View Full Version : Generation III External Engine
- What do ya think about my exhaust plan 1 7/8 LTS merge to 4" to 4" cb
- shift light help!!!
- HELP! Cam Position Sensor Code
- Does ANYONE sell clear 104mm lids?
- Sounds like Exhaust leak under load. But can't find one?
- changing oil pressure sending unit
- longtube headers and ypipe are illegal? and what is the best set
- Stall converters what do they do? And what do i need to get it installed?
- Best Cold Air Intake for C5
- TSP 1 7/8 vs Kooks 1 7/8
- If i get longtube headers will i have replace gaskets all the time
- Bad Vibrations After LT's Installed?
- HELP! Header Identification...Please
- What are the best bolt ons for ls1
- What bolts/nuts for this y-pipe bracket?
- HELP!! How to fix this??
- Hooker Aerochamber
- powerbond ud pully pin
- Cut-out placement
- TSP 1 7/8 LT's, meets True duals, meets Borla. Pics!
- Hooker y pipe
- Do BBK headers come with a catted Y pipe option?
- Exhaust gaskets
- Accessories
- 02 Valve Covers
- Engine miss firing.
- Deepest Sounding 2.5" Bullets???
- BBK intake: coolant steam/crossover tube
- getting REALLY pissed!!!!!
- Water Pump, 160 degree Thermostat?
- Grotyohann Headers hitting everything on install
- How do you install your LT headers?
- I need help with a MAF for my set up??
- What Y pipe will work with Kooks LTS?
- BBK headers
- Just got a full exhaust
- ls6 coolant crossover?
- LS6 mani for cam only
- pcv fitting help
- Is ram air lower box worth any hp gain?
- Missing a Few Header Bolts...
- Some part identification & some questions
- Time on Open Headers
- Breathers?
- Getting to the exhaust shop after headers with no O2'S
- How to reinstall stock a/c on camaro Z-28
- 243 heads stock on 2007 5.3L suburban?
- quick intake/fuel question help!!!!!
- Ebay Knockoff 1 Chambers
- 821 castings bolt on to 98 LS1 ??
- Anyone use Schoenfeld muffles On TD?
- Mpg problems after header install
- P0420 & Best MPG Yet...??
- Need Help: Voltage drops, light dim at WOT- Alternator checks out fine
- Which 02 sensors to buy?
- e-cutout not working
- Flowmaster merge?
- Cylinder head thread size question (Urgent)
- pcv delete help
- patriot performance heads/trickflow top end kit/afr and a vindicator
- Cam swap on 300k mile truck?!
- 102/102 stock motor automatic + more inside results inside !!!!
- tune after headers?
- NEW from Tick Performance: Knock Sensor Upgrade Kit (for 97-98 LS1 Engines)
- POLL: Muffler options- 'rasp' is annoying
- Intake opinions?
- FAST 102 swap, what does this plug into?
- Maf???
- Need waterpump help ASAP PLEASE!!!
- Slow to start??
- Pre-cutout muffler recommendation
- Anyone got these JEGS silicone RAD hoses?
- Smashed A/C aluminum line
- What's my LS1 worth?
- loud grinding noise when startup, starter??
- Starter problems
- Simple Cam Swap
- Dynomax Ultraflow installed...now lots of rasp :(
- Water pump and T stat question
- Lids and Low End Torque?
- Ls6 intake install
- Header/Exhaust Fit
- CHRS1313 Ram Air Installed
- Couple of things not right after TB swap..
- fuel rail removal question
- Dual plane EFI intake?
- TSP Rumbler catback???
- What are splayed valves
- Just got a good deal on wires.
- 85mm Maf
- Best Fitting ORY?
- Wiring diagram request - instrument cluster
- mis firing issue
- QTP y-pipe vs TSP y-pipe
- FAST 92 on mostly stock?
- Water column testing on SLP CAI
- 2 Cutouts Better Than 1 Cutout??
- weird vibration after headers
- How to tell if the egr solenoid is good?
- underdrive pulley belt length
- Alternator Keeps goin bad HELP!!!!!!!!!!!
- How can I make my exhaust LOUDER!!!!!!!!
- Y pipe/ OR pipe recomendation
- Intake leak or?
- Unhappy with exhaust...ideas?
- Alternator charge problem
- New woes, ranting again
- Battery relocation plan
- Coolant Crossover Tube Question
- Stock pipes vs 3 inch
- Oil in coolant :/
- tsp ypipe
- 3 Gauges for A-Pillar - A4 H/C Car
- Fans, With a stand alone painless harness
- SS 3" to 2.5" Pipe Adapter
- Intake Manifold / TB Swap For Dummies
- Pulleys
- Broke a TB mounting bolt
- Broken intake bolt in head. HELP!
