- Heater hoses
- my lid keeps poping open!!! help
- Anyone heard of the new Flowmaster Super 40 muffler coming Dec. 1?
- True Duals - Round or Oval XR-1 Muffler
- Best ram air kit
- gmmg or loudmouth?
- Pacesetters On Big HP Heads Cam Setups-->
- Quiet with cam, headers, ORY - Corsa, Borla or Magnaflow?
- Lanes duals and Torque arm selection?
- Porting TB?
- film inside my intake?
- Were can i get the cheapest peformance cats?
- Dynomax Ultra Flo or Magnaflow muffler in place of SLP dual/dual muffler??
- How would this be different than x-pipe?
- gmmg / sweet thunder
- to x-pipe or not to x-pipe?
- What is this DYNOmouth???
- after header install ??s
- JET HOTS installed!
- weird power loss kinda problem
- Ported TB or ASP Pulleys?
- Initial Impressions of Borla XR1 Oval
- LG 32" Longest LT headers. Do they have these for f-bodies?!?! Wow
- next mods
- Lt headers
- AspPulley Machining
- Part number for ASP belt
- Is anyone with a stock cubed motor buying or going to buy a 90mm LSX intake and why?
- 500 bucks to spend
- Check out this intake for the LS1...(pics)
- HELP. Pacesetter: 98-99 y-pipe vs 01-02 y-pipe? How to tell the difference????
- anyone have soundclip of duals, x, and single chamber flows
- what exhaust should I get
- MAC midlength sound clips
- Borla or Corsa?
- Can MAC headers get installed from the top?
- transparent lids...
- Headers/ORY-pipe o2's
- Spark Plug wires
- problem after header install (long)
- Lane's True Duals?
- Where to get nice exhaust tips?
- About SLP LM and Mid-Lengths
- What type of cutout are ya'll using with SLP
- !AIR pump and hoses. need help asap!
- SLP Exhaust-Switching to TOTL from LM, will the I pipe fit?
- SLP Loudmouth in the Mail!!
- Open headers = warped valves?
- Need help Home tuneing headers
- Whats better 1 3/4" headers stepped up to 1 7/8" headers or just 1 3/4"?
- Need 3.5" to 3" converter tubes ASAP.
- go with pacesetter or stay with mac?
- What do i need to modify if headers are bought
- Broke coolant sensor on Head.
- Will an Off Road Y work with stock manifolds?
- Anyone have clear pictures of Kooks headersor familiar w/ them?
- Help. I need to know what bolts I can use to bolt an engine to a stand...
- Bad balancer
- Can I run lean (MAKE MORE POWER) without having ping/knock if I used NGK TR6 plugs?
- Pacesetter Headers...
- Gutted Cats
- Catback w Cutout vs Headers and exhaust?
- Dynamax muffler question
- cutout hp
- Mid length header?
- Anyone sell clamp on cat heat shields :)
- Powdercoated TB with Chrome Shaft/Springs!
- CryO2 Intake Cooling System
- Knock sensor codes after complete sensor R&R
- Any need to change water pump gaskets?
- Which Header Gaskets to Use?
- Platinum plugs - total crap?
- Header Install!!!!
- Post pics or links to your X Pipe or H pipe setups!!!!
- Mac Install?
- Screw It!!!!!
- Latest Ideas for Minimizing Rasp
- Which shift light?
- Question for WS6 guys only. Funnels?
- What headers will not decrease my HP or torque
- LT1 Catback on an LS1
- SLP dual/dual questions
- hooker exhaust and cutout
- true duel ?
- falty o2 sensor
- To all with Greddy catch can...
- which headers Mild steel coated or Stainless?
- Got the True Duals
- need help quick
- dyno of before/after 3" cats
- NGK TR-55 vs. TR-55-IX
- Aftermarket Ignition
- Universal Wires
- What is average HP gain with headers??
- Catylitic converter glowing RED HOT
- Pacesetter results with LS6 Cam...
- Help with plug wires..
- Wanted - Chrome Meziere Electric Water Pump Pics
- ftra
- Mac Install Problems
- 160 or 180 degree thermostat?
- High Flow Cat's
- ls6 PCV
- Belt Tensioner - Katech or Stock GM?
- Come in and share your Dyno Numbers of before and after headers install PLEASE.
- FLP dual center mount exahaust "Q"
- cut out
- Different X pipes
- please read my spark plug
- Underdrive Pully..to do or not to do
- ngk's?
- Which is quieter with a built motor... headers + mufflex or dual exhaust with x pipe?
- slp loudmouth... problems.....
- AIR Question?
- ??Header exhaust clips with Borla Exhaust
- Coil pack connectors
- Ticking noise with Jethot headers
- QTEC placement
- Hooker Headers
- Jet Hot Header owners come here please.
- SLP Longtubes???
- What would cause a EGR to fail?
