headers + flashing SES light?
  70. Will a LT1 y pipe fit on my car?
  71. Fixed an exhaust leak and now I idle rough.
  72. FLP vs. Jet-Hot LT headers??
  73. 02 sensors
  74. MAC headers collector mod
  75. Will this intake/exhaust setup work?
  76. Y-Pipe ?
  77. What is the most power anyone has made through a Hooker catback?
  78. SSRA Cai and SLP lid
  79. Hooker Y-Pipe
  80. Look what I caught in my catch can!
  81. Cut out questions...
  82. Suggestions to quiet down car??
  83. Power differences between lt & st headers
  84. Duals??
  85. Removing cats - pros and cons
  86. Bought a magnaflow 14267 Muffler is it the right one?
  87. Least expensive LT's and Y..and why?
  88. Problems with Crank Shaft Bolt!!!!!!!!
  89. Borla/Dyno Mouth Owners here
  90. Just installed Jet-Hot long tubes.
  91. ? about vacuum pump
  92. Opinions on exhaust setup please
  93. Pacesetter Y-pipe owners come in.
  94. ASP pulley wont stop squeaking. Help.
  95. Coolant
  96. Where do you buy GMMG Exhaust
  97. Crankcase Vent
  98. Hooker Y-pipe banging, leaking...clamps the culprit???
  99. Does anyone with WS6 use the BG Ram Air setup?
  100. SDPC Ported Throttle Body?
  101. IAT Sensor
  102. O2 delete plug?
  103. Good Aftermarket PS Pump?
  104. LS1 Meziere install help
  105. Who makes a sheetmetal intake that works
  106. No spark to passenger side
  107. Volant Cold Air Induction Owners, Any good verses a new air lid
  108. Which header should I get-$$ no issue
  109. Need quick answer Short belt.
  110. pulley install problems
  111. Engine missing-plug #8 is clean
  112. Low Coolant light ????
  113. electric waterpump?
  114. March Fluid pulley ?
  115. any of you C5 guys have electic cutouts on a stock exhaust?
  116. No cats or no muffler
  117. Installed Hooker LT w/ORYP...add cutout??
  118. What Driveshaft safety loop w/ true duals?
  119. whistling again
  120. Weight of Stainless Headers
  121. How do I test a Idle Air motor?
  122. rubbing SLP lid???
  123. lt install?
  124. Hissing from the exhaust
  125. 90mm, but stock maf
  126. LSX intake
  127. SLP Headers, Cats, and Loudmouth
  128. Port matching a LSX intake
  129. SLP Loudmouth Muffler
  130. Can't wait for the UPS guy !!
  131. mac header's installed now Im hitting the rev limiter
  132. Belt size?
  133. LSX on a 2000, coolent vent tubes?
  134. Removable Cats
  135. lg long tubes
  136. Quick question
  137. 90mm LSX install complete...pics within
  138. LS6 Manifold Install?
  139. Hose Clamp Tool
  140. Do I need O2 sims or can I delete rear codes?
  141. March = 11lb , ASP = 6lb , stock = 10.5lb
  142. Breathers
  143. jet hot rubbing
  144. anybody using the holley ls1 aluminum intake
  145. Spark Plug Holder
  146. Bassani header install
  147. ? about wiring meizere
  148. Question about the FTRA & SLPs deal
  149. ORY Installation???
  150. CarSound High Flow Cats.....any good?
  151. Wow this is a doozy.
  152. loud as I can get!!!!!
  153. Do i need tuning? Opinions please
  154. Just installed Moroso spiral flow
  155. what new bolt do i need with the ASP pulley?
  156. Ported Throttle body worth it??
  157. Pully Problems
  158. Should I buy the relay kit for the Meziere EWP, or just wire it up the way it is?
  159. stock header bolt?
  160. qtp elec cutout bolt to hooker cutout yah or nah??
