PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 [104] 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. voltage regulator?alternator? or what please help
  2. pics of motor mounts?
  3. Car wont start ques????
  4. SLP DD and "cone of silence"
  5. ???TB cable bracket QUES.....
  6. found some problems wile swaping intake please help i need you guys!
  7. Question about Magnaflow Catback Diameter
  8. Water temp sensor idea?
  9. balancer install
  10. Anybody know how to mod a non egr provision ls6 intake
  11. Wiring harness??
  12. Slp maf
  13. Does ANYONE got a motor mount handy need HELP!
  14. ls3 ls7 intake what is the difference
  15. FAST 92 intake top shell question?
  16. True Duals ran under axle into CME???
  17. Question on Headers and EGR
  18. edelbrock intake
  19. ls6 intake manifold swap questions..
  20. Anyone with a FAST descreened the MAF to make it quieter?
  21. Street Warrior?
  22. Another Head question...
  23. rear main seal and main plate question
  24. weiand street warrior
  25. intake swap issue
  26. I need part numbers for ls6 coolant crossover. Please help!
  27. headers....question
  28. cutouts before or after X
  29. Pro Flow XT Intake
  30. Cali Smog and will this pass
  31. about to get pacesetter LTs any tips ?
  32. Dropping The k-member
  33. question about intake manifold vacuum leak
  34. Whats better and why
  35. Plug wires and plugs?
  36. Which lids do NOT hit a factory SS hood?
  37. Anybody believe this?
  38. passenger side Valve Cover breather hose
  39. Help the dremel messed my TB up
  40. EVAP question - what activates the selenoid?
  41. has anyone tried this?
  42. ASP Pulley Charging ???
  43. DMH...Outstanding Customer Service!!!
  44. need help quick
  45. Identifing SLP Dual Duals
  46. 3in or 3.5in?
  47. GM knock sensors different?
  48. TSP TDs or 4 inch dumped?
  49. adding bbk ssi intake and cutout have a few q's
  50. E-brake switch location
  51. Ceramic or Stainless Steel?
  52. Those who have installed TSP Duals come in!
  53. stock OEM header gaskets?
  54. Autometer Temperature Gauge Accuracy
  55. lowered with LT???
  56. Just bought a engine, need parts, wheres the VIN?
  57. Help with MAP wires
  58. Pacesetter Y-pipe?
  59. L92 heads on LS1?
  60. Opinions on dumping a catback
  61. 243s ported vs stock
  62. Please help identify headers/opinions on them
  63. Buy a Portied Throttle Body, or buy a Dremel?
  64. QTP headers and TSP Rumbler???
  65. How bad do solid mounts suck to install?
  66. Stupid question
  67. Meziere EWPs
  68. Catch Can
  69. Sweet Thunders vs. Spiral Flows
  70. magnaflow alteration question
  71. what next
  72. Trivial but Im at a loss! Please help!!
  73. Higher air box?
  74. Super Victor > Victor Jr!?!?!
  75. Trying to decide on mufflers for TDs
  76. Part Numbers for f-body a/c idler & tensioner
  77. Exhaust leak impact??
  78. Did I do something to my fuel rail to make it leak.
  79. [PICS] Katech carbon fiber valve covers installed
  80. TB suggestions????
  81. ls1 oil cooling?
  82. LQ9 Swap, What to do ???
  83. Long Tubes 3 Choices
  84. ls assembly book or vid info
  85. free mods?
  86. TSP True Duals Muffler Options
  87. iac problems, please help
  88. cnc ported tbs
  89. My SLP LM1 Catback opinion...
  90. Header problem please help
  91. What are these things on my intake manifold??
  92. Newly purchased 02 z-28
  93. Broke my oil sending unit...
  94. LS1 vs LT1 Y-pipe ????
  95. Stock Cat Back Size
  96. Will a truck belt tensioner work with Fbody accesories?
  97. O2 Sim. reccomendation.
  98. [PRESS RELEASE] Katech Performance Launches Online Store
  99. Decisions, decisions....
  100. Can I use ls1 balancer on 6.0 iron block?
  101. gmmg and s60
  102. What TB to use with Weiand LS6 intake?
  103. LS style motors dimensions/drawing?
  104. Broke a Sensor...
  105. True Duals??
  106. Long Tube Headers???
  107. Exhaust problems!!!
  108. WS6 Catback?
  109. victor jr. vs. fast
  110. Which would be more beneficial
  111. Are these any good?
  112. FTP lid
  113. O2 sensor question
  114. Exhaust Clamp for CME
  115. Fast 90 intake inner gasket replacement
  116. exhaust moving
  117. Header install how to install site?
  118. headers and intakes for 427ci LS7!
  119. Tune issue or something different?
  120. Electric water pump?
  121. SLP Loudmouth exhaust resonators
  122. Anyone with LPP LT have this problem?
  123. typhoon 96mm or ls6/
  124. I need a new gmmg sound clip
  125. Can't stop overheating!!!!
  126. head bolts
  127. pics of bellow lid to throttle body !MAF
  128. idler pulley question..
