- How do I port my throttle body?
- pacesetter or hooker headers
- Should I put a LM before my cut out?
- No More X... H Pipe OWNZ ALL!!!!
- Hushpower II
- Buy a catback or just muffler?
- Freakin out over headers
- Best fitting LT?
- LOUD MOUTH 2
- How much hp gain to expect from stock manifolds to long tubes?
- Ported TB and SES light?
- Exhaust Question
- Carbon build-up need to be cleaned from inside LT's??
- 10%, 25% UD pulley
- lid vs. fipk
- Installing new engine...what else?
- Idle problem with ported TB
- Will a '02 throttle body fit a 98??
- Slp Y Pipe 3 Inch
- TSP Dual System
- The Sound of a Stang
- Moisture in Intake
- LS6 Seal???
- Pacesetter's vs. QTP's gains?
- Need help!
- Where can I get this spark plug?
- gutting cats???
- Mid-length headers?
- QTP LT question
- Will the SLP CAI suck up water during rain?
- Mufflex??
- Which Header Should I Go With???
- Low idle afer porting t/b
- Stock Z28 exhaust Vs. SLP Dual/Dual
- Custom True Duals
- True Duals are on!
- 1999 Corvette/ls6 intake differences??
- New Edelbrock 304 Stainless Header!!!
- Bump stop mod, will it hurt anything?
- Is this a problem?
- 13111 oxygen sensors
- spohn TA and texas true dual system
- Open Header!
- More Hp Wisper Vs Slp Air Lip??
- Dyno tells flowmasters true flow.
- Is it possible to adjust throttle cable?
- Cooling issues? Man i need help!
- Help!! Quick question about LS6 Intake swap
- you people that run LTs/ORY/Cutout on a DD are insane...
- Computer Reset after SES
- O2 Simulators
- What plugs to use in my new motor?
- Ebay Header experience...
- is this v6/v8 ls1/lt1 borla?
- whisper lid fitting
- Does your car stink? How about burn your eyes? No cat, tuned car...
- Cable Throttle body off 6.0 truck/SUV fits Fbody LS1/LS6 manifold??"80mm vs. 75mm"??
- stock exhaust question
- Best cam for 90/90 set up
- Check out this exhaust
- Long Tube header ?s.
- weiand intake?
- LS6 intake
- New Exhaust...Again?!
- won't start
- Cracked Throttle Body
- ls6 manifold vs edelbrock victor jr manifold???
- 06 gixxer 1000 for trade bad 8.6 @ 145 1/4
- strange noise
- Checking oil pressure?
- Meziere EWP ... which stat to get?
- This is the most fucked up sparkplug i have seen
- Belt for ASP
- Magnets?
- Best Waterpump: GM vs. Napa vs. Autozone vs. Advance vs. Other
- x pipe w/ t/a relocation
- Nology plug wires....
- my idea for duals-anyone done it?
- cut out location stock y pipe
- Duals with the relocated panhard bar?
- Side Pipes for TA
- o2 sensor and extensions Q's
- Adding cats before or after Xpipe?
- Removing Cats Possibly keeping stock muffler?
- Drain plug thread size
- 85mm Air Lid
- what is all this smoke?
- FAST 90 VS VIC JR & ELBOW
- SLP lid outside diameter?
- Swapping from A4 to M6?
- AMW or Elite Engineering Catch Can
- No Heat - Please Help
- EBAY Headers?
- damn blur.....
- Place with cheapest Lt's
- Does it matter how long the pipe is in the H pipe?
- custom true duals??
- TB bypass...
- Painting The Exhaust...
- Pacesetter Long tubes 3" Y pipe Stock exaust What cut out do i need?
- Would a ported TB and MAF help my #'s?
- Finally Getting Exhaust
- Will 99 Manifolds bolt up to 01 Cats? confused?
- QTP Longtube HELP!
- How many cut outs do i need one or 2
- help please, 4 cylinders not firing
- Easiest/Reliable way to get to 500-550 bhp
- Loud sqeeking
- anyone used this fan switch?
- Need help...passenger side lights acting up
- Upgrading my 98 WS6...Opinions wanted...
- Some help please
- Problems after header install
- header HP
- Texas Speed true duals?
- anything happen if i forgot to plug one side of the coil paks just for alittle bit???
- Nology plug wires
- Question on header and y pipe fitment
- Anything at all I can do about rasp? LT, ORY, Hooker Poll too.
- anyone gotta f-body with side pipes?
- Thinking about going True Duals...
- Any better idea to run TD's out the back w/ 1 chambers?
