View Full Version : Generation III External Engine
- installing asp pulley
- header install question
- header question
- Pacesetter header problem
- QTP Dual QTEC Y?
- Pacesetter Headers
- are under drive pulleys worth it ?
- what size freeze plug
- Quieting my Hooker Cat Back
- LM 2 exhaust with ory w/ lt headers??????
- Should I replace my water pump?
- Home Throttlebody porting
- How do you re-install.....
- 98-99 hookers on a 2002?
- proper batt. relocation wiring?
- losing coolant help
- 160 thermostat install???
- Headers.....
- !EGR & !AIR Pass CA Smog?
- WHAT LOCkTITE on header bolts
- Dirt passing through foam {K&N, Holly} filters
- another flowcrap question
- i need some advice
- Air filter
- Coating QTP or Kooks headers?
- New Battery or Not?
- Need help removing intake!!
- bad things about pacesetters painted LTs
- Best shortie headers?
- aftermarket air lid help
- removing tb blade when porting
- TPIS throttle body?
- Tornado.. What are your gains?
- exhaust manif. interference??
- gains from removing a/c?
- Catted X-pipe? haha
- !EGR & !AIR Quick Question...
- Polyurethane Engine Mounts. Yes or No? Pros & Cons? (edit)
- The Mufflex Bump Stop Hanger
- Worthwhile bolts ons for a 5.3 Sierra
- big problem with header install...NEED HELP FAST!!!
- Which muffler would be the quieter of........
- TB Blade Screws
- i put a 80mm tb on and now...
- TB Blade Clip
- Finished my header install!!!
- Removing manifolds
- Pacesetters/Motor mount install?
- Gaskets for my new headers, which ones?
- can you clean a 02 sensor?
- Quick intake question
- Throttle body question
- Removing the emissions on my 2000, where can I get blocker plates?
- Removing cats.. (sound question)
- cfm ?
- Catylitic convert question
- valve cover breather question...
- Granatelli wires
- Edelbrock Slip on Merge collecters VS QTP Race headers ride along
- Ram Air???
- Dr Gas X-Pipe Kit and Cats?
- Header install
- need a quick answer here
- turning a short block into a running motor?
- electric cutout installation help
- Hi-flow cats with a Cam?
- Anyone ever bottom out their Macs??
- LSx Fast Intake torque specs
- average hp gain on longtubes
- HELP...small coolant leak at water pump
- LS6 manifold/stock TB
- ls6 ?
- QTP Catted Y, questions
- Which is THE BEST cat on the market
- question about flowmasters
- H-Pipe Pictures PLEASE!
- MAC headers w/ cats... y/n??
- Best Pulley for the Money?
- how much oil would i loose if?
- Autolite Double Platinum any thoughts suggestions?
- Throttle Body
- Edelbrock or Pacesetter?
- Borla vs TSP Rumbler w/chambered
- How to remove your PCV.
- BBK TB and Granitelli MAF?
- Will this work? Hooker headers to slp y-pipe.
- Do pace setter LT's require 24' extender's for the o2 sensors?
- Install guide for TSP True Dual setup
- o2 extensions
- I'm ordering headers right now and need some quick advice..
- Header Bolts?
- ordering headers in 30 minutes`
- Need an Exhaust
- Factory oil pressure sender thread size. (Need adaptor)
- Install of GMMG
- Need pics of magnaflow installed please...
- Dr. Gas X-Pipes
- Where are you getting you Ported TB's
- Whats the difference between balancers
- GC and filter question
- Header wrap? Does anyone use it?
- Cut Out Length?
- FAST 90mm TB worth it?
- does it matter where the pcv is with a catch can
- How much difference will a 85mm MAF make?
- Older 90 fast TB what were the probs & cures
- Y-pipe/stock Mans.
- 2.5 inch ST TD are done (Pics)
- AMW Catch Can - Worth the $200?
- Is the FAST intake that much better then the ls6?
- The True Duals From ebay????
- LS6 Intake
- Pic of my FAST intake installed
- Header choice...
- qtp guys, inside please
- TSP & Sweet Thunder review
- Need help with long tubes.....
- Anyone who has borlamouth, please reply!
- Finally bought a catback!!!!
- what kind of exhaust is this?????????
