View Full Version : Generation III External Engine
- Idling
- Header hole. Need some input please
- air fuel ratio affected?
- Differences in stock exhaust manifolds?
- Race Fuels
- New Edelbrock LSx Intake Manifold at SEMA, claiming much more power than FAST
- Help! Cold start fouling plugs
- LS3 with LS1 accessories?
- Where can i find bullet mufflers?
- Header ?
- Torque settings
- I have narrowed it down.
- Jegs catback installed...my thoughts on it
- What coils are these?
- little help here..
- Wierd Idle Problem. Need Help Please.
- New exhaust
- Duals with no crossover
- Headers What's best bang for the buck!
- just cant make up my mind on exhaust
- CAUTION: Anyone who has bought a VIC JR in the last 2 years.
- Header install W/ OPEN HEADER VIDEO!!
- loudest IDELING exhaust?
- heads wich ones would be better
- Anyone know this connector?
- One poly engine mount?
- Fan switch mod write-up
- Car Won't Start!
- Fast or Edelbrock
- exhaust
- 98-99 Headers Bolt up to a 2000 SS?
- Carb style TB guys. What filter setup are you running
- Engine build questions.
- Header installation????
- got my tsp LT,s today!
- Would this work as an air filter?
- My findings; Ported Weaind vs Ported LS6 intake
- Fast 92/92
- FAST 78mm smog legal?
- Limitations of 1-3/4" headers vs. 1-7/8"
- Exhaust piping
- How are your Stainless headers holding up?
- How many bolts hold the FAST intake shells together?
- Can I install a corvette MAF on a Camaro
- 2000 LS1 into my old Land Rover
- How do you take the Fuel Rails of?
- I just installed a SLP lid, and now I have a problem!
- muffler/exhasut
- lt1 alternator swap
- SES Light after mods/non catted y pipe?
- Fit problems with metal intake on Z06 weiand 300-111c
- Were to buy Exhaust Flange Gasket??? Thats not thin paper type.
- Oil pan bolt sizes
- o2 sims
- Headers Don't Fit
- Fixed faulty Catylitic and changed 02s... burning??
- Broke header bolt..
- started porting my FAST intake
- LPP header install questions...
- Car is running too hot...Why?
- Prothane Poly Motor Mount Install Tip
- 317 heads questions...
- catback install question...
- Installed my headers with ORY and magnamouth...HELP!!
- Engine vs Vehicle - ID question (VIN)?
- question for u ported fast guys
- question about a alumuminum block, what does b stand for.
- Meziere water pump leaking grease?
- someone please explain these low temp thermostats
- LS6 now or 90/90 later?
- Diff between stainless Kooks & Eldebrocks?
- cam question
- carb
- What kind of exhaust is this?
- True duals... worth it?
- No Oil Pressure..
- Spark Plugs
- flat rate hours for harmonic balancer change
- Edelbrock Pro-Flo XT Manifold?
- Slp Underdrive Pulley ???
- HELP! UD Pulley
- Port'n'Polished Vic Jr pics needed + some info
- Fuel pump install ? (pics)
- Anyone have custom exhaust in the Peoples Rebublic of Washington?
- Is this worth it?
- Stock tail pipe size on a 2002 WS6?
- Does Anyone Sell Front Facing Headers?
- happiest day of my car-loving life
- Still no SES Light
- Mac mids...with a reg aftermarket y pipe
- NOS kit compatibility
- cai ???
- Header install questions
- Has anyone checked out the new SLP Powerflo Exhaust?
- Slp 160 T/stat?
- Header differences 1998-2000
- Under drive pulley question
- Exhaust Leak
- Cam Positioning Sensor??
- fuel rail covers...
- Question about ported throttle body
- *update* no fire with popbacks/backfires
- HELP switching from LQ9 to LS2
- Where to buy o2 sensor?
- Whats The Best Y Pipe Available?
- Now that I'm going back to regular exhaust.
- Anybody use Edelbrock T.B.?
- Spark plug gap ?
- Problem aft, header and y pipe install
- Longtube recommendation
- PCV Valve (Orafice) Integrated into LS6 Valley Cover
- cheap LS1 centerbolt valve covers
- coil bank pinouts?
- How can you tell the difference
- LME in business?
- Long Tube Question
- newb question about exhaust
- Air & Egr
- Swapping LS1 intake on an LM7; worth it?
- Nitrous Dave's Fiber-Tuned intake manifold
- Just installed Kook's Headrs, Y pipe SLP Dual,Dual Ldmth 1 cat, Spohn Solid motor mou
- LS2 parts on LM7
- My GMMG In Action *Sound Clips*
- Getting ready for a LSx swap, rebuild pricing?
