View Full Version : Generation III External Engine
- Borla exhaust question
- hooker header/catback?
- HELP!! Header install, mac mids
- Passing Emitions Without Cat???
- oil pressure sending unit/LS6 intake install Q
- low gain's after headers
- qtp electric cutout ????s
- fast toys ram air induction kit
- QTPcutout/magnaflow
- Cutout on stock setup/catback???
- Best Quiet Muffler
- need new crankshaft position sensor...any special brand?
- Lokar Throttle body cable?
- Innaccurate AFR with cats?
- lower air box on ebay (stealth?)
- throttle cables
- sheet metal manifold question.
- Custom 3" Trueduals over axle , By Lethal PERF.
- New exhaust...
- i finally did it...
- best crank pully
- random tech catback question?
- cutout question
- TSP or LM catback
- Moving Temp Gauge Ls1 Vette
- How to prevent leaky headers???
- Quietest exhaust
- taylor 10.4 plug wire ?
- Any use of exhaust cutouts for me?
- corsa tips
- Shop charge to install a pulley?
- cutouts on a C5 Vette?
- Opinions needed on 3.5" exhaust
- Spark plug unthreaded itself, and came out today.
- Where do I buy oval tips?
- OBD 2/ CA Compliant CATS?
- Corsa vs. Hooker
- My new 100mm throttle body
- corvette or f-body headers?
- Question about FTRA
- Learn me on 85mm MAFs (search is useless)
- wiring - AC wiring
- Does anyone believe the throttle body coolant bypass mod is worthwhile?
- Stubborn #8 spark plug wire
- QTP headers are a work of art!
- which 02 extensions?
- Write ups?
- new Holley TB
- UD pulleys and idle RPM
- anyone have problems w/ Volant install?
- Mandrel bends vs. Crush bends
- Silly Question...
- quick question on bbk 80mm tb
- pressure question with duals
- How to ID an '01 LS1?
- When to buy new o2 sensors?
- egr question
- How to crimp Optispark ends...
- 90mm TB question
- Corvette O2 Sensors
- Header / Y-pipe Banging Issue Solved
- what to gap my tr55 at ???
- do you need o2 extensions for flowtech headers?
- Exhaust question (y pipe)...cant find an answer...
- pacesetter headers and tsp y to be ordered soon...
- newb intake ?'s
- Fast 90mm intake / NW Tb results
- Just got my exhaust now i need some help
- What DSL with Kooks catted Y
- need help with TB assembly
- will 01-02 f-body tb fit 1999
- URGENT, junkyard in Los Angeles
- clogged cat
- Cats or No cats
- Corsa?
- Where can I get the Following?
- no tune?
- HELP! Coil Packs Arcing!
- WTF? - Car runs like ass after LT / TD install!
- GM Iridium Plug replaced Orginal Platinums?
- Quick Facts about headers everyone needs to know.
- Any place to get longer crank pulley bolt locally?
- Powerstick vs Stainless Works chambered
- royal purple
- TB Porting Tips
- Loudest Intake?
- Little help with an exhaust rattle
- Fast 90mm intake gaskets
- ???? TD's getting installed Worried about fuel line.
- Stainless Steel?
- What plugs into the PCV?
- SLP LS6 Intake Manifold vs Weiand LS1 aluminum manifold?
- Tough catback decision
- Best Underdrive Pulley
- pacesetters on a vert>?
- best 02 sensors
- tru dual exhaust
- Tune needed after LS6 intake install?
- Ground Clearance: TSP True Duals, Lowered car
- Is anyone running the Dynatech Supermaxx Header System?
- Re-use exhaust manifold gasket?
- gutted cats
- Pulling the heads with the engine still installed?
- Flowmaster.........restrictions?
- Gm upper engine cleaner
- ASP INSTALLATION have a question
- coated and uncoated?
- 3.8 Header Bolts
- Qtp Headers
- NGK Plug Gapping
- March Underdrive pulley belts
- ! evap, ! pcv guys inside please.
- does the texas speed y pipe work with the spoon torque arm?
- Need help to quiet up the exhaust...
- order LT's now what?
- how long with o2's and open headers
- Loudmouth Owners Unite!!
- TSP true-duals + Cats + under-axle extension PICS! (!56k)
- heat sheilds on headers
- People got me scared
- Is this a LS6 manifold?? 2 Pictures
- Are 02 sensors interchange-able?
- Electric water pumps, how are they holding up?
