PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 [246] 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Where to put cuout
  2. Spark plug install help.
  3. HP difference between tight (1 3/4) and loose (2) header.
  4. are the tb for the 99-03 trucks the same as ls1
  5. Exhaust???
  6. Possible problem found durring cam install ???
  7. FAST 90mm Intake question
  8. 98 PCV replacement...do you guys re-wrap that crap back on?
  9. Where Do I Place A Cut Out??
  10. to remove or not to remove
  11. air pump?
  12. Did any '01 LS1s come with EGR?
  13. GMS 85mm Z06 Conversion Kit
  14. engine and MAF cleaning
  15. Header Install Checklist
  16. QTP Offroad Y-Pipe install?
  17. Is a S3 TB worth a redyno or retune??
  18. Mac Headers
  19. I hate Magnaflow tips!!! Any ideas??
  20. Questions Of All Qustions!!!!!
  21. Has Any More People Tried the Edelbrock Headers?
  22. Emissions :(
  23. List your favorite ls1sounds soundfile (and worst)
  24. Spark Plugs And Wires???
  25. What Next?
  26. RX-7 borla catback for LS1 conversion
  27. Which headers should i buy, best bang for the buck?????
  28. LS6 intake part #?
  29. no thermostat?
  30. broke header bolt off in head!
  31. Why does my Magnaflow hang so low?
  32. Loudmouth or Hooker?
  33. LT1 to LS1 catback
  34. catch can
  35. Bolt ons needed before H/C
  36. Cutout cause stumbling???
  37. balancer issues:bang:
  38. TD, muffler, and more questions
  39. rich or lean
  40. Mac's Install... questions
  41. Spark Plugs?
  42. 90/90 guys come in
  43. What T-Stat for this Fan Activation?
  44. Need Advice on Exhaust Tips and Rear Skirt
  45. Anyone have a lowered car with SLP LT's?
  46. Oil Filler Neck part number?
  47. will stock MAF fit with...
  48. NGK Spark Plugs
  49. Bullet muffler in front of cutout
  50. I need everyones opionion on this
  51. im about to spend money help!!!
  52. Headers
  53. Loudmouth II? Anyone seen or heard?
  54. lowest rumble 2!!!
  55. True Dual Pic
  56. HP: TD vs. Catback
  57. Mac Midlenght vs LT sounds/tone??
  58. nice v6 exhaust...
  59. true dual question
  60. Cammin Beast TB
  61. Won't start! Where are the guru's?
  62. Open headers Mac Midlengths?
  63. What would you get?!
  64. Vibration under my feet from the Y pipe
  65. test pipe's
  66. O2 Sensor Question
  67. Need help with Power Vs Noise
  68. What muffler is this?
  69. Installing Header Question
  70. Who else carries edelbrock race headers..
  71. 02 sensors and computer acting funny after header install
  72. SLP MAF question....
  73. LT's to mid-length's
  74. MAC users come in please....
  75. crossbrace bolts
  76. LS1 questions. Alternater EGR ECU, DBW....
  77. banging
  78. Need to get rid of the exhaust RASP!
  79. pulley install on an A4
  80. I need O2 extension Part #'s
  81. TD's installed today
  82. Fluidampner balancer?
  83. Ordering Exhaust and Headers--Opinions Wanted
  84. MAF Screen
  85. Ported and polished my TB
  86. Need some help!
  87. how do you hook a SLP MAF to a vette?
  88. TSP dual question
  89. Hooker CatBack On...Thanks A.R.T.!!!
  90. QTP y pipe to 3 inch catback
  91. Mufflex kits
  92. would a bullet cut out the rasp
  93. NX TB anybody tried it yet?
  94. low rumble!!
  95. Overheating problem! Need help asap!
  96. JRP TB Testing
  97. NO Spark at plugs????Help!!
  98. How Much Louder, Not to Much I Hope
  99. GMMG is here!
  100. best sounding catback?
  101. rear o2's
  102. Wheres my Cruise Control?!
  103. Throttle body spacers??
  104. true dual mufflers?? over the axel??
  105. Flanges on Long tubes?
  106. air removal
  107. Bad cat plugging exhaust?
  108. Bo White ported TB
  109. 160 t-stat, when to turn fans on?
  110. Dual cutouts or not?
  111. take off or leave it
  112. Weiand intake install questions.
  113. FAST intake and NW TB results
  114. cut out question
  115. 02 heater codes
  116. Dynatech Headers
  117. new mods
  118. How could I make this work?
  119. gmmg ???
