View Full Version : Generation III External Engine
- Pacesetter's (painted vs. ceramic)
- Loundest bullet???
- ~TSP True Duals ?~
- anybody made a homemade loudmouth
- Ported Tb Or 90mm Unit?
- LS1 catback on on 98 v6 fbody FIT?
- Leaking Fast 90?
- Please help, 1996 Tahoe 5.7L
- spintech mufflers
- need help installing e/cutout
- B&B Exhaust Tips??
- Installing LS1 Headers
- check valves?
- i-pipe size
- Got Work Done Now Fan Stays On After I Stop?
- what is this??!!
- Got LTs, Now I Stink?? LOL
- Headers
- How to cut down drone on highway - loudmouth
- I see oil...help!
- SLP Dual Dual exhaust
- Installed Exhaust
- just installed lid and k&n....WOW
- FAST90 TB TPS question
- Bfh
- ls1 to ls6 intake
- Most Quiet Bullet Muffler? Help please.
- Manual Fan Switch?
- A problem in slp`s C.A.P
- FAST/NW 90 good for 800 rwhp?
- Do I?????
- crankcase pressure
- Hookers are in, one problem
- anyone using the tourque tech x pipe?
- bad engine ping after installing mods
- epoxy or jb weld when porting tb
- Throttle body Bypass kit ? 6- 8hp?
- Low idle at start up
- Egr Help
- Which One.....
- exhaust question?
- qtec....foot switch?
- Tb
- Can't get the alternator pulley off???
- Oil in the intake...
- catch can
- Ported Tb Or Underdrive Pulley
- Dual cutout question
- TSP or Pacesetter Y?
- Spiral Flows
- removed AIR now backfiring! help!!!
- what should i do next
- Good headers?
- L92 or LS6?
- Corsa vs GMMG for Drone, Loudness
- Will a QTP ory fit on Pacesetter headers?
- Are radiator hoses going to be the same as stock on a 408ci LQ9
- pacesetters LTs unequal length primaries?
- going with TD's...what do i do with elec. cutout?
- Can I swap my Corsa muffler for a SLP 2OTL
- 2 chamber flows on true duals??
- Header Install Question
- Ls6 Manifuld
- so, is it possible that....
- Intake and TB Compatibility??
- how much would i gain?
- Has anyone done a ram air through the foglight openings?
- Best place to buy MSD spark plug wires?
- Car number
- SES Light - P0420 and P0430..NEED HELP!!
- mobil 5w40 truck and suv oil!
- pacesetters rusting
- Balancer pulley bolt size??
- Are 1 7/8 too big for this setup?
- Flowmaster Cat-Back LS1 to 3.8
- under drive pulley.'s
- Exhaust tone change?
- How well do Spintech mufflers flow?
- Aftermarket Airbox Lids?
- Headers....
- reccommend a intake
- Please help!! Terrible sqeak coming from front of motor.
- cats and a big cam?
- Lid Chipped, HELP.
- Convert electronic throttle to mechanical?
- how to create your own smooth bellow?
- GMMG with lt's+ory does it really sound THAT bad?
- Boom Tubes
- Porting the TB.
- Mystery coolant problem - I am baffled????
- exhaust
- 2 questions about the lid
- Need part # for LS6 intake with egr hole
- Car runs hot with AC on....
- SLP Y-pipe for '00-'02 cars only????
- Corsa or Borla?
- NGK TR -55s
- Getting x-pipe w/ bullets done...how will it sound?
- Intake manifuld
- Outlaw Motorsports ? ? ? ?
- 85 mm lid!!!!!
- LG motorsports lid...
- electric cutout install price
- LTS and TDS + C02
- flowmouth/dyno mouth/borlamouth?
- S3 with bypass finally in!!
- oil sending unit?
- is the FAST intake worth it?
- Where to buy weatherpac connector for oil level sensor
- which plugs
- Took Thermostat Out Should I Get A 160??
- LS6 intake or not?!?
- Who Sells The E-bay Headers
- How many have welded their own exhaust
- LQ4 in LT1 T/A
- First Mod
- Tacking up slack in the gas pedal
- TB & Intake
- tuning question...
- Magnaflow catback
- Best Intake for all motor car??