- Borla sound clip
- Difference in Hooker and Qtp
- I want some headers for Firehawk
- Cutout people inside.(cutout Q's.)
- LS1 Harmonic Balancer
- Decision time, what exhaust setup would be best?
- New Manifold (Slide Plate)
- QTEC size question
- advantage of long tube vs shorty's
- Do relocated coils loose power?
- C5R valve cover part#
- Backpressure ?
- Is there an easier way to slow oil
- true duals - 2.5" or 3"
- Why would a GMAF cause missfires?
- Spintech or Magnaflow??
- Lowered car and exhaust setup
- Who likes their Hookers?
- Slp 85mm MAF
- just when i thought i had fixed it all....
- whuch exhaust best sounds like THUNDER.
- Steering wheel controls and blinker question...
- Anyone using QTP dual cutout y-pipe?
- what headers can I put on a lowered car?
- with ym mods, should I get a LS6 intake?
- Loudmouth On Its Way- Few Q's, CME
- headers with cats for CA.
- 98-00 ls1 owners... need some advice/help
- Minimum idle w/ ASP crank pulley?
- Which airlid is the best out there?
- Headers
- Whats wrong with my car?
- True dual people: How bad is interior resonance?
- what boots for custom wires?
- Will running cats with LT's affect A/F?
- Please HELP!!! Which exhaust to choose?
- Short belt part#?
- Noise coming from Engin Compartment After Header Install
- what kind of muffler should i get??
- Disadvantages of underdrive pully
- Plug Gap
- Steering shaft removal?
- Gutting the cats?
- issues with the new y-pipe..HELP!!
- Short belt # for ASP pulley car?
- just ordered a corsa ,hope it sounds good???
- Part # for radiator/coolant level sensor?
- MTI Clear Air Lid compatable with SLP Bellows?
- Jet hot headers
- SSRA or SLP CAI
- Billit Underdrive pulleys???
- 3" true dual x pipe muffler recommendations?
- gmmg exhaust w/ magnaflow tips?
- people running 2.5" true duals, please read
- Any negative affects running a 90MM LSX intake on H/C 346ci?
- Gutted cat vs straight pipe
- Crazy Y
- QTP Header Size
- cat backs or muffler
- With H/C car, what would dual QTEC cutouts do to hp, tq ?
- maf question
- Pro-M MAF?
- Any difference between A4 and M6 99-02 MAF sensors?
- cant find flow numbers for LT headers
- Underdrive Pully
- Mounting pics & locations of your Greddy catch can...
- cheap bolt ons?
- How good do these work
- Pacesetter Header ?'s
- How do you take off intake fuel lines
- oryp with lowered car?
- stage 8 bolts and gaskits for hooker headers ?
- y pipe hitting floor....
- How to make my car louder/meaner sounding?? help....
- LS6 Intake or TB?
- underdrive pulleys
- What size for the short belt ?
- AIR CHECK VALVES
- help here!! just bought LT's and i need o2 sensor extension
- tbyrne insert for throttle body
- Those who have a Volant
- Ordering Headers what do I need
- GMMG and CME
- I need more low end power!
- info on new Ypipe (no headers)
- Good Sparkplugs
- Help with decision
- 50 state legal headers?
- Need the part number for a water temp sensor for a 2002 Z28
- quick question about installing ASP pulley
- MAF Ends and Tuning (ported?, polished?, stock?!)
- Edelbrock Competition Headers
- How big is the ASP pulley
- FLP header system...I want 3 inch pipes and catback.....
- made my own manual fan switch today.
- Need Soundclips: Stock Internals, Long Tubes, Hooker Catback
- Running rich........sometimes
- Header install: a howto?
- Torque converter.Is a cam neccesary
- TSP Lid Extras?
- any sponsor sell the dynomouth muffler
- Headers Worth The Money? (Need HP Gains, ET Drops)
- Best tool for hose clamps?
- Jet-Hots & Catted Y are in!
- Car can't decide...run great or barely run at all
- lid
- Whats the best catbacks to run?
- Stripped EGR bolt...how do I fix!!???
- Miss on #3 cylinder
- QTECs straight off the headers?
- PLEASE HELP
- FLP system to Borla problems
- exhaust backpressure
- Hooker/ORY/Magnaflow?
- Off road pipe with loudmouth
- FLP$1300 headers REALLY worth it? HELP!
- power steering pump
- Cheapest Place For Loudmouth Exhaust
- Help With Idle
- What is a catch can good for?
- ASP Tensioner Pulley help needed ASAP!
- Is it ok to drive w/o the front O2 sensors
- Cheapest place for Hooker catback?
- Mac midlengths
- Cut out open all the time?
- Headers with no cats? Fuel smell and rasp?
- Car is running horrible after G5X1 cam and header install
- O2 sensors say 98 on one and 97 on another, does it matter?
