View Full Version : Generation III External Engine
- How does this look?
- looking to upgrade my intake on 02 trans am
- I Need Some Opinions....
- LT Headers: Am I good to go?
- Cooling problems, Help!!
- Lost power steering in burn out contest??
- Exhaust removal advice.
- [need some help] .. Borla ProXs with LS1 engine
- i need new mufflers
- Cutout question that everyone can answer!
- Need the size of the oil pan bolt used to drain oil. Mine snapped
- LT and mounts
- confused on exhuast
- Electrical problem
- what is the biggest throttle body and maf that can go on an stock ls6 intake
- Charging issue
- Worth the money to switch???
- Header bolt fiasco
- Denso Vette o2 Sensor part #?
- 5.3L from a 2006 Hybrid Sierra...Differences?
- LS1 Vette Covers to Fast Fuel Rails
- GTO Ignition cylinder failure...
- Went for a Tune
- So my muffler crapped out on me.
- Anyone have info on how to P&P a TB?
- 3.8 multiple misfire helpppppp?
- 2000-2002 y pipe on 98
- Next Best Headers After Pacesetter?
- Midlengths VS LT for a 224/224 cam
- Anyone know of a good TB
- O2 senors
- Hooker Headers Rubbing
- Y-pipe options on Kooks 3.5" collectors
- Will running open headers to the exhaust shop hurt the O2's?
- Modular modified TSP Dual Exhaust
- Help me plan my next induction upgrade (LS1)
- PVC Catch Can Qs
- broken header bolt in head. What would you do?
- Help on wiring for DMH e-cutout
- Fast 102 What Throttle body
- Stupid Thermostat question.
- how to get rid of rasp in exhaust?
- Ls6 Intake install help
- 4" round muffler
- Ls6 Intake vs Full Street and Dyno tune
- Does GM claim any noise level on stock exhaust?
- BBk intake manifold which one do i get?
- clarification...
- Motor Mounts
- gmmg or sweet thunder true duals?
- Throttle Body spacers?????
- 90mm ls6 intake
- Please help with this DTC Code.
- Exhaust part numbers
- Best price on Edelbrock 71403?
- Exhaust/header question
- Dual QTP Cutouts
- water pumps
- Finishing up my exhaust, need opinions.
- running lean?
- anyone using sureflo headers
- O2 extensions..?
- Are all QTP cutouts the same?
- Anyone fitting 24" or 30" Sweet Thunder or similar mufflers?
- tsp true duals
- Starter Problem HELP!!!
- what to plug hole in lid?
- Which one would you run??
- best plug????
- What valve covers do I need?
- Lid Question
- engine need to breath better.
- headers
- Best throttle body for a bolt on car
- 3 inch x with Trak Pak is official
- AFR 215 Preliminary Dyno #'s C5 Corvette Auto with a Stall
- Where to find Cheap injectors??
- Removing a/c grooves off harmonic balancer- who's done it before???
- ceramic headers?
- Finally did it!
- LS3 intake VS FAST 102??
- Very annoying noise/feeling in pedals and steering wheel
- Header Wrapping??
- Disconnect MAF = Harder Shifts
- What does this mean....
- Need help getting intake manifold off
- Charging System NIGHTMARE 04 GTO
- Engine Cranks, BUT WON'T START, NO FUEL PUMP POWER, NO SPARK!!!!!
- Exhaust Install - Realistic Gains?
- 2.5 x with the rest 3in?
- So Spohn Solid motor mounts really do raise the motor...
- Race Headers Clarification
- 5.3 truck upgrades
- probleme cold air mode camaro
- TSP Cats
- LT Header tune?
- Where to start ? ?
- Tach and Speedo single the same
- LS6 vs. Fast Intake
- Need Modding Advice!
- Anyone ever had problems with obx headers?
- TSP Catted Y Knock
- helix power tower results?
- How much is a complete LS1 worth
- Muffler right off the header?
- Running rough after muffler swap.
- 2009+ LS3/LS7 Throttle Body in a c5 question...
- FS: Center Mount Exhaust Valance + Corsa Tips
- slp maf question plz help
- Can't remove the key - problem with the shifter's spring? (see photo)
- Sound Normal For Headers?
- F Body Exhaust Manifold flanges
- Hp gains from ported Tb and Ls6 intake?
- Preparing for LT's
- Fuel pressure guage help!!!
- truck alternator upgrade
- Would this require a re-tune?
- Power loss for 1 second while driving...
- Picture Gallery, halfway through a major overhaul
- My fans won't come on!
- SLP Y pipe Opinions please
- Tb porting
- GTO power steering pump in Fbody
- 5.3L in 79' camaro.. ?s
- For Sale
- for those of you with fabbed x pipes
- Larger MAF to go with a 98mm Fast Toys Lid
- I think I know the answer but I'll ask to be sure...LS2 intake?
