View Full Version : Generation III External Engine
- coolant fan relay control circuit!!!
- Anyone running true duals from the FLP cats/ORPs back?
- h/c install done, car WILL NOT IDLE!
- Anyone have the part number for the driver side LS6 PCV plug
- slp vs. kooks
- hooker headers and qtp cats
- Little bit of TB advertisement
- Please help...air intake problems (codes 171,174 ext lean)..
- LS6 intake question
- 3 in exhaust question????
- damn headers
- SLP Dual Dual Exhaust - restrictive?
- Y-Pipe Install
- Anyone heard about Wieland's LS1 intake?
- What's the best "Ram Air" Set up?
- DIFF. BTWN SS EXHAUST AND REG. Z28 EXH. ?
- Lower airbox questions??
- Quietest cat back system?
- HELP WITH WATER PUMP!!!!!!!!!!!!!!!!!!!!!!!!
- need o2 Ext for FLP LTs on 98 Z?
- Pacesetters are in...
- ASAP! in the middle of Hooker install have ?s
- Valve covers
- A/C Removal question.
- Any info Pacesetter Headers??
- What about this PCV Mod?
- Banks Exhaust???
- has anyone used eastwood silver high temp coating
- Hooker headers QTP cat y-pipe opinions
- loudmouth owners
- First mods
- Resonator on the LoudMouth
- Long Tubes vs. Shorties
- What is the quietest straight through muffler?
- Which hi-flow cat to buy?
- oil cooler problem
- Removed AIR trouble
- Random Tech Highflow Cats
- magnaflow
- HOOKER VS. LOUDMOUTH
- Please help fast
- Where are the Check Vavles?
- Making my own true duals?
- Thermostat mod question
- Oh Baby! QTP Headers are in the mail...
- *Pacesetters...Which gaskets?*
- Which catback system to get (on a limited budget)
- Throwing belts and chirping noise
- Pacesetters are here....pics and opinions within>>
- 2 Quick Questions !!!
- how low do your true duals hang?
- what kind of gains yall!!
- Help with IAC Valve
- Water Pump Changing Time?
- Need 99+ water pump gasket #
- Pulley ?
- new exhaust setup
- ASP PULLEY INSTALLATION ?'S
- MAC HEADERS AND BORLA CATBACK
- ORY and Loudmouth= Sweet
- Kooks vs TTS vs Dynatech
- which radiator?
- 3 grounds on the back of the driver side head..
- Random Tech Metalic cats??
- Those with Kooks, did u use their gasket?
- Random Tech Cat Y-Pipe Questions!
- LOUDER!
- which headers perform best?!?!
- WILL I LOSE WARRANTY?
- Installing Pacesetters???
- Any before and after hp# using headers.
- Spectacle finally has their website back up
- Fluid Damper Key-index??
- plugs/wires and detonation?
- Any problems with using updated PCV valve (LS1)??
- Where is the hole for the oil dip stick?
- Low coolant
- Location of Oil Sending Unit?
- Remove AIR and EGR - HOW??
- Got ported TB. Keep my sensors?
- Attaching Y pipe to I pipe
- Stainless Works Exhaust Systems
- tsp lid for a......
- SFI approved flexplate availability?
- REMOVABLE RT CATS
- Don't know where to put this, ebrake broke, help?
- LS6 intake vs holley intake
- Ported Throttle Bodies
- help with ls6 engine valley cover
- C5 type muffler set up on WS-6?
- Random Tech Exhaust
- what spark plugs?! fast response please!!!
- Water Pump Gasket
- LS6 intake wanted
- TB drill mod???
- Whats the difference between these two water pumps
- Coil Relocation Kit..Anyone sell one?
- To get merge collectors or not....
- Crap in Exhaust!
- My car sputters between 2000-2500 RPM
- identify cat-back
- I want to run 01 headers on a 00?
- throttle body
- LT1 radiator in LS1 f-body?
- Exhaust sound question
- How do JetHots Perform vs. Other Longtubes?
- Meziere Water Pump???
- True duals vs Cat back
- SLP LOUDMOUTH Install
- Does GMMG use sweet thunder chambered mufflers?
- Removing EGR?
- help!!!!
- Neck Hurts, 410s, headers, Halltech on 03 Z06
- SES Light with epoxied throttle Body
- Need help on removing A/C clutch
- 2.5 or 3" X pipe
- What the heck is this sound????????????
- Anyone with StainlessWorks catback?
- Catback system? *DELETED*
- Just a Question on Dynomouth Exhaust.
- MAF wires
- cut out guys
- HELP engine cradle, header questions inside
- Need help quick - fuel pump replacement
- Where to buy polished/stainless factory Z28 tips.
- air pump removal?
- What size borla?
