PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. What size are the FBody motor mount bolts?
  2. New rear main seal...worth it?
  3. Upgrade catback THEN header/Ypipe?
  4. Some talk about TB's and TPS units
  5. Fast 90 worth it
  6. Y pipe + bullet then dumped before axle
  7. true duels
  8. Anybody know what these are for?
  9. Headers, what should I go with
  10. Water Temperature Gauge Help, Port above starter
  11. Fast 90 Install
  12. Abaco Maf
  13. ls6 Manifold install ?
  14. TB hoses
  15. LS6 porting
  16. WTF is this vac line?
  17. Help About Heat Extractors
  18. anyone familiar with pennsylvania emissions?
  19. Coolent Overflow Tank Question.
  20. MS3 or MS4
  21. ws6store shipping?
  22. Problems with FTRA install
  23. Alternator Suggestions....
  24. Attention those with SD tunes
  25. '00 Corvette MAF on '02 Ls1 Camaro??
  26. LS6 intake install!!
  27. would new ceramic headers mess up o2's???
  28. Ported TB, Re-tune?
  29. Heating up your underdrive pully?
  30. To all you TB bump stop modders
  31. Should I be real worried about this crack?
  32. Please help asap, harness plug questions
  33. AIR lid plug
  34. Help identifying this AC part.
  35. Composite or Aluminium Intakes?
  36. Normal header noise? Can't find an exhaust leak.
  37. Loudmouth w/o cats and borla xr-1
  38. LS1 Throttle cable bracket
  39. magical camshaft
  40. LS6 Intake Manifold.....
  41. I know its been beat to death but. LS6 vs F.A.S.T with MS3
  42. 408 vs 346 flow needs
  43. Intake install
  44. headers
  45. loading up cant find problem HELP!
  46. loading up
  47. new maf. need tune?
  48. How much hp from a high flow cat?
  49. Bad ticking noise
  50. quick fix for ws6 short stick?
  51. Man QTP Y's are hard to come by
  52. What size Headers ls1
  53. How much for a DBW TB?
  54. has anyone built their own 3.5-4" mufflex?
  55. ? about e cut out again
  56. head gasket sizing
  57. GMMG vs True Duals
  58. y-pipe bangs floor on right turns
  59. Kooks Revised F body Header
  60. TSP Rumbler Catback Write-up
  61. WHAT would cause my rpms to READ 0!?!
  62. Typhoon Intake..anyone heard of them?
  63. 02 Sensor Rear's to front?
  64. few questions about cutout and ory
  65. Homemade cutout on stock exhaust
  66. Throttle Body And Maf ??????
  67. braided clutch line on header..
  68. ls7 heads on an ls1
  69. Alternator relocation?
  70. Couple questions on headers.
  71. exhaust update..... + header leak question
  72. Electric Waterpump ?
  73. Who has the best deal on
  74. coolant leak
  75. Slp flowpac install problems!!!
  76. what is a good daily cam for 5.3 truck
  77. A/C problem, need help.
  78. Safe with open ory?
  79. How/where do you remote mount the IAC when using 100mm tb
  80. Upcomming purchase??
  81. Exhaust Clamps
  82. Katech valve cover clearance sale
  83. front o2's vs. rear o2's
  84. What else do I need>?
  85. O2 Eliminators
  86. Owners of TDs with Magnaflow mufflers come in!
  87. Dynomax Bullet Damaged???
  88. Muffler Options on End of ORY
  89. Pacesetter or Hooker Headers?
  90. Running a cold plug NA...
  91. Cutout on stock exhaust, what kind of gains?
  92. Can I paint over ceramic coated headers
  93. Fried O 2's
  94. Intakes, intakes, Intakes, Worthless
  95. What size headers for a T Rex cam
  96. Got My Headers...now What?
  97. best maf for stock
  98. Who makes a good Catch can?
  99. Difference in 98-99/00-02 header?
  100. UMI Torque arm reloc. Y pipe question
  101. I found this interesting regarding QTP headers
  102. need to relocate alternator
  103. Coated vs Non coated
  104. E-cutout with side exit?
  105. Pacesetter LT's, Mufflex Y, and B&B Triflo (Sound Clip Inside)
  106. cooling
  107. TD and Mac Mids.
  108. Just threw on an intake NO OIL PRESSURE!!!
  109. heat
  110. Difference in bullet style mufflers
  111. Alternator question
  112. My True Duals **PICS**
  113. What kind of TD's are these
  114. Custom or Universal X pipe?
  115. thunder racing ported tb
  116. LS6 valley cover and LS1 intake manifold?
  117. Anybody tried this exhaust setup?
  118. Catch can mod, cleaning out intake
  119. Magnaflow high flow cats?
  120. Vortec 5.3 intake vs LS6
  121. TSP Duals X Pipe & Sweet Thunder Clips?
  122. harland sharp mod?