- Pacesetter Weight
- Motor Mount install
- Lid Not sealing
- need part number for ls6 intake gromet
- No Grip W/Mods
- exhaust port size
- Corsa Exhaust.... Anyone Running This
- Adjusting Nut Size
- LT Pacesetters with catted TSP Y pipe
- Stupid cut out question
- QTP electric cut out BLEW UP today
- Catch can isn't "catching" anything
- Anyone w/ single 4" exhaust have pics??
- What induction for WS6 now that BG Ram Air kit is out of production?
- Pacesetter's finally on
- Any One From New Jersey That Would Be Willing To Help Get A Broken Header Bolt Out
- balancer
- what are ebay headers???
- AC compressor gone bad??
- !air pump wire
- slp loud mouth?
- "Tricking" PCM into Thinking the EGR System Still Works?
- I just ordered
- Tim99ws6 exhaust clip...take 2~!
- ypipe vibrations
- ca smog question
- WTF at the TSP Y pipe
- which plug and wires?
- ASP pulley or other brand
- Exhaust ???
- Polished TB
- ls6 search
- ACDelco Iridium Spark Plugs
- What Mods Should I Get
- I'm confuse!!!
- Why do Headers take so long
- Ignition Switch
- wiring harness interchangability
- T/Body
- 99 Trans Am Header Question
- 3" ORY to 4" I-pipe, Cutout, into SLP Dual/Dual pics!
- true dual setup: comments please!
- New Balancer Install
- Vacuum Ports
- header gaskets for my pacesetter
- Exhaust manifold and starter questions
- ls2 header question
- y pipe question
- Major Probelm After Manifold Reinstall
- Help
- Please help me decide!
- Broken Header bolt PLEASE HELP ME!!!!
- flowmaster/loudmouth(flowmouth)Will Ilose alot
- What else Do I NEed?
- Which Casting is better
- where to put cut out on true duals?
- Plug gap?
- i need some serious help, im out of ideas
- 90mm Q45 TB?
- LS6 intake
- whats the best spark plugs
- Need O/R Y for 98 Z/28
- ~Exhaust Help~
- qtp long tube e.t.'s
- Just installed TSP 3" ORY w/ SLP Bullet
- Show me pictures of your cutouts
- how much will a tune help?
- Throttle body question
- Pacesetter's made it in today
- Lets play whats the hp/tq game!
- Change front driver and passenger 02 sensors?
- 90mm MAF
- Your LS1 suggestion please !
- Ls2 intake on an ls1
- y-pipe question?
- Carbon fiber valve covers?
- Running Headers With Untuned Car?
- Intake options with Vic Jr???
- Is there anyone from OK. here
- Universal H-Pipe and X-Pipe People Come In and Show Us Pics!!
- Are the slp long tubes worth the $$$
- How much gain should I expect
- SSRA w/ tranny cooler?
- Header bolts
- couple of exhaust questions
- Help Me Decide
- NW 90 TB Question???
- Cats required in OK
- jet hot headers?
- TD's rasp until running temp then sounds good
- Anyone with O/R y pipe with bullet out the back
- lid overlapping
- question on my new car?
- K&N FIPK guys check in... whining...
- what LT headers would be best for my 2000' SS $$$$
- fuel gauge
- Intake????
- Would headers and catted y give me hp gains...help please.
- Need some advice
- TSP Catted Y too close to fuel line?
- Service engine light?
- Valve Cover Spacers
- Where'd my cats go?
- those who port their own TB's come in....
- open headers .....
- Headers Vs. Stall
- A persistant exhaust leak
- What should the torque on the header bolts be?
- QTP or KOOKS...
- TB P&P?
- The Cutout Is Done (WOW)
- ls6 manifold or lingenfelter
- Help with the SLP lid installation
- How to delete PS cooler?
- true dual x pipe
- Simple Question
- Best Street Plugs
- 3 inch inlet muffler...
- SLP Dual-Dual, Hooker, Or Magnaflow for Headers/ORY Setup?
- mufflex?
- Problem in TEMP~
- If my Headers still rub some.............
- Anyone have JBA LONGTUBES?? (not the shorties)
- Anyone have clearance pics of their pacesetters?
- rumbler cat back " over the axle" peice hitting axle.
- true duals with cats and H pipe: PICS NEEDED!
- 1 3/4 vs 1 7/8 headers
- what tips are these?