- Posted this Hypothesis in AET no real answer!
- GM MLS exhaust manifold gaskets P/N??
- what i should tune when installing Trick Flow® 515 HP GenX ™ Top-End Engine Kits for
- 1998 HVAC vacuum lines routing problem?
- edelbrock intake bolts
- Why is my Thermostat an 04-08 ls2/3/truck ????
- Headers,ORY,Stock Cat-Back w/Cutout
- Running Without a Tune
- What happened to the LsXtreme Performance header thread!!??
- looking for headers for a GMC Colorado 2008
- 00-02 cat to Y pipe bolt size/thread??
- Ebay Throttle Body
- Need After Y-Pipe Flow Suggestions
- which thermostat for 5.3 3rd gen swap??
- Cheapest place for a Meziere Water Pump (WP319S)
- spohn drive shaft care
- Trying to quiet down my exhaust...
- vic jr set up for a 370??
- thread size coolant sensor LS1
- this sound right?
- Get the instant fuel consumption
- Switched o2 sensors, gas mileage took a dive
- TSP true dual installation question
- Install ? on fast 92mm intake
- Couple intake questions...
- Idle adjustment
- Slp Manual Fan Switch
- Tsp rumbler
- bbk ssi to fast intake
- ls2 intake on ls1 map sensor location
- 1999 Corvette intermittent no fans
- LS6 spark plug ?
- Fast 102mm intake Question
- 427 LS3 from Erl performance?
- Ls6 intake/egr
- 243's
- Can someone identify this intake?
- Ls1 bolt ons
- Coil Wire Boots
- The greatest accident ever!!!
- true duals for 93-02 f bodys
- Intermttent idle surge
- LSX-R Installation issue on 2002 WS6
- Which y-pipe?
- Need help with crank sensor wires
- Black Widow Throttle Body
- Hookers with TSP Catted Y Borla
- ls6 IM and what TB???
- compression ratio confusion. help!
- Big problem from header install
- Kooks LT's on lowered F body
- Need some help
- Slightly Confused (02 sensors)
- Measurable Difference???
- Long Tube header help, stuck.
- OBX Headers
- I need help on removing my powerbond pulley...
- First bolt on headers and full exauhst help!
- Perimeter to Centerbolt - need clarification
- Stock 2000 TB Question
- coil pack harness connector
- LS1 Camaro cooling system hose's?!
- Intake question
- Hooker Exhaust Rattle On Camaro SS
- So I know that a Y-Pipe banging the floorboard can cause knock, but can solid MM's?
- Time For Duels...(looking at bassani) opinions needed
- Need help with iat sensor
- AIR system in a 2002 camaro z28
- Coolant catch can
- E85
- starting issues
- Tcs light. Help.
- installed 04+ valley cover.....retune needed?
- BOTH Oil Pan Bolt Part #'s Here!
- manual fan switches?
- Cooling fan problems, please help
- Electric Fan temp switch.
- Power Steering Pump Reservoir with Hole?
- LS1 vs LS6 Intake
- New Exhaust... Everyone likes videos!
- Best cam for 317 headed 6.0?
- can you fix an E-cutout?
- crossover coolant pipe
- Where to install an oil temperature sensor...
- Leaky slip fits, how to switch to flanges?
- loudmouth exhaust
- LT1 Y-pipe fit LS1 headers?
- Got dyno tuned after bolt-ons
- '99 DBW help needed. Throttle not working
- Coil / Fuel rail issues?
- what size of fuel injectors to go with
- What Size Bolt Will Fit In The Front Of The Heads For Stock LS6 Heads?
- does anyone have a write up on removing the complete ac system in a camaro ?
- No oil pressure
- Power Steering Pump Whine
- In the middle of my LTs install..need help!
- Why am I so slow?!
- Ideas for a new catback
- What size/type bolts to bolt SBC Th350 converter to 6.0 flexplate?
- Finally!
- Got my TSP duals a wee bit too close to the floorboard
- Muffler Question....
- Starter questions
- bmr trak pak hindering exhaust
- ARH header fitment: 1-7/8 vs larger?
- Underdrive Pulley and Mid-lengths. Good deal?
- best quiet muffler
- slp lid question
- Turn an Lq4 into a LY6?
- how to disable automatic headlights?
- Egr/air bock off plates
- Need help adjusting Throttle cable after 102mm install? UPDATED WITH VIDEO!!!
- My Car is Satan!
- smog pump
- Suggestions on set of headers
- New Heat Shield for my K&N
- Difference between the 2 Fuel Rail Kits for FAST 102?
- Off-Idle Stumble
- 5.3 intake
- CTS-V, VIDEO: Squeak/squeal on start up and shut down
- QTP electric cutout on borla
- Random Stalling
