View Full Version : Generation III External Engine
- idea for true duals
- SLP Air Temp Module
- Hooker long tube install
- Kooks Jets Hots or Hookers?
- What the hell is this noise!!!
- 400 RWHP Should I go with a 3.5 or 4 inch catback.
- Mac ORYP with just a bullet sound OK?
- true dual question
- FLowmaster exhaust.
- dual exhaust setup help
- Autometer tach install
- Anyone have the GMS "Budget" MAF?
- Mac or hooker?
- Borla Exhaust
- Longtube installation - motor out
- How much hp could I gain from Mac headers to Kooks 1 7/8?
- Car running too rich and not holding idle
- Gutted stock cats ... Retuning needed?
- 1 3/4 or 1 7/8 ?
- Any one running the LS1 speed True Dual setup?
- 18HP with ZO6 MAF??
- c5 ported throttle body
- A/C pulley part numbers
- Removal of upper panhard rod for true dual clearnace
- Hooker+Magnaflow sound clips
- Kooks + which combo
- Energy suspension motor mount part ## ??
- Best setup for me
- Banks Stinger exhaust: Rksport
- Hooker long tube header install question.
- Pluses and Minuses of a dual exhaust? I hate the y rasp.
- tranny mount
- LS6 PVC Fix
- 01-02 manifolds
- header flanges
- PPC Headers
- qtp merge header dyno results!!
- How do you????
- Limit on 1 3/4 LT's
- Next mods
- headers
- Bolt-on MN6s running low 12s or 11s
- Just installed FLP long tube headers
- Hooker Y-Pipe Problem
- quick question about hp gains...
- Long Tube VS Shorty Headers
- Need to quiet down my car.
- Is the Granatilli lid worth keeping? Or TSP
- ASP crank pulley possibly broke
- Mac Mid Length Headers
- Who has the new Meziere Electric Water pump?
- SES on SLP Header Install
- Car scared the bejesus out of me today...
- 160* or 180* stat?
- Anyone know the address to BAUER T.B's?
- what is the gm part # for ls6 intake?
- Advantages of stepped headers
- What a Beast
- how much is electric cut out
- To descreen or not to descreen that is the question?
- edelbrok cat back
- Fast Toys Ram Air or Super Sucker Ram Air
- Taking off AIR and EGR
- Oil/air separator
- true dual exhaust hangers..
- Anybody removed the drivers air bag?
- Installed Corsa, it's AWESOME
- You guys see future problems with the way these dual cut-out
- Looking to get hooker headers!!!! A little help
- Can I Ground The O2 Sensors To The Chassis?
- Thermostat question *DELETED*
- Cruise Control w/one cable?
- Dyno #'s of bolt on A4's?
- Descreening the stock MAF, pros and cons
- Cleaning O2 sensors????
- SLP or BORLA?
- Pacesetter Headers
- ASP Pulley and belt sliding off
- Sorry... didn't know where to post... who carries helmets?
- Lt1 vs Ls1 MAF
- No cats
- Those of you that orderd edlebrock headers, do you have them
- Anyone do the Exhaust Mod?
- Electric Cutout vs. Nonelectric Cutout
- exhaust/maf/160 stat question..
- High Oil Temperature
- Hooker catback with Mufflex ORY and LTs
- Installed..... Headers, ORY & Lanes 4 inch single
- how much difference in performance with new lid
- will true duals pass emissions?
- Help me decide!!!!!!!
- hp loss with 2.5" true duels?
- turbo chargers
- where to get turndowns?
- Hookers vs. Jet Hots
- IS A CUT-OUT WORTH THE$$$$$$
- Smooth Bellows cheap? Where to find?
- Which Headers w/ my Exhaust???
- O2 Simms are they needed after u have Edit
- GMMG compared to stock?
- cutting off mac ball flanges {any h.p gains}
- where can I find true duals
- Oxygen Sensors?
- torque specs on intake?
- TSP Lid Question
- problem with ls1 motorsports air lid
- Pulley?
- Anyone using Kooks headers?
- TB Bypass,EGR, etc
- which 85mm MAF?
- Bellhousing cover?
- What exhaust set-up if I were to switch..
- Could cut-out cause P 420 code?
- LS spyder intake??? 35 hp over LS6???
- O2 sensor Info
- Stupid Question
- Will the Hooker catback flow better than the SLP dual/dual?
- Torque specs
- New Intake by FAST
- Is the TSP lid worht changing the one I have.
- Gasket sealer?
- Canton Re-usable Oil Filter
- The muffler shop guy told me
- TSP Lid Problems
- engine upgrades?
