PDA
View Full Version : Generation III External Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 [283] 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330
  1. Ground Clearance?
  2. Any Gp For The Slp Ls6 Intake Manifold W/egr
  3. What Y-pipe fits QTP Long Tubes besides QTP?
  4. tb porting,hype or hp?
  5. HELP Intake question
  6. breather, where to get it and what kind...
  7. catch can gettin oil in upper line/filter?!
  8. What bolt on should I buy next?
  9. valve cover breather filter?
  10. People with headers will dig these
  11. What is this part?
  12. What are the best headers?
  13. What are the best headers?
  14. Chambered Exhaust
  15. 400 RWHP W/O Heads?!?
  16. Loudmouth Exhaust Video
  17. Odd Noise: Water Gurgling....
  18. throttle isnt fully opening
  19. 2 cut-outs at the collectors??????????????
  20. Hooker Cat-Back
  21. are exhaust parts interchangeable
  22. Let the modding begin!!!
  23. Got my MTI billet TB.. Question on Alum intake..
  24. What QUIET mufflers for my 3inch duals?
  25. Header Y-pipe install problem
  26. How much do throttle bodies and bellows help?
  27. X-pipe Clearance
  28. If You Have this whistling sound at WOT:
  29. O2 sims for gutted cats?
  30. Best way to remove Traction Control
  31. Asp Pulley
  32. Intake! Help!
  33. Wtb: Longtube Headers
  34. Doing the Install myself
  35. How many exhaust hangers?
  36. GUTTED MY CATS, am I hurting my power??????????????
  37. True Duels with Ford 9"
  38. catch can....
  39. Moroso Vacuum Pump for LS1... Where??
  40. ATI pulley and SLP 2x timingchain?
  41. Magnaflow or Borla
  42. How big of a deal is the coating on headers?
  43. turndown......
  44. What pulley puller did you guys use to pull your ASP?
  45. SLP Y-pipe and Loudmouth
  46. Mufflex and spin tech??
  47. What's required to match 2000+ manifolds up with a 98-99 SLP Y pipe?
  48. loud mouth to loud
  49. Test Pipes?
  50. Cats - How big, and which brand?
  51. Can you modify SLP y-pipe to work with long tubes?
  52. Intake swap....HELP!
  53. TB bump stop mod?
  54. Custom Center Exhaust?
  55. Aero Turbine Muffler, more power over straight pipes?
  56. stoping PCV oil comsumption
  57. Question about ypipes
  58. Missing crank bolt!
  59. flp long tube headers
  60. Pacesetter catted Y pipe ?
  61. Have the Edelbrock 6570 LS1 Drag headers been released?
  62. bullets or borla xr-1
  63. 3" Duals X / Flowtech Afterburners Installed!
  64. Removing honeycomb in ws6 nostrils
  65. pacesetter LT install.. car = slower and boggy
  66. Sealing Airbox w/ FTRA
  67. Evans Water Pump???
  68. What website for AIR and ERG delete?
  69. Universal X-Pipe question.
  70. LS-6 intake
  71. Help with my Magnaflow Catback...
  72. Quick question..How many O2 extentions for LT's?
  73. y-pipe w/cats or x/h w/ cats. Which way to go?
  74. Lowered and True Duals
  75. Question about Ram air...
  76. Installing kooks headers?
  77. Pacesetter dyno graph
  78. oil problem with installation of headers
  79. Can you modify the ls6 intake to accept egr?
  80. Edelbrock ls1 Intake
  81. any info. for SLP fan switch!!!
  82. Please help shift ligth install?
  83. Multi function gauges
  84. What exhaust system to buy?
  85. 99 TTS headers on a 02 ws6
  86. I need it quieter
  87. how much rwhp do hi flow cats cost ya?
  88. Slp o/r header..Cat y-pipe..Loudmouth
  89. Testing testing...ANYONE have back to back w/ LS6 vs LSX yet?
  90. SLP MAF guys, come on in...
  91. VR Velocity stack at T Byrne Motorsports
  92. Slp Maf or Granatelli Maf
  93. FTRA Addon Scoop
  94. Am I overlooking any hp bolt on's?
  95. line lock kit switch location?
  96. Best plugs and wires for the ls1
  97. header bolts and gaskets
  98. Modification for Pace Setter Y Pipe
  99. Dumb question
  100. Bassani Catback?
  101. Header gaskets?
  102. true dual?
  103. duals vs. ORY and Hooker Catback
  104. Open longtubes cause damage?
  105. True Dual W/x-pipe & single chamber flowmaster sounds great!!!
  106. CME question
  107. Plug Help Needed
  108. flowmaster 40 series?
  109. 02 Extensions
  110. Is The Smooth Bellow Worth Buying?
  111. Besides QTP, list the types of cutouts out there
  112. Stainless steel vs. Ceramic coated Headers?
  113. budget performance question
  114. Question on PACE SETTER long tubes
  115. best bang for the buck tb?
  116. Magnaflow or SLP 2otl?
  117. How many times have you reused intake gaskets?
  118. Sand car headers
  119. how would a GMMG with a G5X2 sound???