- Coating Spray?
- Questions about CME setup...pretty interesting
- Alternator Question
- Where is the serial number for the block located?
- Wide Band O2 Sensors?
- Speed Inc Billet Valve Covers
- help with exhaust selection...
- GMMG woes.....
- 160 thermostat.
- Oil leak.....I think.
- LT/ORY people: Does your cutout rattle when it's closed?
- 85 mm Lid
- true duals with cats
- How to get off a frozen exhaust bolt on cat flange?
- My Spintechs are LOUDER than open headers!!
- Who all is running TSP true-duals/Flowmaster single chambers???Help!
- Electric cutout question
- all long tube guys come in
- Coating My Block
- Vette Bakers hose?
- Is the optional coating that Kooks uses for their headers similar to Jet Hot's?
- GMMG to True Duals
- Best place for mandrel bends?
- Difference between electric fans (F-body)
- What is my weakest link now? MAF?
- I scraped the bottom of my headers will that hurt anything?
- x pipe or hpipe?
- how to use a light tester to find battery draining problem???
- Flowmaster 1 Chambers
- Looking for someting a little more aggressive then Magnaflow cat back
- remove a stubborn Crank bolt to change pulleys
- How to remove rear intake plug?
- finished install of headers SES light?
- Installed Borla...*VID*
- tb spacers
- Cut out change of Tone
- ASP users with Gatorbacks
- Ruining o2 sensors?
- Air filter for drag strip
- what headers???
- exhuast fitment
- autometer guage ?
- Maybe I'll just keep it here.... looks too good...
- Question about exhaust diameter
- I need help with choosing a header.
- Where can I get the Centermount exhast?
- Any WA state cars w/GMMG or True Duals?
- broken header bolt
- Exhaust Tip Question
- F-body & C5 corsa pace car edition
- FAST product?
- Torq Specs for Alternator
- Plug wires popping off
- Air lid air sensor
- LSx cars with center dump exhaust manifolds??
- WS6 I-pipe?
- Holley air filter question?
- Exhaust size and design.
- Slower after LT install?
- after fast intake installed
- LS1 easy question
- Is there a button I could make to retard timing
- can i beat an ls1 z28 with this setup
- No Spark.
- Running two bullets,Hurt?Dynomax&twister
- Lt's ory and cutout with stock exhaust and muffler
- JBA header install
- True Duals on 02 SS
- Spark plug/wires question.
- HELP!!! Fuel pump is not working
- ory
- o2 sensor question
- How to tell if you have a 98-99 throttle body or a 00-02
- correct cluster for 98 camaro?
- Pacesetter Headers Do They Fit Good
- f-body ati balancer w/ ac pulley & pinning tool
- Why isn't my Loudmouth LOUD?
- Another Cutout ?
- LS6 PCV is Drinking Oil!!!
- Flowtech LT's on an LS1 advice ASAP
- underdrive pulley question
- l98 tpi 350 s10 swap
- Best muffler for TD's?
- Katech new product release: Oil Cooler Adapter
- Anyone tried the new Dynomax Catbacks?
- What to do??
- Help with starter wiring
- Quick Question Please Help
- Gains w/ LT's
- *gasp* im going LT's in cali!
- headers installation
- Headers help.
- 00 LS1 to LS6 manifold swap w/ no egr
- bolt ons that actually make a difference
- Powerbond LS1/LS6
- QTP Ypipe????????????
- PCV: Breather Guys
- Amsoil EaA83 air filter
- Running without Thermostat
- new rattle!!
- what mufflers etc.
- ebay xs stainless header... anybody have trouble contacting seller?
- A little muffler trouble.
- backfiring problem
- NGK TR-55s gapped at .055", this ok?
- Leaking Delco Battery. Common?
- I Have Dumped True Duals Should I Get A Cutout??
- Help needed! Engine running rough after header install.
- FAST intake
- Gain to SLP 85MM Mas Air
- !power steering, what belt?
- air lid's available at retail locations?
- Bullets sandwiched between y and Lts
- Exhaust system ??
- resistor chip? does it work
- Starter???
- How are GM and Ford MAF's different?
- bad case of the SQUEEKS!!!
- Chevelle Style Tips?
- Pulley Install On Engine Build
- Lt Header Install
- IAT & Engine coolant sensor SES???
- Best Place For Cutout/sock Manifolds
- Can you buy just the LM mufflers??
- Sound clip of headers vs. manifolds
- a little info please
- Lid Question!!!!!!!!!!!!!!
- Shorty Headers