- Just got my Bauer TB!
- Heads, Cam. Boltons, What Exhaust for me??
- Anyone try Stainless Works Y-pipe?
- I have a vacuum leak somewhere, help me find it!
- need header help!
- water temp guage install
- Anyone have pics of justin sutton xpipe installed??
- Which of these exhausts is quieter/lighter?
- Throttle Body outside diameter
- LS1 Engine Problem
- Ok, what should I do now?
- TPS voltage for TB bumpstop mod?
- Asp pulley question.
- which would hurt worse?
- Headers or ls6 intake?
- Ordered jet hot's..should I order poly motor mount?
- Double roller adjustable timing chain install guide?
- O2 Simms
- For those considering Spintech exhaust...
- Installing Jet hot LTs this weekend.. any tips?
- Mac's with stock CATS?
- How much HP and ET gains from pulley???
- Best way to fix exhaust leak?
- pulleys
- Exhaust
- best spark plugs???
- SLP Longtubes worth 40HP????
- hooker LT help...quick!
- jet-hot or flp?
- throttle body spaer for ls1 motovater
- Where can I find part number for 2001 ls1 valve covers?
- header/cats install issues?
- Anybody try flipping the MAF ends
- Question about LS1 thermostat from a Silverado truck guy!
- ASP Pulley and belts
- TR55's: What to gap to
- Pacesetter LT owners
- Questions about a removing the cat. converter, please help
- How are the Bauer T.B's doing?
- how to contact Random Tech..Carsound
- True Dual Exhaust Question
- Flowmaster or Not
- how high do i have to lift my car to install FLP headers
- What can kill ignition coils?
- LS1s run rich w/ LTs?
- FLP owners in here
- Removal of stock y-pipe
- PCV Modification: Need Input
- Magnaflow with no cats.
- Need help asap with header install....Exahust maniold gasket
- GMMG!!!
- Which Springs would U use???
- ridding mac header rasp ????
- Looking for Dynotech
- Anyone remove their exhaust?
- pully problem!!!
- TPIS throttle body
- MAF Questions
- Loudmouth Pics???
- To get a new flywheel or not...
- Feedback on Mac midlength and Corsa exhaust
- Anyone know anything about these headers???
- Header Sound
- From Mac headers, to Pacesetters, worth it?
- aftermarket hoods
- Starter? Or something else....
- Converting to an auto., will I need to change out my...
- "Larry" Pulley Install Problem
- Flanges and /or kits for weld up headers
- FAST intake
- Know anything about this car part?
- Round muffler after Hooker Y-pipe...Anyone try it??
- Car is running weird, Surges, creeps, and cam's lope is.....
- true duals in wit jethots!
- Proposed solution to getting colder air into the engine.
- Went to the DYNO today!
- Plugs for 11:1 compression?
- how on earth did you install your QTP headrs?
- Changed plugs now rough idle
- Cut-out, SFC install price?
- need help w/ tsp lid!
- Now What? Jet-Hot LT Header Install From Hell!
- Where do I buy a Shaner S2 TB?
- Water Temp Gauge Question..
- anyone have hp number on Kooks headers
- Got 1200 bucks in my hand for headers.... need some advice
- Need help with SLP long tube header install
- Help for SLP long tube headers
- running open headers
- EGR valve
- Macs to Kooks...New dyno #'s
- GMMG Optional oval tips, or not?
- Will y-pipe for SLP LT's fit with Pacesetter LT's?
- High Idle Question?
- another new ls1 intake...the lsx!
- Beating a dead horse....But lets talk sheetmetal intakes
- Decision on GMMG?
- Air conditioning and gas mileage
- Plug wire life?
- Passing Smog with LTs?
- Dynomouth possibly for sale
- Kooks for $560???
- '99-'00 AIR system differences???
- Where to find Hooker Y Pipe......
- anyone have sounds of slp
- DO I NEED TO MAKE ANY ADJUSTMENTS???
- just found out my O2 sensor might be ok...
- CARS Running HOT NO Idea whats going on HElp
- what size cutout for stock Y-pipe?
- water temp or oil temp gauge?
- Maf interchange question
- QTP Ypipe question
- just got z28
- FTRA OR SSRA???????????
- H-Pipe Anyone?
- Quick Question!
- How to strip paint on uncoated headers?
- Best place for catylitic converters?
- Can Headers cause this
- LS1 280Z
- Jet hot lt's in!
- looking for exhaust tips
- crank f*ck up! help!!!!!
- Owners of Whisper 1 7/8" Headers inside please
- ASP pulley or FTRA? Which mod to do first?
