View Full Version : Generation III External Engine
- Fuel rail covers
- Headers (average hp gain?)
- Edelbrock rpm series muffler
- 4'' TO 3'' REDUCER WHERE TO I FIND ONE?
- Chambered muffler in place of LM resonator, anyone have a dyno or time slip??
- Hooker/Jet-Hot Header install pics
- NGK Iridium plugs?????
- LS1 Intake Manifold ?
- What wires do I connect the tachometer to on a 99 Trans Am Ws6
- What did I do to my car?
- Edelbrock Drag Race Headers
- LS6 intake Q&A
- Full Rt/Lft wheel turn from stop > Front wheels jump & skip
- Proform Valve Covers?
- ATT: hooker LT people.....
- Does this sound like the idler pulley may be the culprit?
- Lingenfelter LS6 EGR Intake Adapter
- need true dual pictures
- SLP CAI?
- my hooker lt's??? smoke?
- "Zed" cutout !
- stock crank pully ** NEED HELP **
- Ok...gotta little cash...which one?
- ported TB concern
- pulley ?'s
- Problem taking off the Ls1 intake
- Crank Shaft Position Sensor ?
- Im an idiot. What happens when I do this.
- Spohn TA & True Duals???
- Help with dyno #'s
- true dual setup?
- Pulley question?
- help! what do i gap my plugs to?
- Anyone make a shorter shifter shaft for the Pro 5.0?
- EGR system and Backpressure
- Whats the weight of most 3 inch catbacks and a 4 Inch Mufflex?
- website on parts/steps on relocating coils???
- parts to install ls6
- Hooker cat-back w/ORY sound clips?
- Fast Toys Ram Air ,, Worth IT ??
- Collector Mufflers?
- hey guys puttin some gauges in.....??????
- head light problems on 98 ta
- HAL Shock Question
- how does dyno max bullet sounds with stock ss muffler ...?????????
- SS grille??
- Cams, headers, or Cat-backs?
- Any websites for changing the manifold???
- Custom Bellows
- Custom Bellows
- TORNADO ??? Does it work??
- Max oil pressure after intake install?
- One wide band O2 bung or two?
- Spark Plug Wires
- Will this sound bad?
- O2 Simulater ?
- ls1 truck plug wires longer?
- LS6/LS1 heads- different header gaskets?
- Hooker catback sounds GREAT!
- Need help with vacume line
- Introducing QTP Stainless Steel Long Tube Headers Part II
- Wobbling stock crank pulley?
- 02 simms & extensions
- AC Delco Rapidfire Question
- WIRES AND PLUG?&OPINION
- exhaust dumping
- Installed Bauer TB today!
- blowers?
- Pics of SLP Dual Dual Tips on a Camaro
- RIPPER or PRO-5.0 ???
- BORLA XR-1 SOUND CLIP
- High RPM Rattle?
- Just ordered TTS headers
- Which exhaust system and why???
- H/C installed Flow and Dyno inside!
- Ported TB and Off road Y-pipe for TTS Headers
- Experts please ,,, Got first ever dyno with low numbers with some downward loops
- Truck 5.3 ignition coil upgrades?
- electric QTP cutout feedback please
- who actually sells Grotts LT's.....?
- Performance gain from gutted cats?
- Why do Longtubes make your car run rich?
- Loudmouth Noise Level
- Poweraid throttle body spacer What do u guyz think???
- exhaust sound clips
- O2
- BBK Shorty Headers Results
- Cool C5 Throttle body
- A/C Unit
- Severe Engine Misfire
- Anyone with Magnaflow Sound clips?
- need a good cutout
- Anyone make valvecover spacers?
- got hooker LT but Y pipe on back order Need Help
- loudmouth replacement
- Anyone running PPC's Headers???
- Any reason not to run colder plugs?
- Are there any new affordable Intake designs on the horizon???
- need a pic of a ZED style cutout
- ORP to True dual question. Is it worth the $$?
- chin spoiler necessary for proper cooling of radiator?
- What is an 18" bullet muffler going to sound like in place of my Loudmouths resenator
- My Goal: Run 10s with stock internals.
- Fenris, GaryZ etc. further header discussion
- Free Ram Air Mod (FRA) and Hood Seal...Please help
- Putting Bullit in Loudmouth worth it?
- HPPIII???
- Y pipe worth the money
- Descreen MAF?
- Front grill inlets...
- Texas Speed & Performance Lid
- Bassani Exhuast, Comments please?
- Will a FTRA do any good on a SS?
- !Nostrils Mod
- how to tell LS6 from LS1 and LT4 from LT1
- DMH Electric cutout?
- Jet-hot lt install, reuse egr and air gaskets?
- Did free mods- have pinging- plz help!!
