PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 [261] 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Magnaflow and Cut Out?
  2. borla with my setup????
  3. auto fan switch mod opinions?
  4. TB and BGRA ?
  5. Clogged Cats ??
  6. How would this exhaust sound?
  7. tr55 part #?
  8. What are my replacement options for ball'n'socket header flanges?
  9. Does anyone make a high torque starter
  10. intake and TB
  11. 7 months storage/Iraq
  12. H/C Install.. dead battery / tune
  13. Cavalier ? also in PCM Diagnostic
  14. putting together a 427 for a 01 ss. help
  15. Question about Corvette to F-body intake parts interchange...
  16. What other options do we have for exhaust clamp
  17. What kind of MAF do i need with 90mm LSX?
  18. Car runs like crap after cutout install?
  19. True Duals:Flowmaster 10 Series or Borla Xr1's
  20. Cold start problem, could use some help.
  21. 160 Thermostat
  22. Which headers????
  23. Hooker muffler install question
  24. True duals with hooker mufflers
  25. Found my exhaust but 1 ?
  26. LS1 Motor Mounts
  27. Catch Can and Metco Breather,Where is My Oil Going???
  28. Car don't want to start...could starter be getting weak?
  29. Capacitive Discharge for LS1 Truck?
  30. Any other bolt-ons I should consider?
  31. Good Bullet muffler to stop RASP..
  32. Green Light on Battery?
  33. horrible whistleing
  34. MagnaFlow is BAD ASS.....
  35. TRUE DUAL GUYS please
  36. Asp Pulley
  37. Question for all TSP True Duals Owners
  38. hooker catback problems, please help!
  39. How do you install an ASP Overdrive Alternator Pulley?
  40. Y-pipe problems after header install
  41. Throwing serpentine belt!!!!
  42. texas-speed y pipe
  43. LS1 oil pan question
  44. What ORY?
  45. will my car run like crap w/o 02 sims??
  46. Anyone tried "dynamat" or other sound proofing
  47. Installed exhaust with great results
  48. Car sounds like a civic on steriouds around 2k rpm
  49. What is that darn squeaking coming from??
  50. Coolant sensor in Driverside head?
  51. Anybody had a heater hose fail?
  52. What kind of exaust!!!
  53. How often do your fans run??
  54. Best Plugs and wires
  55. GMPP Intake flow question.
  56. PVC Hose.......
  57. iridium plugs?
  58. mac headers
  59. Water pump upgrade?
  60. True Duals with H-pipe
  61. To Much Popping....HELP!
  62. who has had thrie ls6 intake ported by cartec?
  63. HELP Thermostat ?'s
  64. Rocker Cover Help
  65. WS6 newb - best exhaust?
  66. Mufflex or Hooker Catback?
  67. EGR block off plate
  68. QTP vs Street Pro
  69. Need a little help on finding info on Lid Assy.
  70. Need Opinions w/ Duals and Ground Clearence...
  71. Is this a ls6 intake?
  72. ASP PULLEY FOR FBODY AND C5 diferent?
  73. StreetPro Exhaust Cutout *Video
  74. Just a thought.
  75. Im wondering why ......
  76. Make Hooker Cat Louder
  77. Help!!Car not running right after ASP Pulley install
  78. hooker catback people come in please..
  79. Air Filter
  80. uncoated kooks?
  81. Tune after taking off cats?
  82. Mac headers
  83. Need help with water pump?
  84. Hooker Shorty Headers Keeps Burning #6 Plug Wire...Solution?
  85. Who sells stock exhaust?
  86. 3.5" y-pipe
  87. Best Sounding Exhaust
  88. would you do heads or headers?
  89. header and cam question
  90. GMMG vrs Hooker Cats
  91. NGK TR55 Gapping question
  92. 02 sims
  93. Any gains? Open Borla vs. Duals
  94. Pacesetter guys: Question just for you.
  95. Pacesetters produce as much power are QTPs/Kooks?
  96. Need to remove welds that attach 3bolt flange to TTS header collector
  97. Please don't ream me for this question...
  98. Ordered the FAST 90 MM LSX and 90 MM FAST TB.
  99. Mac Headers
  100. exhaust clearance question
  101. Kooks LTs + Catted Y + LM?
  102. **PICS** my new Kooks LS1 race headers
  103. Stock SS exhaust is it same as slp dual/dual?
  104. gm header gaskets
  105. No power steering
  106. Feels like a lost some bottom end torque?
  107. 1 3/4 or 1 7/8
  108. Do I need an adapter for my Autometer tach to work?
  109. Adjusting the throttle body...PLEASE HELP
  110. Bassani Catback
  111. A Little "Labor Day" Help From Street Pro
  112. welding and pre bent tubing...
  113. no muffler no cats just headers
  114. Examples of rasp.
  115. Headers Install Question
  116. Pulling a Power Steering Pulley
  117. Need a good sounding muffler
  118. SLP Catback...price used.
  119. what throttle body
  120. (RAPTOR) shift light problem, need help
  121. questions on TSP td's
  122. Sorry For Turning Into A Post Junkie But..
  123. What is the AIR system??
  124. What Can It Hurt
  125. Finished my Pacesetter install
  126. GM switching to Iridium Plugs for 2005 model year
  127. Ordered my Kooks!!!!!
  128. power loss? how much?