- Car Won't Start!
- Cold Air Intake - Worthy Gains or No?
- Thinking about making my own TDs.
- dimensions?
- Places and methods to check for Vaccum leaks ?
- 1998 LS1 misfire
- Anyone break
- smaller replacement LS1 PS pulley?
- SLP Headers "new design" review
- FTRA vs SSRA
- Are these good ploy motor mounts??
- Ls1 Camaro Vs Corvette Ac Brackets
- 2000 Ws6
- Yella Terra Ultra Lites and stock bolts - total weirdness, please help
- Sheet metal valve covers???
- Will Chrysler Pulley Remover Work With March Pulley?
- PCV system smoke
- Header Install Help
- SLP LID NEED something ASAP
- Problems with Auto LS1...
- header install question???
- GMMG not a sponsor?
- Any bolt-ons left for me to get 400 HP?
- What do you think about these heads
- LS6 intake worth it?
- 2004 C5 LS1 - factory LS6 intake?
- looking for video true duals out back with bullets
- Holley 4150 TB Idle Problems
- Does anyone have hooker on their car?
- 2000 C5 misfire problems
- exhaust clamps
- How to debaffel my hood?
- part number/ funtion help please
- question on a setup from LSX shootout.
- JUST GOt 78 VET IS IT POSSABLE TO DROP A LS6?
- Underdrive pulley without A/C drive
- ls6 intake swap question
- cme owners
- What else to get to 450rwhp?
- LS6 throttle body gasket work on FAST 78?
- TSP Lid ?
- LT's/other mod ?
- Whats yalls average oil pressure
- Is there a difference in......
- Rank TSP Duals mufflers! Not another which is the best...
- LTs/ORY with stock catback
- Difficulty of removing engine...
- Flowmaster replacement muffler
- Looking for Headers
- True Duals Kit?
- PCM Codes, bad oxygen sensor? Help! Thanks
- I really need help
- what solid lifters ??
- Vacuum leak?
- Exaust feed back
- Coolant leaking while TB off???
- 806 to 241 heads
- what hood should I get for the Z?
- NGK TR55 vs. AC Delco Rapid Fire #12....HELP
- idler pully
- damn CEL wont go away! O2 problem
- intake swap problems
- Exhaust Pics?..I just cant decide... HELP!!
- Full exhaust without tune
- Anyone that know this?
- ls6 manifold
- anyone dyno ther 90/90 full bot on car?
- Can you tell the difference between these Corsa clones?
- Which would be the next best mod...
- help me remove my PCV system
- Using AIR pump as vacuum pump?
- Quieter: Maxflow or Aerochamber?
- Those with kooks or ARH 2" headers..
- AIR pump
- ARH Y + stock i-pipe??
- SLP Fan switch
- CATCH CAN, LS1 valley cover, PCV really needed???
- Building your own x pipe
- Pulley Alignment. PS pump pulley too far back? Throwing belts...
- Motor Mount write-up
- slp loudmouth 2
- Moroso race oil filter
- Motor mount/exhaust question help please
- Need HELP car sputters really bad!!
- 02 maf in 99
- Kooks Long Tubes And Y Pipe
- QTP or any exhaust with it "rubbing" on the K-member
- Gen III and Gen IV
- Stock exhaust scrapable?
- Engine running bad after header install/egr delete
- wiper motor
- Powerbond pulley
- Weiand Street Warrior LS intake anyone running this intake
- Valve cover risers/extensions which ones?
- Pacesetter Lt Hitting Driver Side
- for who wants to hear the SLP LM
- problems with passenger side header install, help please
- 454 boys, what exhaust?
- truck coils
- Muffler change only?
- 1 3/4" longtubes vs 1 7/8" lontubes on stock ls1,chime in
- help with heads
- Fitment of low profile edelbrock elbow?
- header install questions
- Injectors
- 80 or 85mm tb
- QTP Prototype Side Exit Exhaust???
- Looking to add Ls6 intake and Longtubes but worried about Mass Emissions
- Will I lose low end power?
- TB and Muffler Questions
- Help please
- need your guys help desperatly!
- Adding new mods next month
- pushrod like noise after fast install
- Dumped after the y
- Best spark plugs for force induction application?
- Update* UMI Shift Handle Upgraded With Short Stick
- Updated bolt on's
- stock heads if any body needs em
- more header questions
- 90mm vs 4 barrel tb
- exhaust question
- SS Raised Radiator shroud piece for airbox?
- SLP "new" headers
- tb coolant bypass & egr block
- need help!!