- Jet-Hot catted Y-pipe
- cutout causing SES light
- sheetmetal valve covers
- SLP F/L Header setup
- Does anybody else have this noise??
- SLP radiator
- Spintech mufflers
- Major mod time: cruise control... can I install it on my car?
- Best Intake Set Up question ???
- what all is needed to take the cats off
- Ported throttle body DYNO RESULTS... Home ported, Sponsors, stock 3 way comparison...
- "Zed" cutout question
- y pipe ?
- Shorty Headers on an 02 WS6???
- flowmaster coming off/magnaflow going on
- Got my FLP on today(dyno'd)
- Crankshaft Pulley Question
- Installed longtubes & ORP, now wideband will not read
- MAC's, x-pipe, duals installed!
- Open Headers??
- For those that have relocated coil packs, i have a ?
- Long Tube owners - need measurements (HELP)...
- Swapping 1998 exhaust manifolds for 2002's , straight swap?
- Comparison of mufflers for true duals
- anyone have experience with MAGNAFLOW exhaust?
- throttle body...need Info
- How to take the side panel off on the driver side door?
- Is Fast Toys correct??? Shock Tower Brace...
- Loudmouth?
- cheapest place to buy an U/D Pulley ..... ?
- LS1 Injectors
- Borla system
- TR-55's, what should they be gapped to?
- where to buy ws6 lower air box
- Which One?
- RICHER OR LEANER?
- Cat By-Pass Pipes
- what's this buzzing noise coming from the rear?
- Cross Member Support Bolts
- Corsa Yes or No?
- Corsa Yes or No?
- Edelbrock Headers
- Anyone w/Loudmouth got it dumped???
- Weight reduction
- DOES ANYBODY HAVE HOOKER LT'S INSTALL
- O2 Sims
- Throttlebody questions
- Exhaust Tips
- exhaust with all the emission crap.
- Could ported MAF ends actually make you lose power?
- Longevity of Random Tech Cats.
- getting rid of accelerator cable slack?
- Cutout Question?
- Who makes best y-pipe?
- 1 7/8 headers w/ merge collectors
- Hooker Lt's w/ Loudmouth
- Where to put O2 bungs
- Long Tubes??? or Mid Tubes????
- Anyone have Pace Maf results? Please help
- anyone remove tcs?
- What's this?
- Lid question
- Induction Question.... get ready for this one
- How do you get the ASP pulley off?
- Which Motor Mounts?
- help on U/D pully?
- Least Restrictive Cat-Back
- passenger side cylinders not firing!! whats wrong?!?!
- Throttle Body: NEED HELP
- Will 2002 Mac headers fit a 2000 car
- HELP!!! broke wire for oil level sensor
- Who here has had their power steering pump go out?
- '02 De-screened MAF's
- Exhaust leak - problems?
- FLP Headers and a better Y pipe?
- Headers blocking oil drain plug????
- LS6 intake or the Weiand/Holley Alum Intake?
- Ready to get a cat-back!
- Descreen MAF - Yes or No?
- '99-2002 truck TB same as LS1 TB for F-body?
- The Super air system
- WHAT DO YOU RECOMEND?
- Strange problem... losing tach signal?
- what plugs are best for my LS1?
- Sponser with Macs for sale
- FTRA?
- K&N FIPKII
- True Dual Exhaust Question???
- TB bump stop, how to?
- LS6 or SC?
- Mac Headers (need help)
- PLEASE HELP WITH COILS
- Which Headers?
- Silencers?
- RUST on my Jet-Hot headers
- Extrude hone Intake?
- Merge collectors. Worth it???
- k&n filter question
- 02 sensor question
- what manifold is part # 12358465
- Extreme Exhaust Question
- I was bored tonight, but I saved 140 bucks... See pics
- True duals out the back concept design
- SLP MAF & HPP3
- ws6 hood for ram air?
- Jet Hots LTs + ORP + Borla
- Steering shaft problem with BMR K-member
- Those with Loudmouth and bullet to replace hollow resonator
- Do dynatech merge collectors have O2 bungs?
- Headers and stock exhaust...
- Hooker Offroad Y-Pipe Users... Help me out!!
- Pics of installed jet-hot or hooker lt's??
- Pics of Clear and Smoked Clear TSP Induction Lids!
- Ticking Noise!!!!
- Installed an LS6 Intake - Having Problems... HELP!
- Anybody had a noisey fuel pump?
- Lower box ......?
- Good God! MACs w/ ORP + LM = RASP!!!
- at a crossroad with my MAF
- which is louder - true duals or a cutout?
- Anyone using these mufflers??????
- Stock y-pipe removal Q
- Fix or Sell the Mufflex???
- Why does my exhaust have so much rasp?!?!
