PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 [317] 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. getting dynatech's, which collector WON'T leak?
  2. can you guys help me out?
  3. ? about fuel setup
  4. parts needed for throttle body coolant bypass
  5. inch/pounds tq wrench?? Who makes a good one
  6. Any Static/Interference with Weld On Subframe Connector's?
  7. Hookers not coated all the way through on the inside!?!?!?!?!?!
  8. Press Release: 2002 Camaro ZL-1 QTEC Equipped!!!
  9. Bauer Racing Throttle Bodies
  10. ASP pulley
  11. What short belt for ASP pulleys?
  12. Built a better PCV system
  13. HELP...snapped oil pan bolt in block(long)
  14. Check Engine light flashing....Help!!
  15. MAC collector to intermediate fit???
  16. Anybody have leaking problems with the new version of the McCord electric cutout????
  17. Calling out uncoated mac guys
  18. Who runs Dynatechs on the street????
  19. $320 for header installation?
  20. Granatelli MAF
  21. Exhaust ? Help me out!!
  22. 160 degree T-stat
  23. Classic ? SLP or FLP LT's
  24. Solve an arguement
  25. Dyno results from removing TTS cats on H/C LS1
  26. Tools need 4 ASP pulley
  27. Pics(inside) of Random Tech #703000 3" Cats
  28. Changed plug wires now radio interference
  29. What size nuts on stock 01 Cats to y-pipe?
  30. SLP LoudMouth
  31. Beware Dr Gas!
  32. Built Tony(Nineballs) Catch Can Yesterday
  33. Couple Of Questions
  34. How do I get the oil filler neck off???
  35. OK...how do you change plug #8?
  36. Is this exhaust possible?
  37. sell slp longtubes and get dynatech?
  38. Header choice fast... these deals won't last for me!!!
  39. misfire mayhem................
  40. Is it possible to get ~12% more flow out of an LS6 intake with these mods.....
  41. loudest crossflow muffler?
  42. egt questions
  43. Throttle cable sticking!
  44. Shakedown runs with Grotts and ST3500...
  45. Who else makes a Ypipe that can have Cats with the Hooker LT's
  46. Where to buy weatherpack connectors?
  47. Justin Sutton's stainless steel catch can.
  48. SLP MAF or Stock MAF
  49. How much is LS1 water pump?
  50. Off-road pipe
  51. dual intank pump???
  52. nice sounding catback that isnt real loud
  53. thread size on o2 sensors
  54. FLP header install...
  55. What needs to be wrapped for header install?
  56. Which F'in A/C pulley causes the chirping/squeeking!!!??
  57. Hooker LT's: Driver side header is too close to fuel line heat sheild for O2 sensor?
  58. Removed my AC, but isnt there more i can remove back by the pcm?
  59. .050 a ok gap for my TR-55's
  60. ASP pulley bolts(thread pitch)
  61. Best Induction Setup?
  62. Bent rods... what now?
  63. Installing longtubes tomorrow need help!
  64. running rough again
  65. Mufflex 3.5" dual outlet cat back Any Opinions?
  66. Hooker headers and Stock Ypipe?
  67. vacuum line going near passenger headlight
  68. NOLOGY PLUG WIRES
  69. Hooker Y pipe direct fit for Hooker headers? Any modifying?
  70. TR220 questions
  71. WS6 muffler vs. Flowmaster muffler, 1/4 mile
  72. different throttle cable?
  73. EMISSIONS COMPLIANT?
  74. Suprising Dyno Results: BBK vs. port - H/L vs. LS6
  75. ASP crank pulley removeal
  76. IAC question
  77. 7 new wires and 1 old?
  78. TPIS Headers - BIG PROBLEM AT DYNO
  79. I have a BIG RACE tomorrow...URGENT.
  80. Ticking when cold...
  81. *** POST YOUR MODS AND DYNO NUMBERS ***
  82. Where is the least expensive place to buy and LS6 intake without EGR?
  83. I need some part #'s!
  84. Any fix for rattling windows, yet?
  85. Do I hold the record or what???
  86. Just ordered my headers, now I need exhaust help....
  87. Need help
  88. help me blueprint an aftermarket fuel sys.
  89. Anybody cut off old SFC's and reweld new ones?
  90. Does a ported TB make the car run richer?
  91. catylitic converter advice (please read)
  92. header question
  93. addition to FRA
  94. clearance problems with mac headers and y pipe !
  95. Headers and o2 observations and stuff..
  96. What will a BAD O2 cause the car to do?
  97. Granatelli vs slp
  98. Lets Talk MAFs and MAFTs........
  99. Just installed my Supersucker last night and I love it.
  100. anyone have the part number for the INTAKE Bolts?
  101. Powdercoating in NJ/PA area??
  102. problems after LS6 intake install
  103. Help with Walbro-340 install.
  104. torque spec for manifold flange nuts
  105. Budget Oil Catch-Can Photos & Instructions
  106. Couple thousand for mods
  107. Hello All!
  108. Thermostat.. stupid question.
  109. burned an O2 wire
  110. Where can I get some formula emblems?
  111. Hooker LT's Vs. MAC Midlength
  112. Will an LS6 intake make that much of a difference?
  113. 3rd Gen Camaro Pic Inside - - Comments?