- Honing ATI Balancer???
- GM performance wires #? LS1
- manual rack and pinion?
- Please help me figure this....
- What to do with PCV system?
- How much will I gain?
- Looking for a different Muffler/resonator
- BORLA owners come in.......
- Edelbrock Header Questions
- Intake questions
- Borla Corsa or GMMG?
- running with no cats?
- Longtube and ORY decision..
- gmmg exhaust
- Will anyone else make a stock-style 90mm intake?
- Looking for Headers..help w my application
- Just bought LS6 intake
- Pics Of Magnaflow Catback
- Those of you who "cleaned up" pacesetter ORY
- Please Help
- 6.0L Truck Intake vs. LS6 Intake
- Cutouts?
- Kooks and Magnaflow question.
- ? on the mac y-pipe on stock manifolds
- problems to expect after header install
- Lil Y-pipe+cat Help
- Edelbrock Victor Series Headers (not 56k friendly!)
- Do ported throttle bodies really add power & torque or just increased response?
- HOPE I DIDNT LOOSSE HP( no cut out vrs bullet
- Keep borla or get GMMG?
- IS an LS6 intake off a 2004 CTS-V same as anyother LS6 I/T?
- A.i.r. ?
- MSD wiring on an LS1
- Charging Wire Length
- LS6 Intake question
- Who is porting throttle bodies these days?
- true dual out the back or 3' ORY?
- Which plug wires...
- Which Headers!!??
- CuToUt LoCaTiOn
- ?'S on TB????
- NGK Plugs?
- NGK Plugs
- relocated coil packs questions...
- Headers Questions? Loss of MPG
- Smaller starter motor? LS1, LS2 etc?
- Longtubes and GMMG
- march or ASP
- Advice on Cutout location
- Messed up ORY sitation...
- header/ORY installation price?
- Side exit exhaust
- NOS Octane Boost - Race
- Magnaflow Catback
- will A 02 truck throttle body work on my 01 camaro
- Best tucking ORY
- stock y !cats
- true duals for lt1
- Motor Mount Install Guide?
- QTP 1 3/4 and TSP true duals!!?!!?
- diff. in valve covers
- FAST 90mm Burst Panels
- sensors on LS
- do i need a tune if i gut my stock cats?
- Changing plugs
- Power Steering Leak after Header Install
- Where can I get 2 pipes to be an exact replacement for my cat's?
- AIR question
- I finally did it
- installed headers and ORY *PROBLEMS*
- Underdrive pulley and charging
- Coil Trouble
- Ported TB, now idling higher.
- muffler
- Starter compatibility
- Lt Headers, Off Road Y Pipe, And O2 Sensors!
- Getting True Duals out back
- Motor and tranny mounts---did I mess up?
- qtp cutout wiring help please
- what causes......
- Headers for a LS1 2000 GMC P/U
- Throttle Body sensor?
- new exhaust ..
- ls2 intake on an ls1
- Intake ?
- header install - how to get the oil dipstick tube through pass. side header?
- What exhaust with Spohn TA
- True Duals?
- A/C compressor differences?
- Old Granatelli MAF on 04 tahoe?
- TD under the axle
- quick question on exhaust Tips
- From LS1 to FAST LSX Intake Manifold - What is needed?
- can u weld in cats into a hooker/flowtech orp?
- Whats a glasspack?
- ORY 1/2" from fuel lines bad??? HELP ASAP!!
- headers
- Cleaning out an intake
- Which Mufflers Spintech,Magnaflow,Other...
- MAP sensor leak?
- TSP-true duals and the pro-kit???
- Peterock/Qtp header install
- LS6 intake Question
- Fast90-Stock maf/bellows/lid & questions
- Getting cat's tomorrow...
- Hooker headers/hooker offroad y/hooker catback
- A/c?
- Catco Direct Fit Catalytic Converters
- Anyone with duals tried these yet?
- Quietest Muffler For LM w/o Power Loss?
- Help! removing harmonic balancer
- Air pump removal?
- Fast 90mm TB
- Tsp Duals
- 90mm tb to 85mm maf
- Coated VS Uncoated Headers
- why are catch cans expensive? what about this one?
- MSD 6A box
- Power steering leak
- Car running horrible after header
- Simple intake question
- alternator amps?
- Exhaust Question
- Homemade Smooth Bellows (Fernco) Sizes?
- Which Motor Mounts???
- Battery Hold down?
- GMMG does not use sweet thunders
