PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 [281] 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Post header install, car bogging
  2. Flow Tech Headers...
  3. Electic Cutouts switchs
  4. Dyno
  5. Headers
  6. What type of thermostat does the Meziere use?
  7. Questions about the LSX intake
  8. FAST Intake on Speed Channel already!!!
  9. squeaking noise from engine
  10. flows vs. catback
  11. Check out this claim about iridium plugs
  12. Cutouts and True Duals
  13. New LSX dyno #'s
  14. I need just a single fireproof sparkplug wire cover.
  15. Question on Jet-Hot header fitment between model years.
  16. Look at what I got from UPS today!
  17. Who sells torque straps?
  18. Getting Stock I pipe off
  19. Are Denso spark plugs better than NGKs?
  20. Gmmg or Dual Qtec cut-outs?
  21. Can someone tell me where to get 3" Flanges from?
  22. Does Jet Hot Catted Y bolt up to Pacesetters?
  23. Anyone port match thier LSX intake yet?
  24. Corsa! My Impression
  25. Dual cutouts and SLP Loudmouth?
  26. header problems
  27. header problems
  28. Qtec Problems
  29. SSRA installed/pics inside
  30. What TQ Arm with duals?
  31. cutouts. worth it?
  32. weak spark
  33. Installed LS6 Intake, Now Car Doesn't Always Start on First Try
  34. How hot do the headers @ the y-pipe get?
  35. Confused? :confused:
  36. LSX first impression
  37. Custom catted Y pipe?
  38. How many people's ORY hits the floorboard?
  39. True dual owners how much did it cost?$$$
  40. guage installation questions
  41. part number for valve covers?
  42. Opinion on Mufflers for X
  43. pacesetter header exhaust clamps??
  44. Magnaflow configuration??
  45. Will these catalytic converters work?
  46. Hooker LT's and what muffler?
  47. Loudmouth
  48. Y-pipes
  49. Someone please explain this.....
  50. FLP high flow cats?
  51. Jethots come with instructions???
  52. Does anyone have the FLP FL98 headers?
  53. Can't tell if my exhaust is hitting.
  54. Y Pipe Worth It?
  55. LS6 Intake vs LSX Intake
  56. Write up for QTP Elec. cutout?
  57. Any pics of red Meizere Electric Water pumps?
  58. !AIR. necessary to remove air pump?
  59. Is everyones car as loud as mine
  60. True Duals vs. CA Smog Test
  61. plug wires,who's got them.
  62. What length and how many O2 Extensions
  63. Question Removing A.I.R
  64. Remolving EGR without freeze plug
  65. QTP cutout rattle
  66. What to do for exahust with spohn torque arm
  67. Does the holley powershout filter
  68. C'mon guys...need LSX results on a S2 head and big cam 346
  69. Pulley problem? or worse?
  70. Should I weld my y-pipe to my header?
  71. Ds Loop
  72. Slp Header Install
  73. LSX or Holley Intake use LS6 or LS1 coolant pipes
  74. The right size holes to drill in the 160 degree T-Stat for Meziere EWPs are 3/32"!!!
  75. Header brand with no rasp for my setup, any suggestions?
  76. Loudmouth and Pace Setters
  77. post header install problems (HELP!)
  78. Shift light install problem.
  79. ram air & hood latch
  80. Randum tech ????
  81. Off-road Y-pipe for stock headers...
  82. Coil packs the same on LS1s and trucks?
  83. Where can I find large valve cover ??
  84. Stock manifold with true duals?
  85. Fuel Gauge Not Working After AIR Removal
  86. Absolute 85mm TB?
  87. Is the guy at the Exhaust Shop shooting me B.S.??
  88. Borla Catback
  89. Who's used a manual pipe expander for exhaust work?
  90. LS6 on a 99ls1
  91. Sound Clips of SLP DD/Mac's/ORP/Cutout
  92. power steering cooler
  93. Ok to get pacesetters?
  94. Large debris on the MAF screen.
  95. Where to get pacesetters?
  96. Oxygen Extensions. (How Long)
  97. Fast intake and a BBK TB
  98. Another PIG in a POKE?????
  99. choke point
  100. Shaner vs Bauer vs Home Ported
  101. NGK TR55 Plugs
  102. gutting cats
  103. Is running the engine at 160* and below safe?
  104. TB voltage question..
  105. inspection sticker question.
  106. EGR & Header ?
  107. underdrive balancer + alternator?
  108. TPIS tb
  109. What did you wire your EWP to?
  110. WOW Exhaust is LOUD
  111. 78mm FAST Intake Results from Texas Speed & Performance!
  112. Will a hooker muffler fit flowmaster catback?
  113. Seal Or No Seal?
  114. Where is 02 ambient temp sensor???
  115. 427/78mm LSX Test
  116. Cutouts, is 2 better or just 1?
  117. Getting Headers, What Else do I Need?
  118. SLP crank pulley - anyone have one?
  119. 160 Degree Thermostat
  120. Need Help With Lid
  121. Should I get a Weiand/Lingenfelter intake ?
  122. What Muffler Should I get?
  123. Anyone have any feedback on the March pulley
  124. Worth it to swap?
  125. absolute speed 78mm & 80mm throttle bodies are coming
  126. wich is better?