  123. I love new elec cutout
  124. Swapping to LS6 intake - injectors?
  125. tune on a stock car
  126. LS6 intake install !EGR and !Air
  127. Exhaust opinions needed
  128. ABS/Low Traction Control Light
  129. No O2's
  130. motor mount torque
  131. LS1 coils
  132. what spray cleaner2 clean o2 sensor.
  133. How's my TB look?
  134. buying ls6 intake with ported tb?
  135. Making A Custom Y... Need Some Advice
  136. Car acting up.
  137. Switching from flowmaster to magnaflow??
  138. Need Help Fast
  139. adding 2nd bullet or muffler after axle?
  140. FAST on 5.3?
  141. gmmg exhaust installed
  142. Fuel Rails?
  143. Not sure if this goes here but A/C help!
  144. Vic Jr. saga continues
  145. QTP y pipe really that bad??
  146. Best way to connect exhaust pipe?
  147. falling on its face
  148. Magnaflow tips on TSP rumbler
  149. Help!!! Rear Main Seal
  150. ls6 intake install-oil pressure pegged out max
  151. dipping idle after ls6 intake install
  152. what's the max ls6 throttle body size?
  153. Final Modding...
  154. LS6 Intake prep...
  155. How much did it cost you for TD's?
  156. True Dual Muffler Question
  157. Oil Dipstick Bolt
  158. What is the cheapest thing you can do to add horsepower?
  159. Need some Y pipe advice
  160. TSP y-pipe and Spohn torque arm
  161. help! have a quick question!
  162. TSP 1 7/8 Long Tube Headers.
  163. LS6 intake and EGR?
  164. Hole in Header..... WTF
  165. Help! Weird Problem!!!
  166. car running slower that it should
  167. whats the easiest way to do an oil pan gasket and motor mounts???
  168. Exciter Ring Protecter
  169. Exhaust Sound
  170. 02 Ss Le
  171. stock ls6 intake tb ?
  172. Prothane/Clamshell install help
  173. borla or triflow?
  174. How much does it cost to get headers installed?
  175. Problems with TSP Rumbler
  176. LS1 Tune-up
  177. Coolant leaking?
  178. Kooks 3" Y-pipe
  179. shady dealership??
  180. exhaust help
  181. off road X pipe help
  182. Pacesetter Header Help
  183. spend my money heads, cam?
  184. '00-'02 headers fit '98??
  185. Header and Y-Pipe install....now problems....
  186. Just Got My Slp Lm1...
  187. DIY O2 Sims
  188. Lessons learned (so far) from Pacesetter LT/TSP TD install
  189. Catalytic converter interchange
  190. headers and cutout
  191. Adivice on exhuast set up
  192. Ordering a big list, what else do i need?
  193. I need my car fixed fast it is my only car
  194. slp cme
  195. 2002 f-car and 2004 truck O2S compatability
  196. Throttle body compatibility
  197. True Duals and 3-point Subframe Connectors?
  198. ***My Gathering of QTPs Y Pipe***
  199. Cut out, cat back, and TD info!
  200. 11's bone stock engine no cam or heads?
  201. metal coolant line question
  202. Fidanza flywheel turned 0.040", spacer needed?
  203. JBA headers? Really any shorty headers.
  204. Goofy catch can related idea
  205. What does this go to?
  206. how much power required to run air pump
  207. ect gauge
  208. Quieting down true duals
  209. oil pressure gauge F'ed up?
  210. My Norris Motorsports catchcan
  211. fast intake came today( question )
  212. sheetmetal intake manifold questions
  213. Fast intake idle louder than stock?? Help!
  214. More Power & Better Fuel Economy ---> FTRA!
  215. post mac-mid/ory install
  216. Thunder Racing Catch Can
  217. Could someone clear this up for me. Cam/Crank Sensor Replacing.
  218. Which Pulley for stroker?
  219. Muffler suggestion?
  220. Where are you getting your pieces for custom exhausts?
  221. 98 water pump gasket
  222. LS1's 98-00 vs. 01-02
  223. headers?
  224. Intake... LS1 vs. LS6
  225. Cut-out Info Needed
  226. Welding the Block off plate on Mainfold
  227. how much rwhp do i have stock?
  228. H/C/I car -- Replace MAF & Injectors?
  229. TSP Catted Y-Pipe + Dual Electric Cutouts
  230. Terrible noise after intake install... im stumped
  231. ...adding cats...
  232. virgin corvette to be modded.... help
  233. want to make a my dual/dual a lil louder
  234. first impressions with q45 TB
  235. fast 92 combo - need advice
  236. LS2 intake fit and LS1??
  237. getting a custom Y made... wheres the best location for the cats?
  238. 98 style water pump
  239. Glowing D side cat. Internet mechanics in here!
  240. I really need help
  241. autozone power steering pump
  242. CME Camaro guys...what do you think???
  243. Autometer Oil Pressure gauge.
  244. Cats and A/F...
  245. HP gains from 90mm intake/TB?
  246. Compressor seized, what should I replace?
  247. What MM is the stock Ls6 intake TB
  248. Cut-out after catted-y pipe
  249. replacing TPS on stock TB
  250. Intake Questions