  129. TDs vs ORY w/Dual Cutouts
  130. PRC 5.3's
  131. ARH Headers Installed
  132. ftra, 85mm lid and maf installed. did it help? track results inside
  133. Fast intake combo vs LS2 intake/90mm tb
  134. Plug wires?
  135. Loss of comp cyl#3
  136. FAST intake installed, valvetrain louder?
  137. SPARK PLUGS OUT!!! Well.... Sort of....
  138. Help me quiet down my exhaust
  139. Hooker Maxflow Install Write-up
  140. engine mounts made wrong?
  141. Intake decision
  142. Who buys used cats?
  143. A little help? Exhaust
  144. Fuel pressure sender help
  145. Modifying a B&M Ripper
  146. which headgasket
  147. where to weld fitting to pressure check exhaust?
  148. MAJOR pacesetter longtube header problem!! come in!
  149. Is it worth it......
  150. Anyone try the new MSD 2-step for LS cars??
  151. Easy Header Instal for C5's,
  152. Seafoam???
  153. exhaust hiting uper phr mount? pics inside
  154. SLP New headers or ARH?
  155. Using L92 heads, what do I need? Problems?
  156. Borla warranty issues
  157. Mid lengths vs. Pacesetter lt's
  158. Throttle Body and oil pan questions
  159. Throttle Blade Gap
  160. Diablo Question
  161. Valley Cover question
  162. SLP LS6 Intake Manifold ?
  163. 04 Z06 mods
  164. Anyone try the Trickflow UD pulley yet?
  165. Rubber grommet for IAT sensor has a small tear - ok to reuse?
  166. ARP Crank Pulley Bolt?
  167. Can you tune a car with a malfunctioning clutch position sensor?
  168. how much back pessure is needed?
  169. Exhaust Shops
  170. double wall exhaust tips
  171. Intake price question.
  172. After long tubes will i need....
  173. Isky LS1 beehive springs
  174. two 3 inch cutouts
  175. Were to put cutouts
  176. Just got my rumbler on
  177. HELP! I broke an AIR bolt...
  178. Which o2 sensors do you prefer???
  179. changing coolant tubes with bbk ssi intake?
  180. What to do with unneeded wiring?
  181. Full Exhaust, Plugs/Wires...Now Annoying TICK!
  182. Low oil pressure after H&C
  183. Refrigerant Question
  184. Rust on Painted Headers
  185. Head Gasket Question
  186. exhaust and emissions
  187. Identifying a true LS6 intake????
  188. 99 Escalade modability?
  189. LT headers with a regular muffler?
  190. Exhaust for 3.5" collectors? GMMG?
  191. injectors question
  192. 85MM MAF Harness Adapter?
  193. 68 camaro big block headers
  194. Which spark plug wires do I want for my swap
  195. Oil pressure gauge reads 0.
  196. PICS Bassani Tru Dual X PLUS Moroso Spiral Flows
  197. Magnaflow Catbacks price difference
  198. difference between tr55 and tr6 plugs?
  199. single chamber mufflers
  200. fuel line connection on fuel rail....how to discconect?
  201. truck fuel rails or LS1 fuel rails?
  202. LS6 Intake Swap Help
  203. Thanks Patrick G Nice Gain with Flowmaster Merger Y Pipe.
  204. Removing waterpump
  205. Map Sensor Question - 2 bar?
  206. Are there any advantages to a 2 to 1 to 2 pipe exhaust?
  207. witch head is better?
  208. ARH headers question
  209. Traction Control Delete....How to??
  210. Who offers the best deal on......
  211. Oil pressure sending unit?
  212. 98-99- 00-02 Lid differences?
  213. Is this going to help me at all?!?!?
  214. Catalytic Converter placement
  215. H/C car, 11.1 cr, Plugs ?
  216. Upgrading Headers
  217. Best/ Cheapest place to buy 85mm maf
  218. Rev Extreme catch can pic needed.
  219. Help with Off Road Y-Pipe
  220. Iridium plugs????
  221. Solid motor mount experience UPDATED!!
  222. pulley ?
  223. Need some fast help! Need clips of TSP Duals with spiral flows ASAP!
  224. switching muffler
  225. wrapped headers
  226. Air pump
  227. [PICS] Katech aluminum valve cover (new design)
  228. what else do i need with my headers....
  229. R.P.M.(NC) FAST intake porting ?'s
  230. So I'm running open headers and I have a question
  231. bassani TD or custom setup?
  232. FAST92/92..... what bellow to use?
  233. Gmmg
  234. Exhaust leak
  235. Corsa CME exhaust
  236. Alternator Plug wiring question
  237. What should I get?
  238. new exhaust!
  239. New Style PCV
  240. Best Spark Plug Wires
  241. $400 parts and labor motor mounts?
  242. Shock problem!! HELP!!
  243. Need some info on 02 sensors
  244. Plugs/wires a must with lt's?
  245. Lets see some undercarrige header pics!!
  246. What brand headers are these?
  247. Custon Cat Backs
  248. quick question
  249. Catch can placement affect performance
  250. Settle it Once and for All!!! - FIPK vs LID