  161. Is this dent in header ok, buying soon!
  162. Pretty General problem...
  163. Muffler volumes & tone / suggestions?
  164. Which plug to pick??
  165. It never ends...
  166. lt headers
  167. Anyone else see Jett Hott pics??
  168. Hey FAST!
  169. LSX intake manifold?
  170. New Pulley, Do I need a Tune?
  171. Ok I got the B1 cam and Muffler, Would gain any power by putting a borla on
  172. Raising Idle in an A4.....how??
  173. Weird buildup inside lower coolant hose !
  174. guage mounting
  175. help me decide, gmpp intake or ls6
  176. I don't have EGR Pipe?
  177. Anyone powder coated their intake yet?
  178. What size cutout do i need?
  179. Ordering a Lid, do i need Filter?
  180. Cleaning the intake... got a couple q's
  181. Complete Exhaust System Recommended
  182. header question... please help
  183. Pics of my new TPIS 90mm TB
  184. Voltage fluctuates at idle only after new alternator?
  185. my macs with loud mouth is way to loud
  186. question about throttle body bypass mod
  187. 78 or 90 mm intake for cam only soon to be H/C car?
  188. air intake question...
  189. Gutting Your Cats???
  190. k@n fipk vs lid and fast toys ram air
  191. Adjust throttle cable on TB so BLADE opens 100%
  192. Dynatech SuperMaxx Headers??? OBD-II Compliant!!
  193. Quieting the LM/Header exhaust --> H/C soon
  194. True Duals
  195. LT headers: pacesetter vs flowtech?
  196. Rattling Under The Car
  197. Pics of 3" ORY w/dual cutouts and electric openers.
  198. first ls1 header install and a small problem...
  199. Would the FAST intake benefit a cam/bolt-on car w/the LS6 intake?
  200. JBA headers...why different models?
  201. Anyone running Borla wde open, GET A BULLETT MUFFLER!
  202. What's the part# for the filter on the FIPK
  203. Side Exit True Duals
  204. just received the borla
  205. Volant Cold Air Induction
  206. True Duals w/ SLP Subframe connectors
  207. Who is in the 10s? (NA)
  208. Getting a custom Y-pipe made... 3" vs 2.5"?
  209. is anyone having a problem with kooks y-pipe banging the floor?
  210. cut outs 2 or 1
  211. whats the best lt headers
  212. March vs. ASP Pulley
  213. Electric Cut-Outs
  214. poly motor mounts how do you install?
  215. Battery relocation,,, what method did you guys use to splice into the wires up front?
  216. Which gauges to buy?
  217. spohn's new torque arm (stock mounting location) won't fit with my headers
  218. FLP's to 1 7/8 headers
  219. Noticable HP/TQ Gains after True Duals?
  220. Slp Headers (wiring Harness Extension)
  221. bullet muffler help needed.
  222. Switching exhaust (SLP-GMMG)
  223. Ls6?
  224. Clear Airlid, then SES?
  225. what are your iat's (air box related)
  226. Kooks header questions
  227. Katech C5R valve covers
  228. Header bolts
  229. Anybody experience problems with their AC unit?
  230. Anyone using Carsound cats?
  231. Will this size belt work for ASP pulley?
  232. SMH pcv mod?!
  233. Coil packs
  234. Totally Bummed!!
  235. Has anybody used this type of intake w/...
  236. Just put LS6 intake on, have a connector left over?
  237. Header wrap?????
  238. Hooker Headers =8mph In 1/4
  239. If it's available where can I get a lid kit that...
  240. Where to find breather filter for AIR tube?
  241. power diff between cats and offroad pipe
  242. MTI tb noise
  243. How Low are LT's?
  244. true duals
  245. Does your Jet Hot coating look like this after 18 months?
  246. true duals and emissions
  247. striped the rear header bolt,PLEASE HELP!
  248. egr removlal HELP!!!
  249. Mufflers
  250. volt guage moves around alot