  120. Ignition problem driving me crazy
  121. crank pulley puller
  122. Bought my T/A used need help!!!
  123. headers n exhaust
  124. Need some opinions on this set up t/a
  125. Pacesetter Open Headers ok?
  126. Ordering QTP headers tomorrow.
  127. Question for those who welded true duals. What if you need to remove system?
  128. Jet Hot LT's
  129. TSP catted y-pipe next to fuel lines!?!?!
  130. true duals with manifolds
  131. Daily driver w/headers?
  132. AnyBody Lowered With Slp LT's?
  133. E3 spark plug Diamond Fire? Any thoughts? Flame on
  134. Which exhaust system sounds best?
  135. Water Pump LOCKED UP!?!
  136. GMMG and Center Mount Exhaust Installation
  137. Need a A/C Belt size
  138. On a 346... which would make most HP
  139. Question on TB's
  140. Major problem!!!
  141. can you help?
  142. QTP's
  143. people with dumped duals (TSP)
  144. any problems w/ aftermarket maf's after dyno tunes??
  145. good LT question
  146. can I do true duels?
  147. need advice (headers/exhaust)
  148. Asr ?
  149. ignition switch bolts
  150. Sound clip- Pacesetters, ORY and cut-out
  151. header install
  152. Y-Pipe Question
  153. my A/C exploded, need advice
  154. Header install Question
  155. header advice
  156. ls1 advice
  157. Exhaust Manifold Gaskets
  158. Stock Fan Flow?
  159. headers n exhaust
  160. Replacing Starter, Need help quick!!
  161. induction
  162. what is blowback
  163. rattling
  164. 3" non reducing ball flange
  165. Need Help adjusting my valves on my F-body LS1
  166. gians from TB
  167. Ypipe on a Vert
  168. Emissions Q's on 98 TA (would it help to block off?)
  169. Which would you pick?
  170. Wideband O2 Gauge?
  171. Installed Flowtechs today
  172. GASOLINE drip onto HEAT SHIELD!!!!
  173. Kooks header problem
  174. Anyone have a problem with serpentine belt slipping off?
  175. Exhaust Tips
  176. Exhaust Install Tips
  177. I need help with my tach...
  178. Anyone know the Low and High speed fan wire?
  179. What size do I drill my TB hole to?
  180. Need help on what kind of headers are best...
  181. Engine Guys, I Need Serious Help
  182. Mac Header install..Drivers thru top or bottom??
  183. can't decide ''HELP''
  184. autometer air/fuel after header install
  185. passenger side bank = no fire! help me out please...
  186. Direction to mount bullet muffler?
  187. Fast Toys Kit
  188. best place to get pulleys?
  189. exhaust help needed
  190. Both Pulleys or Just one??
  191. Header true dual question?
  192. Granetelli MAF impressions ?
  193. Loud Mouth II
  194. Fast Intake Port Thread (about casting flash)
  195. install today!
  196. ultra z hood; modify
  197. Hey guys I'm new need o2 advice
  198. Does anyone know where I can get a new fuel line to go from the hard line to the rail
  199. DS loop clearance
  200. EGR Fuse?
  201. If you knew then what you know now...?!?
  202. planed hooker lt with gasket and slp loud mouth cat back for sale
  203. Will a hooker aerochamber direct fit in a Flowmaster catback
  204. Flowtech Cutout
  205. Slp headers ground clearance ?
  206. Cutout First Impression
  207. HELP!! Huge problem with SLP Flo Pac installation, HELP!!!!!!!
  208. Can LS1 Ram Air cars use
  209. Looking for Dimensions on stock F-Body Radiators
  210. heres a vid... need to know what exhaust on WS6??
  211. Dropping Cat-back Opinions Please
  212. Hey guys I'm New, True dual ?
  213. Anyone run Mezeire EWP w/ Power Steering?
  214. Installing LSX 78mm intake today!
  215. SLPs Y-pipe
  216. Need a VERY QUIET Muffler that flows extremely well.
  217. NGK's?
  218. motor mount install?
  219. Lane's and lowering
  220. Wish us luck
  221. True Dual Sidepipes
  222. Y pipe?
  223. Y pipe differences
  224. Gutted Cats?
  225. Breathers !!
  226. X-pipe
  227. Pacesetter headers question???
  228. SSRA and lowered cars
  229. Cut out question
  230. Mac Ory
  231. I think I asked already
  232. TSP catted-y
  233. Y-pipe differences?
  234. Just received my SLP Flo Pac with no instructions! Help please
  235. My lid wouldn't fit with stock airfilter....
  236. SLP Longtubes on a lowered car?
  237. Slp Lid Install
  238. fast vs ls6 intakes....
  239. Stock intake
  240. oiling k&n filter
  241. electric valve for borla questions
  242. slp headers a big flop?
  243. Kooks and corsa no go?
  244. 90/90 and fipk
  245. lane's duals
  246. intake?
  247. header set up question?
  248. LS1 Intake Removal Questions...
  249. Need P/S help inside
  250. Can you I.D. this maf