  127. Dual Exhaust cost?
  128. Quick question about Fernco
  129. For those who bought 90mm FAST intakes
  130. FRA appears to work
  131. TSP air lids
  132. quick....ok to run open headers or no?
  133. Those that have removed AIR, did you remove the big pump?
  134. EWP and ASP
  135. Anyone with ASP pullies on dyno before/after their Meziere Water pump addition?
  136. Hp gains w/Mezeire Electric Water Pump?
  137. Service engine soon light
  138. what to pick....cats or a bullet?
  139. Magnaflow exhaust
  140. will 6.0L exhaust gaskets fit a 5.7L?
  141. Lid Question
  142. is it good?
  143. Bauer tb
  144. Will a Mufflex y-pipe work with Pacesetter LTs?
  145. Best headers for LS1
  146. Corsa Muffler Problems?
  147. Man I cut my bellows too short. What would you think about
  148. weather tite connectors?
  149. How would this sound.....
  150. cut out
  151. Does a smooth bellows really make a difference?
  152. Removing heat shield on passenger side...
  153. Knock sensors screwed up after LS6 intake
  154. Which exhaust?
  155. Gmmg tips question
  156. Ssra
  157. question about SSRA
  158. 90mm LSX intake+90mm TB, so do I gotta go buy an 85mm MAF and 85mm lid too?
  159. Best Cats?
  160. full bolt on max HP numbers
  161. powersteering pump pulley
  162. i cant figure this out for my life
  163. Pacesetter come with wires to extend o2 wires.
  164. Best spark plugs for the ls1
  165. what throtlebody?
  166. how do you like your hooker cat back?
  167. Stock Y-pipe different on A4 vert?
  168. Whisper Lid Fitment is Garbage!
  169. which pulleys?
  170. Florida emissions test...
  171. Preliminary Dyno Results from LSX Intake - Courtesy of MTI!
  172. Any gains from 01 Vette maf to a 02 up ZO6 maf?
  173. Cats!!!
  174. FAST Intakes @ Thunder Racing...THEY'RE HERE!
  175. Anybody used the Edelbrock 5505 mufflers for duals?
  176. Hedman Headers
  177. hAS ANYONE EVER CUT OUT THE HOLE IN THEIR RAM AIR HOOD?
  178. Best headers?
  179. Coil pack relocation kit "do it your self"
  180. Intake manifolds questions
  181. what muff. to get with pacesetters
  182. Jet Hot header/y-pipe install
  183. header gaskets?
  184. what Y pipe for Hooker LT's
  185. anyone own SSRA *AND* FTRA???
  186. yet another 85mm MAF thread
  187. ls1/ls7 friendly mods.
  188. quick A.I.R. removal question (yes i tried the search)...
  189. how do i fix this problem..... or tell what it is??
  190. subframe connector question
  191. What affect will run one step colder plug have
  192. Rubber Grommets/98 Valvecovers
  193. Those with true duals and 1 chamber flowmasters?
  194. Slp Header Install Please Help!
  195. looking for pics of TSP smoked clear lid installed
  196. How long did it take to get your Bauer TB?
  197. what mufflres to use?
  198. help me fix my exhaust leak
  199. Ws6 or firehawk radiator intake part question.
  200. Doe's any body have a ATR cat back ?
  201. A.i.r.
  202. If the ls6 intakes only flow 275 ish...
  203. Part Number for a Belt Tensioner
  204. headerbolts.
  205. Pace Setter Y Pipe before/after modification...
  206. Pacesetters, smog or race style?
  207. Custom pully needed
  208. Meziere Water Pump?'s
  209. anyone ever made their own A.I.R. blockoff plates?
  210. Solid Motor Mounts
  211. Pacesetter install, few problems
  212. hooker max flow
  213. TB size matchup to the LS6IM
  214. 3.5 or 3 inch Cutout with my setup?
  215. Pics of my new duals
  216. long black sensor behind intake???
  217. engine bolt torque
  218. Flow numbers for 1 chamber Flowmaster?
  219. Did the bbk shorties ever get carb #'s
  220. length of bolts for ds loop?
  221. Cutout switch
  222. Emissions?
  223. Still need more exhaust clips and info!
  224. Other LS1 intakes?
  225. what else i need
  226. How to make my cutout electric?
  227. Anyone w/LT`s,ORY,bullet dumped before axle?
  228. What Y pipe with cats to go with pacesetter Longtubes?
  229. Where To Buy Pacesetters???
  230. True Duals Without The X Pipe?
  231. Hooker shortie question...
  232. car ideling rough ..
  233. Rookie Header install ?'s
  234. Pacesetter LT Power Gains
  235. cutout not closing all the way
  236. bassani y pipe
  237. QTP Y-Pipe
  238. How do you route wiring harness on pass. side after SLP LT install?
  239. Odd Sqweakin ???
  240. Interested in a GMMG Group Purchase?
  241. Header coating
  242. Ls6 Question
  243. LS6 intake question
  244. My new corsa tips
  245. FLP y pipe, how is the fitment?
  246. Looking for some spark wires
  247. coated or uncoated?
  248. Rasp!
  249. SLP Headers
  250. BG Ram Air