- fans not coming on. did before cam install. now they arnt the car is Untuned. HELP
- Opinions with Super vic and 4150 tb
- Damaged LS6 intake - take a look
- 1 3/4 vs 1 7/8 header?
- New Exhaust
- yanked air/egr w/intake swap. vacuum question...
- Question bout true dual exhaust
- check this out
- Do I need a tune?
- 2.5 cutout?
- QTP New Wireless Electric Cutout Remote Controller Kit
- Bank 1 02 sensor.. is it hard to get to?
- WSQ Ram air
- SLP Lid-MAF
- Can i make it to the dyno ?
- 02 sensor question
- ported stock TB question
- what is needed for 2001 LS1 Fbody to crank without PCM..
- Putting in a Holley EFI System... Car wont Crank with key..but I can 12v start it
- Glass Packs with True Duals??
- PlEASE HELP. Hesitation after Header Install and Tune??
- My first attempt at a Y-Pipe
- show me your accessory drive routing/setup for alt crank & wp only.....
- Question about removing knock sensors from cover.
- street car build
- Fast 90mm Gaskets
- Heeeeeelp!
- Corvette C5-R valve cover ID
- exhaust question?
- What Exhaust is this?
- p/v clearance issues with this EPS cam/AFR heads?
- Tsp rumbler cat-back
- Crane Cam Dual Spring ?
- Summit/Jegs Cutouts???
- electric cutout
- Best catch can?
- Throttle Body???
- Magnaflow merge review
- A PCV delete I havent seen so wondering if it works
- Slp header and y pipe ?
- header y pipe to lm1 problem
- Loudmouth question
- top end build need opinions
- Bellows for speed density?
- 2.25 Borla?
- I need intake descriptions and advice
- aluminum foil inside of the lid......
- tsp catted y-pipe?
- pro flo intake on 5.3
- Anyone have a TSP Rumbler catback?
- Corsa FTMFW ***VID added***
- ls6 vs ls1 headers?
- What throttle cable do I need ? Fast 102 TB and converting to NON Traction Control.
- 2 1/4" True Duals
- Headers, LS6 Intake & U/D Pully worth it?
- Cutouts
- starter/front 02 sensor harness
- S/S LT Headers
- Header install, possible problems?
- 243 Head install question
- Weiand Intake install question
- dual exhaust
- 98 T/A Exhaust (just a section of it)
- How to pass emissons with Longtubes & 604 lift cam
- Quick question about crank damper
- Will an LQ9/LQ4 MAF work on an LS1?
- LS6 intake missing vacuum ports
- 1998 PCV Replacement
- Power Steering Cooler - Why?
- need ls1 torque specs
- 85mm MAF ???
- Whats better for a N/A motor?
- PCV valve, anyone have a picture of this??
- MAF diameter?
- Intake directions...
- Small black nylon line around PCM
- High Flow Water Pump - TPI Parts???
- Ported throttle body
- oil pan clearance
- o2 Sensor - Technical questions
- Will I need a tune?
- name these parts
- autometer tach not reading right..xfi harness, 4cyl mode.
- Exhaust guru's inside please...
- tsp 1 7/8th long tubes
- 2001 LS1 accessory drive part number
- 102mm FAST Clearance????
- Is it worth it ?
- FAST 92mm and 102mm Big Mouth TB's - same bolt pattern?
- Putting EGR back on, can I use current LS6 intake?
- TSP 100mm MAF issues..keeps throwing code
- Going to buy QTP e-cutout, have 2 spots in mind
- E cutout question?
- Electric Cut Outs???
- Question about Voltage
- Mod newb, LT question(s)
- Muffler delete, how is it?
- LPP headers
- header help asap
- blinking check engine light?
- Quick air filter question..
- Exhaust theory
- Quick Cutout Question.
- broke a plug wire >:-(
- Mixed reviews on intake lids
- MAF question
- Need full exhaust
- Engine temp gauge not working on 98
- seriously.... what intake manifold for my 408?
- Perimeter bolt to center bolt valve cover conversion (No PCV provision)
- Would sweet thunders be louder??
- Fuel Pump question
- Homeless connectors!
- Question about stall and dyno
- Jones exhaust? Any experiences/suggestions on a QUIET sraaight-through design?
- sweet thunder comparible to GMMG?
- Fan connector/mate pn on the fan side
- good deal? used true duals
- I normally don't care for FedEx but...
- What belt do I need!
- ARH headers... is this common?
- Alternator Drawing Amps With Ignition Off???
- need some help
- Exhuast Completion Options
- Scoggin Dickey Sheetmetal Intake?
- DMH cutout?
- My y-pipe has a crack in it. I think I like it...
- Finally
- SLP Dual Dual flow
- Maf Dilemma
- Magnaflow exhaust??
