PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 [114] 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. emissions legal long tubes
  2. Throttle Cable Bracket
  3. ws6 question
  4. Porting Throttle Body
  5. ASP Crank Pulley
  6. in need of ls6 manifold
  7. cracked header
  8. LPP headers and TSP true duals??
  9. LQ4 w/ L92 heads Acc Problem
  10. Base tuning suggestions for now with maf and then 3 bar later
  11. 2006 z06 MAF tables
  12. Ordered my Cutout! price for welding?
  13. truck harness for build up?
  14. Speed Inc True Duals
  15. MAF problems
  16. Where to get Goodyear HIgh miler Coolant hoses
  17. Arh
  18. Anyone have problem with JANTZER PERFORMANCE?
  19. Oval inlet/exit Muffler
  20. Pacesetter longtubes vs texas speed 1 7/8 Longtubes
  21. Annoyingly Loud, Raspy, and Offensive... Awesomeness
  22. water pump leak
  23. Electric Water pump LS1/LS2
  24. Installed ported tbody now P0122 code?
  25. For everyone that bitches about replacing spark plugs in an f-body
  26. Need Advice!
  27. True Dual With Powerstick
  28. Mr Gasket Thermostat?
  29. 243 bent valves
  30. Dex out the tailpipes?
  31. How hard to change out the H20 pump, cam, valve springs?
  32. How to tell if an intake is LS1 or LS6?
  33. opening manifold from 78 to 90mm???
  34. Where is the TPS on a LS2
  35. Weiland intake
  36. Car wont start after de-mod.
  37. WS6 Ram Air Q's
  38. borla or magnaflow
  39. Quick Time Performance or Borla Headers
  40. Just Seen The New Gm Crate Motors
  41. Get old muffler back ?
  42. Ls6 intake
  43. Anyone ever had their exhaust smell like a diesel truck?
  44. Hooker CB Bolt Size
  45. how long does it take to do !air?
  46. Single vs Double Roller?
  47. installing LT's tomorrow... got a couple q's
  48. 1 7/8" headers worth it, 402??
  49. need help making 6-wire truck harness
  50. Magnaflow or wait for a GMMG GP?
  51. anyone ran these round magnaflow's?
  52. What else do I need for my GMMG/LPP headers setup?
  53. Need some Input 01 SS
  54. Sparks and wires
  55. Replaced 02 Sensors now throws another code help...
  56. HELP! Running lean?
  57. yes another dumb header question
  58. Opinions Wanted, Valuable Mods available?
  59. Guys that have made there own true duals
  60. engine mount not bolting back on
  61. Do I need a valve cover breather for my NA car?
  62. help this newb out guys...lots of pictures...
  63. What injectors for a 408?
  64. Vibrant Race Muffler owners Inside
  65. Any NA stock cube people running TR-6 NGK's?
  66. notching cross member
  67. exhaust system
  68. Plugs and gap for 408?
  69. New intake manifold!!!!
  70. Cats or bullets
  71. JVT headers
  72. LS2/truck coils on LS1 motor
  73. SLP Powerflo Catback
  74. ssra vs ftra vs jaam?
  75. Oil Pressure Sensor?
  76. DMH performance tough to get a hold of?
  77. Loudmouth question.
  78. Best bang 4 buck air induction
  79. SLP lid
  80. Jegs catback
  81. Looking for a fast answer?
  82. LT maintenance
  83. FAST 90/90 vs Victor Jr?
  84. Hooker slowing me down?
  85. ls6 intake from factory?????
  86. write ups?
  87. sending unit 90*
  88. E Cutout question
  89. have 800 what else should I buy?
  90. Problem with gas pedal
  91. Turn One steering pump.
  92. coolant temp sensor q
  93. pcv setup, i think i have it setup wrong
  94. Headers.....
  95. 4" dumped at the axle
  96. Hooker Maxflow is on. Catback style.
  97. Painting Ugly Pipes?
  98. Cutting your hood.........LOOK
  99. Help!!!!!!!!!!!
  100. part number please?
  101. Change tune for cutout?
  102. MOtor mount nut
  103. Exhaust opinions needed
  104. Buying a muffler
  105. ls1 brackets on a 6.0L block?
  106. manual cutout?
  107. TSP rumbler
  108. Just installed SLP UD Pulley... PITA!
  109. California, headers, cam, and smog....???
  110. Header help
  111. Whining Fuel pump and other problems.
  112. what size bolt for GMPP Carb intake
  113. changed some things, still no fire.
  114. Ported tbody and slp maf???
  115. air/fuel problem after i hit a puddle
  116. Anyone have any ideas why ...
  117. Ligenfelter/Wiend 80mm intake?
  118. what to do when this happens *pic*
  119. Lt's + Tsp rumbler X
  120. LS2 intake on LS1 with 90mm TB?
  121. ARP head studs questions
  122. the perfect LS6 intake rib shave!
  123. Quick Cut out Question
  124. Magnaflow exauhst tip came looking like this...
  125. Love the BBK 80mm
  126. Custom exhaust opinions wanted!
  127. O2 signal wire
  128. anyone running the gm 4 barrel fuel injected intake?