  120. Ls6 intake question
  121. Hooker long-tube installation Question?
  122. Stepped Question
  123. New Dual setup questions....
  124. Qtp Headers/y Or Kook Headers/y
  125. Slp ls6 intake?
  126. help me with my shopping list
  127. HELP! on putting on my ASP pulley!
  128. Caddy 4/6/8 vacuum pump
  129. SLP Long tubes...Yes or No?
  130. Okay, I got her running what do I need to make her fly?
  131. anyone sell polished TB'S?
  132. Help me. Need to get my car to the 8.50's in the 1/8 mile without spending money!!
  133. Question for those with FTRA...
  134. Where to get long bolt for pulley install?
  135. cutout gains w/cam/macs?
  136. Negative effects from removing AC belt?
  137. FLP quality
  138. Inline thermostat?
  139. Suggestions Please
  140. cool pic of my gmmg and cme
  141. How to get the power steering pulley of when lip is gone
  142. Boom Tube on an Fbody.....Its in the mail!
  143. those with GMMG...
  144. Temperature sensor
  145. Stainless vs. ceramic coated headers please...
  146. TCS removal
  147. Side exit exhaust
  148. Question about TURNDOWNS????
  149. Ported Maf Ends And Tb...any Real Gains?
  150. What Will It Take???
  151. E.G.R. blocking plates
  152. How much hp should be expected?
  153. Which Plugs?
  154. SSRA or FTRA?!?!?!?!
  155. Help Soon Please?
  156. Pacesetter, AIR & EGR not threaded...
  157. help with install please
  158. Pics of my QTP Headers
  159. hooker y-pipe?
  160. just got pacesetters, which mufflers?
  161. Better MAF?
  162. 160 Thermostat
  163. safe mods or askin' for pain???
  164. 180* t-stat and fuel mileage
  165. Help with Spark Plugs
  166. 1st Dyno...
  167. When did your stock waterpump bite the dust (mileage)?
  168. What size bullet muffler will I need?
  169. slp headers
  170. Where to buy X-Pipe?
  171. what size pipe for dual exhaust?
  172. New Fast 78mm and 90mm?
  173. Pacesetter problems + some
  174. Should I run an Off road y Pipe
  175. Hookers and a y-pipe
  176. Qtp Y-pipe
  177. Anyone done an oil pressure warning light?
  178. 01-02 Hooker headers on a 99??
  179. Flowtech Afterburners, Magnaflow, Edelbrock...
  180. Feedback on plug wire upgrade?
  181. Pros and Cons between alum. and SS piping
  182. Mufflers for true duals
  183. Which gasket? Stock or paper?
  184. stock maf diameter?
  185. SCE Gaskets - New Copper Exhaust Gaskets
  186. How hard is it to change motor mounts?
  187. I need a VERY QUIET MUFFLER!
  188. X-Mas List... New Exhaust: Help me decide
  189. Pacesetters are on!
  190. impressed with new pace setter install..good headers
  191. Finally got my pacesetters!!!!
  192. anyone else have this problem with FTRA?
  193. do i need new wires
  194. Guys with Meziere, coolant temps too low?
  195. Rasp
  196. What mufflers should I get with duals?
  197. Fast intake and TB questions
  198. Pic of my dual exhaust (Kooks X-pipe; ATR Mufflers; Speed Inc. install)
  199. Maf Ends Good Or Bad?
  200. Question about installing SLP Headers.
  201. Is a open Borla exhaust close to as good as a cut-out?
  202. FLP long tube
  203. Cme ?
  204. spirals or bullets
  205. Metco Breather
  206. Can I switch the rear pieces of other SLP exhaust with Loudmouth?
  207. mufflers
  208. water pump????
  209. Y-Pipe For pacesetter LT's
  210. slp 85mm maf worth it?
  211. exaust leak
  212. Kook's Headers, Advice Needed
  213. true duals
  214. Are '99 Exhaust manifolds different?
  215. Pacesetter Part Numbers
  216. Anyone have/had MAC headers with ORY on stock WS6 catback?
  217. 02 Placement Simulator placement.
  218. Need to vent Freon from A/C system, have ???
  219. How To Install LS6 intake manifold
  220. Rattle in stock y-pipe?????
  221. Muffler swap to make some noise
  222. SLP Dual ORP's with Cutouts
  223. Y pipe for SLP Headers
  224. Made my true duals exit the rear.
  225. B&B Tri Flow Exhaust
  226. spark plug wire question
  227. FTRA vs SSRA
  228. Anyone running pacesetters with their Y and a Borla?
  229. New FAST intake manifold = modest gains
  230. Another intake question
  231. Descreening MAF?
  232. Just installed poly motor mounts
  233. do i need O2 extensions for my pacesetters?
  234. Nasty Performance sheet metal intake gains 43RWHP
  235. borla stinger for the ws6???
  236. PaceSetters Are On
  237. What are the signs of a bad cat?
  238. SLP headers IMPORTANT!!!!!
  239. running open headers...no power???
  240. Quick look at the new F.A.S.T. throttlebody
  241. Anyone Have Pacesetter LT Leaking Problems?
  242. Ypipe brace question
  243. Pacesetter...install/dyno/track
  244. what is stock throttlebody plate hole size?
  245. PLEASE , NGK TR 55 at gap ( .45 ) is it OK ??
  246. Mac Headers
  247. Breather for engine
  248. Torque sheet needed
  249. Pacesetter came with EGR ..How to take off ?
  250. BG ram air??