  129. Magnaflow vs. GMMG
  130. SLP LT's, 3" X, LS6 intake coming off / QTP HVM LT's, QTP Y, 90mm LSX going on.
  131. Anyone run SLP LT's w/ the new TSP tru dual exhaust?
  132. If you TPS is missing will
  133. New Pace 1/78 LTs?
  134. Jethot Headers, ORY and Hooker Aero go on this weekend.
  135. need help choosing next mod
  136. Bassani Headers
  137. Will a LM fit on a 3rd gen???
  138. How to flush coolant properly.
  139. help identify where connector goes...pic inside
  140. ASP pulley installed -- charging issues
  141. Engine cooling question.................
  142. Power loss with Exhaust leak?
  143. Who sells the clear Ram Air airbox cover?
  144. Who sells Heater Core Block off Plates?
  145. LSx 78mm or 90mm
  146. y-pipe->muffler setup
  147. Does anyone sell dual exhaust bends, just over the axles? Hello Lanes....
  148. New Headers need some help
  149. seal it up
  150. true duals whats your set up and price you paied
  151. Anyone extended their 02 sensor wires (homemade)
  152. Fast lsx 90mm intake and tb results
  153. what diameter is the hooker catback??
  154. Where can I buy a longer pulley bolt???
  155. Fixed Ticking
  156. Porting Factory MAF - lose the divider?
  157. MAC headers
  158. another header install ?..please look neway
  159. TSP Clear Lid
  160. ASP pulley fit double roller timing chain?
  161. Can a !EGR '00 use '01-'02 SLP LT's?
  162. Knock at WOT... help?
  163. SLP 2OTL vs. SLP Dual Dual - is the 2OTL that much louder at idle?
  164. Offroad Y Pipes
  165. Can somebody host my video clip?
  166. 90mm tb-what bellows?
  167. anybody know how to make a manual fan switch
  168. O2 extension noise
  169. catch can install ?....
  170. Anyone using SLP LS6 intake and !EGR?
  171. Anyone using electric water pump on their daily driver?
  172. need help !!!
  173. ordered my rumbler
  174. How much difference is there between a H-pipe set up & an X-pipe set up?
  175. True duals with sidepipes!
  176. Annoying cabin resonance - Magnaflow Catback
  177. should i change my i pipe
  178. 90mm LSX guys, are you using an ls1 calibrated Z06 MAF?
  179. LS1 8 Throttle Body Inlet Manifold
  180. Which catback?
  181. Loudmouth Cons
  182. old throttle body question
  183. I ordered Carsound Cats...
  184. Borla XR1
  185. Stainless versus brass fittings for mounting sending unit, which is stronger?
  186. flowmaster super 40
  187. Slp 85mm Maf...what To Do...?
  188. TCS off all the time (ABS is ON though)
  189. Boom Tube info?
  190. SLP MAF Question
  191. Exhaust restrictions ... please comment
  192. AC pulley and balancer bolt?
  193. cats on either flowtech or pacesetters
  194. supercharger-like whine?
  195. spark plug decision
  196. look what the dealer told me please help
  197. Need Ground Clearance... QTP Dual Elec. Cutout Y - Come in users
  198. Magnaflow and Bullit question.
  199. Anyone use this shift light before??? (E-bay)
  200. A/C recharge help needed
  201. conecting Xpipe and Kooks
  202. Need the inlet diameter of the rear pcv on 99 covers
  203. Crayon Trick? Who's heard or done this?
  204. header installed yesterday!
  205. Exhaust band clamp leaks
  206. Meizure Race Electric Waterpump
  207. Prokit and 2.5" True Duals --- Pics ---
  208. Stock lenght of O2 sensor wires, longest to shortest
  209. Anyone ever fab up a custom intake??
  210. Fast 90 MM Intake MAP sensor Help!
  211. descreen with FIPK or not
  212. Cat By-pass Pipes/O2 simms not the answer?
  213. Headers banging Something???
  214. idle setting problem, please advise (already searched)
  215. 02 Simm Question
  216. A/C Pulley Install... How is it routed again?
  217. 00 headers on an 02?
  218. Speed Inc ported TB: any experience with?
  219. O2 extensions...
  220. Not a Typical Header Q
  221. Need some help...
  222. FAST Intake
  223. Changed my mind about descreening my MAF...
  224. Pacesetter install yesterday....Whew
  225. Cut-out/Y vs. True Duals
  226. LS1 -> LS6 intake (potential of LS6)?
  227. I cut off my exhaust today
  228. Everyone else get a ugly a$$ switch from QTP or just me...looky here..pics
  229. Air Box raising kit???
  230. Loud Fluttering sound
  231. ARP Header Studs and stock manifolds
  232. Stock MAF (Ported) vs Granatelli
  233. Fitting cats and cutouts in the Ypipe.
  234. ASP Pulley Problems....
  235. Need Guide to Removing the A/C System
  236. Any issues buying used headers?
  237. Pipe cutting tool.....
  238. Water Pump gasket....
  239. what misc stuff to get for long tubes
  240. Car Acting Up..help!!!
  241. Need part # for rear coolant plugs
  242. !air question...squeaking-ticking sound
  243. Radiator removal
  244. Confirming Meziere Street EWP Flow Rate?
  245. weird smell after header install...
  246. I need pictures of TSP True Duals on the car.
  247. New mass air flow or not?
  248. SES Light 500 Miles After Intake
  249. Popping after Header install..help
  250. RASP with TSP's True Duals