- Which is the best fix for y-pipe bang?
- TB Sensor Screws
- TPS Voltage
- Z06 Maf
- hey exhaust experts, which muffler
- Noise Question
- Tsp Ory???
- true dual straight pipe
- Preparing for header install, some questions...
- true duals: over axle vs under axle
- hooker header install help
- Need help with Catback info
- Switching headers
- Who sale sheet metal valve cover ?
- what is this??
- lowered and a tsp off road y pipe?
- lm exhaust question.......
- Porting LSX 90mm intake...pics or how tos?
- Oil Breather Filter
- Another exhaust question...
- Mufflex Bump-Stop
- plug wires for relocation kit
- QTP HVMC and True Duals (Pics)
- f.a.s.t. vs. slp
- My duals w/single chambers
- quick question please help!!
- Will LS6 intake from 05 CTS-V work on LS1???
- GM Plug Wire Help?
- Clear airbox lid
- Corsa+LT+Highflow catted Y
- corsa or gmmg
- trual duals vs dual cut outs
- 6.0L centerbolt valve covers fit a 01 F-body?
- LT's with pro-kit
- Hood or Fast Toys
- Header gaskets
- are my plugs bad(misfire)
- Need some info on Moroso mufflers
- Who has a 3” catted Y w/ good ground clearance?
- Ceramic coatings?
- Y-Pipe question.....
- Flowtech LT's?
- engine hoisting options
- new exhaust setup
- Long Tubes with Eibach Sportlines
- My new TD setup
- Anyone ever used one of these PCV vacuum pumps to solve their oil consumption through
- Header Install
- Which Headers should I get?
- is an intake off a 02-03 vette an ls6 intake?
- Plug mistake
- jethot coating stock 02 ls6 intake please help
- TSP Y merge vs. flowmaster merge....questions
- Cutout/chambered muffler???
- Header size?
- what exaust
- March pulley problem! help
- Metco breather pics
- catch cans? question real easy
- headers
- Weiland Lingenfelter Intake vs. LS6 Intake
- Effect of ported MAF ends
- Lid ?
- Any LS1 Carb engines out there?
- F.A.S.T. Intake and BMR Strut Brace Cleaance
- snapped tube on radiator
- Cleaning 02 sensors??
- Planning my exhaust settup.
- header install spark plug access?
- O2 Extensions.. How to route?
- Darn knock sensor
- FAST 90/90 On Cam Only Car?
- Cut out question......
- Hooker VS. Pacesetter Headers
- I need some serious help with my exhaust nightmares!
- LS1 and LS6 Intakes??????
- Smog fitting ?s...
- Installed O2 simms and car is running rough-
- True Duals...?
- Kooks installers come in.
- What fuel is the best for 02s?
- Lifting up the front
- Kooks vs. QTP
- bbk intake vs. ls6 with 80mm tb
- Y-pipe Question
- First mod?
- *identify these HEADS!
- spark plugs
- SLP Exhaust Questions!
- With Cats, or Without?
- Stock WS6 Muffler
- Mufflex 3.5" Single Hideaway system...?
- What ORY for shorty headers ?
- Header sizes???
- What do yall think about these?/Jet Hot headers
- Give me some exhaust ideas...
- Help!
- True duals
- contents in a tb bypass kit
- Spark Plug Choice For Heads/cam/n20 Setup?
- '02 Formula Exhaust Question
- spark plug question
- headers
- band clamps leaking, need help...
- Guys need feedback, how to get 450rwh?
- How to?.....
- Oil Fill spout on Valve Cover
- True Duals
- Top breathing manifold needed
- what size hole is supposed to be in the stock throttle body blade?
- question on EGR
- Poly motor mount ??
- What bolts to hold shortblock on stand?
- how to install hooker headers
- What did I break here?
- Borla or Mufflex?
- Magnaflow Catback
- Starter and Longtubes issue ???!!
- Is there an MAF Sensor for TPIS Oval TB's?
- Stock Timing cover fit over Dbl Roller???
- LQ4 vs LS6 Intake
- Are these sweet thunderS?
- Help, hearing a noise!!
- Band Clamps
- hooker headers
- Power steering just went to hell
- best horsepower exhaust?
- water pump hoses....