  114. Socket size for crank pulley bolt?
  115. Difference in stock MAF sensors 98-02?
  116. Sound clips of FLP's and Borla?
  117. RandomTech cats with Hooker Y pipe?
  118. Why am I slower with my SLP LT's, WTF is going on???
  119. Need help.....fouling 1 plug????
  120. Oil temp gauge question
  121. ANy Power Gain with the AC Belt Removed??
  122. Benefits from removing AC
  123. which ypipe should I get
  124. banging y-pipe maybe a different fix
  125. Soft Header Gaskets (non-metallic)
  126. How will a lower temp thermo work with stock PCM?
  127. Need to keep cats..Who makes the best shorties?
  128. Please Help.
  129. Cylinder Numbers?
  130. my up-comming exhaust- I need advice please
  131. How to recharge my Air Conditioning
  132. spark plug wires
  133. Yes..I fixed my banging y-pipe!!!
  134. CUTOUT questions....Please look
  135. pros and cons to torque strap?
  136. Replace LM resonator with WHAT???
  137. 60,000 miles Service???
  138. Bought Hooker headers today!!!!!
  139. How much for Oil Change$$$$
  140. duals are finished
  141. Will a rich condition cause the plugs to foul out?
  142. RADIATORS - Discussion...
  143. Hooker Long Tubes ne one?
  144. Electric water pump question
  145. Officially sick of my Hawk HPS pads... what should I get as a replacement?
  146. FLP Y-Pipe... good enough or go custom?
  147. Anybody know a shop who will...
  148. Ok, I ported my TB. Now how do I polish it?
  149. size of pipe inside muffler?
  150. mystery ticking/EGR question
  151. got oil drain plug problems cause of headers?
  152. what are the knock sensors tq'ed to?
  153. Whats the big deal if I dont coat
  154. Ported Throttle body question!
  155. How do you get the fuel line(rubber one) off the intake?
  156. What is the proper air/fuel ratio?
  157. induction cooling.... possible?
  158. SLP 2OTL exhaust
  159. Mods.. what next??
  160. Installing headers...Will i need anything???
  161. Anybody running true duals with MACS?
  162. Thinking of long tubes now... Best bang for the buck.
  163. TTS install problems...messed up hole in head,idea and 02 sensor question???
  164. Switch to true duals?....
  165. Fuel PSI
  166. Meziere water pump....any gains from it?
  167. Cut out placement for my setup?
  168. Is it difficult to install an electric cutout?
  169. Flipped the lid, has anyone done this?
  170. Pics of my new dual ram air setup...
  171. A warning to my fellow longtube owners (FLPs especially) NOT dial-up friendly!
  172. Break in period for loudmouth
  173. X-Pipe or H-Pipe?
  174. HotCam w/ LS6 intake?
  175. Donaldson Disposable Paper Air Filter
  176. Exaust install...
  177. MAFT
  178. What kind of 1/4 gains w / long tubes
  179. Country Boys exhaust
  180. LS6 intake with EGR ... What are the different designs?
  181. cut outs
  182. Put ported factory MAF ends back on and unlocking problem gone
  183. Which Spark Plug wires should I go with?
  184. anyone got a Mccord electric cutout?
  185. Slp Sf bolt ins... Flp headers
  186. how can i tell if a plug is Blown
  187. 99 FLPs on a 2001
  188. Aftermarket cats. Worth it?
  189. Dynatechs are better,I was wrong......
  190. Question regarding condensation coming out of tail pipes
  191. How much gain: 3" vs. 3.5" I-Pipe
  192. Has anyone lost a fuel pump?
  193. For those who have FTRA. How does the block-off plate attach?
  194. Best Sounding Exhaust System
  195. Other Guys Headers
  196. Bigger MAF=lean or rich?
  197. 99 MAF wiring color
  198. LS6 Maf?????? Help!!!!!!!
  199. how do I remove the EGR tube?
  200. SLP dual/dual with stock Z28 tips
  201. Got my car weighed, what do you guys weigh?
  202. Ram Air
  203. MSD Plug Wires, Does Computer Learn Them?
  204. ls6 intake manifold
  205. Need some help! Multiple Missfires
  206. dynomouth=LOUD
  207. Will Hooker Y-pipe hook up to Stock I-pipe?
  208. Thinking about upgrading the fuel lines
  209. SLP Long Tubes and Clearance: Ground Flat!
  210. Measurements
  211. Lets compare Catbacks..
  212. Is there a MAC long tube header?
  213. For those of you with a Supersucker?
  214. X-pipe with cats?? would this work?
  215. what can I do to increase horse power externally, all ideas welcome
  216. Anyone using the timing tuner yet?
  217. Pic of my dual cutout ypipe
  218. What is the best exhaust system for LS-1?
  219. need clutch any suggestions??
  220. LS-Spyder manifold from Nitrous Warehouse?
  221. Thinking of a new exhaust for my Heads/Cam setup
  222. Dynoed my car today
  223. RPM Problems
  224. How much Horsepower?
  225. DUALS!! Over the Axle?
  226. Will a driect flow lid made for a 1998 ls1 fit a 2001 ls1???
  227. WS6 Lower airbox?
  228. High Flow Air Box
  229. anybody that has relocated the coil packs
  230. Exhaust thoughts.........
  231. Any REAL dyno numbers---> X Pipe VS 3in single setup?
  232. cat off...O2 sensor mod?
  233. mounting maft on TA......
  234. Any before and after pic's of ported Mac's ??
  235. pulled a sparkplug WTF?
  236. Running rich...........
  237. How much longer for Extended Warranty
  238. Going to try to install the Hooker LTs tomorrow, any tips????
  239. Running really rough
  240. NGK TR5 Question
  241. Smoke
  242. extreamly loud exhaust
  243. Y pipe for Dynatechs !!
  244. Pix of custom Y off Grotts...You MUST see this!
  245. Any reason NOT to use a ported truck TB on an F-body?
  246. What H/C, bolt-on setup for max rwhp in a daily driver?
  247. Granatelli MAF
  248. Headers
  249. New exhaust idea!?
  250. What brake fluid?