  129. gmmg+lts+cme+ cats
  130. 6.0 Swap
  131. Thoughts on muffler/bullet dumped after ORY?
  132. do I need a fuel pump
  133. New Exhaust
  134. installing GMMG, LPP LT headers, ORY..jack stands or ramps???
  135. Question about the LS2 intake.
  136. fast 90 help?
  137. Shit up at my rad
  138. which charcoal canister...
  139. Weiand Street Warrior Intake
  140. Question on TBs
  141. Front O2s
  142. Headers and y pipe
  143. lsx guys, car tries to start, but wont fire.
  144. Alternator: Look at this pic
  145. Is this muffler available
  146. ls6 swap question
  147. Random pink wire....
  148. quick question about engine harness
  149. Can a 1999 Camaro SS Gas Tank Directly Fit a 1998 Trans Am?
  150. Cutout Exhaust
  151. Do LPP's leak like QTP's?
  152. So I see how they Port LS2 intakes.....
  153. What TB for a ls6 intake?
  154. tb bypass or cut and cap
  155. Deals on msd plug wires?
  156. Gasket help?
  157. where can I purchase billet ss grill
  158. QTF header not fit on my Camaro
  159. difference in coolant lines
  160. Straight true duals-no H or X pipe
  161. Best STock Exhaust Manifolds
  162. GMMG Exhaust
  163. Sunoco hood and low profile edelbrock elbow clearance?
  164. LQ4 bottomend/LS1 topend Parts needed?
  165. installing the FAST
  166. question about headers?
  167. Cut Out Question!
  168. Do any of the LS based motors use a 8 rib belt setup?
  169. fast92mm install question
  170. Header Install
  171. Who ports FAST intakes?
  172. Ms3 112 Vs 113
  173. Custom wiring for electric cutout
  174. Fitment Problem with QTP longtubes
  175. What intake manifold does a stock 2000 corvette have?
  176. So I dynod tonight (1st) and only made 8 HP more open cutout
  177. LS6 or Fast 92
  178. TB bypass cooling problem
  179. Edelbrock cast elbow vs intakeelbows.com elbow
  180. UNPLUG O2`s
  181. Speed Density bellow?
  182. 02 wideband and tranny temp guage instail
  183. burning oil+catch can+no pcv valve
  184. Hard Head Throttle Bodies??
  185. P1-SC Procharger GTO parts wanted
  186. DISTRIBUTED anyone!!!
  187. alternator od pullley
  188. Can't get Prothane Motor Mounts to line up
  189. worse CAI help please
  190. Anyone run no catback?
  191. Header Install Check List.
  192. power steering pump
  193. 2004 corvette intake manifold
  194. Borla & Cut out Q.
  195. Exhaust ? 3", 4" or Bassini True duals
  196. Fast Porting
  197. new exhaust clip/pics
  198. Edelbrock manifold ?
  199. tsp band clamps
  200. Anyone else ever have a cracking problem with the FAST?
  201. What mod should i do next??
  202. AIR/EGR Delete Question
  203. Rubber Coupler (92mm to Fast toys & MAF)
  204. Street Warrior intake?
  205. Ebay catback?
  206. 92mm tb on a 90mm FAST?
  207. Will this be OK
  208. throwing belts over 4000 rpms
  209. LS1 heads
  210. LS7 Intake options
  211. What y will work with qtp's?
  212. slp flowpac
  213. 383 and Victor Jr
  214. what do you guys think about my exhaust combo...
  215. EGR Bypass ????
  216. SLP Header install.
  217. P0135 questions. please stop in if you've had this code
  218. does the mufflex 4" mate right up to the ARH y pipe?
  219. Anywhere to buy Autometer Cobalt Wideband gauge??
  220. Exhaust
  221. Headers + No Cats + Magnaflow Exhaust= God
  222. Super Victor
  223. I just bought a 98' Z28
  224. Another motor mount question
  225. Which setup should I run
  226. BBK spacer
  227. THE BEST 95mm TB so confused!!
  228. so i've read a lot of post here...
  229. cutting out cats the RIGHT way???
  230. LPP header install problems, need help asap
  231. FAST 78mm or LS6
  232. How to install exhaust tips??
  233. Throttle Body Coolant Bypass PICS!
  234. New Ported TB by Spartan Performance W/ PICS!
  235. Finally!!
  236. TPIS 90mm LS6 intake? If you haveone POST HERE!!!
  237. Quick header bolt question.
  238. Plugs & wires question.
  239. bogging on the launch?
  240. where to power alternator with relocation?
  241. Who Offers Ported Victor Jr Intakes
  242. maf question....stupid one
  243. install troubleshooting
  244. Victor jr or fast 92mm
  245. need spark plug gap/install info asap!
  246. Think I might have the wrong powerbond pulley?
  247. Can we see some engine pics? Not in car.
  248. Info on ported FAST intakes
  249. Problem with o2 sim..
  250. Edelbrock Catback - Thumbs up