- TRUE DUAL EXHAUST SOUNDS?
- Borla or Cutout?
- Opinions on adding ported TB
- Wanted: Louder Exhaust
- Pacesetter headers??? Any info or Dyno's???
- gear whining
- Anyone using the Bassani y-pipe w/cats?
- Spark Plug Wire Swap
- Any before and after gains with Kooks headers??
- Anyone running Mac Mids and ORY with CME?
- SLP exhaust
- Anyone using the PPC or QTP headers?
- Borla cat-back with CME tips
- Anyone have true duals over the axle?
- Anyone make a stainless steel x-pipe for '00 SS?
- Tru duals & X pipe, with weld in TQ arm pics. WOW!
- JetHot LT's Install W/ Hooker CatBack
- WAT SIZE X PIPES TO GO WITH?
- LT's and Flowmaster
- *DELETED*
- Changing my Dynomax bullets for Borlas in my duals
- Using GM header gaskets.....do I use RTV?
- Open header MAC's,will it hurt HP from o2 readings
- blocking AIR system (ticking noise)???
- Anyone make an x-pipe that mates with...
- Need sound clips and opinions on true duals.
- Which catback is the very "best?"
- best ory pipe on a 2000 Z28
- Intalling TC and Headers next week.....
- Header gains on 2000 and up cars...
- SLP Loudmouth
- Normal for a car to run 10* to 15* hotter when....
- PCV boot
- Vibration when reving car
- Need a Hooker LT/ypipe pic from under the car
- Y-pipe concern
- What size cutout?
- LM OR TRU DUALS (X PIPE) FOR JET HOT'S LT?
- Mac vs Hooker LT dyno..
- Upgrading
- Mufflex, Hooker, or Loudmouth.
- best headers for 98 ls1
- TSP Lid, How Long for clear and smoked?
- Exhaust cold-start rattle?
- Solid results from before to after spark plugs?
- GM part # for ws6 lower airbox
- Spintech Muffler installed- Thing sounds awesome.
- Exhaust installation & removal
- Are the front O2's different from front?
- Installed headers...banging under hard acceleratio
- Cutout?
- anyone have good directions on making o2 extension
- GMMG raspy with LT's and ORY-pipe?
- mods and gas mileage
- LT's with or w/o Emissions?
- '01 FLPs on '00 car
- what exhaust is louder with headers
- What gage wire goes to the O2 sensor, starter, etc
- Don't know which catback to get
- Electrical Hell :( plZ hElp
- Loudmouth sounds
- header install
- LS6 Intake Install... HELP!
- Help:car stalling vacuum leak? what does this mean
- Nology wires
- TSP Lid Hood Clearance?
- I Need Louder Exhaust.
- Anyone have pictures of a sidepipe setup?
- Do the newest Jet-Hots have heater box issues?
- Flow for Catbacks
- Question about spark plug gap?
- ASP pully question
- Jet-Hot LT's, No Cats and a Loudmouth.
- Exhaust for a convertible with emissions.
- Help Energy Suspension Poly Motor Mount Part#
- b&b tri-flow
- NGK TR6 plugs without N2O... help needed
- FLP headers bang - Y-pipe upside down?
- need advice!!! loudmouth exhaust with this header
- New Hooker Headers
- Painted vs. Coated headers
- air bag light is on after removing it...resistor?
- LS1 vs. "standard" SBC?
- getting even flow.......
- 01-02 F-bodies came with LS6 intake?
- Questions About Kooks Headers
- power steering cooler
- Hawker battery web site?
- AIR pump removal
- New option for LM resonator replacement?
- Any difference with an upgraded radiator?
- Thermostat Question
- exhaust
- Power steering Question's
- Gutting cats...will it change my AF mix? Sound?
- I'm a new guy to this board. . . Howdy!
- Another "Which Header" Post (Sorry)!!!
- Any new word on TSP's Ram Air System
- LS6 intake ?
- Question about powersteering cooler?
- Questions about MAF ends?
- 3x3 to 3.5 out Y pipe users...
- STOCK LS1 Throttle Body...
- whats the best headers to go with??
- P0702 - Trans Control Sys Electrical - in an M6?
- short belt mod?
- pics of the relocated oil and coolant catchcan
- SLP maf
- Just wanting to clear up some 6.0l stuff
- TR's "Old Man" cam
- need help fast!
- camposition sensor?
- Hooker cat back - where to buy
- mac headers question
- Texas Speed and Performance Lid Hitting Hood...
- WHERE TO GET X PIPES?
- Those that replaced your window motor
- Kooks vs SLPs dyno results
- stock intake internals
- TSP 85mm lid, filter, bellows
- What is the "grott" design?
- Anyone have the true duals from LS1speed?
- What about these long tubes?
